Thanks for your reply.
I bought 2002 Infiniti QX4 from private party. However, he didn't gave me owner's manual.
Do you know any website from which I can download the owner's manual.
Any help will be greatly appreciated!
Ajay
Mine is 2001 model by the way. Thank you.
To those ends, we will be shutting down the general make/model discussions and work exclusively with specific issues. This requires us to populate the make/model subsections with relevant, interesting and timely topics. Rather than having the hosts simply create boilerplate topics for each make/model, we feel that you, the owner, the make/model enthusiast and the prospective buyer can best judge what those topics should be.
You can help by adding a discussion (it's easy!) or suggesting one here.
To add a discussion, click on the last link in the "You are here" line at the top of this page. That will take you to the topic page for this make/model. Review the list of topics and click on the "Add discussion" link when you've decided what topic you'd like to add. Follow the directions and you're done! Feel free to add more than one. Just avoid duplicating existing topics and try not to make it TOO specific!
Your help and continued participation in the Forums is greatly appreciated! Thanks.
It seems that this is a prevalent problem for QX4 as I saw several posts about this. Appreciate any information about the fix. I saw a website that will fix an ERR2 problem in QX4 for $295 plus S/H, but one has to remove it first and ship to them. Has anybody tried to pry the panels and remove the CD player? Is it a tough job? What kind of tools are needed. The car only has 38,000 miles and look quite new with no scratches. I do not want to scratch the dash panels by doing it myself if it is a difficult job. Any information will be appreciated.
Infiniti QX4
Did you ever get it resolved or does anyone know what the problem is.
Thx
After sitting in the garage for about a week, I noticed a "oil slick" under the right front area of the engine. My local mechanic thinks it is the oil cooler. Before replacing the cooler,he ordered two O rings and hopefully that corrects the problem. Has anyone else had this happen?
So far, I really like the SUV. It has many luxury features, drives great and the engine has lots of power.
THANKS!
Jerry / Winston-Salem, NC
SUVs and Smart Shopper
thanks Steve
One time I was driving a rental car going south to San Diego in summer. After a few hours, my left arm got some sunburn...
When I shift the second time to "N" and ack to "D", I feel much less of that. It is the same whether at 2WD or Auto.
Did same test on RX300 and it has much less "push" even the first time shift.
It is emanting from the area where the right-rear seat BACK pivots and contacts metal underneath the carpet. Go back there, remove the headrest and put aside (when I say right-rear I am referring to right as viewed from back of vehicle).
OK....pull up on the tab that pulls forward the bottom (butt) cushion, and pull until the cushion is vertical.
Now the culprit as I said is the seat back/contact zone. Pull the lever, and move the seatback forward a couple of inches, then push it back to the lock. This, or similar/perhaps faster repetition should reproduce your sound. The sound is more like a clicking sound... I placed a piece of cardboard under the area where it's occurring.
This is tough to describe, so if you need additional info feel free to email me at radioclashman at aol.com
Good luck!!!!!
Thank
Is it OK to clean the vinyl surface with leather cleaner and conditioner? I guess it's OK but maybe not the best way.
Hope someone out there will help.
Tom
The above is from NICO.com, and they say this failure happened on quite a few VQ35 engines.
I haven't heard it from anywhere else but NICO.
I hope nothing will happen to my 02 down the road. So far, it has none.
i have the nav system.. can i use the cd slot behind the nav system to play music cd's?? if so, have anyone used it to play burned cd's??
whats a good place to buy a cd changer sleeve?? my qx4 came missing one... thanks!!
There are two pieces of metal looking squares on the plastic, next to each other but on two different sides, both close to engine. Anyone knows what those pieces are for? To block heat from engine?
Or maybe they are hiding side terminals?
This smaller battery is bolted down in the tray very well and secure. The plastic thing is thin, like a thick paper, with the same height as the new battery. It is loose horizontally, but its top is held down under the crossbar so it will not move.
I am not sure why the original batery died so fast. I didn't feel any slow cranking the day before. Only in the morning the battery was noticeably weak but started engine OK. After about 6 miles drive to Costco putting gas in, battery was completely dead.
Actually I didn't expect any reply soon. This thread is not very active.
I tried to learn how to post pictures by searching around, but soon gave up struggle. Would you please tell me how?
One you've done that, you can click on one of your photos. There'll be two boxes there - one's a URL for linking to your photo and the other box has the URL for pasting the photo into a post. So copy the stuff in one of the boxes and paste that code into a post.
If you know the URL of your photo (maybe it's hosted elsewhere), you can use the IMG button under the posting box - so you'd click the button, paste the code and then click the button again to close the code.
Still too confusing? There's a simpler explanation in the Help file.
It's even easier when you set up your own CarSpace (see link at the top of this page). Once you have done that, just go to your CarSpace and copy the link for insertion into a message here if you want to display the picture in our Forums.
[EDIT: Steve types real fast! ]
However I am glad to be giving this vehicle a good life, because the previos owner, well lets just say the oil was black, transmission had never been flushed or filter changed, it had original belts. But it is a new age, and a better life despite the decrepid handliing of such a nice vehicle. They did not destroy it completly though the transmission had no leaks nor were there any metal shavings just a tad bit of sludge on the magnet I have since changed all the belts, added a new trany filter and gasket, put in full synthetic mobile one oil, changed out the 3 year old air filter and now she pers like a kitten, not to mention I had all the widows tinted.. Only thing left to do is a tune-up.
Now on to the CONS, First and formost is the I wont say absolute lack of engine power however a few more horses under the hood wouldnt hurt, There is a bit of noise from the engine as I drive, but once you get up to the cruising speed of 65 she coasts along, and it does seem the faster I go the smoother the ride gets. As far as gas milege goes reg unleaded gives me 17.3 mile per gallon and plus gives me 17.8 miles per gallan 80% freeway and 20% city, Personaly not enough to really care about I'll stick to regular unleaded.
All that said I do love my truck. I own my own buisness and use it for the company , I have a full size 5 drawer tool chest in the back and I dont even have to lay down the seats. NOW NOW I know what you are thinking HE IS USING IT AS A WORK TRUCK, "Inconceivable"!!! But I treat it well, and I am not finished on the upgrades.. and in case you are wondering I paid 7500 hundred for the vehicle. and one more point of intrest there is a 900 dollar add on NADA for the low miliege however I checked as soon as the miles goes to 101,000 miles I lose the add and it drops the value by almost a thousand, now I new this going in but I felt I was getting a great deal any way that even when it happens It will still be worth more than I paid for it.
If you have any questions for me feel free to post them and I will try to get back. I know I had alot of questions when I was buying mine... O and by the way most all of the parts can be found at you local auto parts dealer or if need be just cruise over to nissan where you will pay 30% less since the pathfinder and the qx4 are one and the same.... Sorry the post was so long I just wanted to be helpfull....Looking forward good times....
