Visitor Agreement.
Yes, it's true. At 70 the MT is loud and not great gas mileage.
That doesn't sound right. The idling MT Fit uses less than that, between 0.21 and 0.32 gph. If the engine were in deceleration mode it would use nothing. Perhaps it only kicks in if you have high rpm?
My 2002 S-10 was so severe about this that I had poor engine braking (no ScanGauge back then). I had to turn the key off if I needed real engine braking.
Guess everything is relative. My average mpg for the first 10 tanks in my MT Fit was 36.1. I do a lot of highway driving and when I'm on a highway with a speed limit of 70, I zip along at 80. Admittedly I always have the radio on, but I don't find the noise bothersome, and I'm very happy with mpg.
hey, probably 75% highway. in the city btw 40 and 50 and btw 55 and 65 on the hwy
Why, that's what hybrids do.
Finally, no engine will use less gas when being used for braking assist (decelerating) than it uses to idle. It is an absurd proposition to suppose that a working engine (decelerating is work) could use less fuel than an idling engine.
I think this is incorrect too. During decelerating the enine doesn't require energy but actually produces it, which is why hybrids use deceleration to recharge the batteries, that's also why you can push-start a car with a manual transmission.
Most of my mileage comes from two 600 mile road trips I make each month, which accounts for my overall decent gas average of 34.3 mpg. Without those highway trips, though, I'd be averaging somewhere in the 25-28 mpg range.
Can anyone say if an AT is louder at 70 than an MT?
Would be cool to have scanner reading of both at speed :confuse: :confuse: :confuse:
The slower you drive, the better gas mileage you will attain. One can also try anticipating stop lights and coasting to them instead of racing from one to another like greyhounds. There are any number of things to do in order to squeeze mileage out of these cars. I learned quite a bit (am still learning) from "cleanmpg.com"
Take a look at the site and good luck to all you "Fit" owners out there! It's a great little car, isn't it?
Got a new 2008 MT FIT Sport Pearl Blue
Best price I could get was 15,625 + sales tax and $110 tag fee $16,700 out the door. Anyone seeing way better pricing?
Today was the 1st time I sat or drove one. What's the purpose of the ratcheting handle, that will release the seat on the outside top side of the front seats? Seems redundant to the lower seat track release on the front bottom. Was thinking it was bolsters or lumbar but could not figure it out.
I'd like to get one of those center consoles for stuff. Saw it was a special deal from Japan and not listed in the Accessory book????
I hope to start posting my MPG rates. .
Thanks for the seat school.
Is there a lumbar adjuster?
Brian
Anyway, overall average for the 1500 miles was 39.6. I drive a standard very carefully (shift just over 2000, etc). As you might expect I am extremely pleased.
I suspect that when the temp gets above 32 for most of the week my mpg will get even better.
Gene
Love my Fit!
I'm looking for 50- plus mpg this spring. I've hit 48.339 as a high thus far. Good luck to you.
2. If the ignition is on the engine is burning fuel. If you turn the engine off while decelerating I hope you carry a signed organ-donor card in a fireproof case. In order to push start a car with a manual transmission you have to inject work into the system, by pushing the car or going downhill at sufficient speed to do what the starter motor normally does - turn the non-running engine over to overcome the initial load and the drag of cylinder compression This has nothing to do with the behavior of the running engine under deceleration.
Wrong
It takes electricity...aka the starter, to start a car.
Yes, it does seem that 1 minute is the "efficiency" number on whether to idle or not a modern fuel injected engines. I may have read that in one of those "How to get the best mileage" articles.
Hybrids' starters have been engineered with this assumption, as have a few gas engine models that are available in Japan and Europe that have the automatic idle stop mode.
Bob, indeed it does, but a bit of extra fuel is normally injected at the time of start, which is what creates a debate of how long an idle stop one needs to have in order to overcome this deficit.
When engine braking, the engine doesn't require any gas since the car's momentum keep the pistons moving. The RPMs don't accurately measure how much gas is being used. Going downhill under engine braking at 3000 RPMs isn't using the same gas driving 3000 RPMs on level ground.
All these are absolutely true. In fact, with today's fuel injected cars, computers are usually programmed to cut off fuel when the throttle is off. Conversely, in today's cars, what the throttle position sensor reads has a large impact on how much fuel is actually injected, and different amounts of gas can be injected even when an identical RPM is registered in different driving settings.
Load = more fuel consumption = less mpg. For short periods my money is on let it idle over start and stop. Plus gas is cheaper than replacing starters as well, and we all know how warranty work goes for wear items like starters and breaks and batteries.
my $0.02 is do what you want but tell us so we all learn from it.
When I first got my Fit, I ran it to fuel exhaustion, just to see how far it would go and what the needle would look like in the fuel gauge when all the fuel was gone. That was my very first tankfull of fuel so it is not as good as the mileage I now get, but it worked out to 420 miles and 13 US Gallons to splutter and die.
Since then I have achieved 466 miles on 13.4 USGals. Don't ask me how I can get more fuel in the tank now, I don't know. I do fill my tank to overflow by the way, to achieve these numbers and to calculate my fuel consumption figures accurately. All these numbers assume that the fuel pump figures are correct???? Who knows??? However the calculated fuel consumption numbers verify the fuel added and the miles run are checked against GPS numbers so I know they are good.
By the way, I have had no adverse effects on the engine from filling the tank to overflow every time and my mileage numbers are in the ballpark so......
So, for those of you in other countries, the Fit will hold 51 liters of fuel, or 13.4 USGals, or 11.2 Imperial gallons of fuel. This is handy to know if you are heading up country where Gas Stations begin to thin out. In that case you can fuel up to overflow and count on 416 miles or 670 km (with a bit of reserve).
I am not sure why people complain about the range on the Fit. My last car was a V-8 Mustang MT which was lucky to see 280 miles out of a tankfull in town and 350 miles on the highway. Range did not seem to be a problem with that car and the Fit will go another 100 miles further than the Mustang on a tankfull so why complain.
I hope this has been helpfull and that someone may benefit from my numbers.
Cheers, Pete
So if you're trying to fill up the Fit by multiple top-off squeezes, remember that you might not be getting as much extra gas into the tank as you think.
BTW my last fillup was 32.7 in mixed highway/suburb driving in freezing temps with my auto sport Fit.
The people who claim to stuff 12+ gallons into their fit -- I believe them!
When I refuel to top it off, I do not cycle the pump on and off. Rather, I feather the valve so that the fuel runs out slowly in a clear stream, not foaming and bubbling like a mountain brook. This ensures more accuracy from the meter, and avoids cycling the valve. It takes about two minutes to get the last 10 liters in. About the same amount of time as filling a 10 liter plastic gas tank if you include unscrewing the cap and screwing the cap back on. I can see and hear the fuel tank vent line operating in the fuel as it percolates down the fuel filler tubing during the last 10 liter fill. With some gas pumps, it is difficult to feather the valve so that it will go to a low fuel flow. Sometimes, I just give up and take what I can get.
A fuel flow meter is quite capable of metering fuel at slow velocities BTW, on a 42 gallon aircraft tank it is not uncommon to be within a quart of accuracy from a full tank to dead empty. This fuel is metered from idle to full throttle and all the RPMs in between so it is possible. In other words, the fuel flow meter is totalized by the computer and the actual fuel burn and the calculated burn by the totalizer is within a quart on a 42 gallon tank. You know the tank is empty when the engines stops running!
An automotive gas pump is just a fuel flow meter with a fuel totalizer hooked up to it. (Along with a price gauge too!!) The difference being that it is regulated by government inspections and the fuel density is averaged out to measure as if it was pumped at 15 degrees C, or 59 degrees F.
Anyway, what I have found is, that I can usually put another 10 liters into the tank after the auto shutoff feature activates on the nozzle. Which works out to 2.5 US Gallons!!
My Fit does not seem to run any differently when it is topped off, than when just filled to the auto-shutoff. As to longterm damage or ill effects, I have been topping off as described for 8 months now so.....
Cheers, Pete
I reached 350 miles today and filled mine up for the 1st time. 70% freeway at 65 no A/C manual 5 speed Sport. 9.144 gal or 38mpg on tank #1 for me. I think the dealer over filled it so on the way home at 172.5 miles (90% 65 mph freeway no A/C windows cracked 5", it was HOT today) it took 4.59 gal 37.4mpg.
My owner manual says 10.8 gal fuel tank
after the E light comes on they say 1.7 of the 10.8 is reserve.
9.10 to e light
I think I proved that today.
Drove 5 more miles past E light and at the pump one more auto pump cut off past 1st. That was 9.144
I love it when stuff adds up.
I'm very pleased.
I'll have my scanner gauge this week and will be able to find out what it like best. I plan to test a number of things
I did think that it would get better than 24 mpg at 2400 miles. I expected some break in time but I also miss the extra horsepower at lower speeds that the Civic got for that higher mpg. I admit that I have left rear defrost on a lot and use the blower defrost when necessary while driving. I almost always have the heat on at least halfway since I live in PA and it winter. I am hoping the mileage improves as the weather warms and I can use the environmental accessories less.
Could someone tell me how they have done with different gas combinations. We have some stations that say 10% ethanol and some that say nothing about how much ethanol they are using. How much do you think this is causing the reduced mpg?
Because I have the Sport I have been upshifting frequently trying to get the RPMs down. Has anyone found this to help their mileage? I just started this recently to see if the mileage would improve. I have tried driving it in standard but it is very difficult to use the paddle shifters, turn, and accelerate all at the same time. It was easier when the stick was on the floor. The AT does seem to be doing a pretty good job getting it to the highest appropriate gear with some notable exceptions. That is, after a period of acceleration it will ride 4th gear unless you decelerate a little and then it goes to 5th. You can tell this more by RPM than by feel. I have been upshifting earlier when I don't need to accelerate any more.
I have not yet had it to the dealer but will get the recall fix for the airbag and ask them about the mpg. Anything else I should be focusing on for this visit?
Other than the mpg we are really enjoying the Fit. It is much easier to get our twin 4 yr olds in and out of the back seat than the Civic and the different seating configurations make it much more versatile.
As to the thread on sound, I do have to say that the Fit is quieter and more comfortable at 65 mph than my 02 Civic. I did not test the MT but the RPM in overdrive is fairly low and the car in general is fairly quiet for a hatchback.
EPA Rating of three different transmissions:
Manual 5-spd: 28 city / 34 highway
Automatic 5-spd: 27 city / 34 highway
Automatic (S5): 27 city / 33 highway
Granted, it's not much of a difference, but the efficiency sticklers in this thread might be able to shed some light as to why. In the thread history, there is a lot of speculation that the paddles make for better mileage. Could this be the end-all answer that they're actually worse?
You could ask the service manager at a Honda dealer for the statistics or drive each yourself. See what RPM each is turning at 60mph in OD.
Kip
