Toyota Camry Hybrid MPG-Real World Numbers
1131416181921
  • tnltnltnltnl Member Posts: 9
    I am thinking about getting a TCH.
    Someone in a forum suggested that a Camry 6 cylinder only would get 1 or 2 miles less then a TCH, is this accurate?
    Also, how much power does the TCH have when loaded with passengers? I am wondering about passing power, etc.?
  • sgoodmansgoodman Member Posts: 14
    Not true, although it depends on the season and length of trips. In the winter, on short trips (10-15 minutes) around town, my TCH got only around 24 MPG. Now that it is warmer it gets 31 MPG overall average. On the highway it is easy to get 36-38, and many get more. I don't think the 6-cyl Camry comes close to that. There are, however, a number of nonhybrid cars out there that can get >30 MPG.
    The TCH does not have the passing power of the 6-cyl Camry, but it is pretty good if you want to floor it. You tend to be so conscious of fuel consumption, though, that there is much less temptation to floor it than in a non-hybrid. But if you really need to move, the TCH does pretty well.
  • wvgasguywvgasguy Member Posts: 1,405
    Remember too that sgoodman's results may not be typical. Depending on where you live, how you drive, etc. I just drove my TCH to work this AM, mostly on the interstate at 65 mph and got 41 mpg. Yesterday on a mixed interstate, town and rural drive I averaged 41 for about 80 miles. Interstate driving is not even the sweet spot for my TCH, It really shines on rural 2 lane roads.
    My lifetime FE after 51,000 miles is 37.3 mpg. I've never gotten less than 32 on a tank (and that was extreem weather and fast driving).
    Some may suggest their 6cy or even any other car where the EPA advertises a high hwy FE claim, do as well as a TCH, but unless someone tracks their FE all the time, they probably don't have a clue about what their car is really doing.
  • loves2readloves2read Member Posts: 48
    have had our 09 TCH for little over a month--have driven over 1K mainly short distance (under 5 mi) on city streets with red lights--not stop and go driving on freeways under the battery and has 4 or 5 distrance runs on freeways--but I am not a commuter--retired now--and don't really need to drive long distances to do my daily living....I knew when I decided to buy a TCH that I would probably not get the super efficiency that some people post about because my routes are different...
    have put in 3 tanks of gas and have been getting with the math about 33.2 to 33.8 as the avg mpg....
    when we stop the car and check the mpg readout--we get many EXCELLENT showing over 35 mpg--so I keep expecting to get a better MPG when I do the math...
    I am not super disappointed since I realize that much of my driving routes do not take advantage of the strengths of the hybrid system---but I do try to maximize my battery use and just the coasting effect (which my husband says works in any car--not just a hybrid)...I have had some concerns about what my MPG dial is doing when I compare it with the little icon showing battery/gas engine/wheels on the center console because they seem to be at cross purposes at times--but people said that is normal---trust the car's system--so I am trying to do that...
    the only consolation is that I know we would not gave gotten numbers even this good if we had bought a 4 cyl XLS top of the line (which IS what we would have bought)...or a 6 cyl Accord and I know that my friend who bought a new 09 6 cyl Camry --and does basically the exact same type of driving I do --is getting way less than we are--under 20 for sure...
    it just seems like I have enough of those uphill starts from the light and hitting reds vs greens to make an impact and doing errands in my area there is no way NOT to have shorter distances which eat up the MPG
    I am starting to find streets to use that don't have so many lights or stop signs
    We are using this car when we go out together in the evenings and on weekends which we definitely did not do when I had my PT Cruiser--so I know my husband appreciates it vs using his Tahoe...
    just hope I can learn as I go on how to maximize the hybrid's strengths...
  • grggrg Member Posts: 15
    I have had my TCH 21 months, and I don't understand how the new owners are seeing such low mileage. I have a 2007, and I average 38 mpg in the spring and fall.
    If I use the air conditioner on eco, I get a little worse mileage. The worse mileage is in the winter when I use the heat/defroster. But I never get let than 32 mpg for a tank of gas. Hills aren't an issue because what goes up must go down, no? I agree that there is a definite style of driving, and one has to hope for 2 lanes so the acceleration people can pass on the left. I eventually get up to the speed limit, but it is slower. I find the whole process a positive relaxing experience. As far as tips goes, there is a basic "thrust and glide" approach that should be engaged to maximize the use of the electric engine. It can be searched for through this website.
    I live in the hills and granted it is not an equal exchange of energy between the ups and downs. But what I notice a lot is when I'm going uphill and getting say 20 mpg, my excess power is still charging the battery if I'm not pushing the car. Then when I crest over the hill I have a full charge and my gage will drop to 60. If I am then in an area with rolling hills or mild grades the battery power added to the idle engin will propel me with an FE rating still above 40.
    My one tank of 32 mpg was on an interstate driving at 80 to 85 for about 3.5 hours in a cold (less than 40 degree) rain. rain usually costs me the most pain, but wind and cold add as well. Idon't live in a large metropolitan area with numerous stop and go situations and I must assume those getting 24 have those situations. I have driven in every other situation and can't get below 35 unless I intentionally push hard. Even spending a weekend inside the loop at Baltimore I was able to get 39. Not every redlight was an uphill start.
    I do have to make an effort though to not be in the fast lane, do fast starts, and all the other things I did in the past.
  • mz3smz3s Member Posts: 17
    With all the mileage posts here i'm just not convinced a hybrid is the way to go. Better mileage and all is great, but why should I have to sacrifice my driving style to get the numbers? I'm not a hypermiler, but not a nut either. I don't see the benefit of adding complexity to my car, paying more for it, and having to putt putt it everywhere pissing off other drivers for the extra mileage. And its not that much given that i drive normally.
  • redmazda3redmazda3 Member Posts: 28
    From your name it looks like you own a Mazda 3s. My wife and I own a 2007 TCH and a 2004 Mazda 3 Hatchback. She drives her TCH as if it is a regular gas engine car. There are times, when I am behind her in my car, that I have trouble keeping pace with her starts and she goes just as fast around corners as I do in my Mazda. She drives the TCH about 90% of the time. Her commute is about 8 miles of stop and start driving and she still manages to get around 36 mpg. So without really trying to get excellent gas mileage, she still gets really good gas mileage. When I drive the TCH, I can generally squeeze a couple of extra mpgs out of the car. We love driving both cars.
    good for you guys, glad you two are happy with your cars, assuming you like your MZ3. your wife's camry is delivering as advertised.
    my issue is whether its all worth it. they make weird popping noises. For me, no.
    Thanks for an honest post. it's certainly better than hearing people getting that mileage figure and complaining. and with the "on this one occasion on the luckiest day of my life when i found a blank check and a four leaf clover... oh yeah... going down the hill with the engine shut off I got a billion skillion mpg. those stories are kinda cool though. it keeps my own imagination in check.
  • shazam3shazam3 Member Posts: 13
    "If I use the air conditioner on eco, I get a little worse mileage."
    Hmm?!? That's odd. I thought I read on the manual that if you use the AC on ECO it uses less power therefore you get improved fuel efficiency.
    I'll try driving without ECO to see if I get better FE like you are experiencing.
  • snaab93se1snaab93se1 Member Posts: 69
    Just curious....what other cars are you considering? Love my TCH but I got it in Feb when they were not in demand. If I was buying now ...not sure it would be the premium they are asking over MSRP. Only difference in driving it verses a normal gas engine is a slight shudder when starting and a slight whine when stopping...both of which are not annoying to me and I am annoyed easily. Must give kudos to the A/C as yesterday it was 115 and today was 111 and had no problems cooling the car with no tinted windows....did decrease the mileage but no more than any other car.
    Better mileage and all is great, but why should I have to sacrifice my driving style to get the numbers? Even without changing your "style" I'll bet the TCH is significantly better OVERALL than your Mazda.
    I'm not a hypermiler, but not a nut either. I don't see the benefit of adding complexity to my car, paying more for it, and having to putt putt it everywhere pissing off other drivers for the extra mileage. And its not that much given that i drive normally. If other drivers get "ticked" at me because I've decided to start obeying the law (speed limit) well that's something I'll just have to live with. As for benefit, saving thousands of dollars is a benefit. For me, I can afford to drive a gas hog, but why waste money when I can use that money elsewhere more wisely.
    The US attitude will be forced to change, soon I believe. It won't make a lot of people happy but it will happen.
  • miser_manmiser_man Member Posts: 5
    I am the new owner of a 09 TCH and after 1,600kms I have already beat the dealer posted mileage of 5.7 l/100km (50 mpg). I couldn't be happier! The 4WD Tundra I returned to the dealer averaged 16.5 mpg on average, so a 2/3 reduction in my gas bill will save me roughly $450/month! I went through many posts on this site in the days up to buying the car, and learned about P+G, and regen braking, so it came fairly easy once I was behind the wheel. I drive on primarily flat land, with a couple of hills each day (live in the Niagara escarpment in Ontario, Canada).
    I have noticed that my regen component varies wildly from day to day on the same altitude change, and wonder if anyone has a good idea of the best regen technique? Do I coast down the hill (about 2km long at 6% grade), riding the brakes to keep my speed at the limit, or should I take a back road down the same hill that is much steeper and requires severe brake riding?
    Delighted that you are happy, and your new mileage is good, but not as good as you report. 5.7 liters/100 KM corresponds to 1.5 gallons/60 miles = 40 MPG, which is what you should get on the open road. The dealer rating is 34 MPG highway. 50 MPG is what a few hypermilers claim, but 38-43 is what most normal folks achieve. But that's good.
  • cdn_tchcdn_tch Member Posts: 194
    5.7l/100km = 49.5 mpg (imperial) = 41.2 mpg (US)
    1 gal (US) = 3.785l
    1 gal (Imp) = 4.54l
    Standards are wonderful! So many to choose from :-)
    Hmmm. Looks like US standards get us less every day! :)
    Yah I said I lived in Canada, so I of coursewas talking Imperial gallons. But don't feel too bad about your US standards: we are paying $1.34 per litre; about $5.09 a US gallon, so you may get 20 % less in your gallon, but you sure have cheaper gas than we do!
    Does anyone know anything about the throttle algorithm that determines when the gas engine should start. Toyota could sure improve this car by giving the driver some different modes to choose from: how about a sport/econo switch on the dash to vary the travel on the accelerator before the ICE kicks in. I find that its really tempermental; I would like to be able to just push it down and have the battery run me up to its max speed (assuming its safe to do so).
    Hey wvgasguy,
    I remember when I first got my TCH nearly 2 years ago, I who live in Colorado, was comparing my mileage with your in West Virginia. Now, the recent posts show much lower mileage. Are the newer TCH's engineered differently and getting worse mileage?
  • lazarbeamlazarbeam Member Posts: 1
    I am also a 2007 Hybrid Camry owner driving in South Florida that has always gotten between 34.4 and 37.6 MPG for the first 14,000 miles. This is not true with the last 4 tanks of gas. I now get around 29.2 MPG. I took the vehicle to Toyota and they say all is well, must be the Ethanol Blend. How can a 10% Ethanol blend cause a 17% reduction in MPG? This does not make sense. I would be better off with a 90% sized Gallon of real Gas.
    I am still investigating the problem.
  • quixotic1quixotic1 Member Posts: 23
    I went back to the dealer in Coral Springs and had my 25k oil change.
    They showed me my air filter was terribly dirty and suggested I get the fuel injectors cleaned. I was dubious but allowed them to do the work. $200 for both. Presto! My mileage went back up while driving to NC. 40 mpg going 80 plus on ethanol blend. I am in NC now where they are not adding ethanol yet and the mileage seems consistent. I will give my report when I get back to the land of ethanol (S. Fl.)
    You can change the air filter yourself I believe. Try that & see if it helps. :)
    They should be the same. My guess is that the early buyers were those of us who were obsessed ;o) and the later buyers are made up of a large group of people that want better gas milage now that prices are higher and don't necessarily want to change their driving habits. Not true for all of them but for a lot of them because they say so in these postings.
    I had to drive a lot more this past winter, my wife now drives the TCH daily for 50 to 80 miles. My lifetime FE is now standing at 37.3, mostly from what I can see is due to her driving the majority of miles. I can generally do 2 mpg better than her.
    Thus where I get 37 to 39, she gets 35 to 37. I'm guessing most drivers are like her, they make some changes but are not willing to "lear" the system, they just want to drive. That's OK, but it can and will cost you a couple of mpg's. It's not a lot of money or gas so why worry.
    The EPA ratings simply reflect a new testing mode and there is no difference in the car. Where as I could meet the EPA numbers before, I simply exceed them now. They are just a relative base for judging against other cars so as long as I know what "type" of driver I am I should be able to exceed EPA now by 10 to 15% no matter what I drive because of the way I drive.
    so of of what a driver can get relative to MPG efficiency in a TCH seems to me to be related to where they are driving and what type of driving they need to do...
    this is RELATIVE--not FIXED--the only way to truly compare MPG efficience is to drive exactly the same course in the same conditions as another drive--once with the same TCH and once with a different one really--
    and compare the MPG figures....
    a person who lives in one part of the county with a different physical configuration of routes and also different temperature means is going to have different numbers than I will...
    it is not comparing apples to oranges but maybe Gala to Granny Smith or Delicious to Yellow Delicious
    frankly when there is no way to actually validate claims it is ephemeral to certain extent...
  • inincubusinincubus Member Posts: 11
    This may sound irrelevent to this thread but,
    As an owner of 2007 TCH, don't worry about your mpg number at all.
    I used to average around 33 mpg until after 6 month of driving.
    Nearly 2 years later, i get 39.2 mpg
    The fuel efficiency will get better as you drive around.
    Also, if you care so much about it, your driving habbits and style will change, resulting a better mpg.
    I hope this helps, I just don't want some of you to worry too much like i did.
    It is a relative comparison.
    My opinion, for what its worth, is that you should know what your FE was on your previous vehicle as compared to the EPA and you'll do about the same on your TCH. Of course with the TCH you have the opportunity to then well exceed that figure if you indeed change your driving habits (you can do that too on your old vehicle).
    On just about every vehicle I've had in the last 10 years I averaged just over the low number on EPA FE postings. However I am averaging 37+ over 50,000 miles on the TCH. Just below no the old EPA rating but well above the new ratings.
    I've got several friends that are still telling me their car gets 35 mpg. No way. I know what they drive and while they may have a trip or two where they do that there is no way they get that good. A lot of people don't know how badly their vehicle truly is overall and then when they get in a TCH and only get 34 to 35 they are disappointed. It's hard to prove anything to these folk. Be informed.
    yesterday I went to eat with my friend who bought a new 09 V6 Camry about a month before we got our TCH--she is not very gadget adept and I was doing her blueetooth connection for the 3rd time--and showed her how to toggle between the screens on her electronic display---
    her AVG gas mpg is one of those--it showed 17.9 I think --or maybe 17.6--when she saw it, she went "OHHHH"--meaning that is all I am getting????
    so I could tell she was disappointed since even the V6 is supposed to get more than that in town where she does most of her driving...
    but she is not a very gas-conscious driver--she speeds and then brakes instead of coasting up to the light--she jumps on the gas going away from lights--
    so I knew she was not trying to maximize the POTENTIAL for better mileage...
    she had an Avalon before and would have bought another but the new one is so much longer than the one she traded in--it would not really fit that well in her garage...
    anyway
    we took trip from DFW to San Antonio and the New Braunfels area last week--drove I-35 through Waco and Austin so it was mainly freeway non-stop getting there and coming back--
    we averaged almost 40 mpg coming back and had about 38 going--don't know if there was a head-wind/tail-wind situation since I thought the hills would have cancelled each other out...
    in-town the mpg dropped of course but still we did pretty well--
    and we are hoping that giving the car that long of a drive will help with the breakin since mostly I have been doing short trips in town and not seeing much above 33 as an AVG....still glad I got it--
    was a little noisy on the road--the tires are the Bridgestones and they are noisy--but the car drove well--had passing kick when we needed it--and my husband was pretty happy--
    we also got a full set of golf clubs, a rolling duffle bag, a carry-on size bag and items like a blender, golf shoes, and some food stuff in the trunk--we had more space than we throught for actual storage--but the dropdown for the battery vents can be a little tricky as well for storing taller stuff...
    I have an 08 TCH, and often don't get the mileage reported here. The 3 most important determinants of my mileage are:
    1.) Length of trip: For the first 6-8 mins, I see a characteristic stair-step appearance on the MPG monitor, increasing from about 10 to 30. If the trip is <10 mins I will typically not exceed roughly 25-30 MPG, and I need about 12-15 mins for the trip average to exceed 30.
    2.) Temperature: In summer, I am getting overall mileage ca 32 MPG (w/lots of short trips). In winter (15-35 deg), I got 24-28 (on short trip city driving).
    3.) Hills: Going to work, a lot downhill - 38-40 MPG over 7 miles. Coming back, 30ish, 24 in winter.
    When I first got the car in the early winter, I was a bit angry and disappointed - thought I got a lemon. Now I see that EPA "around town" #s may be high for short trips, and the "highway" #s low, as we can get 38-40 effortlessly on long trips. I know there are many on this forum who get much better around town (but I wonder about the length of their trips), but it is impt for those who don't to know they are not alone.
    Macolyte
  • larsblarsb Member Posts: 8,204
    Your experiences are not unusual. But this is not a TCH problem. You do not have a lemon. (Low mileage does not constitute a lemon anyway.)
    ALL fossil-fuel-powered cars (non-hybrids, diesels too) have lower MPG at the beginning of a trip, before the engine reaches optimal operating temps. The best mileage occurs after then engine is warmed up.
    If all or most of your trips are short, you will consistently see far below EPA averages in ANY vehicle. It seems worse in a hybrid only because the expectations are higher.
    In the cold months, using the heater hurts your MPG.. In the summer, using the A/C affects MPG a lot also.
    You will get the best MPG in your TCH while in moderate temps, using no climate controls inside.
    The average combined (City/Hwy) MPG for a large group of TCHs is between 34 mpg and 37 mpg overall. People with short commutes are the lowest.
    The absolute worse performers combine these scenarios:
    1. Live in a place with very cold winters.
    2. Have a short commute.
    3. Use the A/C a lot in the summer.
    That combination will assure that you get lower than EPA averages in ANY vehicle. In a hybrid, it will SEEM worse because you expect better. But it's no different than any other similar car would do.
    Thanks. Absolutely right. Macolyte.
    My "town" and short trips are different than most. I have no problem at all getting 40+ mpg on a 4 mile trip into town with a cold engine. However with that said, I don't commute so lots of times when I make this trip it's with a car that had previously had a longer drive and the battery is in the GREEN charge area. Additionally, I live on a hill and while I always lose a tenth getting up to go home, when I leave I can coast and ride my brakes for about 1/4 mile before I hit the road into town. The engine will run for that first start up anyway so I'm getting to add milage to the warmup without using a lot of gas to drive the wheels. Once I do that, if there is little traffic I can go about 50 mph and get 45+ mpg with little effort.
    I believe for many it's an issue of several back to back short trips commuting day after day rather than just short trips in general.
  • wreednelsonwreednelson Member Posts: 10
    Driving it right [conservative] I get 38 - 40MPG, occasionally better.
    Driving it in the mountains I get 34 - 36 MPG.
    Driving "like everyone else drives" I get 36 - 37MPG.
    Driving it with a car top carrier I get 27MPG [YIKES!]
    I drive a lot. These numbers are solid. This is a great car.
  • calliscallis Member Posts: 2
    I purchased my car in May 2008, and I was getting 37-39 MPG on a tank. Right now, I have a 1/4 of a tank left and I am getting 32.7 MPG. My car has 3081 miles on it. Has this happened to anyone? Is so, what was done to make it improve?
    I live in southern Louisiana, so I am only driving on flat land (no mountains or hills)
    I think your gasoline has probably started to have more ethanol added to it
    my mpg was less than 32 when I started a new tank and I had several more long distance runs on that one (which makes for higher mpg than my normal in-town driving) so I am thinking that the place I buy my gas from--a Kroger site that gives 10 cent discount to people who shop Kroger has just started adding/buying gas with more ethanol
    the disclaimer at the pump says it can have up to 10%---
    looking for new gas station w/o ethanol to see if there is difference
    now I am starting to worry about its effects on my engine...
  • plknjplknj Member Posts: 121
    After my accident... when they had to rebuild my TCH, the milage dropped from 40+ mpg to 36. I brought the car back to the dealer and they ran a check on the car. It showed nothing... but, the milage wnt back up.
    This occured again after a recent visit where they worked on the car... the milage dropped again to the 35-36 range. Again I asked them to run a system check. They did and found nothing! But, the milage on my car returned to the 40 mpg range.
    If you have noticed a marked drop in milage after having the car serviced, ask them to run a system check and see if this helps.
  • shook4shook4 Member Posts: 4
    We have had tempeture in the mid 100's for the past couple of weeks. I have noticed a 3-4 MPG drop in town driving on our TCH. I think it is because of the battery drain due to the AC, AC blower fan, and all the engine cooling requirements such as the electric radiator fan, water pump, etc. I think the battery drain requires the engine to run more often to recharge. I also noticed it was very difficult to rum in total battery mode. Now that the temp is below 100 the gas mileage has returned to normal. Anyone else experience this issue in extreme heat.
    Absolutely normal. I live in Phoenix, and have had my TCH for a little over 2 years now.
    Summer tanks in my car have gone as low as 29 MPG and as high as 40 MPG if most of the trip is highway miles.
    A little trick:
    If you know the car is heated up and the battery charge is good and you are below 42 miles per hour, just turn off the A/C button for a few seconds and the car will sometimes go to electric mode. After all the cold air has blown out of the vent system and the car is in "E-Mode" just turn the A/C button back on. In some cases the car will remain in E-Mode and other times it will go back to gasoline.
    I have used that method dozens of times to get a little more "battery time."
  • talmy1talmy1 Member Posts: 55
    The battery capacity drops at high temperatures, reducing the amount of time one can run on battery even more. Long trips with the air conditioning on will reduce the battery temperature and improve mileage. I just consider either temperature extreme to be bad on mileage.
    Live in phoenix as well...and yes the MPG drop when the temp is over 100 is about 3-5 mpg. I notice that the battery drains faster mostly because the a/c is running at full capacity....but I can't complain....after sitting outside in 115 degrees for 5 hours in full sun with only a front sunshield the a/c cooled the car down rather quickly. Still the lowest tank I've recorded is 33.1 and that was the hottest week here with temp highs over 112 all week and was forced to keep the car outside during the day.
  • bigc_1bigc_1 Member Posts: 3
    Bought a new 2008 Camry Hybrid in December 2007. Have put 15k miles on it so far. Average mpg are 36.4. I have a lighter foot than my wife and can get a consistent 40 when I drive. Recently completed a 411 mile trip over flat lands and mountains. Took 10 gallons to fill the tank. Dealer replaced the rear brake pads at the 5k service as they were making noise. Has a slight noise from rear when braking lightly. Noticed the right rear rotor has a slight rub spot when rotating the tires. I performed the 10k and 15k service using Toyota 5-20 oil bought from dealer. (Mobile 5-20 in a Toyota container). Fuel economy improved after winter was over. Bought some 0-20 oil to try this coming winter. Actual mileage is a little bit less than the computer indicates.
    Heading out tomorrow for a 2500 mile trip. Will post any significant events when I get back.
  • nnnnnpatelnnnnnpatel Member Posts: 27
    Just for clarification, are you saying that you are getting 33 mpg even with 112 degree weather? My hybrid is coming in on monday, unfortunately it is in black color and in the valley where I live, it is 100 degrees for couple months.
    nick
    Yes 33.1 is the lowest tank I've recorded.....usually its about 50% city 50 % highway. This week its been very humid and around 108 and the mileage is back to 35 even with the a/c working overtime. When I first got the car in Feb was averaging 37-39 mpg per tank but the temp was averaging between 60-90.
    Great car....you are going to love it.
  • tjackson12336tjackson12336 Member Posts: 4
    I commute 120 miles per day. 20% rural hills, 20 % in town and 60% highway. First tank was 40.3 mpg. Second tank 42.1 mpg. I typically am driving the speed limit or just a few miles over. So far so good. Great mileage for this large of car.
  • sunkist2sunkist2 Member Posts: 2
    I have had my 09 TCH for two months with just under 2000 miles and the mpg has been around 36-38 running the A/C. The last tank is showing 42.8 without running the A/C so a big improvement. I use 100% gas (no ethanol) and am curious if the E10 stuff hurts the mpg. I also have a 96 Camry that typically gets 31mpg on 100% gas and when we tried E10 the car ran lousy and the mpg dropped to 28-29. Will E10 have the same effect on the TCH? E10 in the OKC area seems to be predominate now and it is getting harder to find 100% gas. I am hesitant to try E10 if it will hurt the mpg (even if it is a few cents cheaper), not to mention what other "bad" things E10 might do to a car.
    I have 09 TCH bought in May--used normally for in town driving--stops/starts and lights and since I'm in TX run my AC---I normally get a 32-33 avg and the gas I normally put in has ethanol to certain %--there are times we have gone on the road and gotten more like 38-39-40 mpg and bought gas that probably had no ethanol...
    so yes--if you have ethanol mix it will lower your MPG no way to avoid that since it is law of chemstry...
  • lzclzc Member Posts: 483
    The energy content of gasoline is 112-114,000 BTUs (winter/summer blends). Corn ethanol contains 76,000 BTUs. E10 reduces the energy content about 3%.
    So, I guess the bottom line is I need to stick with 100% gas as long as I can get it. Something I knew all along but was hopeful the TCH would handle the "garbage" stuff better. Whose brilliant(?) idea was it to introduce ethanol into gas? Wait, don't answer that, I think I know who!
  • colorlarrycolorlarry Member Posts: 1
    I just completed a round trip between Syracuse, NY and Hyannis, MA in my new TCH. The tank average for the trip to Hyannis was about 40 mpg. The average for the trip from Hyannis was about 36 mpg. The routes were identical as were the driving conditions. The difference? The gas bought in Massachusetts for the trip to Syracuse was 10 per cent ethanol.
  • bjrownerbjrowner Member Posts: 3
    I am also seeing a discrepancy between the readouts, and when I calculate MPG in my 2007 THC at the pump. The read out on the console is usually anywhere from 3 to 5 mpg better than what my calculation is after filling up at the pump. When I asked the dealer to check to see if the on board calculator was reporting accurately, she said the on board one was working fine. She said it is just calculated differently than when at the pumps. I have no idea what that means. How can both be correct? How would they check the accuracy of the on board calculator? Thanks for any insight you may have.
    A 3 to 5 mpg spread between dash readout and hand calculation seems excessive to me. I've experienced a .5 to 1.5 mpg difference, with the dash reading high more often than hand calculation. Some of that can be accounted for by the difference in when gas pumps click off.
    I will say that about the time I conclude the dash reading is always a little optimistic, I get a couple calculations the other way. So, it just may be not as precise as some might wish.
  • tsytsy Member Posts: 1,551
    I agree, mine is usually only 1-2 mpg off (always higher though). This is similar to my experience with other cars with trip computers though. I believe it's calculated by the computer through how much fuel is going through the injectors which must not be completely accurate but is a close estimation.
    tom
