Land Rover Discovery and Discovery II
1545557596097
  • nanuqnanuq Member Posts: 765
    You're smart to avoid the 33" lifted gnarlified Disco (or Defender) because it's likely it's had some hard use offroad. Without adequate preparation and followup care it can have some damage. If you're really in love with one, look at the frame rails and the attachment points for the suspension trailing arms to see if they've been thrashed a lot offroad. Those are hard marks to erase. I'm with you... find one that's been to work and back 1,000 times, then put on your own tires and suspension. Start with a good solid baseline.
    The swivel ball is where the CV joint lives in the front axle, you can crawl beneath and see it clearly. There's a fill plug at the top, a level plug at the front and a drain plug at the bottom. They can be a bearcat to refill unless you turn the wheel hard toward the side you're working on... the ABS sensor ring is right inside that fill plug. If the owner has refilled them with Rover grease (the nasty green stuff) then it won't drain well at all... and that's an indication the swivel seal that wipes the ball has been leaking. This is pretty common.
    An owner might not want you messing with his truck to that extent, but if you're a serious buyer then all he's risking is the replacement of the lube in one of his swivels should you decide not to buy. It's simple, just crank the wheel over hard, pop the drain plug and catch the spillage. Check it for metallic flecks and milky streaks, then plug it, and refill it. Don't overfill because that messes other things up in there.
    Heck, it might even be easier to drain and check one of the diffs, and they'll tell you the same story. That just takes a 1/2" socket wrench... the plugs accept the snout of the wrench.
    For pricing, take a look at Ebay. Yeah I know that sounds spooky, but there are lots on there and the prices are low. Or look at kbb.com for your local area.
    Good luck!
  • rkoeslerrkoesler Member Posts: 62
    go for the Rover. I've had numerous Toyota products, and while they are almost infallable, they do not have the soul of a LR. My 00 DII has been an absolutely perfect truck for 3 years and 35000 miles. I had a 99 DII which was a true lemon, so I traded for a 00 Toy 4Runner, but got rid of it after 6 months because it was just a "perfect appliance" and I could not develop a relationship with it, like I had the Rover. So I bought the 00 DII, and have never been happier.
    I've also had Nissans, BMW's, numerous Mercedes', and a variety of "american junk", and all have had their share of problems - but not the 00 Disco!! So go get it ... Happy Rovering to all.
  • fdion1fdion1 Member Posts: 28
    I got all the info from nanuq compiled in a little document and I've added a few notes from various rover sites. So I'm ready to go and look at a Disco SI. But they are truely hard to find in this area. Particularly if I discount the 96.
    I'm not sure that the 96 issue is as big a deal as I tought it was initially. There is a local truck with 80K. It looks like it's been used solely in the urban jungle altough it has the LR brushguard and steps/slides. It's an SE7 and it's at $10K or so. But, it's a 96...
    I've found a 99, and looked like I was on to something (low mileage, good price, S1, dual ac) but it turned out to be an SD. Leather seats is a requirement.
    I've found lots of 140K+ miles vehicules.
    So now I know:
    SD = base model
    SE = leather, dual air, more?
    SE7 = an SE + jump seats
    XD = AA yellow special edition
    LS = ?
    LE = ?
    LSE = limited special edition 50th anniversary?
    And that no matter the trim, you could get roof rack, brush guard, slides, tow package, dual ac, dual sunroof, auto box, cd player as options. What's with that pneumatic foot rest thingy I've seen in adds? What about an hydraulic step? What's that for?
    Anybody can fill me in on what LS and LE trims are and did I miss anything?
    My '96 is an SD and it has the leather seats fore and aft. And in the earlier model years, the leather used was *extremely* high grade stuff. I read once the world's leather market has five grades of leather. The first grade used to go exclusively to L-R and one other manufacturer (was it Bentley?) and the American leathers were grade 3. Now it's all changed and I have no idea what you can get... but the seats on my '96 are immaculate (with visible wrinkles) and she's got 82k hard miles.
    About jumpseats, I found a pair in a wrecking yard for $175. $40 worth of hardware and some careful cutting was all it took to put them in, in one evening's work. I got aftermarket seatbelts and they work fine.
    If you find a good looking '96 ask Tincup about its service history... he's a great asset for running that down. If the carbon cutting valves have been done, have no fears about the truck.
    Regards, -Bob
    If you mean the one at the aft end of the truck, its primary purpose is to reduce your departure angle when you're climbing a steep bank. *wink*
    Actually it's a swingdown step to help people climb up into the rear jump seats. I didn't put the step on mine for the clearance issue, and because the jumpseats are accessible just fine by kids (who are the only ones who want to ride back there). If the rear bumper is really dirty you might have to pick your kid up and chuck 'em in the back... that's part of the fun and it keeps their knees clean.
  • blockislandguyblockislandguy Member Posts: 336
    Fdion1, IMHO the non-leather, leather -like fabric in the SD is actually better and longer lasting then what they put in the SE. (Keep in mind that with the SE you also get the armrests, though I don't think Nanuq has these in his!)
    But, if you truly have to have real leather, have it put in later in the aftermarket for less money and more color and style choices. Same thing with a sunroof. The aftermarket ones are cheaper and probably better. (The Rover dealer West of Boston puts in aftermarket "roofs " in most of his SDs as a matter of course.)
  • tincup47tincup47 Member Posts: 1,508
    LSE and LE were 1998 MY vehicles only. The LSE was a higher spec vehicle than had been offered in the preceding years and had body colored bumper ends and mirrors, chrome bumpers, Lightstone seats, additional wood and leather trim. LE was the standard 1998 model. I know of no SE being sold in the US. There was also a 50th Anniversary LSE that had Bahama Beige seats with lightstone piping instead of Lightstone with black piping, special wheels, and 50th Anniversary Mats. Prior to 2000 MY all Discovereys had Leather or cloth seats, SD models generally having cloth and being manual seats. The Duragrain Leatherette did not become available until 2000 at which point all Discovereys got power seats.
    Duragrain would probably be best to last a long time. The 1999 SD I saw had cloth seats tough. From what I've seen, they dont seem to age very well. I'm sure it all depends on the owner and how they used their Disco.
    What are lightstone seats? Did the LSE get the jump seats and dual AC or is that optional anyway? 50th anniversary doesn't seem like it's worth the premium. Had it gotten the safari roof rack and the brushguard...
    BTW, are there side steps that are slides? Or do you have to choose between the two? A friend has a Land cruiser and the slides are also steps. I think they are factory.
    Francois
    I understand now that I've seen one in person. Some adds are really funny in how they describe things. Also, I've seen advertised a 4x2 Discovery??? I dont see how that is possible from factory. I can see an easy way to do it later on by using locking hubs, but that still leaves all the axles turning.
    The rear step should have been designed to retract back into the bumper. A hitch will reduce your departing angle too. I see another problem area, the rear bumper corners. They are not steel. I bet these get damaged easily.
    Is there a reason why there is no land rover club on edmunds, is it that the volume of discussions is very low? Or just too few owners on this board?
    Is it the zf4hp22 auto tranny that is used on the SI disco? I know the Range uses that. I love that tranny, as I got that on my Peugeot 505 STX. Doesn't feel like a slushbox.
    Francois
    Is there a reason why there is no land rover club on edmunds...
    That would be a very good question to ask here: Owners Club Changes, Suggestions, & Announcements!
    Lightstone is a trim color for the leather seats, it is a very pale beige. Rear A/C and jump seats were optional equipt on the Discovery I LSE vehicles. There was no such thing as a 4x2 Discovery, all Land Rover Vehicles from at least 1986 on are permanent 4WD or AWD (Freelander) vehicles. There are no locking hubs on any of our modern vehicles or any way to take them out of 4WD. Discovery 1 vehicles have excellent departure angles, even with a hitch or rear step. The trans is the 4HP22.
    It is a wonderful trans, and if you think it feels nice and solid onroad, you should feel it in low range! Woooohoooooo, it'll slide a deck of cards off the dash as it shifts forward gears. BANG-BANG-BANG and you're cruising (at 15mph!)
    My poor rear hitch receiver has taken a beating over the years, but I haven't ground thru it (from the underside) and it's still solid as a rock. But my rear bumper corners? I've torn each one clear off several times. *Sigh* Time to move up to a real rear bumper.
    I had found a nice 98 LSE with low mileage, advertised this weekend and it sold in 2 days...
    Francois
    I was looking at a vehicule in georgia (online) and checked on it and it's pretty funny what I found:
    summer 2000 it was sold at an auction
    september 21 2000 - accident, right front impact
    september 22 2000 - yet another accident, this time a rear impact, more damage
    was sold 2 months later with a total of less than 900 miles.
    Wow, that's 450 miles / accident average
    I'm thinking somebody couldn't pay and was trying to total it, or drinking problem...
    The next owner took care of it for 3 months with no accidents, then sold it (maybe the original owner again!)
    August 2001 - another accident, rear impact
    July 2002 - yet another accident, front impact this time
    It did cover about 40K during that ownership.
    A little better.
    20,000 miles / accident average.
    Needless to say I will pass on this vehicule.
    Drive safely,
    Francois
    Shouldn't they be H rated? I see a lot of no brand light truck tires (not H rated) on most discos for sale. If you going to put that much money on a truck, why put cheap tires...
    I'd assume one would put something like the Michelin 4x4 XPC or the Pirelli Scorpion A/T (at almost half the price of the michelin) or even the Michelin 4x4 Synchrone if you stay in the city.
    I would definitely buy steel rims and proper offroad tires, but that means I'll have to buy 8 tires...
    So anyway, what tires come from the factory?
  • tomcatbubbatomcatbubba Member Posts: 5
    Greetings,
    I have spent the last seven months at sea, just got home, and now have to move the family from coast to coast. I have tried getting the factory wiring harness but they seem to be back ordered. Does anyone recommend an after market wiring kit. I would rather go factory but I have about two weeks before I have to leave which means the factory option is probably out.
    Thanks for the help
    Tomcatbubba
  • tc1004tc1004 Member Posts: 1
    just bought a hse7 and asked for the $1k manuf to customer and the dealer (matheny jaguar in jax,fl claimed they had no idea what we were talking about. we still have the edmunds print out on it and trying to pursue what should be our $1,000.
    has anyone received since may 1 2003 the $1,000 rebate?
    if so how did you collect?
    VERY STRANGE...if you go to edmunds today 6/7/03 you will not find the same rebate...they have conviently changed it to manuf to dealer...odd BUT i assure you i will get to the bottom of it?
    let me know any good testimonies of your getting this kind of rebate, please?
    ps:so far the hse7 is totally awsome for 41,500 plus tax/title!!!
    tc1004
  • mbperkmbperk Member Posts: 9
    I went buy Carmax yesterday, and found they had a nice 2003 Land Rover Discovery SE model (Dual SR, Xeon Headlamps, Heated Seats, Rear Air, Etc.) at a another Carmax dealership. It looks be be in great shape. It has 9000 miles.
    I ran a carfax report on it, and I found it had been a Rental Car somewhere in NY. It was purchased in October 2003, and sold at auction in April 2003.
    I have read mixed messages on these boards about buying a Rental. What should I do??
    Can you get the VIN to Tincup? He can tell you if they're dumping it due to chronic problems (doubtful). More likely they just don't want the slim profit margins for renting something that expensive.
    If it's been well maintained, doesn't show signs of obvious abuse, and has plenty of warranty left, sure... I'd buy it for the right price. Look it over closely for offroading damage... sometimes people rent 4WDs and beat them offroad knowing they're not going to have to pay for it eventually. That abuse will show on the undercarriage.
    Good luck, -Bob
    Land Rover has had agreements with Hertz and Enterprise for about 2 years. They tend to turn cars over with relatively low mileage on them as their customers do not want to rent cars with higher mileage. I can check the Warranty History but I see no issue with buying a rental Discovery.
    I bought my '96 with 9 months on the clock (for a VERY good price!) and now that I've taken her "over the hump" she's tough and reliable as an anvil.
    I didn't know she was a rental before I bought her... I didn't know enough about the beasties to realize I should have asked. I had some major teeting pains (Tincup should be able to pull up PAGES of service work) but my svc manager went the distance with me and man am I pleased now. I can't say enough about the lads at Land Rover Anchorage.
    For what it's worth, they basically turned my '96 into a '99 and all the things they did were on the TSB list. Subsequent Solihull creations addressed the TSBs with new designs, and the gremlins are banished. Forever? It appears so.
    A couple of things were apparent on my Disco, evidence of abuse during the rental period. My rear bumper was bent down on the passenger side, and there were some impressive gouges on my frame rails. Knowing that, and anticipating what kind of mechanical havoc was probably raised inside my engine in the process, I still find her to be absolutely stone reliable.
    And I'm not even going to close this with a Lord Lucas Disclaimer. HAH! How's THAT for feeling cocky?!
    You are always quite entertaining to read. Is the list of things you had to do in the archive on this board?
    I'm curious.
    Francois
    Can it be repaired if it wont go back up? I checked out a replacement step, $239.00. Surely you can just replace the cartridge? What is a good online dealer to buy disco parts from?
    Francois
    Try a "Discussion Search" for "Nanuq" and you'll find lots of posts to while away the hours with. There's probably a few messages with the "telephone pole buried up to the crossbars in snow" pic in there too :-)
    If the search pulls up the erstwhile forgotten discussion about the.... um,
    Never mind.
    The replacement gas strut for the Discovery I step is part number RTC9593AA. The strut for a Discovery II step is part number KVL100040.
    I've yet to find the info on the repairs, except something about a roof rack, but I wont mention it :)
    Also some interesting readings about some guitars and such...
    thanks for the info. Looks like about $98 for the repair kit, at a few online dealers. Not too bad. I need to get me a set of microfiches, there is much to learn from them I'm sure. I got them for my Olds Aurora, and it's invaluable in understanding how the stuff is put together.
    Also, I sent you an email regarding a specific vehicule, if you can help.
    Ciao,
    Francois
    If you wind up buying a Series I Disco, I think you can do without the microfiche... I have a complete workshop manual I'll give you. It was given to me by Wasko, another long-timer here on the board. If it will help you maintain your own truck, I'll be happy to send it to you. It is an EXCELLENT book, and you can likely fix anything on your truck with it, and a good set of tools.
    Regards, -Bob
  • denver8denver8 Member Posts: 42
    Since we are talking about eariler posts I remebered your post about paying off your truck and the next day the check engine light came on. Well I sent in my last payment today.. Now I just have to sit back and wait for the wheels fall off.
    Ain't it great? And the way these things are built, there will be no more payments until we're good and tired of them! Congratulations.
    It won't be the wheels that fall off. I swear there's a sensor in the driver seat that determines the inertial mass of your wallet. Once it gets heavy enough the light comes on.
    Thanks for the comments. I bought it from Carmax Monday, and I returned it this morning. It was not well taken care of. The paint (Java Black) had swirl marks all over, and had a few places that were touched up. The hinge on the rear door was rusted, and corroded.
    I ran a Carfax (Wish I would have checked here before it did...Tincup thanks for the offer) on it before I bought it and it came up as owned by a "Major Car Rental" company in October of 2002 in upstate NY or NJ, Carmax bought it at auction in April of this year. It looks like it went through a hard winter because it appears to me (Not that I am an expert) to have salt residue in many places. The glove box had a broken hinge and the hook that holds the cargo cover was ripped out. Just not a well taken care of rental.
    I found an excellent SE7 on ebay with 1100 miles or so. But I just have this apprehension on buying off ebay with not being able to look at it myself. The seller has excellent feedback for selling high end cars, but the VIN looks funny to me. The first part is SALTW...I thought Disco's all started with SALTY???
    Forgot to add that the extra key was on a Hertz #1 keychain. I cannot believe that Carmax left that on there.
    Bid only on auctions where sellers allow you to cancel after you inspect the car.
    Buying and Selling Cars on eBay
    Thanks for the offer. If I can confirm the truck I'm looking at had a valve job then more than likely I'll become the owner of a 96 Disco SI.
    Francois
    Thanks for the advice Steve. The vehicle is in Texas, and I am pretty sure that I will not be able to inspect it until after I receive it and by then I doubt they would take it back. It really does seem like a great car. And from the looks of it they have sold numerous ones on ebay and those buyers seemed happy.
    Here is the link http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1- - &category=6294&item=2418498883
    They are a licensed Lexus Dealership, and they have excellent feedback. So should I stay away from this?
    Brad
  • clpurnellclpurnell Member Posts: 1,083
    I live less than 12 miles from this dealership. I can go look at the vehicle for you if you want. However I have had extremely negative experiences with the new car side of this dealership (shopping for lexus rx330). Let me know soon I will be out of town for a week starting tomorrow.
    I'm not sure I got to the conclusion of this, and reading the archives only made things muddier.
    Is 1996 really the only year that has had problems with the valves? I know this was caused partly by the GEMS version, but somehow, I would think the new valve design release date would be what I'd need to look for even on a 1997. Plus a 1994 and 1995 would have the same problem, altough the 3.9. From the engine manual I found for 3.9/4.0, the valves look the same to me.
    So what is the final word on this?
    Francois
    PS. Nanuq, I've not been able to test drive yet. Somehow I have the feeling that they changed the wired/plugs and it's still running rough... Which would indicate valve job if it hasn't been done.
    It could be a pending valves problem, or a throttle position indicator, or the tubing feeding the vacuum lines to the plenum could be gooped up, or... even the connections in the fuse box beneath the hood can be corroded, leading to confused ECUs. If it ain't purring like a kitten, walk away. If they can't explain exactly what they did to make it purr like a kitten... walk away.
    '94 and '95 had no real trouble with the valves. You're right, some '97s had it too. It was eventually solved, as those were BIG ticket warranty items for Rover. It started when the 4.0 engine appeared, which coincided with GEMS. Something in the combination allowed unburnt fuel and combustion byproducts to deposit on the valve stems of the exhaust valves (which is why injector cleaner has no effect toward fixing it). That accumulates and causes the sticking exhaust valves. They replace the tapered-stem valves with square shouldered "carbon cutting" valves which then prevent the deposits adhering to the inside of the valve guides.
    Keep looking, you'll find a Rover that sings your song. Don't jump too soon.
    Christian,
    I sent you an email. I just bought it, but if you would go by there and check it out I would greatly appreciate it. How do you like that FX35? My wife has a Infiniti G35. First infiniti for us great car, but really small with our baby.
    I will be sure to mention to Barrett about how you had a bad experience with them. Sorry to hear that.
    Man! The people on this board are the best.
    MBPERK posts about running a carfax after he bought a Disco. Some dealers offer to run a free carfax for you if you express some interest in a car. Beware. The short, abbreviated ones they produce lack the same detail that I've gotten on ones I've paid for as an individual.
    Instinctively, I feel that Carfax knows that they couldn't sell the service to dealers if it was going to produce any significant detail beyond was the car stolen or does it have a salvage title. When I approached Carfax on this to complain that they seemed to trim their reports on dealer requested reports, they responded that there were different levels of reports etc. etc. It sounded like they had reports tailored for sellers or buyers. Just pick which side of the sale you were on!
    Personally, I wouldn't accept simply , as in MBERK's case, the fact that a "Major Rental Company in either NY or NJ" owned the vehicle. I'd like to know which one. Certainly the maintenance program at say Avis might differ from an off-airport rental house. If I could determine that the vehicle was owned by Avis at Newark vs. Dollar Rental in Syracuse I could make a few phone calls to the maintenance people and make some assumptions about the usuage patterns.
    Net-net, I'd suggest that the prospective buyer pay for his own carfax report and get much more detail.
    TINCUP, what say you?
    I will check it out tomorrow AM for you. I will be right there anyway as I am taking the FX in for it's first oil change. The dealers are right across the highway from each other so it is no problem at all. I absolutely love this vehicle we are about to take it on a 2500 mile trip (rt) over the next week. I have two kids and the FX works for us but we tend to pack lite. It will be interesting to see how it handles the gear for such a long trip.
    I got a 30 day unlimited to search for my vehicule. I wouldn't trust a piece of paper given to me by a used car dealer. Run a carfax yourself. A lot of classifieds now include the VIN. Run it, if it looks good, then you need to verify the VIN when you go look at the vehicule. Dont get the one from the window sticker either. Get it from the dash. I've seen one case of a typo that still passed the checksum on one truck I checked. In that case tough, carfax came back empty handed. Still...
    If you see auction on the carfax, approach with caution.
    If you see commercial rental, pass. I went to see one, man, what a basket case in disguise!
    I'd also get the vehicule history from Land Rover. I hear there is a number you can call to get that kind of info, or go to a LR dealer to get a printout.
    Once everything pans out, that's when I'd do a test drive. No need to waste your/their time if you find something scary on carfax.
    Then, if you know enough about cars, and have compiled a list from all the info that Nanuq posted on this board (for a series I, on an SII, that is a whole different story) and can do the inspection yourself, do that. Else go to a garage you trust and have them inspect the vehicule.
    Francois
    My wife and I just came back from looking at a few Discovery. The first on our list was what I tought was an Arles blue from the picture. Except that Arles blue was never a color for the Disco. Turned out to be Avalon blue metallic. A 97+ colors.
    Next, a white one. This is Alpine White. Erronously advertised as a 97. White was not available in 97. From the VIN, a 96. You learn something new every day.
    Last, a red one. Portofino red, a 94-96 color I understand. Not to be confused with Rioja red introduced in 97, altough I cant really tell...
    During the past week we also looked at a dark green 97 (is that Charleston Green?) and a Willow Metallic. I've also stopped counting the beluga black discos, altough we haven't gone to see one for sale per say.
    So, quiz time. What do you think my wife's favorite color was, what was mine and what is yours?
    Francois
    BlockIslandGuy:
    It was a Hertz rental. The spare key was attached to a #1 Hertz key chain.
    Chris:
    Hope the trip went well. No doubt the goodies (Navigation & DVD) inside came in handy.
    The one perfect color for a Rover is metallic silver. When you gouge the paint, the aluminum showing thru is a perfect match! ;)
  • psquaredfilmpsquaredfilm Member Posts: 2
    Hey People,
    Have read about some of the valve issues with the 4.0
    I'm trying to decide between these two vehicles and have put a deposit on the '95. Is one better than the other?
    The 95 is well priced but seems to be leaking antifreeze from below from what seems to be the water pump.
    Is this normal for a car with 66K?
    The dealer said he'd fix the "leak".
    Anyone know how much this would cost to fix if I got stuck with it?
    Other questions:
    when should you consider changing the timing belt(chain) on these vehicles?
    What is the difference between a Disc and a DiscII?
    Anybody recommend a garage in the Brooklyn or New York area other than a dealer?
    Thanks for your help in getting me up to speed
    p2
  • b4chun7b4chun7 Member Posts: 2
    Hello. My '96 Discovery is fine and just went over 100k miles problem free. However my '99 RR purchased last year just lost its propeller shaft as I'm travelling down the highway. Besides being totally miffed, has this happened to anyone with a Land Rover vehicle? I had great things to say about LR till now. I'm even fighting with LRNA because the warranty may cover the shaft but not the other damage it caused under the carriage. Can someone suggest a good approach to this besides me having to take someone to small claims court over this fiasco? Thanks in advance.
    MBPERK, when Carfax indicated that a Volvo 2001 XC I was considering buying from our local Volvo dealer had been owned by Hertz and stationed at Logan Airport I was thrilled. Probably good maintenance, certainly good records, maybe even better maintenance than a busy individual would give.
    Well I called Logan. Never could ever get through to anyone in the garage. Ever. Only the ticket agents. Finally, I was passed a message out from Tony in the garage (his daughter was a ticket agent as I recall) that every car they had was maintained A-1 and I shouldn't worry. Yeh, right. So, I checked the air filter on this under a year old car. It was clogged. Never had been serviced. The oil was dirty but all oil is after 2000 miles and the Volvo dealer had thoughtfully removed all oil change stickers. Spying a plastic clip in the on the drivers side of the windshield I knew that this must have been a rental car because afterall this was where they put the Hertz folders when they wait for OJ Simpson to sprint in for his Volvo.
    To make a long story short, I never was able to tell if the condition was better or worse because Hertz owned it (and I learned a year later that ALL 2001 XC have that plastic clip in the windshield, rentals or not.)
    I wish you well with your new vehicle. We've had good luck with the so-so maintained Hertz Volvo. (It immediately had a change of all filters and fluids to include Red Line ATF and Mobil 1).
  • discofrk75discofrk75 Member Posts: 7
    The wife and I are planning on purchasing a 2003 Disco SE7 and I had a couple questions. First, is the old adage of a "Break-In" period still needed and what would that entail and second, the dealer told us something that sounded pretty strange to me, he said that the "NEW" LR only need to have their oil changed once every 12 months. Pretty weird. I have a 2000 VW and if I went more then 4 months without changing the oil and doing the regular maintenance the car wouldn't run as smoothly. I'm not trying to compare a Jetta to a Disco however I just don't want to be misled by the dealer.
    Anyway, any other advice to a LR newcomer would be greatly appreciated.
    - Maurice
