Visitor Agreement.
Ran through the entire engine looking for any and all problems and found that the alt was bad. Went to napa dropped a hundred bucks and bam - starts right up.
thanks mike.
I believe this is a classic case of Divine Intervention. :shades:
additional: starter was tested by jumper cable to starter stud. No joy(or motor spin)
conclude starter is used up.
130,000 miles
The Problem:
The first time the engine is run, it starts normally and runs smoothly for about 5~10 seconds. Then the RPM drops to a few hundred and the engine chokes, coughs, backfires through the air intake (not the exhaust). It often stalls and must be restarted. After about 5 minutes of the rough idling it will smooth out and run fine for the rest of the day. I will often get a P0300 error code (engine misfire) an occasional P0101 (MAF) error and P0440 (EVAP) code. These are never together (only 1 code stored), and do not always occur after the first starting (the P0300 being the exception) .
The engine trouble light will often “flash” after the above without any trouble code found, and the engine performance is sluggish. Usually the check engine light will go off and not return if I stop and restart the engine. After that the engine runs fine.
One additional symptom occurs (rarely) in that if I have been driving at highway speed for a lengthy time and stop – the engine stalls. But, it starts right up.
The engine burns oil (at the “normal”, for the Trooper engine - 1qt/1000 miles) and there is never any Blue smoke from the exhaust. It acts like fouling, except it start normally them the choking starts. I also thought about a clogged fuel filter or fuel pump, but that too would be a continuous problem.
Have you seen this behavior before? It does not seem to be getting worse, but with the cold weather it may become so.
Coasted back down to flat ground and it took several minutes before starting.
What would be causing this?? Thanks..
I dropped a support brace that was in the way, but did NOT have to mess with the exhaust manifold. I have several different length extensions that helped quite a bit. I just crawled up under it and worked on it, would have been much easier on ramps or a lift.
Good luck,
Bill
tried to start it and I had nothing had full power to dash lights headlights radio but no start got out my flashlight crawled under driver side checked hot wire it was tight took
field wire off checked it put back on got back in an it started up drove home next day I
went out an it started 6 times in a row went in took my shower got ready for work it started up stopped at NAPA for wiper blades got back in guess what thats right nothing got out crawled under this time I noticed when I moved the hot wire the
solenoid housing moved also but after 5 tries it started went to work got done an believe it or not it started drove home next day it started another 5 times in a row sat for a couple hours went back out a nothing never started after that so i took jjoker's advice when I took starter off because I didn't want to mess with exhaust pipe . Going to take it an have it rebuilt not going to pay no 145.00 for new one if I don't have to if you know what I mean. Hopefully this will take care of it I hope will post new message when it's fixed.
PS thanks jjoker for the advice
I hope this makes sense Im not good with car stuff
Hope this helps.
There doesn't seem to be gas getting far enough. The car sounds like it wants to start but isn't getting fuel. The turning is normal and so we're pretty sure the timing chain hasn't slipped.
One problem is that the fuse box with the relays in the engine cab, doesn't seem to be getting power to some of the components on the engine block. We tried testing several areas from the fuses to a few components and there is no charge. It was suggested by a friend that maybe the on board computer is defective or damaged? Could this be it and how do we check? Any other suggestions please let me know.
Mahalo from Hawaii
My experience is from a different climate, though, and based on the behavior I observe in mine. I doubt very much that your problem is ECU related as long as the engine starts eventually. More likely that a poor ground is at fault for most common problems. When you turn on your key, your fuel pump should turn on for two seconds. This pressurizes the system. If it does not turn on, then one reason you might have to crank longer is that the engine has to build up enough oil pressure through cranking to tell the ECU it is OK to turn on the fuel pump. Once it is on, then there is enough pressure to inject fuel in the cylinders. If you can check the fuel pressure with a guage, you will see that with the fuel regulator working, fuel pressure is about 4 pounds lower than when it is plugged in and working....in other words 46# maximum, 42# or so when regulator is working at idle.
The electrical system that Isuzu built is a complex one, and it is not unusual for certain circuits to be hot and others not, it depends on the key position, engine running, alternator charging, etc;.
The fuel pressure regulator, which is tough to replace is a common problem. If the diaphragm is holed or torn, raw gas floods it when the pum is on and richens the engine to the point it has to crank a few times to clear the gas. If you cant get a gauge to check fuel pressure as I wrote above, you can pull the vacuum feed to it and CAREFULLY attach another hose to it and suck and if you taste raw gas, then the diaphragm is bad.
If it is not this, then the next possible item may be that you need a new water temp sensor for the engine. Not the one for the gauge though. The one for the ECU. IF it is not working right, the computer does not know the state of the engine and adjust fuel mixture accordingly. It, too, is hard to get to on the crossover tube on the back of the engine.
Finally, a lot of owners have remarked on this same hard start problem. A man who is a former Isuzu technician has commented that one reason Isuzu went to a new reluctor ring (on the crankshaft) in later models was because at times when the engine was stopped and then restarted, the computer (through the CPS you replaced) would have to crank longer so the CPS could "count" the gaps and distances over again, resulting in longer crank times than others. That was his theory, anway. In 96 they went to a different timing reluctor and software for the ecu, so go figure?
My engine loves cold weather starts....starts within a revolution but after it warms up or on a hot day, it cranks a while before starting. Just the way it is.
Hope this helps. One guys opinion.
92' Isuzu Trooper,
SOHC 3.2L,
Man Trans,
CA Emissions,
Electrical problems (no spark),
(originally belonged to my younger sister)
for a couple of years the speedometer and odometer would suddenly quit while in motion, then come back after turning off the car and restarting (sometimes), and occasionally had a starting problem for her (p/s pump leaking on the alternator)
I bought it from her for $500 the beginning of last December. The starting issue increased in frequency even with a new AND Clean alternator.
-Put it in a shop the Last week of December.... and it's stayed there nearly 4mths... A week after arriving there it stopped starting consistently.
-Crank sensor was bad (replaced)
-has no spark
-replaced good ignition control module and good ecm
-has no spark
-checked all wiring (supposedly), connections and relays
-no spark and they gave up
I have copies of their trouble shooting trees and flowcharts with notes - if you or anyone you know is familiar with troopers (and/or) this list of symptoms I would really like to get back on the road soon
This shop's been pretty thorough (I initially wasn't expecting much from a brake and muffler shop), they had already gone through checking continuity, and backprobing between the crank sensor, icm, engine fuse box ecm and even cab fuse box. (They've also replaced any fishy looking connectors or cleaned them)
They're missing ground signal from the ecm to the icm but I'm pretty sure they said the wire tests out good, and the ecm is basically brand new and passed factory tests
I'm stumped unless the wire from that pin could possibly have just enough corrosion to inhibit one signal and pass another
I'm new to this forum and this is my first time using it !
My son has a 91 Trooper and just this past week it wouldn't start at times. We would get the "click click click" noise when turning it over. Tried to jump it, 'nothing'... put the battery on the charger and it charged up within an hour, put it in the troop and nothing. Then an hour later went out and it started right up. He drove 500 miles back to school this weekend and it ran great. This morning he went out after class to start it and "click click click" again....
Is this something as simple as a battery, now that he is in his college parking lot ???
thanks so much !
I've bypassed the fuel filter and it seemed to run a little longer but not by much. My theory is a weak fuel pump. I can't hear the fuel pump running at all. But fuel runs out the line at input of fuel regulator.
Before a cut a hole in the back bed to get at the fuel pump (the bash plate and fuel tank are hopelessly rusted in place), how best can I verify the ECU is giving proper signals to the fuel pump?
thanks Jk
1. The starter engages when the key gets to the "ON" position instead of the "START" position.
2. The starter sounds like its staying engaged the whole time.
3. When in gear I don't hear the starter, but when I put it into Neutral or Park it grinds.
This seemed like a straight forward ignition switch problem, however I just replaced it with a new part and the problem is still there. Any ideas or thoughts as to what could be making this happen?
On 4-1-2012, I bought a NEW starter, (not rebuilt), from Auto Parts Warehouse for $88.00, found a discount coupon on-line for 10% off + final cost was $79.46 delivered to my front door by Fed-Ex in 2-3 days, with a 1 year warrantee..
Since I'm working with limited tools, this seems the best solution to my problems of a bad starter.. I hope Idon't have to drop the a-arm too..
I have a 1998 3.0DTi Trooper that starts OK from cold in under 2 seconds but when I restart it later after it has warmed up it refuses to cooperate. It just cranks on and on until the battery dies. As soon as the block reaches 70 degrees centigrade the engine will not restart. The engine is a 4JX1.
It has been at my local dealer for the last 4 weeks where they replaced 2 oil pressure sensors, changed the oil (for the 3rd & 4th time in less than 2 weeks) and replaced the oil puckup tube going to the injector hydraulic pump at the rear of the block (it was cracked & split at the top). All 4 injectors were replaced 3 weeks prior along with their seals and a new injector wiring loom as well.
A high pressure gauge was fitted to the injector hydraulic pump last week which showed the high pressure side as OK but the low pressure pipe only showing 10-20psi on the warm restart, 40psi minimum being needed apparently (70-80psi on cold start). The gearbox was dropped out yesterday to gain access to the small hydraulic pump and it's now assumed that a pressure relief valve within may be the cause of the warm restart failure. The workshop is now thinking of a change over engine and using all the new bits from my engine but I'm not really keen on this idea.
Has anyone here experienced similar warm restart problems in their (4jx1) 3.0 turbo diesel?
Perhaps someone here may know of a fix for the problem.
I will be most grateful for any assistance as I use my Trooper for my work, volunteer emergency work in the bushfire (wildfire) season of south eastern Australia and in leading offroad trips for my offroad club.
Hoping someone can help,
Evan
I've read through all the forums i've found, and the best clues I've gotten are few and far between, like:
1. transmission oil temp sensor that's bad
2. Some problems with the heat shield on these, and it confuses electrical connections.
3. Something with the Torque on Demand System that disables the system if its not quite right.
This all started after flushing and changing the transmission fluid. Before that, the pan gasket was leaking and it started to slip because the tranny fluid was so low.
At first I thought it was a Anti-Theft problem,
but it has to do with the heating up and 4 hour wait. Because if I drive a short trip to the store, I can start it back up, every time.
Occasionally, the Torque on Demand light flashes "Check" very briefly and then goes off usually only when I'm in Drive waiting at a red light, and sometimes when just starting (like the fluid isn't sucking through the transmission correctly?) That's the only suspicious behavior it has. All gear shift fine, and runs fine, no other warning or console lights.
Has anyone seen this? Someone out there has got to know what this is. The symptoms are just too consistent.
Could this actually be a transmission-overheating issue?
Does any one recommend installing an extra tranny fluid cooler?
I'd really be grateful if there is anyone who's seen this before.
Thanks a bunch!!!
Good luck
Temps in January plummeted below freezing here in augusta ga. !993 Isuzu Trooper, 3.2 single cam. It cranked that first frozen morning, 10 degrees F. But I did not let it run. I went back out an hour later and it turned over but would not crank. I let it sit a couple of days hoping it would "thaw out" and crank. Nope! My mechanic checked the plugs and changed them and it cranked. He took it to his shop. When I got it back he had changed the MAF sensor. I drove it a number of days then one day after shopping I came out and it would not crank. I had it towed. The mechanic got to it an hour after that, so almost 2 hrs later and it cranked. It did it again and this time he kept it a couple of days and replaced the cranking sensor. Oh, and the truck has over 250, 000, drove great all this time and does not rattle nor smoke. She is always serviced timely too. So then less than a week after crank sensor deal she does this again, won't crank after being driven somewhere. She would not do it once she got towed to the shop. I kept it til it cut off again and then I drove it a long ways THEN took it to the shop hoping it would NOT crank while it was at the mechanic's shop so he could get a code on the computer. Well, it wouldn't crank and he first shot it up with starter fluid. She coughed and sputtered but cranked. We replaced the fuel pump. It was 21 years old so why not? Yet again it cut off to the point we agreed to just expect it to when we had to go to the store or work. Now three days ago she had a new symptom. We cranked her up, turned on the AC and just sat. We never just sit. After about 10 minutes she cut off. NEW problem. The yesterday, the icing on the cake. I was driving her to the bank and when I went to change from second to third gear, I accelerated and she began to choke up, so I dropped it back into second and got to the hill to try to make it back over the bridge towards the shop. After this turn it didn't matter which gear, she would try to choke and once we got on even road she choked more until we got to the shop driveway and she cut off. My mechanic had said before this it may be the ECM so I have been anticipating the Trooper dying like this. To date we have replaced plugs, cranking sensor, MAF sensor, ignition module, fuel pump and filter, reset the computer, and he pulled the computer yesterday, called me and told me to give him some time cause it may not be the computer. All I know is that something is getting hot and is keeping her from cranking. Yesterday, turning off like that when I accelerated...I have no idea. He said it can still be the computer. What has me puzzled is what could he have seen when he pulled the computer to make him now think it is something else shorting out??? Do any of you have an answer to this? She is a good ride and I am worried. Thanks!!
