Cadillac Deville: Problems & Solutions
Griffman12
I have a 1993 Sedan deVille with 132,000 miles. Have had it for over 10 years and it has been babied. Just got back from a 600 mile trip to North Carolina. This morning the battery was dead (a 28 month old Optima). Charger indicated it was bad. Replaced it with another battery, now the lights on the inside of the car stay on all the time (like a door is open) and it will not lock the doors when shifting into drive. Starts normal. Have not drove it yet. Disconnected the battery a couple of times and still the same result. Suspect the computer is kaput...advice??.. thanks..ds
It runs fine when cold or cool, but stalls when hot (Las Vegas + 10 miles). It will start back up but, stall again until it is allowed to cool about 5-10 minutes. Then it will run for a while. After a stall, the fuel line still have some pressure on the return side.
Any ideas?
It doesn't "click" it just won't turn over. I had it towed to a dealership (even though it started 1/2 and hour later) and they couldn't duplicate the problem.
Did you ever get an answer on this one?
You can actually have the coolant tested for CO contamination, that would tell you right off. A compression test might not pick it up.
Have you checked the thermostat, just on a long shot?
Dr. Tom Cotter
Can I check for contamination myself. If It is contaminated do that mean I need to change the head gasket. Someone told me water maybe leaking into the intake
manifold. I don't know help please.
P.S. Whatever you do , run a Carfax on it if you don't do anything else. Remember my friend, AN OUNCE OF PREVENTION IS WORTH A POUND OF CURE.
So far I have replaced the fuel pump, filter, pressure check. They were not the problem..
Please, I need help..
So far, I have replaced the fuel pump, filter. Pressure check. These are not the problem. Please, let me know if you fix the problem.
If I let it warm up as its pretty cold out now, it will stall about 5 minutes into the warmup. Once I start it again, no problem.
Does anyone else out there know what these common problems could be? I have had it on the computer, but after changing numerous sensors the problem is still not resolved.
Maybe what he meant was (if you have the Northstar engine) is that the heads might be warped and Cadillac considers warped heads throw-aways---they generally don't rebuild old cylinder heads. And putting new heads on an old engine might stress out the bottom end of the engine, that's true.
If you do have the Northstar, don't try to rebuild it---get a new engine from Cadillac. Hopefully you won't need that, but......
Anyway, if the heads aren't warped or cracked, I don't see why you couldn't replace head gaskets. The problem is, once you open the engine up you have to be prepared for the worst.
Ruff
HELP!
