an 02 i bought in feb 10 with 104K (i saw right away the ignitioin lock cylinder was bad and had to learn how to giggle it just right in order to start). i put 4K on it and it has sat for the majority of the last 3 or 4 months.First started shutting down in the middle of driving, and then not starting at all. my first success at starting it again was with quick starting fluid, ran for one day and then wouldnt start again, then i found this forum and tried wd40 on my keys, manually locking and unlocking both doors, turning the key in the on position for 10 min (that worked like 4 times).
So today i decide to take another shot at it after not starting for a month...i turned the key and floored the accelerator pumping it and it started maybe 7 times....now back to nothing.
i have dreamed of owning this car since the first time i saw it, finally i had the means but i put everything i had into buying the car
so has anyone thought of the ignition cylinder or switch? i havent really seen it mentioned on here but i know they turn on systems such as the fuel system
HHHHHHEEEEEELLLLLLLLPPPPPPPP!!!!!!!! :confuse:
Anyway, I went out to start my car later that night and after some cranking, it turned on. This morning, no go. It's cranking like it wants to start but it's not going the full distance. I don't know what is going on and it's so frustrating after not having a car for six months, getting one, and only using it a handful of times before it cuts out on me.
Please help.
If you mean changing the fuel pump, it's in the tank. The tank needs to be removed for access.
The mechanic we took it to to be sure it was the battery informed us about a little snick in the security system: For whatever reason, the starter chip in your key won't be recognized and the car won't start. The mechanic said that you had to leave the key in the starter for like ten to fifteen minutes before the problem corrects itself. Hope that might help.
2. "My uncle (a mechanic) took the starter off and had it tested. It was lock up and had no power, totally shot! So I spend $140 on the starter and stood through the embrassment of having my car worked on in the grocery store parking lot. And still that did not work". So I guess it's safe to say the starter wasn't the problem?
3. "So everyone is now thinking it must be the security system". Did the "security" light come on and flash when you tried to start it?
Your Alero has Passlock II. The key deosn't have anything to do with it like in the "Passkey" security systems used in the past.
If the "security" light is coming on and flashing when you try to start it then turn it to the "on" position, wait 10 minutes and see if the light goes out. If so, then try to start it (this is in the owners manual for reference).
If there's been no security light, and the engine spins when you try to start, then the first place I would look is the fuel supply (pump/filter) and then the ignition switch.
If nothing happens when you turn the key to "start", I would look at the ignition switch & battery cables first (would say battery, but it's new, make sure it's not dead or rundown). Also check that the power to the solenoid on the starter is present when the key is turned to the "start" position. Unless the solenoid on the starter engages when you try to start it the starter will never turn.
Also, what does "reset my keys both times" mean? The keys in a Passlock II car don't have anything to do with the security system.
Is the security light coming on and flashing when you try to start it?
I am a retired GM Electrical Engineer. I own a 2002 Grand Am, and had this problem two years ago. I bought a Shop Manual for my car ($130.00), and worked out a way of bypassing the Passlock II system on my vehicle. After making the modification on my car, I have not had a single instance of No start caused by the Security system.
Last week, as a favor to a friend, I performed the same modification on a 2003 Alero. It took less than an hour. (not counting the time I spent taking photos of my progress) The modification was successful on that vehicle.
Details of the modification are posted on my personal website at:
http://www.bergerweb.net
There are instructions on how to do the modification using two methods. Both methods bypass the security module in the ignition circuit. One bypasses it at the connector to the Body Control Module, which is under the glove box. The other does the bypass near the ignition switch, which can be reached by removing the radio.
Please post back if you find the instructions useful.
Richard Berger
My local Radio Shaq only supplies 2.2 and 3.3 resistors. I'm needing a 2.7 resistor. Is it o.k. to use the 3.3 resistor? I serously doubt that I'll be able to find a .5 resistor; to add to the 2.2.
All help is needed. So far, I've taken out the radio, located the yellow, black and white wires. I've straped the insulation off of the black wire.
Also, if I press hard on the brake, turn on the wipers, radio, raise a window all at the same time of trying to crank, it willllll sometimes crank. NO JOKE!. :confuse:
I should have mentioned in my instructions that you can use any resistor from about 1000 ohms to about 4000 ohms. I chose a 2.7 Kohm because it's closest to the center of the allowable range. On my Grand Am, I used a 2.2 Kohm resistor, and it worked just fine.
I'm talking about when the security light comes on and flashes, or comes on and stays on solid. Read my website:
Your answer should be there.
NOTE:
Definitions: CRANK - The starter motor makes the engine turn over. Rr-rr-rr-rr-rr.
START - Engine roars into life - Vvrrooooooommmmmmm!
DOESN'T CRANK - No "rr-rr-rr-rr-rr"
DOESN'T START - No "Vvrrooooooommmmmmm!"
Well, here you are in the Alero forums too. Did you get tired of helping out people with Grand Ams? (just kidding)
Dick Berger
IF YOU CALL THIS NUMBER AND COMPLAIN ABOUT THE SECURITY SYSTEM
1800- 630- 2439
CALL THIS NUMBER/SUBMIT YOUR COMPLAINT/ AND RECEIVE YOUR SERVICE REQUEST NUMBER
THE MORE COMPLAINTS ABOUT THE SECURITY SYSTEM THE BETTER
PASS THIS INFO ON
Needless to say, I was so happy.
Followed your instructions to a {T}
The wiring/work look beautiful. :P
To make a long story short, it didn't work. :sick:
My security light no longer flashes......
Today, it stays on consistantly... controlling my battery; as to wear it will not crank
:sick: :sick: :sick: :sick:
If the light is on solid, it means that the BCM has found a fault with the security system. This could happen if you soldered the resistor to the wrong end of the yellow wire...You can check to see if that is the case as follows.
* Remove the kick panel on the passenger side so you can get to the BCM. (see instructions on my website for Pontiac Fix.)
* disconnect the center connector from the BCM
* find the connector pin that has the yellow wire going into it. It should be the center pin on one side of the connector. Directly across from that pin, should be a pin with a black wire connected to it.
* measure the resistance between the above two pins. They should read very near to the same resistance as the resistor you soldered into the circuit.
If your ohmmeter reads a very high resistance or an open, you didn't make a good connection on the ground (black) wire, or you connected the other end of the resistor to the wrong end of the yellow wire. If it reads near zero ohms, the wires are shorted together. If the ohmmeter reads the correct resistance, the BCM is at fault.
There is one other possibility. In my original instructions, I recommended using a 2.7kohm resistor. That means 2700 ohms. If you soldered in a 2.7 ohm resistor, that is the wrong size. Remove it and replace it with one of the following:
2000 ohms - color code- red black red
2200 ohms - color code- red red red
2700 ohms - color code- red violet red
3300 ohms - color code- orange orange red
All of which should be available at any Radio Shack store. After you mentioned in another post that you could not find a 2.7 resistor, I edited my website to make it clear that any of several resistors would work.
If the color codes for the resistor you used are red-violet-black, you have used a 2.7 ohm resistor, which will not work.
I suspect there's more going on here.
This is the classic symptom of a clogged fuel filter. Have that checked first. Fuel filters are much cheaper than new cars.
Good luck. If you don't mind, We hope you will update us on the results... whether the fuel filter, or whatever else... solves your starting problem.
Originally when they replaced the crank sensor, this fixed the problem for a solid week. I really think the electrical might fall apart and I'll keep having different problems.
Dick B.
Dick
The website URL is: http://www.bergerweb.net/grandamsecurityfix.htm
