I hope the xterra you bought doesn't cost you more than it is worth. Apparently the 05 -07 (maybe other years, I read so many I got depressed and had to quite) frontiers, xterras and pathfinders have problems with the radiator leaking coolant into the transmission cooling lines causing total transmission failure to the point they are not repairable. From what I read it is about 5k - 6k for new radiator and transmission.
According to what I read, Nissan doesn’t care that their customers are having to pay for their mistakes also, or that they may loose their life. I guess as long as the ceo and the rest of the corporate yahoos makes there millions the hell with customer. They’re more suckers born everyday ;[
Toyota makes there share of blunders also but from what I have read they own up to some of them (google Tacoma frame complaints) .
Lucky for us consumers, we have the internet to warn others and to learn from other lessons.
Maybe these manufactures will figure out they need to stand behind their vehicles and customers or they end up just like there vehicles, in the scrap pile.
I apologize for the rant. I really just wanted to warn you about your xterra and thank you for your post.
Regards
Mad Michael
Mechanical and earlier than expected failures occur, but when it comes to lives, a totally different approach is expected. Purposeful ignorance of this issue by GM Customer Service is proof that the organizational failure within still exists today.
I do appreciate the words of warning, i'll check into that.
Ya know, the complete truth is, i've owned Chevy trucks since i graduated high school in 1979, at least half a dozen or more. I really, REALLY, like the old Chevy trucks, from 1987 back til 77' . Mind you, their bodies did rust out pretty bad, but they would last FOREVER, and you could actually work on them YOURSELF!! But when GM decided to make them where you couldnt work on them yourself, and make them cheaper, so they could jack up the prices, and pay their UNION employees over 20.00 an hour, GM went to S--t. They are no different than ALL the other car companies. Like my dad used to say- "PUT EM' ALL IN A BAG, SHAKE EM' UP, AND SHAKE EM' OUT- AND YOU CANT TELL THEM APART- THAT ALL LOOK THE SAME".
Myself included, AMERICANS (most of us anyways) are getting FAT and LAZY, and we want it EASY. We can only blame ourselves for letting GM and all the other companies stick it to us, because we take what we get, instead of saying NO, and turning our backs. In 1979 you could buy a SILVERADO brand new for 8000.00, Today, thats not even a good downpayment!! HEY- WE ASKED FOR IT!! Thanks, JIM said that!!
Might be a good idea to check that bearing before you lose a wheel, or brakes. Like i posted many times, i had to hit a BIG yello pole at Lowes, to keep from ramming a car in the parking lot, due to NO BRAKES.
Good luck. Welcome to the JOYS of CHEVY OWNERSHIP!!
Jim said that!!
Has pulling the fuse helped ? I noticed the better braking right away.
My problem was slightly different is that the pedal would pulsate as if ABS was activating causing the brakes to slightly loose pressure as if in a accident. After doing all you did, I finally pulled the ABS fuse and cure problem. If you want to see if that is the problem, pull the fuse and see if that helps. ABS light will come on but brakes work fine. Been that way for 4-5 yrs and 50k miles now.
Has anyone else heard of this or had this problem - or is the dealer full of BS?
It's great that your dealership has narrowed down the potential cause of your shuddering to the drums. We'd be happy to follow up on anything for you if you like; please get in touch via email at socialmedia@gm.com if we can look into this further (include your name/Edmunds username, phone and address, the last 8 of your VIN and current mileage, and the name of your dealership).
Sarah
GM Customer Service
The way i read it, not only did the TIRE MAN "narrow down the potential cause", He figured it out, which turned out to be a "MANUFACTURERS DEFECT", WHICH STATED IN 500 GM stated that they had "SEEN THAT PROBLEM BEFORE".
AS usual, GM builds faulty trucks, then blames everyone else when they cant figure out what they did wrong!! DEFECT- I DONT SEE NO STINKIN DEFECT!! WELCOME TO THE WONDERFUL WORLD OF OWNING A PIECE OF CRAP GM PRODUCT- HATEFUL JIM SAID THAT !!
SURE AM GLAD I BOUGHT A CHEVY, AND NOT ONE OF THOSE D--NED FOREIGN JOBS THAT LAST A LIFETIME. I SURE SAVED ALOT OF MONEY BUYING AMERICAN, wait a minute, that dont make any sense, forget i said that. Have a great day, Hateful Jim said that!!
Its unfortunate that I had to not only diagnose the problem for them but had to prove it to them as well. But on the good side they did fix the issue under warrenty and now my truck stops like a brand new truck.
@joe in calif, The emergency brakes on these trucks suck too. The cable goes to a small set of aux brake pads on the rear wheel., I had mine totally redone at 125000 miles, it barley stopped me. If you buy or have bought the truck, check to see that all the total brake system(lines, sensors, master cyl, etc., everything) has been replaced or do it before you pull your trailer.
Are any of you also getting anti-lock coming on at low speed (5mph) braking? If not then that will be next on your list. I really like my truck but GM messed up a couple of things. Why they haven't done a recall on these braking systems seems a little short sighted, but I guess not enough crashes?
Rotors (I have 4 wheel disc) + one front and one rear caliper, ABS wheel sensors under the recall, brake lines front to rear. I was getting the 5mph ABS activation for awhile even after cleaning my new sensors. The problem seems to have "gone away" for now. If it reappears I'll pull the fuse and do it the old fashion way.
Lets not talk about the 3 rear bumpers I have replaced and the huge hole on lower rockers do to the quality material GM uses, that's another issue. :lemon: :lemon: :lemon: :lemon: :lemon:
Ray T
There is a GM customer service rep. (gmcustsvcsarah) monitoring this site so pose the question to her regarding the ABS wheel sensor recall issue. Give the last eight digits of your Vin# and email contact.
The bumpers I bought new from Carolina Auto Supply (http://www.autosupplyhouse.com/) for around $129 BUT I had to go thru a friends business to buy since they do not sell to general public
Ray T :shades:
