I have a 2003 X5 3.0 with only about 29K miles on it. Warranty expires in December of 2006.
1) What extended warranty options are there
2) Are they negotiable - What's a good price
3) Do they really cover everything that the factory warranty covers, or am I gonna start getting raked over the dealer coals
After some research I found out that the vehicle's previous owner had gotten some bad body work done. After reporting it to the dealership they invetigated my problem and also had me take my vehicle to there body shop for an estimate. And now they have determind that since they did not see any problems when they CPO the car and they also contacted there BMW rep. and he also agreeded without the Service Manager and the BMW Rep. looking at the car.
So can anyone give me some advise on how to resolve my issue?
Btw
I did contact the Customer Relations and they where no help what so ever.
Thanks. :sick:
I'll repost it there.
Recently (9 months ago) I brought a 2001 CPO X5 and after 9 months I'm starting to have issues regarding paint facking off.
Btw
I did contact the Customer Relations and got no where.
But for the most part I need some ideals on how and who else
can I contact to help me resolve my problem
Door membranes was a good guess but I guess not
I was scrolling thru Edmonds and I found your post. It is very old but I was hoping you could help me with what seems to be the same prob I am having with my 2006 5x. I have had it to the dealer 4 times for a rattle/banging from the tailgate area. They have replaced the motor, lubed and oiled everything, tightened and untightended things and after a day I hear the noise. It is so aggravating after spending so much for the car!...My last car a Jeep Liberty was awesome!..no noise not service checks it was a great little SUV for half the price. I was wondering if your issue was ever remedied and info you could pass along would be great!
Christine<, NJ
I have a 2006 x5 that has a constant rattle/squeak in the rear tailgate. I have had it in the shop 4 times. They have replaced the latch motor, lubed and oiled everything, tightened all bolts and whatever else they could. I am at wits end with this car. Anyone have this issue that could pass along how they fixed it or any tips on what I can do!.....HELP
C
Also very interested in whether you have any opinions on your 3rd row seat - is it roomy enough for your needs? Is there any cargo space left if 3rd seat is upright?
Also, does anyone know when the auto liftgate will be available? Thanks so much!! :shades:
The 2007 model only gained 7.4 inches in overall length from the 2001-2006 models (which had 29 inches existing between the 2nd row seats to the tailgate), so it is basically impossible to fit a full size thrird row with 34 inches of leg room and leave adequate distance behind the third row and the tailgate for safety in rear end collisions.
Addressing the 3rd row option, from the two replies so far i would say those individuals dont own the car. Thier responses are a copy and paste from some review or just a 5 min. observers take. I have a 4 year old and a 1 year old But we also have alot of family close by and many of which are kids. The need for us was 80% use without 3rd row and 20% use with it. With the 2nd row adjusted forward there is enough room in the back. My sister in-law has an explorer with a 3rd row bench seat option and the space difference is non. there is enough space behind the 3rd row to fit basic things but wouldnt suffice for a trip to Costco. Does fit a large size stroller though. No concern what so ever with the 3rd seat being close to the glass because the seats sit very low. This is my biggest complaint at the same time. The seats are positioned much lower then the other seats so my 4 year old and even my niece who is 7 can not see over the seat in front of them.
If your needs are for a full time 3rd row then i would consider something larger.
Personally i love the X5. i have friends with the MDX and family with the explorer and spent months test driving and weekend driving everything out there and for me it is a perfect fit.
Spray each for about 3 minutes then look inside before moving to next area. The hatch gromments will sometimes pop out and this will cause a leak in the left or right rear areas. If its in 2nd row floor then you have a door leaking. Post back on where you find the leak and I will walk you through the repairs
Has anyone run into a similar issue? Any suggestions or ideas?
I love my X5 and am not happy about the thought of giving it up. Just would like to know if this is a fluke or an ongoing problem with the vehicles.
Thanks in advance for any insight. I am at my wits end!!!!
I need a recommendation for an independent BMW mechanic who know X5s.
Thanks in advance
I have a 2005 X5 4.4 with the same problem. There seems to be some issue with transitioning between 1st and second gears after stops. We brought it into the shop three times, they reprogrammed the computer twice and of course it did not help. Has anyone else had this problem and know how to fix it?
I notice this morning that my Nav screen won't turn on. The radio controls seems to work but there is no screen whatsoever. When I turn off the car and restart it, I noticed that there is a quick flash on the screen but that was it. The BMW logo didn't even appear like it usually does.
I have a 2003 X5 4.4 and have never had a problem with the Nav screen before.
Any help or suggestions will be greatly appreciated.
thanks all.
I hope your X5 is still under warranty if they have to replace the nav system. The first step probably will be to update/re-install the nav software to make sure it's not a problem with corrupted software.
Oil levels in new BMW engines are monitored electronically. If the engine has no dipstick, you check the engine oil level using the onboard computer or the iDrive system. They have an "electronic dipstick" that allows you to check oil levels while the engine is running and even while you drive the car. No more stopping the engine and fumbling around hot, dirty, crowded engine compartments.
Look in the index of the owner's manual under "oil" for instructions.
The truth is that you will not learn 100% of the iDrive functions the first time you drive the car, but you should be able to learn 75% of the features after a couple drives. The important features (like stereo controls) that you use every day are easy to learn and most of those features also are controlled by buttons on the dashboard or steering wheel. Beyond that, there will be a few obscure options that you don't need to use on a daily basis and you can look those up when you need them (like the ability to use iDrive to check engine oil levels while driving on the highway, or re-setting your tire pressure monitor).
I've had several vehicles with iDrive since it first debuted. I like it because it provides extremely detailed control over the vehicle's features. It's great for people like me who want to configure the vehicle to my own personal preferences. But it requires some thought. You have to learn something new and there is a bit of a learning curve the first time you use it. Apparently, that's a problem for journalists.
But you don't need special equipment or skills to mount run flats on a wheel. You can replace run flat tires with regular tires (as long as they're the correct spec), so you aren't required to use them forever on a car the has run flats as original equipment.
I looked at Suburbans and Hummers (H1, H2, H3), I own a Land Rover, I looked at Nissan Armada and at the Mercedes GL and ML.
After the iDrive - the other systems were a joke. The Audi was the WORST. It had what seemed to be hundreds of buttons in the center console by the shifter which lit up when pressed and that changes the function of other knobs and dials. I would have crashed looking at that.
The iDrive is like a mouse. You can move it like a joystick, rotate it to go thru lists and then press it in to select. SOooooooo Easy. I agree with the other comment that ONLY THE PRESS seems to not like it.
Get the X5 FOR the iDrive. It's great.
DH
Wondering if the new transmission resolved your issues. What did you need to do in order to have them replace the unit.
Mike
Jay
I can get you at least to removing the door panel. Looks like you have to be real careful with the airbag and the door handle light wires.
http://www.carstereohelp.com/stereoremovalBmwX5FSpkR.htm
Unfortunately it doesn't say how to remove the door handle but that's probably just some bolts or allen bolts after you remove the actuators, cut the moisture barrier (which you must re-tape) and get the air bag out of the way.
Regards
Juliette
