Isuzu Rodeo Maintenance and Repair
The light for the digital clock has gone out... how do I repair?
My guess is that the clock can just be pulled out, but i'm not too sure.
1. Does anyone else's ISC have a button where you can control your suspension? I have never seen a button or knob and was wondering if that sort of thing exists.
2. The problem is that I can't get the shocks from NAPA or any other autoparts store. The only place that has the shocks that fit the Rodeo is the dealership and they cost $140 a piece because they are the "Intelligent Shocks." Are there any other solutions? I don't mind not having smart shocks.
J
Thanks in advance
Thanks guys
thanks!
You might try Autozone, where they do a CEL code readout free of charge. It might be that you now have another problem (like the leaking exhaust manifold on my 1998).
Mechanic seems to think it will "go off on its own", after I drive it for 50 miles or so, but he hasn't researched this problem yet. I will return the car to him, but I am hoping to learn something from someone about whether or not this vehicle requires some sort of routine to "reset" the engine code, so the light will go off.
Anyone know?
Thanks VicG
Thanks, Winston
:mad:
Thank you,
Deanna
Thankyou
SUVs and Smart Shopper
I had the same problem in my 94 Rodeo a few years ago. It was a mechanical problem. There is a little gear inside the speedometer, which was worn out and had to be replaced. Best, stan_il
