Now this past week i barely have any you can feel it there, but just no where near as warm as should be or was. Now I have had talked to about 10 different mechanics including my dad who has worked on Chevy's for 40 yrs. They all seem to be lost. Seems to be blowing both cold and luke warm air. We have changed the thermostat. The fluids are full the radiator is full. The hises that go into the heater core are warm to touch, but i was told you should not be able to sit there and hold them and you can.
Please Help!!! :P
Hello Blazer owners I am a new Blazer owner just bought my first 4 months ago. Got a 2000 Chevy Blazer ( my dream vehicle).I have always wanted one. Well I am having troubles and no one seems to know what could be causing it. I have no heat. and with living in PA with temps lately in the 20's everyday it gets pretty chilly without a heater. It is odd had heat till Thanksgiving day, went out and started the truck and just didn't seem to warm up. I thought might be due to that it was only 11 degrees out, the next week had heat back but it was warmer too.
Please Help!!!
Chevy Blazer/GMC Jimmy: Problems & Solutions
1: Record your Radio security code or set it to "0000"
2: Check the switches in the Dash to make sure they are not defective.
3: Disconnect the battery for 3 minutes and try to engage the 4WD. CAUTION--SEE STEP 1
If at this point you still have no 4WD the it is most likely the Transfer Case Controller (Located in the Dash or Right Kick Pad)or the Transfer Case Encoder Motor (located in the Transfer Case).
I okayed the repairs and after I got vehicle back then GM said they decided to pay only 40% of agreed cost "because of the mileage on the vehicle(?)".
For a vehicle that was babied since day one that I owned since brand new, I thought it ridiculous that trans would fail with less than 60 thousand miles on unit.
For GM to offer to only pay 50% was an insult and then to screw me again by changing refund amount was final straw.
I highly doubt GM will ever have any of my future business if this is how they treat a customer who had chevies since 1974.
Lots of others want car buyers business and I will hope they treat long time customers with a lot more respect. Goodby GM
Thanks for any help.
ED
