Just bought a brand new 2008 CRV EXL with Navigation.
I like the car, but feel a bit frustrated to not have the Bluetooth capability or IPOD integration...
How are you guys doing this?
I read above a mention to "ADVANCE" model but never heard of it.
Any help will be greatly appreciated.
:shades:
Probably won't happen until new dual capable receivers hit the market. Although both are sattelite radios, they are not 100% compatible. The signal and encoding is different.
How can I get tho codes?
juan.
Fort lauderdale.
On some radios if you press 1 and 6 while powering up, or something like that, it will read out the serial number.
If not, then take out the radio. The serial number is on the back of the radio.
It is a good idea to enter your radio code in your Honda Ownerslink profile, along with the key code.
But I found a thread w/ advice and got the code I needed by calling Honda corporate. Here's the story:
http://www.honda-tech.com/zerothread?id=1370390&uid=999509572&postid=25320040#25- 320040
Until your street is located, put in the address of the home/business located just outside the entrance to your subdivision as your home address. I usually find I can make it home once I get to the entrance.
Gregg
I mentioned this to a AAA auto center (I was there for fixing the window glass- which was another unexpected thing that the glass on driver side window just slid and fell inside the door frame- cost me $750 to fix that). The guy said he'll charge $90 just for checking the CD player.
I'll appreciate any advice. Thanks in advance.
Raj
Then there's the "blue spark" technique described in the How to Remove a Stuck CD Guide, but that one seems pretty risky.
Crazy, isn't it? I've never owned a car that had a problem with a CD player. Fortunately, I've got over 45,000 miles on my CRV and that's the only thing that has ever gone wrong. I still love my car.
However, assuming it can't be done for whatever reason (I'm not tossing this and buying an Acura) are there other nav systems with bluetooth that can be installed (ie replace my current system)? (Not being frivolous....I cannot use an ear piece).
My husband's Lexus has a completely integrated gps and bluetooth system....that is what I would like. Is there such a thing to replace what I have currently in my car.
Kim
Amazon has them for under $400. You will need a PAC SW-SI controller to integrate the steering wheel buttons, and XM/Sirius/HD radio receivers and iPOD cable.
Everything is on the touch screen, and it runs on Windows CE, which makes it hackable.
From reading the manual, it seems to say that random is for playing songs from within 1 CD, not all 6. Is this true?
Barry
We just leased a 2010 CR-V, LX 2WD model. We can tune in local stations, but there is a lot of static in the reception. Anyone else having this problem?
Has anyone else had this problem? My old car had 100k miles and I need a good reliable car with AWD and bluetooth. I am so disappointed and don't know what I can do. It seems to me that the CRV car sounds are too loud for good bluetooth projection and/or they put the bluetooth in the wrong place to at least prevent this.
Let me know. Thanks. .
I'm planning on test driving one tomorrow and will make sure to place a couple of calls while on the highway test drive to friends/family who can give me a review of how I sound using the car system. Not sure if that one test can really replicate real life situations, but at least something I'll definitely test. The concern obviously is that even if it is OK in the test vehicle, from the problems reported above the car I actually get might still be afflicted with this issue. Its got me thinking!
