Ford F-Series Fuel Pump/Fuel System
I have a 1990 ford f150 6cyl in which i have changed the fuel filter, both fuel pumps(have duel tanks), and i am still having a fuel pumping problem. The pumps pump for a long time before shutting off. The truck will not start until they shut off. Have checked the fuel lines fuel is pumping throught the fuel filter and also into the injectors and fuel is also returning back to its proper tank. Any ideas on what to replace now?
I'd read many times that the problem is hardly ever in the engine control computer, so I kept looking elsewhere. I finally got to the point that it could possibly be the computer.
I took the computer out, opened the covers and found some burnt and disconnected leads on 2 of the components -- two capacitors actually. I bought another box from O'Reilly's, plugged it in and it started right up.
Hope I helped. Let me know
can you help?
stan58
steve
Gas engines have one pump. In the fuel tank.
steve
I don't think wiring would keep pump from holding pressure, would look at fuel lines for leaks first.
again just a guess, Good luck
won't run unless you feather the gas pedal. I changed the fuel pump and gas filter. It has
30 pounds of fuel pressure when cranking the engine. My question is, why won't the
engine start and stay running. Fuel regulator vacuum hose is dry. (it's not leaking).
Please reply. Thanks for the help
golflover629@comcast.net
The symptoms you described and the things I listed describes how my truck acted. Talking to people and reading up on it pointed me to not consider the ECM box -- that the ECM box hardly ever goes bad, but, after running into many deadends I eventually got a rebuilt ECM from O'Reilly's and it has been running like a top -- again.
Not saying that is what you are dealing with -- just want you to keep your mind open to that possibility. God luck.
Depending where the line broke depends how to do the fix. Autozone sells a mending kit for those lines that come with the new quick connect ect. If the line is damged or leaking, the easier fix would be to repair that section. If it is a return line, you can also bypass the first tank all together with a sutible size tee, rubber fuel line and clamps. If you choose to do the bypass, just make sure your splicing into the same type of fuel line on the other tank..,return or outlet. If you specify where exactly the line broke, or if it is the tank fitting itself, and more info on the type of vehicle and fuel system, such as does it have a selector valve ect. Any way hope this helped, good luck.
Thanks Stan 58
HAPPY NEW YEAR
Here is the trick. Drain the tank of fuel. Use motor cycle straps to secure the tank in place while you remove the two tank straps completely. Motor cycle straps almost work like a pully so you can lower the tank down slowly to undo fuel lines ect without breaking them. Good luck with it.
f150 - trying to replace the rear gas tank. But I don't know how to disconnect those fuel lines. there is a clip on the lines themselves right in front of the gas tank and I have removed, does the lines then just pull apart?
Thanks in advance
HD82
PS, if you waited for the message to come on, you waited 2 long. You should check your water seperator monthly at least.
Mark.
Rickster
Rickster
thanks again
rickster
Rickster
The check engine light is not on and we have already changed the filter.
Thanks for any advice.
