Farout
With the re-flash - when do you shift into 4th ?
and did you notice better MPG?
vacrd
Farout
Farout
Farout
Thank You,
Megano1
Do you mean to say that you could drive 800 miles between fuel tank fill ups? Cool!
I went through my 25000 oil change on schedule B without the yellow light coming on, a new milestone since this is the sixth EGR valve the Liberty has had. The last EGR change out included a new throttle plate.
I made the 1000 trip on new Goodyear Wrangler Silent Armor tires, and I noted no appreciable difference in fuel economy. Gosh darn, it didn't snow in the Cleveland area, and I wanted to try these tires out. By the way that was the weekend St. Louis was shut down for snow.
Then, I wake up from my dreaming and I face the real world of 22 to 26 mpg! There is no way on this green earth you got 42 mpg!!!! Maybe someone should show you how th figuar MPG!!! Can't fool us here!!!!!
Farout
There is NO WAY your 2.8 L CRD weighing 4,300 lbs did 42 MPG!!!!!! Perhaps you just don't understand that you can not archive 42 mpg any more that the 3.7 Liberty can get 32mpg, as one person so tried to convince a forum here some time ago. If you claim to really have gotten 42 mpg, then you made a record that has NEVER been achieved before! Notify DCX I am sure if what you say is true, they would buy your vehicle, to find what you did to get to an emissions Tier that would meet 2010 standards! In fact I will challenge you to prove your remarkable story! Post the name of the dealer and I will personally call the dealer and if they say you have achieved even 35mpg I will write you a forum apology and ask for your forgiveness!
SO PUT YOUR DEALERS NAME ON HERE OR BACK AWAY! I for one do not believe you, and perhaps there are others as well!
You have been on this Liberty Diesel for 4 days and come here telling a whale of a tale and expect some of us to believe you? Why don't you just apologize for telling a wooper, and just be like the rest of us. We all wish we got 42 mpg, but it just don't happen in one of these Liberty CRD's! Heck that's like saying a 18 wheeler got 20 mpg, and that too just is not happening either. So either do as you asked me to do or state the dealer! For someone who has been here 4 days you have no business asking anyone here to "shut your mouth" we don't generally treat one another like that. Me thinks you opened your mouth too wide, and put your foot in it!!!!!!!!
Farout
Megano1, the valve stopped moving in the closed position and error codes indicated reduced EGR flow. It was replaced under warrantee like so many others on the forum. I didn't do a very good job of getting detailed information for the forum as to why it failed. It was a quick in and out repair.
Just keep in mind that if something sounds too good to be true then it probably isn't, but we don't have to shout about it!
I'm not wanting to argue about my fuel mileage, my concern is why can't I even achieve the mileage that my window sticker says?
P.S. Get your calculater out.
The problem is not the Jeep, it's the BTU contents of the fuel we have to buy.
I really thank youand the other HOST's for changing the forum back for us stubborn hard heads. Beside that I am from Missouri and to some that is a handicap.
TO ONE AND ALL MERRY CHRISTMAS!
Yes, I think most would agree. My only issue is that the tone should be civil and nonconfrontational.
We have more than 20,000 miles on our 2005 Liberty. I drive 70-75 mph on interstates. We've made several long trips lately -- two adults with luggage -- and tend to stay in the 28-29 mpg range. The longer the trip, the better the mileage. Conversely, running around town drops us into the 18 mpg range. In between is, well, in between.
The best mileage we've seen was 32 over a 700-mile stretch of I-5 ... and that was on B99 Biodiesel, which is supposed to cost a roughly 5% mileage loss. I regularly run B99 and the Jeep loves it.
Temperatures drop into the low 20's where we live, but still the Jeep starts right up. Perhaps the secret is that we're not running homemade crap filled with chunks of yesterday's greasy diner leavings.
We buy from Seattle BioDiesel, a reputable manufacturer. Based on our experience, they make good stuff. I've taken to hauling 5-gallon plastic containers on trips, so I have some BioD to mix in with the Dino. Even using the cheap Wally Mart gas cans, BioD does stink. And no, it's not dangerous, as hauling gasoline would be. After all, it's mostly canola oil.
I'm a sports car guy, not a fuel mileage nut, so didn't even think to pump up our tires a bit until reading this forum today. We're still running the 31-32 psi that the dealer puts in when we drop over there.
Pumping up the tires and sticking to a 50-55 mph speed may well put the Liberty into a much higher fuel mileage range. Maybe we ought to ask more questions before we jump on a fellow Jeepster about his mileage claims.
Farout
The only way you can tell my Jeep runs on B99 are:
1. Exhaust smells different, though not like any french fries you'd want to eat (vague vegetable oil smell);
2. The engine is quieter because BioD has better lubricity than dino; and
3. There's no exhaust cloud when you accelerate.
I do not have an exhaust cloud when we accelerate, and starting on these cold below 15 F with no cloud either, just a typical heat cloud which is very little.
farout
When I picked up my new Liberty from the dealer, the tires had about 15-20 psi.
Remember Ronald Regan who, when dealing with the Soviets, said that we should trust them to do what they say they will do, but we will verify that they have done it.
In that same vein, I would check the torque of the lug nuts on the wheels also.
I just had the above recall done and am wondering if anyone knows just how much torque they took away when they reprogrammed the ECM. I tow a trailer that is 4500# and don't want to feel like I'm driving a Chevette. I can't tow the trailer now as it is snowed in.
I was really stunned as around town I did not think there was any difference. I am not going to be amazed if DCX has to re-flash these computers because I think there will be sore complaints for sure.
Farout
I read your forum to discover the CRD has EGR issues and now thanks to the Feds, has been discontinued. The vehicle I am considering has 15 K on the odometer.
Would it be a hopeless dream to expect 32 MPG on the hiway if driven reasonably? (My Subaru does that) What about parts availability and overall reliability/durability of this vehicle.
I am well familiar with diesels having owned several including a Golf TDI which regularly got me 52 MPG.
How would you rate the tranny and it's life expectancy? I hate automatics but thats all I can find in a CRD.
Hope to hear from you soon. stubak911@aol.com
Comfort of a long trip cannot be predicted. I recently drove 800 miles in one day. It was raining heavily in the morning, heavy traffic in the Paris area, some slippery roads and a fairly long stretch at 80 mph with cruise control. Our CRD beats most sedans because of it's passenger room and regularity of the engine. A steady 2600 rpm and good company erases fatigue when driving this jewel.
Hi Stubak,
This is what I have from 19 months of data:
Average summer mileage is 24.9 mpg
Average winter mileage is 23.5 mpg
Average highway driving (23% of tot over 27 mpg) is 29.5 mpg
Average village driving (23% of tot under 22 mpg) is 20.4 mpg
Average Mixed driving (54% between 22 and 27 mpg) is 24.2 mpg
Overall average is 24.3
Highest is 32.8 mpg
Lowest is 17.9 mpg
Highway driving is mostly 65 mph on cruise with some 55 mph
It is difficult to break out all highway from all village, but I think this does a pretty good job. I drive very easy so it looks like it would it be a hopeless dream to expect a consistent 32 mpg on the highway. You will get that once in a while, but not all the time. I have a friend who put 265,000 miles on an 80-something Subaru (spelled backwards U-R-A-Bus, old joke that applied to that car but not yours) with very few problems. Rust finally got it. Something to think about before you dump your Subaru.
farout
Farout
Time to accessorize. First up....the tires seem a little wimpy. they almost don't seem big enough. What do you recommend? Currently BB has 225x75x16. Something a bit wider that won't kill fuel economy and will do well all year round but especially good in snow.
Farout
Are you prepared for $90. oil changes, $120. fuel filter changes, $280. differentials changes every 12,000 miles. This CRD is not a cheap vehicle to keep repaired by schedule B, and NO one can ever qualify for schedule A. As time goes on after the warranty parts are high and labor is a big item. Read the Liberty Diesel forum and go back a year or so. There are a good number of past CRD owners that have gone with the Lemon Law or just traded them off at a huge loss.
I traded a 2005 Liberty Limited in on this CRD Sport, I was so stupid to think the better fuel mileage would be a good trade off. Like I said it was a dumb idea, and the repairs and cost of up keep has been way out of line. The warranty repair has been out of reason even DCX agrees with this. Caution is the word I give you. Ask the service manager to go over what are the service requirements on this vehicle.... before you sign any papers! I hope this helps, and you go into this with your eyes wide open.
Farout
Our CRD has 30,200 miles and is an 05 June 14 build date. You can call and Dodge, Chrysler or Jeep dealer and they can answer all these questions. You might have a EGR valve out, or a turbo. You should have had the 2 differentials fluid changed and a new oil change with Mobil 1 0-40w or 5-40w in the vehicle. I might even suggest that the fuel/water filter should be something that might have been changed. Who had the CRD before you and why did they trade it? We get from 18 to 24.6 mpg just depending. Your CRD should shift into 5th lock up at 55mph. If not there is one reason for not real good fuel mileage. Do NOT use Bio Fuel more than B-5, as it waxes up the engine, and it will void the warranty.
Now the bad news. Our CRD has 30,000 and has been in the shop 25 times in 16 months. Good dealer service is very hard to find. If you did not get an extended warranty DO IT ASAP! These CRD's do have more than normal repair histories. Only 11,000 of these CRD's were made, 8,600 in 05 the rest in 06. Every time you go in for ANY problem call the Customer Care line at 800 992 1997. They will keep a record of your problems is you have any. Should you get a problem vehicle it could mean a way to resolve any problems later. Chrysler is in the process of buying our CRD now and should be complete in two weeks, we hope. We liked the CRD Liberty but they just could not fix some problems that we got worn out with.
You should move over to the Diesel Liberty forum, that's where most of the CRD owners post. Good luck, and I hope you got a good one. Oil changes are about $90. and fuel/water filters are $ 150. if you can do some of the work yourself it will save you $.
Farout
