Are you currently in the market shopping for a new vehicle? A reporter would like to speak with you; please reach out to [email protected] by 10/21 for more details.
Jeep Liberty Real World MPG
steverstever Guest Posts: 52,457
edited September 2014 in Jeep
This discussion is for reporting on your Liberty's gas mileage. Please mention your odometer reading and your driving style, city/highway mix or anything else that will help others compare their mileage to yours.
If you have the diesel flavor, check out the Jeep Liberty Diesel: MPG - Real World Numbers discussion.
«1
  • benibikerbenibiker Member Posts: 9
    In response to some of the discussion regarding MPG. I own a 2002 Liberty Limited with the 3.7 and I get 22 MPG in mixed driving and I get 27 MPG in the highway. The only thing special I do to my Jeep is use Mobil 1 synthetic motor oil. I have a limited slip rear end so I never loose traction as some have posted. I just heard about the lower ball joint recall and realized I missed the lower ball joint recall back in 2003. Guess I should have that fixed. I haven't had any problems what so ever with my Liberty, I love it!
  • faroutfarout Member Posts: 1,609
    beniker: Please excuse my bluntness, and you might even say rudeness. Having lived a good length of time, life teaches a lot of things. One thing I am able to spot is a mistake or a miscalculation. I am very positive you have made an error. There is no way you could achieve you gas mileage you claim with a 3.7 V-6 with a 4 speed automatic transmission.
    I am sure it's fun to joke with people. I could say my CRD liberty gets 37 mpg too, but everyone knows that's not true. Just as we all know what you have said is a joke as well. And you caught someone who bit into your hook.
    Farout
  • jayriderjayrider Member Posts: 3,602
    On my 03 Liberty I average 15-16mpg strictly in town with some stretches of 2-3 miles of 45 mph cruising a few miles between stops. If I add about 50% interstate it moves to 18 mpg---rarely any higher. Straight interstate at 60-65 mph I can average 22-23 mpg if conditions are favorable. With a headwind or rain-- it drops to 20 mpg. There have been trips where I have a bit of a tailwind and keep it at 55 mph where I can get to 24 mpg for a stretch but that's the best I've done in three years. It can help a bit if you can fuel up with
    %100 gasoline and avoid the ethanol blends but that's about all we have around here.
    3.7 with automatic is what I have. I don't usually put much effort into driving with super efficiency but if you are really careful, you might be able to do a bit better.
  • theronrohrtheronrohr Member Posts: 51
    Well at least there's a little life over here so I'll repost my message from the main board... (Cleverly rephrasing it so it sounds like a question about gas mileage :) )
    I was wondering if anyone can comment on the 6 speed manual version of the Liberty? Such as what kind of mileage do you get?
    Also was wondering about how it shifts, whether the clutch engagement is touchy or progressive and what rpms are normal for highway cruising?
    Don't have a stick but I do have a story to relate in this regard. I was in the market for a cheap ride in 1992 and ended up deciding on a plymouth / dodge sundance stick with air. The deal seemed pretty good back then so I went to two large dealers and drove six cars identically equipped. I did that because I wanted a car that shifted, idled and accelerated smoothly right away. Even though these cars were identical, my test drive efforts were worth it. The cars with the most attractive colors unfortunately were poor drivers--hesitation-vague shift points etc. I would have chosen poorly. The dealer said that once I bought it they would correct all concerns. I didn't have to get involved in that fiasco because one car stood out. It was bright red -- not my first choice but it drove and shifted way better than the rest so I bought it. Kept it nine years and 114 k miles and only had issues with the a/c the last 3 years.
    My advice--- go drive at least two or three Liberty stick shifts and see what you think. Previous posts don't seem to indicate a great deal of mpg improvement vs automatic -- you save bucks when you buy but lose big when you sell.If mpg is a big consideration in your choice of cars, the Liberty won't make you happy. It is what it is -- a heavy little truck that I find a lot of fun to drive. The other problem is that you have to settle for part time 4wd with the stick which limits its usage to extreme conditions like off road and very poor traction surfaces. I like the full time option a lot.
    Go take a few test drives and let me know what you think. The most important opinion on this issue is yours. Have fun!
  • libbmannlibbmann Member Posts: 10
    I have an '05 Liberty Limited running synthetic oil, a K & N air filter, and Goodyear Fortera tires. I'm an easy driver. I bought it in May of '05. It now has a little over 26,000 miles on it. In that time it has averaged overall 18.4 MPG at an average 41 MPH according to the elapsed time. I drive predominately hiway with some city driving. My guess is that it gets around 15 or so around town and strictly on the hiway between 60 - 65 MPH it will get 23 - 24 MPG. If I get up to 70 it will drop to 20 MPG. If there is a headwind, side wind, rain or cold weather it will lower the fuel economy accordingly. I can't say that I'm disappointed with the fuel economy because I knew what I was getting. I have 4 wheel drives since the 70's and for its weight the Liberty does well. I would much rather drive it than an econobox.
    libbman: I am pretty sure you are judging what you fuel miles per gallon is by what the electronic readout says in the overhead information center says. Having had a Limited I can assure you this readout is very far off. The only real way to know what your mpg is requires you to do it the old way. Fill the tank up as much as will go in. at the next time to put fuel in fill it up all the way. Now form the current mileage subrtact what the mileage was when you filled it us the time before. Now devide the gallons into the miles drivem. That is the true miles per gallon. Our 2005 Limited Liberty got a pretty consistant 15 to 16.5 mpg. The very best was 18mpg. There is just a very slight chance with a good wind pushing you, than 24 mpg could be reached. The 3.7 with the rear end they come with just won't get 24 mpg if even that. Now our Liberty CRD gets 26.4 mpg and that's doing 73 mph with the air on.
    Farout
    Actually I did figure it out manually. I had 26,076 miles on the odometer and I put in a total of 1418.817 gallons since I bought my '05. That figures out to 18.378 MPG. I keep records on a monthly basis. I have checked my overhead and it comes out approximately .1 to .3 off per tank and that could depend if I try to get that last drop in or not. I have had 4 Jeeps with overheads and this one is the closest to acurate. My odometer does read a little slow, about 1 MPH slow and that is measured against my GPS.
    libbman: I can honestly see 18.4 miles to a gallon, but how anyone gets 24 out of a 3.7 is amazing! I know that some people can milk a 6,000 lb Caddy and get 20 mpg, but I sure don't know how it's done. It could be just right temp. conditions, and everything is just right, then it comes up perfect mpg.
    Farout
  • caribou1caribou1 Member Posts: 1,354
    These values were taken when refueling using the trip mileage counter and are already averaged per type of driving condition:
    - 4WD at 7500ft altitude 18L%KM ~~13 USmpg (this one is less accurate)
    - heavy rain/snow 12.5L%KM ==19 USmpg
    - local city traffic 11.3L%KM ==21 USmpg
    - interstate 80mph 10.23L%KM ==23 USmpg
    - mixed / commuting 10L%KM ==23.5 USmpg
    - interstate 70mph 9.46L%KM ==25 USmpg
    My "global" average mileage is now 22.5 USmpg after 3 years and 52,000 miles. This comes to almost 12,500 USD worth of diesel fuel over here :sick:
  • tusitalatusitala Member Posts: 2
    I've driven the same '02 Liberty Sport 4x4 w/ 3.7L engine (not mine - a family member's) on two long-distance trips. The first was a one-way from North Carolina to Maine in October '04, almost all on multi-lane interestates, typically driving with the CC set at 5-10 over the limit. My average MPG (computed the old-fashioned way) was 22.8. This past July I took a round-trip from Maine to upstate New York, about 2/3 on interstates, but a good chunk on rural state roads and some in town, 5-10 over again whenever possible. Average MPG for that trip was 19.9.
    It ain't great, but it's better than the miserable mileage my on-its-last-legs '95 Trooper is getting - 16 MPG on mostly highways if I'm lucky!
  • mmontgomerymmontgomery Member Posts: 5
    Greetings all. Just purchased a 2003 Liberty Sport 4wd with the auto transmission. Here's my question - would anyone recommend any simple fixes or upgrades that get a decent payback with fuel economy. I've seen some refer to K&N air filters, figure the obvious stuff like putting air in tires is always good. Any suggestions on things you've done that worked out good?
    mmontgomery:How many miles does your Liberty have on it? Are you sure that the place you bought i from did a spark plug change, and air and oil filter change as well? What kind of mpg are you getting?
    These things I mentioned are very basic to good mpg. However if the things above have been done, here a few things to bring out better mpg on any vehicle. Go to Synthetic 5-30w oil. Make sure the tire pressure is 33 to 36psi. Use the Cruze control as much as possible. Avoid jack rabbit starts. Don't use the defroster any longer than you have to, this uses the air conditioner to take the moisture out of the air, using fuel like in the summer. Don't let the engine warm up for long periods of time. Run some injector cleaner in your gas tank to glean out injectors and valve body. If spark plugs were changed recently, pull one out and make sure its a Champion, and gaped at the right measurement. Look under the Liberty and make sure the gas line does not have a leak of any kind. You can even make sure the transfer case lubercant has been replaced and is clean and full, the same goes for the axles as well.
    My experience is when someone is trying to sell a used vehicle they make the inside and outside detailed real nice, but the upkeep items they do fool with. You can't see those items, and that's where money gets spent rather rapidly, but it's more important than making the outside and inside look brand new.
    If you did everything I said the mpg that you will gain proberly won't be what you are wanting to achieve. In tip top shape expect 15 to 16mpg and on the road 17 to 19mpg
    Farout
    Right on Farout, but you forgot to suggest only driving to destinations that are downhill and downwind from your starting point.
    Actually, I filled up tonight for the first time, clocked just over 16mpg for a mix of local and over road driving. So I checked the air filter, and surprise! - filthy. Carmax says they do a multipoint service / inspection, this is something a bit obvious to have overlooked. Checked tire air, and the other stuff, and it looks fine. Will wait to see what impact a new air filter and routine driving has on me.
    Thx!
    Mike
    jayrider: I just always assume those things are present. Remember the test of a real Jeep driver is to brag about how many miles you get to a gallon. Always make your mpg at least 2mpg more than the other guy.
    Farout
    mmontgomery: In my 46 years of driving I have not seen fuel mileage go up very much by just changing the air filter. Yes, maybe 1/2 mpg or less, but not a big amount.
    Let me show just what the difference in mpg makes. Say you are getting 16mpg. You want 19mpg, that might make you feel much better about mpg your Liberty, right? Well the truth is there is only .03 per gallon difference between 16mpg and 19mpg or .60 cents a 20 gallon tank full. But there is more to economy than just .03 cents a gallon. We got our 06 Liberty Sport for $3350. less than we could have bought a Compass equipped as close to the Liberty as possible.
    The Compass 2.4 CVT II gets maybe 24 mpg. the Liberty 17mpg. At $.035 divided into $3350. = 95,714 miles before you would notice any savings in fuel compared with the Compass with the 3.7 V-6 Liberty. So just fuel mpg is not the big answer for cost per mile of driving.
    Just drive like this Jeep has to last you for 10 years, and you will be far a head.
    Farout
    Farout -- agree with your calcs. Filled up second time (first time after my first complete fill) and saw mileage improve by 1.5mpg -- makes me think they don't exactly top off the tank totally. Did get Carmax to change the filter, although that was half way through the tank -- doubtful that was it.
    I do think I'd much rather have the Liberty than the Compass, though. Nicer handling, feels far more solid. The commute isn't all that bad for me, most of it is freeway and the car it's replacing - a 98 ford ranger - got about the same mileage.
    Thanks for all the comments, guys!
    Yeah-yeah Farout, but just think of the bragging rights you would have accrued after those 95,714 miles passed beneath the Compasses' leaking oil pan. Not to mention the lifestyle changes brought about by the new found riches accumulating every time you fill'er up.
    We all have seen these down right lies about what great gas mileage the Liberty gets in the News Paper adds especially in the Sunday paper. I saw a Ford dealer add for a used 2004 Liberty for a 3.7 gas, saying "Great on gas 30 mpg!" The same dealer had an add saying the Escape had a V-8. Must be a new sales person?
    Farout
    Actually, the Liberty would get 30mpg if it were being towed by the V8 Escape.
    I have one of each, and they get about the same real world mileage -- the Liberty has more of a truck feel to it but has more oomph in the engine compartment, but the Escape drives a bit nicer on longer trips.
    All I can say is that's what my trip computer tells me and I verify it by dividing the number of miles I drive with the gallons I use to fill up my Jeep. You say impossible... Nothing's impossible... Maybe my Liberty's exhaust, intake manifold, valves, etc. just came together just right. Maybe the fact I live in Honolulu? I'm just telling you what I get... :shades:
  • cybdivercybdiver Member Posts: 1
    I have an 02 and stopped looking at the mpg. If you have a jeep then you can't care about MPG. They are notorious.
    A V6 3.7 is a hefty engine don't expect to get toyota miles.
    You bought a Jeep to go rough, did you think you could go cheap too? Want Miles get a Rav4 just stay off the trails you will block them when that thing gets stuck.
    Having a Jeep is a auto love thing. You tell someone you have a Jeep then move on. They don't get it. They don't understand but they respect you. A Jeep is Respect.
    There are Rolls, Mercedes, Porsche, and there are Jeeps.
    Even a Hummer does not get the respect a Jeep does.
    It says something about the owner. You are a free spirit, able to go over obstacles.
    As the legend goes--
    It's a Jeep thing, you wouldn't Understand.!
  • glhperformanceglhperformance Member Posts: 24
    I have the 6 speed I average 20mpg I have seen 23 and as low as 18 using 4wd in the dead of winter.
    It seems you're not gaining anything with the manual shifter. Are you happy with it? How easy is the clutch in heavy traffic after a day's work or a long walk in the forest?
    Between 18 and 23 mpg with an average of 20 sounds pretty good compared to most other postings i've read. Usually people with the automatic are getting more like 15 average. I suppose it depends on where you drive too.
    How is the manual to drive? I would guess since its a big engine it should be easy to shift but maybe a little slow to engage. (compared with the small cars i've driven with manuals.)
  • ecramanecraman Member Posts: 25
    Our 2002 Liberty Sport will do about 13 around town and at best 21 on the highway. 2005 CRD does 26 all of the time but that is mostly highway.
  • bobkeenerbobkeener Member Posts: 2
    My big problem with my Liberty is she is a piggie, 12 mpg city and 14 mpg highway. I have never owned another car I did not get in the EPA rating for gas mileage. My 94 Jetta got even better than the EPA rating.
    I am naming her Miss Piggy.
    Anyone else disappoint with the economy of the Liberty? Is it just mine or do they all do this bad?
    you must have a problem because most everyone is reporting the low 20's cruising on the highway at 60 mph.
  • stingray66stingray66 Member Posts: 7
    Bought this vehicle new for my wife. After review of all contenders in this class, she settled on the Limited model, hoping to receive respectable mileage. This is our 4th Jeep, we know we sacrifice a little but this "vehicle" gets absolute miserable mileage. We now have 5,000 + miles and I have tracked every tank from the 1st 200 miles. Best ever achieved is 18.4 on a 300 mile all highway trip. Generally see 14-16 on the highway with mileage around town at 10 mpg (really) or less. After 1st 3,000 miles, switched to Mobil 1. No dramatic gain except an excellent oil. 2 different dealers have said nothing they can do except drive it and get some miles on it, it will improve with break-in. 5,000 miles and no improvement. Very disappointed and thinking of getting rid of this "lousy" vehicle. Our 2000 Gr. Cherokee 4.7 L gets better. My Suburban got better. Jeep is not wanting to do anything and have turned a deaf ear to the issue. Anyone have any suggestions to help improve the mileage?? If it weren't for the "crappy" mileage, we could probably learn to like the car, but this is a major irritant. :mad:
    I know the mpg computer is not extremely accurate but what does your read out to when you cruise at 60 and reset the console? Mine is always around 20-22 mpg but changes with wind and terrain. Around town maybe 15. You should make sure that you have the computer chip reprogamming procedure if you have a Liberty that is affected. Unless you get almost what you paid for it, you will never recover in depreciation what you lose in gas mileage swapping vehicles. For 10000 miles the difference between averaging 20mpg [impossible] and 15mpg at $2.75 a gallon is $258. You can adjust it anyway you want but mpg is rarely a sound reason for switching vehicles. If you like the Liberty, enjoy the ride and forget about the mpg. If not, swap it for something that does better and smile when you fill up but don't figure out what that switch really cost you.
    Jayrider,
    Appreciate the comments and I agree to the huge loss in trading vehicles. It is more the issue that this small, but heavy, vehicle is so "thirsty" and the big machine, Jeep / Daimler-Chrysler, is unwilling to even offer any "words of wisdom". The typical "party line responses" get old. What iss the "computer chip reprogamming procedure" you mention? Is that a recall item and what years or Vin/s/n range vehicles were affected? Is this something that may improve the mileage?
    Thanks - Stingray
    You might check for posts re the chip re-program or ask your dealer. I have an 03 and it doesn't effect me but I have read posts here that refer to it. Good luck.
    I went and looked at the Jeep website and there is shows the sport (either manual or automatic interestingly) as having a gear ratio of 3.55. The limited comes with a 3.73 ratio. So that should make the limiteds appear faster and less fuel efficent. I would have expected the automatics to all have the 3.73 but in any case if you were to replace the final drive gear (not too expensive to do since its in the rear pumpkin right?) to a yet higher ratio it should help mileage I would guess.
    Appreciate the opinion and tend to agree with the ratio theory. Down side to this is the frt. and rr. ring&pinion would need to be exchanged to maintain proper drive line balance. This becomes more complicated and expensive. Drive line wond-up, just like with different diameter tires, can be quite a problem.
    I do feel Jeep "screwed up" putting a 3.73 ratio in. A 3.48 or 3.55 would have been more appropriate. With this engine, they are too high in the Hp curve, compromising fuel economy. Naturally they will never admit to this, just like they ignore the whole issue with low mileage problem. I've talked with several other owners who have the same complaint.
  • yeloroseyelorose Member Posts: 5
    I'm so happy, I had to tell someone! I have an 05 Liberty Renegade 4WD. Usually I get about 17 mpg in mixed driving (60fwy/40city). One tank was only 16.5, so I really babied it this week, using every driving trick I knew and got the mileage on my last tank up to 20.90 mpg. This is the absolute best mileage I've ever gotten. Now if I can get used to everyone blasting by me on the freeways and side roads, maybe I can do it again! ;)
    Heh, heh, congratulations! But its pretty sad that you have to work that hard to get 20 mpg. Did you try overinflating your tires? That's been the most effective thing for my Mustang on long trips. I'm interested in the Liberty's cousin the Dodge Nitro. Its supposed to be rated a little better on gas but I'm not sure why.
  • redlemonredlemon Member Posts: 4
    I have a 2006 diesel and I’m only getting 22mpg if I drive it right. Is there something wrong with my jeep liberty crd 4x4. After 19K it isn’t getting better. Friend of mine regularly gets 25mpg on his 2005. It is expected to get 22-26.I do my calculations myself. Thanks
    :confuse: ">
  • bmartinpebmartinpe Member Posts: 51
    Ask your friend if he fills his tank with imperial gallons instead of American gallons. 20 miles per American gallon would equal 25 miles per imperial gallon. (Because the imperial gallon is bigger.)
  • synlubessynlubes Member Posts: 184
    i get about eighteen miles per gallon to twenty in town and about twenty three to four on the road dont pay attention to the readout display it will be off about two to four miles
  • clintondeeclintondee Member Posts: 8
    I was worried about buying the Liberty instead of the Patroit because of gas mileage issues. I figured the Liberty would get around 18mpg and the Patriot around 24. I steered my wife towards the Patriot but she would have no part of it. She wanted a "real truck" and once she drove the Liberty it was all over. The liberty does have the ability to go through much deeper snow the the Patriot and is a real truck. After filling up with 360 miles on the odometer I figured out that we got 21 mpg on our first tank of gas. It stayed at 21 mpg for the second tank now also. This is a mix of 50/50 city / highway driving not exceeding 65 mph or 2000 rpm's to often. The transmission is great and offers a lockup gear so you can let off the gas pedal a bit and watch the rpm's drop a few hundred to 1600 and still be going 60 mph. I think thats the trick to getting good mpg out of the Liberties. At 21mpg I'm glad we went with the Liberty instead of the Patriot and before it switches over to the Nitro style. :D
  • dgaylorddgaylord Member Posts: 1
    have 04 3.7 auto 87k miles if i drive 70 according to my gps i get 18 mpg manual calculations and filling up till gas can't put any more in. if i drive 55 and around 1600 to 1700 rpm with cruise 1 get almost 23 mpg which comes to almost 12 to 15 dollar saving on a tank of gas didn't take to much convencing and thinking about installing a air cell throttle body won't be much but anything helps maybe headers and new exhaust any test results from anyone i would appreciate. would a chip help?
  • mwolf9000mwolf9000 Member Posts: 29
    We just finished a trip of about 3,000 miles in our 2006 3.7L Liberty. Averaged 24.5 mpg driving an average 65 mph. And around town in general use it's been getting 22 mpg (summer) and 20 mpg (winter).
  • digger12digger12 Member Posts: 5
    so me driving to california isnt going to be a major stop and go as to gas,thats good to hear,i am going after the same model,just either a 06,or 07,i am set on the liberty for the roominess in the front seat area,i dont care anything about size,i just enjoy a nice mid sized car and allowing me to cruise,and not think about anything except where i am going and the time it will take for me to get there. :)
    Don't want to dampen yr. spirits on the liberty but I have never been more disappointed in a Jeep in my life. The Liberty was our 4th and the mileage was beyond miserable. Can't dispute what people are posting but did talk with other local owners and no one was getting this kind of mileage. Jeep/Chrysler/Daimler was beyond worthless to work with. Although the Corp. Product Support group finally eluded to an issue, they would not assist in doing anything to improve the mileage of our vehicle. Within a year and at approx. 6,000 miles we traded for a Hyundai Santa Fe. Amazingly different vehicle and double the mileage. It does what they claim it will do. Hope you have better success then we did. Was not wanting to trade but could not tolerate the issue any longer. I'm totally turned off on Jeep and Chrysler product at this point.
  • dragonbluedragonblue Member Posts: 1
    I am new to this group [just added]. I have not seen anyone discuss the practicality or usefulness of updating the fuel injection system [with a system such as Advance Auto's K & N K&N Fuel Injection Performance Kit] which may improve the MPG stats. It costs about $260 if you install it yourself. I do not know the impact on the warranty it may have.
  • stevedebistevedebi LAMember Posts: 4,098
    "Within a year and at approx. 6,000 miles we traded for a Hyundai Santa Fe. Amazingly different vehicle and double the mileage. It does what they claim it will do."
    Well, yes, but then Hyundai does not consider their vehicles "trail rated".
    Yep, You are exactly correct. The Hyundai Santa Fe is not "Trail Rated". The last thing we wanted to do was get rid of the vehicle but after "playing the stupid game" with Chrysler and attempting to work with their so-called "customer service group" the agravation and frustration was not worth the fender badge to say we owned a vehicle that was "Trail Rated". I coopperated with them in every fashion for almost a year, hoping we could work out some reasonable solution. There was total disinterest and they lost a loyal customer. We walked away from our 4th Jeep due to "poor" treatment and lack of concern. I am a reasonable person and know what customer care is all about. I manage a customer support group and have done this type of work for 30 years. I can recognize when disinterest is a factor. My focus is to always be fair and objective. Jeep/Chrysler was not. They made a choice and so did I. "Trail Rated" is not worth 50% less mileage and below the supposed standard of other user and consumers. Truth in advertising is also a factor and they were not even close to meeting the EPA advertised mileage values. There is a reason U.S. car manufacturers are losing to the off-shore companies.
    " "Trail Rated" is not worth 50% less mileage and below the supposed standard of other user and consumers."
    I meant no criticism of your choice. I was merely pointing out that Jeep has focused their energy on making their vehicles off-road capable, and not on fuel efficiency. Those 4WD components are heavy, and the transmission requirements for off-road cause more drag when on road.
  • 2006liberty4x42006liberty4x4 Member Posts: 2
    I am new to this site as well and wanted to comment on my own 2006 Jeep Liberty Sport. I have to say that I am not all that impressed with the power, styling, mpg, or the terry cloth that the seats are made of! This vehicle is my first new car purchase and from driving friends vehicles that are relatively comparable (Nissan Xterra, Saturn Vue) I am venturing to say that I will also not purchase another Jeep. This post is not meant to be insulting, but the "Trail Rated" tag is overrated. I don't have the confidence to put my stock Jeep up against much of anything else in its class. It is significantly underpowered and the stock 16 inch tires don't instill much confidence offroad. I feel that if Jeep wants to remain competitive with its offshore rivals, they do need to reengineer just about everything with the Liberty.
