Jeep Liberty Real World MPG
This discussion is for reporting on your Liberty's gas mileage. Please mention your odometer reading and your driving style, city/highway mix or anything else that will help others compare their mileage to yours.
If you have the diesel flavor, check out the Jeep Liberty Diesel: MPG - Real World Numbers discussion.
I am sure it's fun to joke with people. I could say my CRD liberty gets 37 mpg too, but everyone knows that's not true. Just as we all know what you have said is a joke as well. And you caught someone who bit into your hook.
Farout
%100 gasoline and avoid the ethanol blends but that's about all we have around here.
3.7 with automatic is what I have. I don't usually put much effort into driving with super efficiency but if you are really careful, you might be able to do a bit better.
I was wondering if anyone can comment on the 6 speed manual version of the Liberty? Such as what kind of mileage do you get?
Also was wondering about how it shifts, whether the clutch engagement is touchy or progressive and what rpms are normal for highway cruising?
My advice--- go drive at least two or three Liberty stick shifts and see what you think. Previous posts don't seem to indicate a great deal of mpg improvement vs automatic -- you save bucks when you buy but lose big when you sell.If mpg is a big consideration in your choice of cars, the Liberty won't make you happy. It is what it is -- a heavy little truck that I find a lot of fun to drive. The other problem is that you have to settle for part time 4wd with the stick which limits its usage to extreme conditions like off road and very poor traction surfaces. I like the full time option a lot.
Go take a few test drives and let me know what you think. The most important opinion on this issue is yours. Have fun!
Farout
Farout
- 4WD at 7500ft altitude 18L%KM ~~13 USmpg (this one is less accurate)
- heavy rain/snow 12.5L%KM ==19 USmpg
- local city traffic 11.3L%KM ==21 USmpg
- interstate 80mph 10.23L%KM ==23 USmpg
- mixed / commuting 10L%KM ==23.5 USmpg
- interstate 70mph 9.46L%KM ==25 USmpg
My "global" average mileage is now 22.5 USmpg after 3 years and 52,000 miles. This comes to almost 12,500 USD worth of diesel fuel over here :sick:
It ain't great, but it's better than the miserable mileage my on-its-last-legs '95 Trooper is getting - 16 MPG on mostly highways if I'm lucky!
These things I mentioned are very basic to good mpg. However if the things above have been done, here a few things to bring out better mpg on any vehicle. Go to Synthetic 5-30w oil. Make sure the tire pressure is 33 to 36psi. Use the Cruze control as much as possible. Avoid jack rabbit starts. Don't use the defroster any longer than you have to, this uses the air conditioner to take the moisture out of the air, using fuel like in the summer. Don't let the engine warm up for long periods of time. Run some injector cleaner in your gas tank to glean out injectors and valve body. If spark plugs were changed recently, pull one out and make sure its a Champion, and gaped at the right measurement. Look under the Liberty and make sure the gas line does not have a leak of any kind. You can even make sure the transfer case lubercant has been replaced and is clean and full, the same goes for the axles as well.
My experience is when someone is trying to sell a used vehicle they make the inside and outside detailed real nice, but the upkeep items they do fool with. You can't see those items, and that's where money gets spent rather rapidly, but it's more important than making the outside and inside look brand new.
If you did everything I said the mpg that you will gain proberly won't be what you are wanting to achieve. In tip top shape expect 15 to 16mpg and on the road 17 to 19mpg
Farout
Thx!
Mike
Farout
Let me show just what the difference in mpg makes. Say you are getting 16mpg. You want 19mpg, that might make you feel much better about mpg your Liberty, right? Well the truth is there is only .03 per gallon difference between 16mpg and 19mpg or .60 cents a 20 gallon tank full. But there is more to economy than just .03 cents a gallon. We got our 06 Liberty Sport for $3350. less than we could have bought a Compass equipped as close to the Liberty as possible.
The Compass 2.4 CVT II gets maybe 24 mpg. the Liberty 17mpg. At $.035 divided into $3350. = 95,714 miles before you would notice any savings in fuel compared with the Compass with the 3.7 V-6 Liberty. So just fuel mpg is not the big answer for cost per mile of driving.
Just drive like this Jeep has to last you for 10 years, and you will be far a head.
Farout
I do think I'd much rather have the Liberty than the Compass, though. Nicer handling, feels far more solid. The commute isn't all that bad for me, most of it is freeway and the car it's replacing - a 98 ford ranger - got about the same mileage.
Thanks for all the comments, guys!
Farout
I have one of each, and they get about the same real world mileage -- the Liberty has more of a truck feel to it but has more oomph in the engine compartment, but the Escape drives a bit nicer on longer trips.
A V6 3.7 is a hefty engine don't expect to get toyota miles.
You bought a Jeep to go rough, did you think you could go cheap too? Want Miles get a Rav4 just stay off the trails you will block them when that thing gets stuck.
Having a Jeep is a auto love thing. You tell someone you have a Jeep then move on. They don't get it. They don't understand but they respect you. A Jeep is Respect.
There are Rolls, Mercedes, Porsche, and there are Jeeps.
Even a Hummer does not get the respect a Jeep does.
It says something about the owner. You are a free spirit, able to go over obstacles.
As the legend goes--
It's a Jeep thing, you wouldn't Understand.!
How is the manual to drive? I would guess since its a big engine it should be easy to shift but maybe a little slow to engage. (compared with the small cars i've driven with manuals.)
I am naming her Miss Piggy.
Anyone else disappoint with the economy of the Liberty? Is it just mine or do they all do this bad?
Appreciate the comments and I agree to the huge loss in trading vehicles. It is more the issue that this small, but heavy, vehicle is so "thirsty" and the big machine, Jeep / Daimler-Chrysler, is unwilling to even offer any "words of wisdom". The typical "party line responses" get old. What iss the "computer chip reprogamming procedure" you mention? Is that a recall item and what years or Vin/s/n range vehicles were affected? Is this something that may improve the mileage?
Thanks - Stingray
Appreciate the opinion and tend to agree with the ratio theory. Down side to this is the frt. and rr. ring&pinion would need to be exchanged to maintain proper drive line balance. This becomes more complicated and expensive. Drive line wond-up, just like with different diameter tires, can be quite a problem.
I do feel Jeep "screwed up" putting a 3.73 ratio in. A 3.48 or 3.55 would have been more appropriate. With this engine, they are too high in the Hp curve, compromising fuel economy. Naturally they will never admit to this, just like they ignore the whole issue with low mileage problem. I've talked with several other owners who have the same complaint.
:confuse: ">
Well, yes, but then Hyundai does not consider their vehicles "trail rated".
I meant no criticism of your choice. I was merely pointing out that Jeep has focused their energy on making their vehicles off-road capable, and not on fuel efficiency. Those 4WD components are heavy, and the transmission requirements for off-road cause more drag when on road.
