Toyota Echo Real World MPG
What are your day-to-day mileage experiences with your Echo?
Well, the running average, now covering almost 10K miles, has just edged back up above 41 mpg, in my '02 5-speed. But I fear this tank coming up, with pretty much 100% A/C use, will drag it down a bit again. This car is amazingly consistent though, with the running average hovering right around 41 mpg and no fill-up ever being more than about 5% off the mark above or below.
#5034 of 5053 first mpg report by marika Jul 09, 2006 (5:45 am)
I've had my Echo for about 3 months now. It took me that long to go through a single tank of gas! Here are my stats:
-2001 5spd coupe
-flat N. Fla terrain
-exclusively city driving
-50% heavy, 50% light traffic
-exclusively short trips (<4 miles)
-light but constant a/c use (lowest setting)
-9.02 gallons, 341 miles = 37.7 mpg.
I was hoping to break 40. I drive like a granny, coast as much as possible, irritate the mess out of the people behind me, etc.
And your gas mileage will drop by about 20%, if my experience is anything to judge by. For a car that is no quicker off the line, but obviously will hold a lot more stuff inside.
And there will be no difference between the '06 and '07 I assume, as this current generation is in its twilight years. If they delay the Corolla as they now say they will, there will be an '08 too, and by this time next year there may be cash rebates, so if you can wait that long (or at least until winter), you may get a better deal.
Good luck! :-)
That A/C is a killer for the mpgs. I think it has a much bigger impact than excessive speed does. I figure this is about an 8% drop in fuel economy for me, and might be the lowest single tank I have ever had with the car.
Could be a fluke too, of course, so with it appearing that the weather is going to continue unchanged for a while, I will probably have more tanks with a ton of A/C use, and I can see how I do then.
Lately the AC is on most of the time but the mileage for the last three months has been closer to 42 mpg.
It is in winter where it drops to 36-38 mpg.
It just keeps on truckin' - I am headed up to Yosemite in it on Monday for a short trip - I wonder what the mountains will do to the mileage.
Also discovered a tire with a slow leak - dontcha just hate that? :-/
I think the slightly poorer mpg of the winter gas and colder morning start-ups is offset by the almost constant use I make of the A/C in the summer.
But then of course, I live in coastal California, so.......seasons? What seasons? :-P
360 miles, 9.25 gallons, 38.92 mpg. And gas is down to $2.90/gallon as well! The little car definitely went easy on my wallet this morning.
And hey, $2.82/gallon means the whole fill-up cost me $20.02!! I can't remember the last time I filled up for $20, although once upon a time long ago that was what I anticipated at every gas stop.
Oh yeah, and gas is down to $2.69/gallon. The whole fill-up was $25 - any day now I will be able to fill up on a $20 bill again. Fantastic!
Did 454 miles, put in 11.3 gallons, which comes out a shade over 40 mpg according to my calculator. Nuttin' to complain about there! :-)
385 miles, 9.2 gallons, which is 41.8 according to my calculator, call it 41-1/2, still it keeps the average up very nicely. :-)
Still 39 is acceptable as long as it doesn't repeat too often...
They say resale values of large SUVs are rebounding as gas prices stay moderately low. I say, why spend all that extra dough to gas up, even if it IS less expensive right now?
Gas is going back up in my area even though it's still winter, up to $2.70/gallon now. Glad my little car will go so far on each ounce of gas...I was thinking about it today, and with this gas mileage, my Echo only needs 3 ounces of gas to go a mile, or to put it another way, just a Big Gulp of gas would propel my Echo more than 10 miles! :-)
Tonight was not so good, 395 miles on 10.25 gallons which only comes to 38.5 mpg. Averaged with the last tank I am slightly below the 40-mpg average I have come to count on.
It's time for fresh oil, air filter, and tire rotation next week. Perhaps that will boost my mpg numbers a bit. :-)
It helps that my daily driver is the Echo! It now has 81K on the clock. How many miles on yours, mopar71?
Certainly it is a very good car to have around with the gas getting ready to hit $4/gallon.
I have only had better MPG last year in Arizona on a long stretch of highway at a steady 56 MPH and getting close to 52 MPG (51.92).
Total miles on my car are 165k. This little critter is getting better and better.
A couple years ago i went to Atlantic City and back a distance of about 165 miles. I went a steady 60 mpg and got 51 mpg when I filled the tank. I almost never drive long distances and over 45 mph. Thats the only time this happened. Better than a Prius I think!
usually get 41 mpg, depending on AC use.
Rear and passenger seats removed for better cargo capacity, negligible improovement in MPG.
Mostly rural/highway driving on eastern LI which has some hills, but is generally flat. A couple trips to Toronto via the Adirondacks, similar milage.
I was doing one thing different on purpose to see how high I could boost my mileage, and that was instead of passing cars by speeding up, I would slow down behind them until the road was clear, and then pass them at 65 mph (101 is 4 or 6 lanes the whole way, in case you're worried! :-P). It was an evening drive both ways, neither day was Friday or Sunday, so I could do that easily as there wasn't a lot of traffic.
Another long trip I took in it, I was running 65-70 mph with higher-speed passing and had the A/C running all the way, and was still pulling 46 mpg in long highway stints.
The Echo is possibly the most amazing gas-saving machine sold by a major car manufacturer since the days of Geo Metros and the special hi-mi Civics of the late 80s and early 90s.
edit: when I am in town, the Echo is my commute car, and like kneisl1 I always fill at the same gas station, almost always at the same pump. Unlike kneisl, however, my mileage never varies much. 39 is a rare and low reading, 42 would be rare and high. Almost without exception the mileage is always 40-41 in town, and I fill it when the light comes on, so my fills are always 9.5-10 gallons. Gotta love that consistency! ;-)
But of course if you do a grinding stop-and-go commute every day and you like luxury features in your car, well then of course you should go with the Prius.
1. You want to make a statement about the environment with your car. Prius does this outstandingly.
2. You want partial-zero emissions, as opposed to ULEV (Echo) or ?? (Yaris - is it LEV or ULEV? I think it is just LEV).
3. You want seat heaters, a 10-speaker factory stereo, cameras everywhere, keyless start, the list goes on and on. If you want a high-tech or luxurious car that gets fantastic gas mileage and has rock-bottom emissions, the Prius can't be beat, and the Echo isn't a contender.
If you are looking for basic transportation that is rock-solid-reliable, has high fuel economy and low emissions, and can keep up with the crowd on the road, well then Echo or Yaris is your man! :-)
Anyway, the Echo is INDEED a contender as far as I'm concerned. I just bought a 2004 used one, and it is just as "rock-solid" reliable as the Prius in terms of durability, in fact a lot of the parts look like they could be nearly interchangeable. Look on the net & you'll find several forums where people have ridden their Echos up to or past the 100K-mile mark and are writing about its integrity and reliability.
But yes, the Prius does beat the Echo on emissions (of course) when it's traveling at 15 mph in town because it's running on its battery.
So one out of three of your list of three -- it's an important factor, but if I actually had at least $15000 extra that I'd have to spend for a prius, would I put it in a car for around town, or could I buy 15 electric bikes.
And most of my remarks were directed at the current Prius model available since 2004. I have driven the pre-'04 (like your ex's '02) quite extensively, though, and I agree: there is nothing whatsoever about it that is high tech except the powertrain. And it was a fairly miserable drive at that, and did no better than the Echo did for gas mileage.
Now if I wanted all the gadgetry and they offered a Prius with a stick and some sort of handling package, I would probably look at it very seriously. But as things stand, I am enjoying my minimalist phase, and my Echo has yet to need a repair, now at 85K miles.
