And yes, mine is a stick shift. Expect 3-5 points worse if you have an automatic.
Despite that, the last tank still returned 42 mpg just as usual. A/C doesn't hit the fuel economy anywhere near as much as cold outdoor temps do in winter.
The good news is that my marathon commute is officially over and I am moving closer to my job, and will use a fraction of the gas I have been using. Goal is to leave the car parked on the weekdays and just use it for travel/recreation. The bad news is I expect my mpg reporting will decrease significantly with a more irregular driving pattern.
One thing that could account for it is that on this tank, I spent quite a bit of time transporting two other adults in addition to myself, and running the A/C a fair amount of the time.
Anyway, I hope it is a one-time aberration!
Good weather or bad, A/C or no, I can count on 40-42 from my little MPG champ! (I couldn't resist: I got a personalized license plate for mine that says MPG CHAMP) :-)
But I will be looking next time to see if it evens out with an extra-low tank, which would mean it didn't quite finish filling today.
372 miles, 8.5 gallons, makes 43.75 mpg. So I've been averaging better than 43.5 mpg for at least the last 750 miles.
Which gets me to wondering: it had its major service about 1000 miles ago, maybe 1300 miles, and that of course included fresh engine and gear oil and a new air filter - perhaps all that helped with the mileage a little bit. Every mpg counts with the gas at $4.50! :-)
One thing I have now firmly concluded is that cold winter temps hurt mileage in the Echo a lot more than heavy A/C use does in summer. All my driving lately has been around the 'burbs, with frequent regular A/C use as our temps have been getting into the 80s on many days and occasionally into the 90s. Despite that, I am getting some of the best numbers I have had in a while!
It is an Automatic, that's true, but that seems a world apart from the 40-50 MPG people are posting here. What am I doing wrong?
To get the best mpg on the highway you need to maintain 60-65 mph. I have gotten over 50 mpg twice now when doing that. I should mention I almost never rack up "highway" miles most of my driving is done in town, specifically 6 miles to work and back never exceeding 45 mph.
With the advent of 10% alcohol in gasoline since a couple of years ago I get much worse mileage in winter than I used to. Probably average 35 mpg occasionally 33 mpg sometimes 36 mpg. I used to get 36-38 mpg years ago. Summers Im getting 40mpg and even better this summer occasionally up to 43-44. (but to be fair those figures include a little "long distance" cruising on errands of 15-20 miles.
I would check your tire pressures frequently (weekly) making sure you keep 32 psi in them. You also have to drive and accelerate s l o w l y. Your AF is clean, right? I also do oil changes every four months and average 1500-2000 miles between changes.
I am happy to report, however, that I have for once broken the 40 mpg barrier. After extensive research and determining that my odometer is inaccurate by about 3.3%, I have acheived 441.8 miles on 10.571 gallons (427.7 * 1.033) for just about 41.8 mpg. This includes a 186 mile trip to San Diego and back, and the rest a little of everything. I have invested in a Scangauge, so hopefully my numbers will continue improving from this point.
I highly recommend the Scangauge II, worth every penny. However, I did have to adjust my consumption factor to +6% after the first tank, so dont get too excited until you get real numbers at the pump. Luckily my disappointment was slightly offset since my car also understates miles driven.
My 2001 Echo achieved 41 MPG AVERAGE over 170K miles in a commute with 50% city and 50% stop and go.
'02 5 speed. Lots of hills where I live in the Bay Area, but I also do a lot of regular driving on rural 2-lanes where the most you can safely do is about 50 mph. Doing 50 in 5th gear has the engine just loafing along.
I heard that Toyota uses high strength steel in their cars which may explain how the car held up? :sick:
There are flippers on Craigslist offering $3,000 for any Echo regardless of condition. I'm starting to worry that the Echo will get stolen, but am considering leaving the keys in the Suburban hoping that somebody will steal it. :shades:
The Echo has always been an outstanding value in a commute car, but it sure is earning extra brownie points this year! :-)
A number of folks who have bought the new '09 Corolla are reporting low- to mid-40s mpg. There's a new sheriff in town! :-P
[IMG]http://i277.photobucket.com/albums/kk56/27461/trailer.jpg[/IMG]
Who wants to take bets it was a case of the pump shutting off before it should have? :-)
I will post next fill as well, to see if the mileage is really up or if it gets balanced out.
After never having a 50 mpg tank before (think I topped out at 48.7) I had four within the space of a month, and three consecutively. Since mid July my last tanks have been: 44.6, 51.7, 44, 44.9, 45.3, 50.4, 53.7, 52.6, and 46.4. The first 50mpg (51.7) tank came on 90% steady 60mph driving long trip. The second 50mpg tank (50.4) was faster (ave. 70mph or so) but was nonstop driving from northern to southern Montana, 388 miles in one run. The next two amazed me: 53.7 and 52.6 mpg. How possible? They were entirely within the confines of Yellowstone and Grand Tetons national parks, with 45mph top speeds. Lots of driving, but lots of stops too. This really shows the amazing numbers possible driving 40 in fourth, 45 in fifth, never accelerating rapidly.
The final tank of my vacation I hoped to drive all 80mph on my way home (through MT speed limit is 75) to try to nail down the effect of speed on mpg. I averaged 80mph for @300 miles, but for 150 or so miles more like 65mph. End result was 46.4mpg.
What are my conclusions? Nothing surprising: (1) speed matters--60mph gets great mileage but even slower is still more efficient (2) length of trip matters--short is bad, long is good, really long is even better (3) This car is awesome--I drove well over 3000 miles on this roadtrip and gas prices were the least of my concerns (especially when I realized every other vehicle in MT and WY is some Dodge dually pickup that costs $150 to fill up).
Oh well. If I could just force myself to slow down, I'm sure I could bring it up a few points but hey! I'm in a hurry! :-P
325 miles, 7.5 gallons.
