Visitor Agreement.
We will see.
Gp to this site and click on the lower left where it says Your Mpg. You can keep a running record of your MPG and keep it for ever and for others to see.
Are you guys using manual transmissions or coasting in neutral? The only time I've ever recorded over 40 MPG was by shifting into neutral when approaching red lights or going down hills. I stopped though, since I heard it could be bad for the engine from most sources.
I really need to buy a Scanguage
At this point, I got my landlord's brother who is an amateur mechanic to come by and he was able to reattach the casing without a problem. However with the hose, he simply reconnected it and said not to worry about it... I didn't feel comfortable with this advice, so I took it to a Canadian Tire and they reattached it properly.
So bottom line, dealing with the air filter is a little more complicated with the Echo than with most cars.
Anyways, does anyone have any suggestions for good low rolling resistance tires? From what I can tell visually, they don't seem to be worn out, however according to Google, I believe they are designed for grip rather than fuel economy. Also seeing my mileage drop from 36-39MPG to 34-36MPG AFTER removing my winter tires AND getting my alignment corrected is leading me to believe that there may be issues with the tires.
The wife has a Prius ('08) It is nice, the ride is better and it has more luxeries, but she paid for it- five times more than I did for the Echo....
In a stick shift Echo, it's child's play to pull 50 mpg on a highway trip as long as you keep it to the speed limit and no more.
A lot of tire shops will offer you "a bit more tire" (a bigger size) as mine did when I went for the Echo's tires, but sticking to the 175/65/14s that were stock (unless you had the appearance package in later years) will give you the best mileage.
This little car is really something in the fuel economy department. :-)
'02 5-speed 4-door.
Anyway, it was a hair under 6 gallons for 286 miles, a whopping 47.5 mpg!! Of course, I assume it was a short fill so I will average it with the next one, but still I bet the average for this 700 miles will be more than my usual 42. :-)
Gotta love how frugal the Echo is with gas.
Sometimes I shut down the CC because when going up hill the transmission would downshift to maintain 70 mph. I just let the car slow down 5 or so mph but stay in high gear.
I realize this isnt an ECHO we're talking about here but I mention it because many current ECHO owners may find themselves in a Yaris someday.
I haven't been tracking mileage for the last year because my wife has taken over the car and I'm on foot except for weekends. But we'll be going on about a 2500 mile road trip soon, and will chart the mileage. Last year a similar trip got just a shade under 50mpg average and three tanks of around 53.
I have a bad feeling the most FE/affordable ever to be made car will be the ECHO.
I just really want them to follow through with a Yaris Hybrid. It'll weigh less than a Prius (which is really pretty big) so it should do better over all including operate under battery power to a higher speed.
http://www.hybridtechnologies.com/products
Thanks to kneisl's advice, I am upshifting a bit sooner these days than I did when I first got the car, and I make a habit of not exceeding the speed limit on the highway, expressly to conserve gas. But beyond that I do none of the hypermiling stuff some Prius owners do.
Still 42 mpg overall, over the last 65K miles. The little guy gets new spark plugs and air filter (and maybe a battery) this fall. :-)
'02 5 speed.
At least that's usually the case. Echo seems to be one of the most extreme examples of that out there.
Words can't describe how much I LOVE my Echo... at 200,000 miles going gangbusters up and down the highway with an automatic transmission, I still get 34 mpg.
(I have to say though... the interior of the Yaris doesn't look NEARLY as nice as the interior of the Echo.)
384 miles, 9.4 gallons, that's not quite 41 mpg. I hope it is a 1-tank aberration, and that the new tires are not going to cause my mileage to decrease permanently.
On the plus side, the tires are nicer to drive on than the last set, with very little downside beyond a bit more "squirm" on the tread because it is such a deep, widely spaced tread on this tire.
'02 5-speed, officially past 125K on the odo now.....
379 miles, 9.4 gallons, 40 mpg.
If I get much better wet traction than the precious little I had before, I guess I might call it an even trade...
'02 5-speed.
It was immediately apparent when I got the new tires that they were much softer than the old ones, and probably have much higher rolling resistance as a result. One consequence of that was BOUND to be lower fuel economy, but the ride is softer now too, which is a plus, and if I do end up getting lots more traction in the rain, I guess I will call it even.
They are very grippy!
Below is an interesting link about a similar study... with references.
/denis">link title
Certainly as tires age, the rubber hardens even if they still have a lot of tread, and that hardening decreases traction but increases fuel economy.
I pull about 32-34 mpg and drive it kind of hard. I am an aircraft mechanic and we do alot of driving to various airports here in SoCal. Not uncommon to do 800 miles a wk.
Recently i have been getting a pinging sound while taking off from a light or under low pedal acceleration, and when i did a plug change i noticed a little oil in the combustion chamber. Any advice on how to get rid of this pinging?. i use 87 but even w/89 or 91 octane i still get it..
I have a duplicate but is there a way to get an original from Toyota?
I feel so stupid!
I was pleasantly surprised by how helpful they were. I got a spare factory key for $16 which they made off my VIN number.
There was also an option of a cheaper metaheal key for $10.
I can relax now
Still chugging along here, up over 132K now, got 43 mpg on the last tank but it had more straight highway driving than I usually do, and the tank before that yielded only 39. :-(
Should have bought tires with a higher speed rating like the ones I had before, the dropoff in mileage has been a consistent 2-3 mpg. The Michelins I got are Harmonys, a soft little S-rated tire, and the Yokohamas I had before were H-rated. Harder tires, less rolling resistance, better mileage (and a harder ride).
Fell for the Harmonys because of the 80K treadwear warranty.....
