does anyone have a good source of HHR parts? I can not find the running boards they say I need to install to fix the problem. any ideas?
thanks everyone,
kathy
If my message got posted in the wrong place, I apologize.
kathy
-turn ignition to ON possition (NOT Accessory or Start the manual has a diagram), its the postition where the instrument cluster lights up with all the Symbols, just before starting. Leave all these indcator lights on while reseting.
-Go to INFO button (on steering wheel)
-scroll to OIL LIFE
-pump gas pedal 3 times
-Some will beep or just reset.
-turn ignition off, start the H, and check if reset. Should read 100%
Shounds like you were on the right track.
Please help.
Well, a bulletin came out finally and there is a grounding bar behind the drivers side kickplate that had gotten wet from driving thru car washes and became corroded. They fixed that and have had no problems for the past 2.5 years.
Steve
Pitch changes with speedometer changes and does not change if I shift in to neutral.
Does not become noticeable until about 25 MPH and is not louder when I open a window
I am from GM Customer Service. Can you please email me more information about your vehicles situation so I can look into it further? You can access my email by clicking on my name. Thank you,
Mariah GM Customer Service
The noise is a soft version of what you would hear if you put a playing card in your bicycle spokes. of a loud house hold fan in the same kind of pitch ranges you hear from a Piper Cub airplane pulling the banner up the beach
I need to get some more information about your vehicle in order to look into this further. Please email me back so I can look up more information on your situation. You can access my email by clicking on my name. Thank you,
I did jack up the wheels and spin the tires. I am not familiar with FWD. It is not real tight but seems OK.
How is everything on Betelguese?
I am from GM Customer Service. Can you please email me more information regarding your vehicle so I can look into it further? Thank you,
