Visitor Agreement.
Actually, the Lucerne with the 3.8 will stay in 2nd until almost 90 and in 3rd until it hits the electronically limited speed of 107. The digital readout will tell you when you are being limited. Pretty cool.
People who say this car with the 3.8 is underpowered do not know what they are talking about. If you drive it like an old lady then sure, it will be slow. But it has plenty of power when you get on it. I have even pulled a few trailers with it and it did just fine.
No one talks about the leveling rear air suspension. It is great to have a car that can be loaded and NOT ride on the rubber shock bumpers, bumping down the road like most loaded cars do.
What about the GM Oil Life system, that when actually used in accordance with the instructions from GM, only requires oil changes about every 10K miles? That is a huge money saver. Besides, the oil still looks new at 3K miles so the 3.8 must run really clean, hence the longer oil change intervals.
I have had 12 brand new cars including Honda, Mazda, Hyundai, and a lot of GM products and the Lucerne is my favorite by far. I have had mine for 10 months and I already have 35,000 miles on it. I drive a lot and I can appreciate a quality automobile. The Lucerne is it.
And then it's mated to one of the world's most pathetic preforming (though very reliable) transmissions.
The 3.6VVT is a much better engine for that 4-speed transmission that GM has been using for nearly 20 years.
IIRC, one of the Pontiac models has a manual gearbox and the 3.8/3.9 engine. And it's a blast to drive.
my second car 94 Buick Park Avenue Ultra is a perfect example of torque from an American car. Press Gas and a car moves you even @ a low 2k rpm. If not for its weight 3900 lb, it can beat even 05 maxima 3500 lb.
In my opinion 04+ maxima behaves like an American car, though on a diet.
My sister owns an '06 Impala LT with the 3.9L V-6. While it's still a VERY powerful engine, it's still very noticeable as to how much difference there is in starting power between her car and mine. While I understand comparing her engine to mine is apples to oranges, the torque numbers don't know how many cylinders are used to create them nor does the rest of the car (mine is much heavier BTW) know. What I (and anyone else riding along) know is that the extra low-end torque makes driving around town much less "busy". It also makes a huge difference when you have well over 800 lbs of flesh in the seats and accelerate (uphill) onto a 70 mph interstate highway. My brother-in-law (who drives her car as much as she does) was amazed by the difference.
Again, I realize this is not a fair comparison but it does speak to the value of having lots of torque at your disposal. Those high rpm hp numbers look impressive on paper but they don't always translate to usable power on the road.
MULARKEY - and I think you know it, HP is acceleration - The mathematical relationship is: HP=(torque x rpm)/5252. The important component of this formula to understand is 'RPM'.
Torque is a quantifable measurement of instanteous twisting force available at any given engine at any given engine speed and obviously is an important part of how a car drives. An electric motor, for example, has its maximum torque available at 0 RPM.
Referencing the formula above HP is torque applied over time. You can have all the torque in the world (let's say a diesel, or a pushrod engine, or a big V8) but if the engine doesn't rev quickly, HP must be limited and so is acceleration. It is HP/lb of vehicle wght. that will give you an accurate idea of how well a vehicle can accelerate - NOT ft/lbs per lb. I recently drove a ML320CDI diesel (200hp/400 ft lbs.) and even at 4500 lbs. I'll guarantee you that it is quicker off the line than my 3600lb 270hp/250 ft lb. Avalon - BUT, 0-60 or quarter mile not close - why because that OHC engine revs so much more freely and quickly and my HP/lb. is much better. And then you can go drive a example at the other extreme, the extremely quick S2000 with 240 HP and ONLY 160 ft lbs.torque all available well above 6000 rpm. By your contentions, that 2800lbs ought not be able to even move with that kind of limited torque, but wrong, once you hit about 6k rpm the thing becomes a rocket - peak HP doesn't hit until nearly 8000 rpm. At something about 12 lbs. per HP it should run in the 5s 0-60, which it can. A very demanding car to drive smoothly and quickly BTW, as it should be and an absolutely astonishing normally aspirated engine.
But you are right about ONE thing, that being that these new engines with VVT (or even better CVVT) do serve to widen out those torque curves in these OHC engines that, by definition will rev more quickly and produce more HP. It is about time that GM has figured out how to use some of this technology instead of foisting all these pushrod marvels on the unsuspecting American autobuyer. I can't believe that GM can 'sell' the 3.6 to Suzuki (in the Vitara), and then only put it in the the 'black circled' LaCrosse/CTS, leaving the 3.4, 3.5s, and 3.8s etc. throughout the rest of their products. Makes no sense!
You're missing what he's saying. And that is, many/most torque curves (torque vs rpm) aren't very flat. Ideally, you want a graph of HP vs rpm to be a straight (increasing) line, and not one that is concave up. The car just drives better that way.
I've owned two of them in a row - a 94, and then a 2002, and both of them at once because I liked the old one so much. I got rid of the 94 in 2005, not because there was anything wrong with it (well, valve stem seals let the engine burn some oil), but because the wife got tired of me owning two of them at once. Literally everything still worked properly on the vehicle, though I did do new front ball joints 118,000 miles, and I had put new coils, wires, and a starter in it before that point.
My mechanic loves it because he said it is one of the few "real" cars still being sold today. My 2002 at 60,000 miles is due for it's first front brake job, and first tranny fluid and filter replacement - still has the original tires. Also a great car for shadetree mechanics - easy to work on for those with lower mechanical skills.
The Grand Marquis has no street cred because they aren't flashy, and they don't change enough for journalists to write about. Ford hates them because they last too long, which is why they are trying to push you into a Montego - how much did Ford spend to design an inferior product? Sure, it looks better on paper, but come see me with it when it is ten years old and throwing CV joints, engine mounts, etc. - no thanks.
They are also great for rush hour traffic because people always let you over - probably because they think you are 80 years old and blind :P
Now, about the torque/HP discussion.
I know all of that - it's just that in plain terms, the way most engines are made today, HP translates into top-end speed and highway acceleration. The engines are peaky, like the S2000. You said that once it hits 6000rpm... Well, it's a toad at 2000-3000 around town.
Power at RPMs that are silly high, mated to a silly tall gear set - makes for fantastic numbers and highway mileage, but translates into nothing useable.
A Buick LaCrosse with the 3.8L engine develops *advertized* power and torque at speeds in excess of 90mph - in third gear. That's verging on bald-faced lying to us, as no consumer will ever see more than 2/3 of that "power" in actual use. Some won't do much better than 1/2.
But the 3.6 GM has - does the opposite. It runs like a turbo-diesel. Very flat and low torque curve, which means you get maximum power behind your acceleration and it holds it there nicely. You'd think that after more than 100 years of designing engines for cars that they'd have figured out how to make an engine like this. Wel,l they have, actually, just that everyone worships HP in the U.S. - like computer power. Gotta have that extra 20HP - despite the fact that outside of a track, you'll never see it.
P.S. It's lb-ft.
But, if you really want a flat and accessible torque curve, drive a diesel and then, wonder why the thing simply doesn't accelerate. It doesn't because the engine is slow to gain speed (rpms), and therefore HP - the best indicator of any vehicles ability to get out of its own way. A lot of accessible torque really does help a car's drivability, but is worthless without an engine that can spin fast enough to take advantage of it!
This is the catch - as a general rule, engines with a lot of torque (created by things like compression ratios, rotating mass, displacement, long strokes etc) are the same ones that are more reticient to gain engine speed...
*quote*
all the cars in this group will deliver at least 75% of the rated torque between 2000 to somewhere about the 4500 rpm maximum rating
How about 75% at 1500 and 100% at 2000. That's an entire WORLD of difference. Where most other engines start, this one ends up. That mean that even in gentle city driving, it's already putting out over 200lb-ft of torque. That's a silly amount, really - like a diesel. just it's not slow like a diesel, given the nearly 6000rpm redline.
Go test-drive one. Pound on it and notice how quickly it responds. How litte effort it takes to make quick transitions, even with arguably one of the most "old person's" automatics on the planet hooked up to it.
The 3.8 has more than 200 lb-ft of torque at 2000 rpm IIRC. it's not the maximum torque but how much torque is produced at lower, useable rpm values in normal driving that make a car nice to drive. When you have to rev to 6000 rpm because the torque is anemic at 2000, you have a completely different car.
3800 graph
3.6 graph
Roland
As I have said, however, the 3.6 is likely 'Detroit's' best effort but I think the car to get it in has to be the new Aura, at least then you can drive on a European chassis not made of sponge rubber!
A car like that is called 2007 BMW 350i, which has a torque of 300 ft-lbs from 1400 rpm to 4000 rpm for a power of 300 HP.
The typical V6 lurches and usually fails. You need quick torque to get it going - or an engine that spins up instantly like the RX-8.
P.S. Yeah - but I thing the BMW costs oh - twice as much last I checked...
I can honestly say, I commute into DC every single day, driving my Azera and it's proven to be very nimble and capable of getting into those quick openings when I need it to. Only thing is...I don't leave the transmission in auto mode, it's usually in manual mode and that makes all the difference.
I have found at low cruising speeds of 35 or 40, the transmission will shift all the way up to 5th gear and when you go to pass or make a quick move, it's gotta down shift all the way to 2nd or 3rd before you can do anything. By keeping it in manual mode, I can cruise those speeds between 3rd and 4th gear and shift when I need it.
I have never had a problem with the automatic tranny shifting on my Azera. I very rarely use the manual mode, only when I want to play around.
I think I can honestly say I use manual mode more than just leaving it in auto mode because it is so much fun.
The 3.6 GM is a better engine (for a 'detroit' product) but is still light years behind the V6s in any of the above - especially the Nissan VQ and the best (and most technologically advanced) V6 currently available, the Toyota 2GR. As one poster has noted, it is so smooth and quiet that you really don't know (or care) that it may be at 4k rpm (or 2 or 6 for that matter), it will leave about 95% of what else is on the road in the dust, and then when you finally have to pull in for some petrol you are further rewarded with FE that can easily get into the mid 30s. By your definition, a Northstar Lucerne would also be undriveable in traffic, simply because in HP/torque ratings (and your oft mentioned curves) are at the same kind of numbers that any of the above engines are? Drive one (or the DTS) and then you can feel what a good V8 feels like.
Again, you are right about one thing, those cars mentioned above aren't in the same class - they can't see that far down! You had better stick with cars of the same ilk - things with those wonderful 15 year old Duratechs and 50 year old pushrods!
Just for curiousity so we can be on the same page please describe (car and engine) what you feel to be a "commuter box"
I mean...that's one of the arguments about the Azera and the Avalon...fully loaded, the Avalon XLS (fully loaded) will hit your bank account for slightly more than $30K, the Azera Limited (Ultimate package) will only cost run you just north of $27K...a $3-4K difference between two cars that of the same class.
As far as commuter boxes go...I always envisioned the likes of the Sentras, Elantras, Corollas, Cobalts, Neons, Civics and such. Just my 2 cents.
Exactly. All of the ones captain2 listed suffer from the same problem - unless you manually shift it/go into manual mode. Fast in a straight line but dreadful in traffic. No - really - test-drive a V6 with stickshift and 6 speed gearbox or a RX-8 and it's night and day. One is "okay" and the other launches into traffic like a scared dog. There's a sense of urgency and being pressed back in your seat and the automatics all... meh.
The GM 3.6 is special not because of the technology, but because they engineered it to work in reverse in the LaCrosse.
Compare the CTS 3.6 and the LaCrosse 3.6. Same engine but tweaked - one has 255Hp and a typical high-end torque curve. The other has 240HP and uses the VVT to put all of the power at the low-end where it's normally lacking. I don't know of more than a couple of engines out there that take this approach. GM could really make inroads if they dropped the 3.8 for this engine.
As for drivability, Plekto and I just disagree. I find no drivability problems with any of the cars Captain mentioned and have driven them all (except the Passat).
As for GM dropping the 3.8, that would certainly be BIG trouble as their reliability would drop significantly if the 3.6 was in more cars. The 3.8 / 4 spd combo is uninspiring, but at least its reliable.
Well...he's comparing the drivability between automatics and manuals. That's like apples and oranges. Unless you get sport tuned tranny...you're gonna have some sort of lag. However...if you anticipate the need to mash on the gas...you can compensate for that lag and get the punch you want when you need it.
At some point, GM will need to take a chance if they want to get anywhere!
The CTS (manual) isn't much better due to how they've tuned it.
And, of course, there are no drivability problems with a good V6 - he just doesn't seem to understand that there are a group of engines like this that sound and feel good at higher rpms - most of them just don't happen to be 'Detroit' designs - where I think his real problem is.
I'm not sure of Buick's plans for the Lacrosse, but there is a good chance that the Azera might get a 6-speed automatic for 2008 because the upcoming Veracruz is getting the same engine with a 6-speed. Maybe GM will use their new 6-speed auto in the Lacross soon. That might help along with a power boost.
EXACTLY - finally somebody that seems to understand the difference. Available troque at any given rpm gives you the initial 'tug', but acceleration has much more to do with how well the engine speed increases under load.
The Azera 3.8 is a pretty darn good engine - something I think GM and Ford wishes they had - its willingness to rev the reason why it outperforms the LaCrosse - despite that usual Korean weight penalty. Take about 200-300 lbs off the Azera and it would run with things like Avalons and Maximas, and maybe even pick an mpg or two!
What is Hyundai's torque in the 2000-3000 range? Do you graphs of the torque curve?
That's where most drivers perceive the "power" of the automobile when doing part throttle starts from stops. 100% of drivers I know don't spend time at full throttle and full speed in any gear. I realize others like to compare those top peak figures, but they're not reality driving for most people; i.e., the beltway around DC the two times we visited. Stop and go.
Please note torque is affected by final drive ratio along with the individual gear ratios in the transmission. Good choices make a car seem completely different.
Toyota's motor is a beast, but once you load an Avalon up. It's $3k+ more expensive. The Ford Five Hundred is probably going to be the closest thing to it once they put the 3.5L motor in it.
I'd like to see a graph like this.
3.6 LaCrosse
The Avalon, incidentally, the highest resale value in its class (at least according to C&D) perhaps justifying some of that initial price pain, depending, of course, on how long you plan to keep it! IMO the Avalon to buy is the 'Touring', handles better, you get the leather, HID lights but not a lot of additional 'bling'- about $31k sticker with sunroofs, homelink, stereo upgrade etc.
The Avalon Touring with all those goodies is closer to $33k MSRP, and it is very hard to get deals at a Toyota dealership (at least it is around here).
Got a family friend a deal on Avalon 6 months ago...
$30 over invoice.
The CVT in the new Maxima/Altima is interesting - if you nail the accelerator - the engine just goes to about 6000 rpm and stays there until the car 'catches up' to the engine or you reduce the pressure on the gas pedal. Seamless acceleration but not the kind of thing that you would think would serve to minimize noise - the VQ, however, is easily a solid enough engine to do this and FE has gone up a couple of mpgs I guess because of lowering the mechanical losses inherent in a traditional auto tranny. I personally think that the jury is still out on CVTs although I don't know of any specific issues buyers have had with them...
I don't really like Nissan's CVT because it is belt driven rather than chain driven like Ford's CVT. I guess it just scares me a bit. Otherwise the two CVT's are relatively similar.
That is a nice feature, but it doesn't really help the car accelerate. The Azera is over 1 second quicker to 60 than the Lacrosse despite being heavier. On top of that it get's worse gas mileage on the highway.
imidazol97 summed up my position pretty well. Armchair quaoting of figures from a test-track at full-throttle by some professional is meaningless.
Full-throttle, the Hyundai is quicker, but it's much MUCH slower in part-throttle maneuvers. In the LaCrosse, I only need to put the pedal down about 1/3 of the way to get moving - and quickly. A 20-40mph roll-on is done quickly and gently - no slamming down a gear or flooring it. Just a nice increase of the gas and - done. Try driving a Crown Vic for an example of this behavior. Yes, it stinks for anything else, but the ability to effortlessly choose a speed and get there without hearing the engine or working at it - that's the goal if you can manage it, IMO. The ultimate expression of this is an older Mercedes S420 or S500. Want to go 30? Done. Want to go 50? Finished. Want to go back to 20? Your morning coffee's not even upset.
The Hyundai? I've driven it. It feels like the 3800. Noisy and like the throttle has two positions - grandmother and racer. And a lot of vagueness inbetween. Not bad, mind you, but it doesn't have ANY feeling like a V8 does. The GM 3.6, though, feels like the world's smallest V8. Very nice to drive in city traffic(and a first for a Buick - lol)
P.S. The Altima(thanks for bringing it up) gets around this with a nice non-stepped CVT. Go drive one(or both) and see what I mean.
Effectively what is happening is that we now have engines and trannies with 'intelligence' that 'learn' our habits and therefore 'anticipate' what 'it' thinks we are going to do. Then, it gets 'confused' when 'it' makes a wrong 'decision'. Most cars out there will do the same thing that the Hyundais you talking about do - 'gear hunting' has gotten to be very common these days, and the problem will become epidemic as more and more manufacturers use these technologies. And it will get worse, as the new Federal mandate for stability/traction control systems necessitate even more invasive computers. In my Avalon, the 5 speed can be forced into a bothersome 'hesitation' if I reapply throttle in a specific manner from lower speeds. The solution - learn how the car 'wants' you to drive it and adjust to the way that some programmer in some lab somewhere decided what is best for all of us. So it turns out not really a transmission problem in the traditional sense but a software issue, although for some that have difficulty 'adjusting' it presents some rather serious impact on drivability.
PS noticed no such problems on a 06 Sonata V6 that I had on a longer term rental - thought it was a sweet ride especially considering the price.
The Toyota dealer here deals quite well, and generally to a couple of hundred above invoice. Although not for discussion in this Large Sedans forum, they currently have 20 Prius in stock, and I just talked to a salesperson on the base model. They're selling them below MSRP (he offered $21,750 for a base model with Option Package #1), which is a switch for the Prius. On the other hand, they've never had that many in stock before either.
A source of lively discussions on the Avalon sites for months, it was assummed that the 6 speed would be better - something that appears to not be necessarily so - judging by the results in the Camry/ES.
A corollary of Murphy's law: the more complicated something is, the more likely it is to break (or not work right). One of the reasons why the Toyotas (and BMWs and MBs) of the world are starting to experience some unusual (for them) problems, and the 'US brands' are improving - thanks in large part to some rather ancient (but proven) drivetrains.
So when you semi-whomp on it, it gets all confused. Me? I'll never buy another automatic again - problem solved. 200+ HP and a 5 speed gearbox is plenty fast.
GM gets around all of this by having the "Abraham Lincoln" transmissions. 3 speed with overdrive. With a big enough or torquey enough engine (Northstar V8 for instance)it does very well. And it's cheap to fix. No computers at all in it - at least non that are trying to out-think you. - so it's at least predictable if sluggish.
