Mainstream Large Sedans Comparison
11516182021134
  • kwk1kwk1 Member Posts: 39
    Parked! LOL!
    You could push a Vette faster than a 500!!
  • captain2captain2 Member Posts: 3,971
    actually the 6 speed - a couple of years ago while I was shopping many of these cars. While I found the 500, specifically, a well designed 'space' ship with unexpectively good fit/finish and egronomics, all thoughts of actually buying one evaporated when I turned the key. While the engine is fine at within the usual 1500-2500 rpm operating range, it sounded and felt extroadinarily rough and strained under harder acceleration in those ranges above maybe 4000 rpm. Much like those rental Vulcans at Hertz. The 6 speed was also a tad recalcitrant and rough shifting as well. The CVT may indeed be a solution to this problem but it shouldn't change how the engine sounds and feels under load. It is simply a matter of refinement, the Toyota 2GR (or the Nissan VQ and even the Hyundai 3.8) can and will pull all the way to redline really without you even knowing it, feeling it, or even hearing much. The new 3.5DT is apparently little more than a bored/stroked 3.0 and should solve the HP deficiencies, but I think the jury is still out on whether it really solves anything in the smoothness/willingness dept., have read conflicting reviews. In any case, Ford should not have produced this car with a 15 year old 200hp engine, the car could have been so much more.
    BTW, there are a whole lot of 4 bangers out there that, by your contentions, are 'adequately' powered that will blow the doors off your 500 - kidney belts are recommended.
  • allmet33allmet33 Member Posts: 3,557
    You fail to mention that when you're passing said Corvettes, the owners are usually tooling along the highway and not thinking about you in the least bit. However, if a Corvette owner was to step into the gas, you would find it quite difficult to even keep up with a Corvette in your 500. ;)
    Come on now...keep it real!
  • louisweilouiswei Member Posts: 3,715
    Keep up?
    Talking about an understatement...
    results just in on a 'top secret' Corvette performance test - they do not run very well without any gas in the tank - the Kia Spectra which for some reason gets quite a few more mpgs, blew the impaired Corvette's doors off! ;) This is about as a ridiculous conservation as barnstormer's initial suggestion?
  • discgolfer99discgolfer99 Member Posts: 42
    YOU'VE GOT TO BE KIDDING ??!?!
    If you are routinly passing up Vettes, they are obviously just crusing along. If you think for one minute that your 500 could beat a vette "in a race", YOUR CRAZY, MAN !!!
  • floridabob1floridabob1 Member Posts: 1,190
    RE: 891
    Smoking what?
  • barnstormer64barnstormer64 Member Posts: 1,106
    Heck, even I don't give a darn when I see a 500 trying to pass me up because I know if I want to I can smoke that car in any given second.
    Precisely why I don't need any more power. ;)
    It doesn't matter what the other CARS are capable of . . it matters what the DRIVERS of those cars are doing with the available power.
    I think it would be more appropriate to call the 500 "adequately powered" and the Azera and other large sedans with more horsepower "exceptionally powered".
    I'd go for that . . because NONE of these vehicles is truly UNDERpowered.
    I have frequently passed a few Dodge Vipers in my Jeep Cherokee but I don't think that means my Jeep is the faster vehicle.
    You need to READ what *I* posted, not what others think I posted.
    Question: if I routinely pass up most vehicles, regardless of how much "excess horsepower" they have, do I really need more power?
    Are you buying a sedan to "race"?
    For the job at hand (which doesn't include racing), the Five Hundred is more than adequately powered . . as is demonstrated by all the Corvettes I leave behind.
    If they want to get in a race with me, I'll let them blow past me and have their adrenaline and testosterone surge. And hopefully let THEM pick up the State Trooper up ahead. ;)
    I've certainly never noticed it sounding ROUGH. I'll admit it may sound "strained", though. However, it's getting the job done. If I'd wanted the sedan primarily for ACCELERATION, I probably would've gone with the Chrysler 300 (or later Dodge Charger) with the V8 Hemi. I test-drove one of the Magnums early on. I originally got a Freestyle, and that's what led me to eventually get the Five Hundred, as well. While the Magnum (and 300, I drove one of those, too) certainly elicited some visceral excitement from the torque and HP, in the end, the Five Hundred and Freestyle were more than adequate for what I needed the vehicle to do. And they won out in other areas. Primarily the ride height (I don't think any of the sedans can compete in that area), and also with the smoothness of the CVT.
    It's TREMENDOUSLY better than the transmission they had in the Taurus with the same engine. I'm sure the engine sounds about the same at high rpm under load . . . however, the newer vehicles do have better sound isolation . . and I think the road noise from the Pirelli tires on the 18" wheels also helps in that regard. :surprise:
    To me, the smoothness is really more a function of the transmission. I just haven't noticed any roughness in th ENGINE itself worthy of note.
    From a purely MARKETING perspective, I can't disagree. From a PRACTICAL standpoint, though, I don't see that much difference. Not to say that I wouldn't have opted for the more powerful engine had it been offered at a reasonable price, though. Also, I think it's a testament to the design of the Duratec 3.0 that it CAN still be used in a car over a decade after it was introduced. But it's always needed a better transmission than Ford gave it, and the CVT is just what it needed, IMO.
    Actually, I'm quite sure there ARE some 4-bangers out there that can out drag-race me. But in significantly lighter vehicles, probably. And/or they have a super-charger or turbo-charger.
    What I really worry about in the power department, though, is whether the vehicle can safely merge onto an interstate with a reasonable acceleration lane. Some around here (especially in construction areas) would demand a MOTORCYLE to really be safe. Also, the vehicle needs to be able to "get up and go" around cars that are travelling too slowly on the freeway.
    What I do NOT have to do, though, is to be able to out-race everybody that wants to race. I'm perfectly willing to let those drivers go by me. I'm pretty happy with 10mph or so over the speed limit. Anything much faster than that and I worry more about speeding tickets than whether I can pass the next vehicle out there.
    I will say that I tend to drive alone or only with 1 or maybe 2 passengers, and it's certainly NOT hilly around here (or most places I travel). So, I can't comment on how the car would perform (or not) with a full load in a mountainous region.
  • tjc78tjc78 Member Posts: 17,823
    "Also, I think it's a testament to the design of the Duratec 3.0 that it CAN still be used in a car over a decade after it was introduced"
    It's that thinking that is KILLING GM and Ford. You just cannot keep putting these old engines into new body designs. It just doesn't work and is not keeping up with with the foreign brands. I for one, am glad that Toyota is phasing out their 3.0 / 3.3 great engine, but over 10 years old now. The 3.5 is so much powerful and gets better mileage. Why can't the American brands get this??
    And basically unneeded, IMO (see above posts).
    Well, they ARE now putting the 3.5L into the Five Hundred. How much that'll actually help, though, is another story.
    I'd LIKE to think that the demographics for sedans of this size/calibre aren't buying based on HP/0-60 times as a main criterion.
    Then again, I almost fell for it when I decided to test the Magnum and 300. :surprise:
    Ultimately, though, I strongly suspect that I'll be keeping my Five Hundred and Freestyle much longer than the typical buyer of foreign large sedans (or that matter, American sedans). And I just as strongly suspect that I'll still be passing by cars loaded with all that extra horsepower on a routine basis. I'll spend less money up front, pay less in insurance, and by keeping the car longer, end up with a much better cost per mile driven. All in comfort and enough "oomph" to fit my needs.
    Ultimately, that's what counts, I'd say.
    I'd also like to think that with current oil prices, that people would start to wonder just how much more efficient a new 3.0L would've been, and how that would help our predicament. Of course, maybe I shouldn't worry so much about it since I'm in the business of finding and producing oil and gas. :blush:
  • tinydog1tinydog1 Member Posts: 83
    Before I purchased my Azera, I was considering a 500. The dealer let me test drive a fully loaded Limited AWD (CVT) 3.0 for the weekend.
    I live in a very hilly area. The on-ramp I take every morning is straight up a hill and I need lot's of power for
    merging. The 500 just didn't have it. The engine was rough, unrefined and extremely loud. Revving to 5,000rpm trying to climb that ramp. I promptly returned the car to the dealer and even after the dealer offered another 3k off the price, I still said no thanks. The Azera makes that same climb at 2,200rpm without as much as a whimper, shifts so smooth I often have to look at my tach to see if it's shifted. A smooth, quiet rush of power that after 1 year has yet to dissapoint. :)
  • rpfingstenrpfingsten Member Posts: 154
    "You just cannot keep putting these old engines into new body designs
    Well, they ARE now putting the 3.5L into the Five Hundred"
    " And yet GM is determined to stay with their old 197 hp engine in the Buick Lucerne.. I drove a 98 Regency Elite with this same engine, and while it was a good "steady" engine, I can tell you anytime you were facing hills, you could feel the engine strain. Of course GM is offering the Northstar V8 but it will cost you an extra 2 grand. Costly but Necessary if your gonna drive this car. ( my opinion )
    Roland
  • gamlegedgamleged Member Posts: 442
    "The Azera makes that same climb at 2,200rpm without as much as a whimper, shifts so smooth I often have to look at my tach to see if it's shifted. A smooth, quiet rush of power that after 1 year has yet to dissapoint."
    Very well stated, and equals my Azera experience for a little over 4,300 miles since I took delivery in mid-November!...
  • fannibalfannibal Member Posts: 23
    I agree as well. I have about 2000 miles on my azera, and It is indeed a very nice car. silky smooth and all. When I shopped around for the car, i could not find a reason to pay 5-6k more for an avalon. I did not try any american cars, but from the sounds of it, i didn't miss out on much.
    Not quite sure where you were going here. Yes, the 500 finally gets a better engine after a few years because it can't compete. My point was that if Ford would have introduced it with the 3.5 things would have been much better (and there may be a 500 in my driveway). As for GM, both powertrain options in the Lucerne are outdated. Anyway, we have traveled this path before. Some people prefer the older designs and some of us like the high tech powertrains in the imports.
    so maybe we can agree:
    Avalon/Azera/Maxima = exceptionally powered = competitive
    Lucerne 3.8/500 3.0 = not exceptionally powered = non-competitive.
    tinydog's experience/comments 500 is exactly how I felt about the 500 and mirrors tjc78's opinion that 'Detroit's' continued habit of foisting ancient technologies on an increasingly saavy buyer is really what the problem is. Do you think, for a minute, that it does Ford any good to have to discount their cars an extra 3 grand just so tinydog, for example, will consider a car that he feels is unsafe as he struggles to get it to merge safely on a highway? BTW, Ford can make whatever claims they want on the 3.5, but you will have no chance of finding that engine in the 500 today, and suggest that even if it is an improvement it may be awhile before can get rid of whatever 3.0s they have left and/or the UAW allows them to shutdown the plant that builds them. Don't hold your breath.
    Toyota has had, for years, wonderful 3.0 and 3.3 liter V6s orders of magnitude smoother and quieter than any DT ever thought of being. But instead of resting on their laurels, they go ahead and come up with a completely new engine easily sufficient for their new Avalon and soon to follow Camry as well as many many other things. Why, because they understood they HAD to - 200 hp is just not competitive in 3500 lb. large sedans. The result, of course, is an engine that is not only class leading but one that also saves Toyota hundreds of millions a year. It does sometimes take money to make money - something GM/Ford don't have.
    I have no beef (or experience) with the 500, and it may be very "adequately powered". If I was trying to make the point you are trying to make, it wouldn't include the word "corvette". Your statement makes inference that the 500 can beat a vette, as can be seen by all the flack you received.
    PS: I'll race you for Pinks !!!
  • joe131joe131 Member Posts: 998
    You must all realize by now that barnstormer is just having tongue-in-cheek fun with you about the 500. It was obvious to most in the beginning, but by now you'd have to be about room temperature to not get it.
    (and an inference is drawn by the reader; an implication is made by the writer)
    Sounds like poor road design, to me. ;)
    Fortunately, I've never had to live with anything like THAT. So, I can't comment.
    Competitive how?
    Clearly I found the 500 to be competitive, and even the winner. As have others. There ARE other things that matter in buying a car than 0-60 times and horsepower.
    Suffice it to say, I love the CVT and the ride height of the 500. Couldn't find that in other sedans.
    Busted! ;)
    I still stand behind my (carefully worded) statement, though.
    And it WAS stated to make a point.
    If one HAS to win races, then the 500 isn't the vehicle for you.
    All I can say is that given where I drive and my driving style (which I would classify as fairly aggressive, but not overly so), the Five Hundred was more than adequate in the acceleration department.
    I really did consider the Magnum/300 initially, driven primarily by my "mid life crisis", I suppose. :blush: But it only took a few test drives to realize that while the Hemi V8 left a great impression in the seat of the pants, there were other factors that were far more important to me.
    Anyway, I mainly object to the pejorative term "underpowered" when applied to this vehicle. Granted, there MAY be some places and applications where this is so. If you've got an on-ramp that goes straight uphill, maybe it's not enough power. I'd be more likely, though, simply not to live in that particular location. ;)
    Is there any model-by-model comparison chart on that? I mean the height as experienced by the driver, the driver seat height (or range of adjustment). With the Azera, I find I just sort of move sideways into it. By comparison, when I last got into my old '90 Accord, it felt like I was dropping into a pit... :surprise:
    Competitive how?
    you are obviously missing the point and have never driven any of these cars or otherwise you'd understand - it's not a HP or acceleration contest as very few of us that own sedans like this are going to race anything (especially Corvettes) - its competitive or non-competitive in respect to overall drivetrain (and correspondent overall vehicle) refinement in combination with the better safety you also get with a vehicle with more power.
    actually I'm happy that you are satisfied with the 500 - as I have said in earlier posts it is a well designed car in many respects - but not for me - I do have this thing about enjoying driving - at least occassionally.
    if I may - the 500 is maybe 3 or 4 inches higher off the road (drivers seat ht) than most of the other cars in this group - a result of some design work by Volvo. While that may not sound like much, it does make a lot of difference, as we strain to see around other cars and in some cases smaller SUVs.
    Good point captain2, it's really not all about HP or accelerations. I personally would love my car to effortlessly go 85-90 mph (at below 3000 RPM) instead of hearing the engine screaming and struggling. Also, when I heavy foot the gas paddle I would expect to see the tachometer needle races to redline instead of it tumbles and tumbles to it.
    That's how I'd describe the 500. I'd be a bit surprised to see that the Azera has a similar ride height, but I could be wrong.
    you are obviously missing the point and have never driven any of these cars or otherwise you'd understand,
    But I *do* understand, since I've driven other similar vehicles to the 500.
    I haven't had any complains in that department, either.
    I like THAT benefit of it, as well. But mainly, I like how I can just "slide over" into the seat of the Five Hundred and Freestyle. I'm not sitting down into the vehicle (like most cars), nor am I climbing up into the vehicle like most truck-based vehicles.
    I believe I'm at 72mph when I'm at 2000 rpm. That would put me at 2500 rpm at 90mph.
    I don't really notice that. Then again, I normally have the ipod or XM playing. ;)
    When I "floor it" (not ALL that common), the tach races VERY quickly up to very high rpms . . . with little to no hesitation. I'm not sure how the non-CVT transmission responds to that, though.
    Uh...Engines don't work that way...
    Test drove a Fusion with 3.0 DT before, no contest with the 3.5L 2GR-FE in the Avalon.
    If you're locked in a given gear it does work that way. (I'm assuming constant speed, not acceleration)
    If you don't believe ME, you can see for yourself:
    http://wahiduddin.net/calc/calc_speed_rpm.htm
    All you need to calculate the vehicle speed from rpm's (under the conditions above) is to know the gear ratio and the tire radius.
    Obviously, more HP will result in faster acceleration. You were testing a vehicle with a typical automatic transmission, though. If it's anything like that on the Taurus, you probably experienced a significant lag before the transmission decided to downshift. That lag is basically non-existent with the CVT.
    all the cars in this group TMK will turn something around 2000 at 70 - the Avalon FYI 2100. 4 bangers traditionally closer to 3000, V8s slightly less than the 2000 - as such any of these cars will normally operate in a cruise mode between 1500-2500 rpm (in high gear) at normal speeds, and will not be especially noisy or rough at cruise - the 500 and Lucerne included. The difference is what happens when you need or want a more sudden speed change - let's say passing that semi on a 2 lane highway and you need to get from 50 to as much as possible as quickly as possible - how well the car accomplishes that task and how it sounds and feels doing it - that would be among the primary differences between those cars I'm calling 'competitive' vs. those I'm calling 'non-competitive'.
    these have been around for years, primarily in Europe, in economy cars, and do allow for some mechanical efficiencies that the traditional geared transmission doesn't - one of the reasons why, for example, that the new Altima can pick up a couple of mpgs despite a HP increase. The reason, I guess we haven't seen them earlier - problems in use in higher HP engines (higher torques) and also with correct operation in low temperatures. TMK Nissan has not had any serious problems with CVTs in the Murano and nor has Volvo/Ford in their applications. But, given the newness of the technologies used, still think that it is way too early to declare them a success.
    It is an unusual sensation to drive these things, the engines 'sets' at a specific rpm relative to your throttle pressure (requiring a computer to decide how fast you actually want to accelerate) and then the car seems to 'catch up' as those gears continuously change, road speed increasing as engine speed remains somewhat constant. There is generally no gear change 'bump' as you would expect with a taditional auto (or manual) tranny. Some drivers will like it, others won't, but if you can visualize a 10 speed bike that has a cone at the rear wheel instead of those sprockets and the chain moving up and down the cone any position it wants - that would be the principle (oversimplified a bit).
  • patpat Member Posts: 10,421
    I think that's a perfect explanation! :)
  • quietproquietpro Member Posts: 702
    I believe the theory behind better acceleration and economy is that the transmission can dial up the optimum gear ratio for maximum acceleration power from the engine (horsepower) and then, once cruising, can maintain the optimum RPM for economy.
    Depending on the reliability of this technology, I see it making the newer 6-8 speed automatics obsolete. Why settle for 8 speeds when you can have virtually infinite speeds (within the operating range of the engine/tranny). I would miss the shifting, though, so manuals may make a comeback (or heaven forbid, those old fashioned four speeds). :)
    I feel that OTHER things are a lot more important than this. I don't mind the car being at 5000+ rpm in such cases . . as long as it can get the job done. For me, the Five Hundred gets the job done well, and it feels fine doing it. One could ask for lower rpm's to decrease the noise, I suppose . . but that's not critical in my decision-making.
    It is an unusual sensation to drive these things,. . . Some drivers will like it, others won't,
    I honestly can't figure out why some drivers don't like it . . it's how an automatic transmission *should* feel, IMO. I've always felt that automatics should be smoother than they are, and that they have too much lag when you stomp the accelerator, resulting in unpleasant shifts. The CVT solves all of that.
    It's also interesting to get the car in a mode where it's actually still accelerating but the rpm's are going DOWN (on a flat road, too).
    Can't say that I have a whole lot of argument with you here - but it is not the traditional rev-up shift/rev-up shift experience that we all grew up with. Would guess that the folks out there that really don't like it as those that prefer the manual tranny and the control over the driving experience that the MT allows - but I'll agree with quietpro, if the CVT does prove out to be a durable and reliable alternative, the multiple speed AT will become a thing of the past.
    Gee, wouldn't it be funny if the CVT proved to be the technology that replaced the traditional torque converter equipped automatic transmission, while at the same time allowing the true three-pedal manual transmission to soldier on? Personally I don't see that happening, however, I've been wrong before. :blush:
    Best Regards,
    Shipo
    well there are the automated clutch DSG systems already available in some German cars?
    Yeah but DSGs and SMGs are just fancy automatic or semi-automatic transmissions. I was referring to true manual transmissions.
    Best Regards,
    Shipo
    I think he mentioned even 8 and 10 speed transmissions.
    I would think that with THAT many gears, the benefits of the CVT would start being diminished. The main thing, IMO, would be how the transmissions were programmed. If they still "hesitated" and then chose a gear significantly away from the current gear to go into, that wouldn't work all that well. But, if the gear ratios are as close together as a 10-speed would allow, I'd think you could probably program the transmission to shift between each subsequent gear to smooth things out . . instead of just jumping from a high gear to a low gear after some hesitation.
    Still, the concept of a CVT seems so simple and elegant to me, that I wonder why it wasn't chosen years ago as the de-facto standard for automatic transmissions. I can't hel but think there must've been some sort of mechanical limitations as a reason for it . . or exhorbitant cost differences.
    I learned on a "three in the tree", and while I can appreciate the benefits of a manual transmission, I can't imagine having to live with one all the time as my main vehicle.
    My old '77 Accord was a 5-speed manual, and I liked it well enough... except in stop-'n-go driving... :sick:
    I am of course on the other side of that argument. I started driving manual transmissions in 1977 when I lived in San Diego, and since then every car that I've had has been equipped with a manual transmission. Please understand, in every case I overtly sought out cars with a stick shift, in spite of the fact that I've lived in the metro areas of Los Angeles, Atlanta, Detroit, Cupertino, Chicago, New York and now Boston. Needless to say, I'm very well aquainted with heavy traffic, and from my perspective, "I can't imagine having to live with an automatic all the time as my main vehicle." Errr, well, actually I can imagine it as for the first time ever my company vehicle isn't a car, it's a minivan with an automatic. Ugh. I cannot wait to get back into a car with a stick.
    Best Regards,
    Shipo
    Precisely.
    Or in other words, it's great to shift when you WANT to . . but not when you HAVE to. :P
