Honda Accord High Mileage Success Stories
Suggestions: (1) go to Consumer Reports and read ALL about buying a used car (2) Find an honest professional mechanic - there are many - but one that work on Hondas. (3) Look at cars being sold by individuals such as your neighbors, fellow workers or students - and non dealer, private party Ads in the newspapers. Beware of Street Wholesalers who are pretending to sell their "sister's" car. You can tell them apart from private parties because their cars are too clean, too polished and you can eat off the engine it's so clean.Also the brake pedals are worn at 28,000 miles (impossible in reality) and the odometer was broken and he has replaced it. Plus they push you. (4) Look at a bunch of cars, pick the best and take it to the mechanic - he'll charge a reasonable fee to check the car out. The seller won't let you take it to a mechanic? You no buy car. (5) Check all the online price books and find out what Kelly Blue book thinks the value is ... check four professional sources. You get a price bracket for the car - that in turn sets up your offering price. And, one last thing (you'll probably have done all this anyway) buy a short term CARFAX subscription. A beautiful, "one owner" car I almost bought had in fact been owned by a rental company, been leased twice and been passed around to three dealerships. CARFAX saved me thousands. Good Luck
One thing that i've noticed is that using the RainX type of windshield washer fluid really helps when it rains, that i don't have to utilize the wipers nearly as much. The rain just beads off of the windshield.
I would like to find a new driver's side carpet mat that is reasonably priced. Honda would rather sell a set, versus just one mat. Perhaps a junk yard may be the place to find it.
I wanted to top off my coolant recently and compared the various types of coolants available. I found myself walking out of a store recently and seeing someone else adding Prestone to their Honda, for which i suggested there may be harmful silicates and borates in Prestone that could reduce the life of a Honda cooling system and water pump. Thus at that point i knew that i had made the decision to visit the Honda dealer, to buy coolant made specifically for my Accord.
Per the discussion of heat under the hood. When i stop to buy gasoline, i always raise the hood, not just to check fluid levels, yet also to hopefully let some of that heat dissipate. Thus i keep the hood up till i'm ready to drive off.
Wow! My 03 V6 only has 56k right now. Have you had any problems with the car? How often have you had the transmission fluid changed? It may be a look into my future.
I've had to replace the air conditioning core and also get a new power steering pump. Living in the Southeast where it's mostly hot, one uses the air conditioner year round. I've been driving Honda's since 1986 and getting 200,000 plus miles on each car, yet this is the first one that i had to replace the power steering pump.
I purchased the accord EX 4cyl 09 last week and in my first tank, which is about 3/4th empty now, I got a mileage of about 300 miles. 80% interstate. Do you think that the mileage might increase in the near future or is thr a way to tune up to give better mileage?
99% highway and we get 33-35 mpg. This is figuring it by dividing gal into miles not using the computer on the car. The cars computer is alway 3 less and shows 31 mph. It took about 15 k to break past 28..
Oh never had a single problem
A little bit prior to 11/24/2008, 122,566 miles, the check engine light went on in my 2004 Honda Accord EX Sedan Auto w/ Nav. I took it into the dealer and was told it was my Canister Shut valve. I heard mixed stories on what led to it, with one service manager saying that there was nothing I could do to replace it, while another one said that I should have been doing the fuel induction service (something not mentioned in the manual) every 30k miles. The estimate to do this was $410 (including the cost of the oil change - minus the cost of oil though because I brought my own Mobil 1 5w-30 in). However, thankfully I had some random $100 off coupon which had actually expired but they still took it. So my final cost was $319.83 to replace the canister shut valve and oil change.
I wrote a letter to Honda customer care saying I was a bit annoyed with this if it could have been prevented. They called me back and said though the fuel induction service isn't mentioned in the manual, I should listen to what the dealer says specific to my area. Anyone have thoughts on the fuel induction service?
With my car now at 122,566+, I still need to take care of the big ticket items it's due for such as spark plugs, transmission service, and coolant. I'm thinking of emailing the dealers around the area to see if I can get the price low. I have the 120k service in general due, but I'm planning on doing the cabin and air filter myself to soften the blow. Usually, I try to get everything done at firestone since most of the service is just inspections.
I would like to find out what others use to clean the cloth upholstery and seatbelts... thanks.
I need to use a scrub brush on some stains but this stuff is great.
