Tahoe Suburban CD MP3 iPod AUX XM Sirius
What a collection of acronyms!
Got a question about your radio (remember those)? Tune in here.
Collins
Collins
Here's a link to the Belkin product:
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=149006
See link below:
http://www.tentechnology.com/products/products_flexibledock.php
Have fun and enjoy your Tahoe! So far so good with mine. Like it better than my Land Rover!
See my profile for pictures.">
http://www.smartpark.net/usa/iConnect_11feb06.pdf
http://news.yahoo.com/s/nm/20060803/tc_nm/apple_automakers_dc_3
here it is....enjoy
http://www.thesourcecc.com/estore/Product.aspx?language=en-CA&catalog=Online&cat- egory=ipod_car&product=1419577
Anyone know if there is a radio exchange program through GM or Delphi to upgrade radios? I know there was 15 years ago when I was at a GM dealership.
for example, when i press the catagory button, the radio says "for xm use only" or "xm not installed" or something like that.
my questions is, is the xm radio different than the stock non-xm radio, or is there a card or chip or component that can be installed aftermarket to take advantage of xm?
i understand that xm is a subscription, but didn't want to pass on the truck just because the option wasn't included.
if the xm is a completely different radio, i will buy a portablw, but if it can be installed as a feature on the current radio i will have it installed.
Just bought a 2004 z71 yesterday and put two cd's in the 6 cd changer and they didn't play. I have tried to eject them and I get a message that says no disc and I cannot put any other discs in. Apparently the light to the right of the changer is supposed to blink and turn green before you can perform a function. The light never blinks. It seems it is not working at all. Anyone else have this problem? If so, can you offer some advise.
Now if you send the XM audio signal to the head unit via a FM modulator (built-in or another module), the weakest link is this FM modulator. Even if it is perfect, you will lose some fidelity (15KHz vs. 20KHz). In addition, FM modulator route has limitations of FM tuning for car (roll off trebble and cut down on stereo separation to reduce noise) when the FM frequency you selecting is interfered by local FM stations (of same frequency is adjacent to it). This Audio - FM - Audio process adds noise and causes degradation.
Direct audio connection is again the best for Audio fidelity. For your 07 Yukon, it has the Aux audio jack. So in theory, it should be as good as your 04 system.
jt
GM XM receiver is a remote box located in the trunk or under seat,..Most, if not all GM radios are XM compatible regarless if you opted for XM or not. So there is no difference between the head units. Even on Bose/non Bose option, there is only one head unit. Everything is connected thru. the vehicle bus (GM Lan) that tells the radio if it has the XM box or Bose amp attached to it. It will configure accordingly
The nice thing about having XM compatible head unit and GM XM receiver is XM is now part of your radio band :AM/FM/CD/MP3/XM. The head unit now can integrate XM with other modes. You can also control XM, save XM station presets, audio settings like you do AM/FM. I do not know if there is an aftermarket XM box that is compatible to GM vehicle (control functions)
You could also use your portable XM receiver. But you can only use it in the Aux mode just like you do with MP3 player (ipod) by plugging its audio cable into the Aux jack. It is again, Audio interface only. You can't control XM portable unit from your radio. Radio does not care if it is MP3 player, CD player or XM receiver. It is just an external audio source.
jt
I know with the last gen trucks (we have an '04), the BOSE system is generally thought of as not impressive at all, and for the most part, a lot of the regular base Delco standard systems offered in '02 and earlier models even sound richer to a lot of people. Case in point, I still think our '02 Avalanche with the standard Delco pieces sounded better overall than the upgraded BOSE system in the '04 Suburban.
But I digress. Has anyone compared the stock system in a new '07 back to back with a BOSE upgraded version? Again I've heard that the BOSE is not that spectacular, but I've yet to see anyone with an LS or LT1 Chevy (or SLE GMC) model mention much about the standard non-BOSE in comparison.
Anyone able to comment on that?
I know i consider myself fussy on sound and that was the major dissapoint for me with the 4runner...
The only major bug is the ipod.....i use the monster cable that connect to the base and sometime i wich i could put the music louder!!!even at max some song aren't loud enough...when i want them loud!!!!
XM radio is the best thing that happen to me...even my wife miss it now with her van...i mean...no ads...no talking...just music....and maybe it's just mne but the sound quality getting better...before i found that the major channel (80's-90's... and top 20 etc) had crystal clear sound but other like fred underground and boneyard were less clear....to the point that i didn't listen to them anymore....but i found out recently the the sound is much better now..on par with the other channel....
:P
Bandwidth is not an issue because the the signal is a digital stream. Actually, the "channel" bandwidth is quite narrow. That's why they can fit so many in.
Can you change songs with the steering wheel controls? Or use the nav screen to select a song?
Audio control: Use the audio knob of the radio or the shafts on the steering wheel. You cannot control audio using the iPOD steering wheel.
Other features (change songs, brightness, etc): only with the steering wheel of your iPOD.
Sound quality is great!(because it is a direct audio connection). Now I don't carry CD's and barely listen to the radio.
I do remember reading in the owners manual that anytime that you disconect the battery, prior to doing it your suppose to enter a security code to keep your radio/cd player, etc from locking up. I've personally never done it and I guess have lucked out because my radio never locked up on me, at least not yet. Hope that this gave you a little help.
New GM radios now make the "Turn Signal" sound along with Seat Belt chime. Everytime you turn on any of the related functions, the radio is told to make the sound accordingly. So when you put the original GM radio back in, you will have these functions back.
jt
One thing you could try is to reset the radio head by temporary disconnecting the battery power to it (removing/reconnecting the fuse(s)) when the radio volume disappears next time. The battery disconnection/connection gives the unit a cold start and often can fix "brain dead" problems. I used that on my GM minivan once or twice a year when its body computer hangs up and does not operate the power sliding door.
jt
If it is just the radio, is it both am and fm, or any and all stations?
I had a little bit similar problem once years ago with a Chrysler mini-van, I took it in and they ordered a replacement radio. Never had the problem after.
I am from GM Customer Service. Can you please email me more information about your concern, so I can look into the situation further? You can get my email address by clicking on my name. Thank you,
Mariah GM Customer Service
