Honda Accord Audio Questions
Let's talk about your iPod, MP3 and other audio questions here.
I also searched the web and found these adapters:
neo iOnAux
Dice Electronics
USA Spec
Reviews
Review of iPod Adapters
Review of Neo iOn
Does anyone have experience with any of these?
Kelly
(P.S. - using the URL tag under the post box will prevent that problem with longer links.)
USA Spec iPod Adapter
Does anyone have any experience with this? Do you have installation tips that may help me avoid damaging my new Accord?
Kelly
http://www.logjamelectronics.com/sounsnhond3.html
Try this navigation pass-through "Y" harness for Accords with factory Navigation systems:
http://www.logjamelectronics.com/piehon03fmm1.html
Alpine VehicleHub Pro
Kelly
Kelly
If you think that you have a problem, you should visit your dealer's service department under warranty. You'll probably get better service there if you don't use the word "suck" when speaking with the service advisor.
The reason I generalized my question is because I've read in other Honda forums that the window embedded antenna doesn't work that well. I know the Accord hybrids come with a traditional antenna, so I don't understand why Honda would use a less-than-effective solution in other Accords.
I suspect that if you live in an urban area with stronger signals, it is fine. It's on the weaker signals that it doesn't seem as good as other radios I've had.
http://www.beaufordbuddy.com/ipod_install_1.htm
Unfortunately, it's very expensive, requires a lot of add on interfaces, and probably should be professionally $$$$ installed.
Kelly
Steve Vigneau Review
Gizmodo Review
Here's what I'm considering instead: USA Spec
You've not indicated what your model year or mileage are. Is your vehicle still under warranty?
Make : HONDA Model : ACCORD Year : 2003
Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.)
Service Bulletin Num : 204 Date of Bulletin: FEB 16, 2004
NHTSA Item Number: 10014250
Component: EQUIPMENT
Summary:
IN VEHICLE ENTERTAINMENT SYSTEM DISPLAY PROBLEMS. *NM
Check to Request Research. Submit below.
Anyway, same deal with $800 from the dealer (+/-). Instead, I took it to a local audio shop that did repair work. For IIRC $100 they fixed it. Turns out that there were some broken connections (welds I gues) on the circuit board. They soldered them up, and it worked fine for the next year+ that I owned it.
Not sure what the problem with the Accord is, but you might be able to go this route. I don't recall hearing of anyone doing it though (on the other Honda dedicated boards) but I haven't checked lately.
i'd try it out but have no cdrw on hand.
I've never had that occur.
The FM is obviously not as clear but it is much louder.
Mrbill
An aftermarket stereo is likely to get stolen eventually and doesn't fit the looks of the car anyway.
Set up some playlists on the iPod so you don't need to keep messing with it and searching for songs while driving.
Other people have said good things about USA SPEC; some recommend Harman Kardon's Drive & Play. I understand that Honda offers a "Honda Music Link", but reviews on that have been mixed. There is an advantage, however, in having something that Honda would install and guarantee. What I'm looking to do is simply to be able to select playlists from my iPod and play them over the car stereo, either as is or in shuffle mode. What would be the best way for me to go if this is all I need? Thanks for your help!
The Music Link isn't worth the money because the functionality is so poor, so Honda guaranteeing it is no great benefit.
I usually have it on shuffle mode, so if a song comes on that I don't want to listen, I just flick the chan button and move on to the next one!
It also has extra aux inputs so you can plug another music source (like a protable sat radio unit) into the box and run it through the aux port.
With the ipod, it also connects into the dock port, so it charges as you go, and will automatically stop charging 30 minutes after you shut off the car.
ANd best of all, no more static, and looking for an FM clear signal (not many of those around NYC!)
