Visitor Agreement.
Regards
Bert
Regards
Bert
My big reason for wanting a replacement wrench is it's use as the crank for the jack. Even though the head is broken, it will still work in that capacity.
I have done this job on my own 02 Axiom and it was not hard. Two bolts for the rotor; 2 for the caliper/pad assembly. And, you WILL need air tools to do this job, as these bolts don't come loose easily. Other than that, it is no harder than any FORD or GM rotor replacement or pad replacement.
Here is an excerpt from the 02 Service manual that will guide you thru it. You might want to search for the 03 Service Manual online. It is pretty inexpensive and is in PDF format. You pay them for the manual and download it. I have used mine again and again and it pays for itself.
Pls. download this PDF file in the next day or two. The steps for the 03 should be identical to the 02. File is located here:
http://www.vivagen.net/Docs/2002_Isuzu_Axiom_Service_Manual_pg717.pdf
Hope this helps you.
You might as well take the drive shaft out.
Regards
Bert
:mad:
Regards
Dautlas
It's quite a complicated system with lots of sensors and devices and connections and two computer modules controlling it. By the way, you can buy a similar manual yourself online for your 2004 Axiom in PDF format as I did for less than $20.
Just looking over the chapter on TOD, I see that there is lots of room for potential problems in your TOD system - some of which might even be covered by the Powertrain Warranty. For example, if your front speed sensor was bad, it might cause the lag you are referring to.
There are also diagnostic codes that you can access via an OBD2 connector that will tell you if your TOD system is functioning properly in the first place, or possibly posting errors.
I love to tinker with stuff myself, but at first glance, this system looks pretty complicated, even to an engineer type like me.
So, my suggestion, is to find a qualified dealer who can take a look at your system for you and find out if there's a problem. Barring that, if you are going to experiment, you need the full service manual and 2 days to pour over how this works and even that might not really be the right solution.
I do understand your problem and your frustration though.
Hope this helps.
"The rear wheels spin in the TOD mode, so the driving torque is not transmitted to the
front wheels. The indicator lamps will not show the 4L and TOD status."
Please advise and provide any EXTRA details, such as specifics on lamps lit or trouble codes if you have them.
Or just get the manual and check out the TOD chapter. It's ALL in there and if you have a digital voltmeter and an Isuzu Tech 2 reader, and some auto repair skills you can pinpoint the problem without the dealer.
Regards
Bert
But this whole thing of the rear wheels switching to the front is weird. The TOD will switch torque on the same "axle" but shouldn't switch rear to front.
Call the Isuzu service department a Zimbrick in Madison, Wisconsin. And describe the problem to the service manager. He won't know where you are calling from and he should be able to tell you if this is covered under the warranty and may have an idea as to what the solution is. It's only a short long distance call and you may get a helpful answer.
Good luck
Bert
They have good stats on HP & Torque but some "experts" at certain consumer sites completely missed out on what a LEMON this brand is. You have to be BRAIN DEAD to buy anything made by ISUZU. Sorry but this is coming from am OWNER and RESEARCHER who knows that ISUZU is company that is better off dead.
And many have reported problems that should never have happened in the first place, while Isuzu as a manufacturer has stood by and done nothing. I am talking about brake problems, frame rusting problems and transmission problems - these seem to be the big 3 problems that are costly and that many experience.
I've had brake problems galore and documented the fixes here... but have been lucky on the tranny side and have seen no problem with frame rusting (knock on wood). And, I know folks with other Isuzu models (Troopers for example) that have owned them for over a decade and have over 200k miles on them. My Axiom has just crossed 100K mark.
So, I started looking for a replacement vehicle that had similar stats (interior space, features, mileage, etc.) and I had a hard time finding one. The top 3 contenders were the Honda Pilot (which was rumored to be made by Isuzu - I am not sure if this is true), the Dodge Nitro (which has had lots of odd problems, including tranny issues, and has lower mileage), and the Toyota Highlander (which is probably part of the most recent recall for gas pedal issues?). My friend swears by his Saturn Vue, but GM doesn't make them anymore, and I would never buy a GM anyway, due to quality issues. I went to the Nissan dealership, but the mileage figures and the sticker prices scared me away.
What I am saying is that the Isuzu Axiom, when serviced well and working properly, is a good solid SUV that should get 17-18 MPG in the city on 10% ethanol gasoline. But, if your experience is different, you probably will disagree with this statement.
Since I have had a hard time finding a good replacement for the Axiom that I like, I have learned to appreciate my Axiom more. It's probably not worth much anymore, and if the tranny goes out, I'll be singing the blues for sure, but it's paid for and I intend to drive it until it becomes nearly worthless... or until the recession is over, because I don't have a spare $30K to spend...
"Warning Light Operation
When the ignition switch is in the START position, the
“BRAKE” warning light should turn on and go off when the
ignition switch returns to the ON position.
The following conditions will activate the “BRAKE” light:
1. Parking brake applied. The light should be on
whenever the parking brake is applied and the ignition
switch is on.
2. Low fluid level. A low fluid level in the master cylinder
will turn the “BRAKE” light on.
3. During engine cranking the “BRAKE” light should
remain on. This notifies the driver that the warning
circuit is operating properly."
Also, I found this: "Also,
check the brake warning light. If a
failed system is found, the light
should indicate failure."
Sounds like a major brake problem or brake/ABS problem. I would take it to the dealer and find out what's up. You need a functioning brake system - it's a life safety issue. Post back what you find out.
To be clear, the motor moves back and forth about 1/4 inch as it operates, in a direction towards and then away from its mounting plate (and the firewall). Not sure if this is proper operation for the wiper motor or not. That is, my motor may be coming loose from the mounting plate, OR this may be NORMAL for it to wiggle back and forth as it works the wipers.
Would anyone be willing to pop the hood on their Axiom, turn on the wipers and report back if their wiper motor flexes back and forth, or if it just sits still, WITH the wipers in either low or high position?
Please... this would be a BIG help to me, as the service manual is not clear on either HOW this is supposed to operate, or what happens when the 4 bolts are removed... so I would prefer to leave it alone.... (i.e. "don't fix it if it ain't broke").
Please check yours ">and post back here....
THANKS!
Check out this facebok page
http://www.facebook.com/group.php?gid=187031801231&ref=ts
i was wondering if anyone can provide a picture of where bank 1 sensor 1,bank 1 sensor 2,bank 2 sensor 1,bank 2 sensor 2 are located in a Isuzu axiom 2002???
i would really appreciate the help
There are 4 O2 sensors in the 02 Axiom. I think they are made by Bosch and are pretty inexpensive (~ $70). Changing them out is actually easier than changing a spark plug.
The trouble code will tell you WHICH ONE has gone bad, and then you just buy one and replace it. You can go to Autozone or Advanced Auto Parts here in the US and they will loan you their scan device to pinpoint which one is bad. Then replace it, unplug the battery for 30 minutes to reset the code and you should clear the code and be ready to go (at least this is what I remember from changing mine back around 50K miles.) Anyway, it is really easy to do.
This diagram shows all 4 sensors, although only two of them are labeled in the picture. Hope this helps:
http://www.vivagen.net/pdf_docs/2002_Isuzu_Axiom_Service_Manual_pg1563.pdf
Worse, the motor assembly, which I reported earlier had a big wobble to it, broke a HOLE IN MY FIREWALL, as one of the 4 securing bolts worked a hole in the firewall from the wobble.
We thought we were stuck in Panama City, since it was raining that day. The guys at Firestone clued me in to the fact that I can just buy a bottle of RAINX and use two coats of it and no wipers - which worked great! Meanwhile, the motor assembly is a $200 special order part, and I have waited 10 days to get it from my dealer. It should arrive tomorrow (finally). Will have to take the car to a body shop, as they will need to spot weld to reinforce the firewall! Incredible.
BEWARE OF WOBBLY WINDSHIELD WIPER MOTORS. If yours exhibits this symptom, have someone check it out. This is gonna probably cost me $400 by the time it's all done.
I did some research to find out that there is an Isuzu parts dealer in South Florida that says they can get parts easily. I have not used them, but they do ship to other states, so you might want to make a note of these guys. Also, if you know another dealer in your state that has ready access to parts for Isuzus, and you can vouch for them, please post that here, too.
Here is the source I found (do your own due diligence):
Isuzu Parts
1881 N State Road 7
Hollywood, FL 33021
305-757-0234
THE REASON I AM STATING ALL THIS IS THAT WIPER MOTOR WOBBLE, if detected when the wipers are working and the hood is up, is what appears to have caused the premature failure of my wiper motor assembly and the damage to the firewall when the bracket broke. YOURS COULD BE NEXT, so you might want to check it.
Last, but not least, it turned out that the replacement wiper motor assembly is a GM part. Ironically. In fact, it's the same one used on the 2002 Honda Passport and Isuzu Rodeos. So, I could have bought it online for about HALF the price I paid at the local dealer, if I had just had the right part number. The part number is: 8-97365-748-0, in case anyone needs a new wiper motor assembly.
See it here: http://www.hondapartsnow.com/electrical_exhaust_heater_fuel/b__0310~1998~honda~p- assport~4dr_4ex-l~4at~ka~windshield~wiper~washer.html
And, in conclusion, we may be able to get a lot of our parts at the local Honda dealer if there is a matching Passport part. Go figure. Could have saved like $84.
May post photos later of the broken wiper motor plate, in case anyone is interested.
The body shop supervisor encouraged me to remove the wiper motor assembly myself, as well as the cowl and wipers and bring it to him dissembled, and he would do the welding job, but they actually reinstalled the wiper motor, too, which I was delighted to see.
Finally, I have wipers again!
If you have a really wobbly wiper motor, you might want to have a mechanic check it before it fails. Or you can unplug it, loosen the 4 bolts and pull it away from the firewall about 1 inch (which you can do without detaching it from the main wiper arm behind the firewall, as there is some play or flex there) and check the underlying bracket for cracks (failure). Mine was cracked to the point it fell apart after it was removed. Complete bracket failure at 105K miles. Could it be because it's a GM-Isuzu"> wiper motor?
No really thanks for sharing this as I'm going out to check my wiper motor condition. I'd probably be in the same boat and let it go until catastrophic failure.
Let's see now.........
Replaced Shocks - no more adjustable shocks - Rides Better
New Transmission - Under Warranty - Yeah!
New Fuel Pump and Gas Gauge Sending Unit also Under Warranty - Yeah
113,000 miles and starting to burn oil at about 1 qt. per 900 miles, oh well..........
Rear washer tube/pump shot
Rear wiper arm fell off - Know where I can get another one? Breakers don't have them.
New Calipers and brake pads Still crappy breaks.
Put electric brakes on my welding trailer and brake controller on the dash and when towing the trailer the car actually stops better than it ever did. That's sad isn't it.
Wondering what's next.........................
Best Regards
Bert
Looking at the full Service manual, there are two coil springs on each side, topped with a round rubber insulator. So, you could order new OEM springs from those companies that sell Isuzu parts (see other related postings on that). If you opt to do that, be sure to order the rubber insulator "cap" - referred to in the diagram literally as a "rubber plate", as it would be inexpensive.
In fact in the workshop manual, in the troubleshooting chart for the suspension, for the symptom "suspension bottoms", the service manual lists these 3 potential fixes:
"Vehicle overloaded. Reduce load.
Faulty shock absorber. Replace shock absorber.
Incorrect, broken or sagging springs. Replace springs."
So, if you wanted to add an air lift kit, you could, of course, but the problem could be old or worn out springs, which are almost as cheap to buy as the air lift kit (although probably more difficult to install).
Finally, if you want to buy an air lift kit, they are available for the Axiom. Just Google "Isuzu Axiom Coil Springs". I found three different websites that sell air lift kits for Axioms with that search phrase. There may also be companies that sell add-on stiffeners.
Hope that helps.
Regards
Bert
And, the irony is that it wasn't that hard to do either. Only took about one hour to do, too. Time to celebrate!
By the way, I now DISRECOMMEND that place in Hollywood, FL for parts. Those guys are a ripoff. They quoted me $147 for a seat belt assembly without shipping. The list price is $127, and it was about $102 at Scarff Isuzu. With shipping about $115 delivered.
Anyway, I am thinking I could have just lubbed the original one. The seat belt assembly appears to have merely gotten gunked up with dirt, dog hair and the like. I thought the retractor spring was bad, but now I think that the Service Manual is wrong and you can clean/lube the original OEM belt retractor and get it back like new.
The instructions that came with the new one were unreadable, so fortunately, it is will documented and illustrated in the Service manual. If you opt to try to do this let me know.
Also, I will be cleaning, lubing and retesting my original seat belt assembly next week, and posting it on Ebay... it seems to work fine now that I spent all that money. Hope this benefits others, with sluggish seat belts that don't retract, as it is not a hard job to work on one.
The numbers for the Montoe shocks are:
Monroe Sensamatic
37159 Front
37160 Rear
Bert
SENSA-TRAC® TRUCK SHOCK ABSORBERS
37159
37160
Regards
Bert
Here is the posting I made a while ago:
http://townhall-talk.edmunds.com/direct/view/.f0e3b5f/124#MSG124
I'll have to go out and do mine to remember the steps. But it's simple. I think you just push and hold the service button then step through the mileage you want for a service interval.
I'll try later today.
Regards
Bert
The poor guy at Pep Boys ended up cutting off all 4. The tops of the rear 2 and the bottom bolts of the front 2. The rears just because they were ridiculous to get at and work and on the front the lower bolts were rusted solid to the sleeves which pass through the shock itself.
Felt bad for the guy so I gave him a nice tip. Anyway cost me $237.00 including a 50% off labor coupon. Not a bad deal for how much of a project it was.
Axiom rides like a normal on frame suv now. Not as soft as the "Normal" mode and not as harsh as the "Sport" mode.
Went with the Monroe Sensatrac's as suggested.
I still appreciate the better ride though.
Regards
Bert
Sorry to hear about your problem with your 04 Axiom. Based on your description, it sounds like what you are actually talking about is the Anti-theft and Keyless Entry Controller Unit, which as you mention is not a standard item, but an optional accessory. In the Axiom Workshop Manual I bought on Ebay, it is detailed in Chapter 8H-14 on page 1964 of 2100, where it is shown as a small CPU unit, about the size of a small hard drive for a PC, that is located behind the glove box.
Based on a first read of this info, it would appear to be an easy changeout, but I have not studied the details of it. For instance, how you get the new unit calibrated to recognize your key.
Looking at the wiring diagram, it appears that this unit is heavily integrated into the entire starting system, so you would have to replace it, IF YOU ARE TALKING ABOUT THE SAME PCU.
So, one option for you would be to spend the $15 to get an electronic copy of the service (workshop) manual and take a look at this info. If you are a good mechanic and good with electronics and repair, you should be able to do this job yourself, with the caveats already mentioned considered. I suppose you could get a used Keyless Entry Controller from a salvage yard, or you can get discount Isuzu parts from the Scarff Isuzu n Washington state, whose website is isuzuparts.com.
It does not look any harder than replacing the CD changer or installing a satellite radio system. You remove the glove box from the dash, then the unit itself is located behind the glove box, attached with 2 screws and 2 connectors. You remove the old unit, then follow the two pages of instructions to "prepare" or sync the new unit to your key, then install it. Can't see anything difficult about this, and it appears that once again, the dealer is trying to gouge a customer for the repair.
Check with Scarff on the cost of a new unit tomorrow. In the meantime, get the 2004 Workshop Manual - you will need it for the two pages of calibration instructions alone.
