Keith
hrhauser, did you finally get your dead battery fixed, if so how? Thanks.
Good Luck
I guess if it's a diff it'll get gradually louder and eventually there won't be any doubt, right?
It is available, but expensive. 300 minutes for about $100. You can get all of those other cellular providers (AT&T, Sprint, Cingular, Alltel, etc.) to put you in a 300 minute plan with 3,000 minutes nights and weekends for a lot less than that ($40/mo for you and me ... and you have to believe that they get a volume discount, right?). In the IT world this is called a "managed service", they are providing the dial tone, hardware, setup/config, troubleshooting, dancing elephants, etc. But I don't see where the stock calling plan/phone service needs to be a managed service ... of course they see why it needs to be that way because they need it for the base OnStar stuff to work and they can put a premium on the service and have an ongoing revenue stream with a solid margin. (Marketing 101, except they forgot the part where I will probably drop them now as the minutes either expire or are used up.) I'm not going to pay them that kind of premium any more. Of course, even if you don't pay them for any of the OnStar services they may have to keep the system alive. Otherwise, they couldn't use OnStar to repo the vehicle when you don't make the payments. (did you see that in the GMAC financing paperwork?)
I agree that the voice dialing has its problems. I enunciate (nice word, eh?) fairly well and still have trouble getting the thing to pay attention to longer numbers. I end up working around it by going into "store" mode where it is planning on only numbers and doesn't think it heard the "dial" command all the time. Once stored the common numbers are pretty handy in voice mode.
http://www.thecarconnection.com/index.asp?article=4733&sid=192&n=156
So,could someone comment on off road experience? I do not plan on "mudding", mostly hill climbing/mountain trails and beach driving. Any experience in the sand? Thanks for your comments.
Thanks in advance
Any recommendations as to what is drawing a charge to drain the battery?
The vehicle is driven at least every other day for local trips. Could the alarm LED and lo-jack be enough to draw a new battery down within a month?
Thanks for your replies.
Anyone know how difficult/expensive it would be to swap out the standard Denali transfer case with one that has a low gear while retaining the AWD system?
Just an idea I would start with the 4WD mechanic at your GMC dealer and see what they can tell you.
TN Denali Lover!!!
As a quick test, try turning the key to "on" without cranking the engine, the dash message & indicator lights will come "on". You may be able to hear the electric pump in the fuel tank running. After 15-20 seconds, the fuel pressure to the injectors should up to about 50 psi. Turn the key the rest of the way to crank the engine, & I suspect the engine will start quickly. If you have a pressure gauge, you could also check the fuel rail pressure, before starting to verify holding pressure.
This type of problem is not that uncommon, & should be covered by the bumper to bumper, & emisssions warranties. Give this a try & write back. Good luck! Dave.
