Visitor Agreement.
Some fuel pumps are much louder than others. Good luck, both on the test, & on the quieting. Let us know how you make out. Dave
Does anyone know whether most or all moder fuel-injected gasoline engines run such high pressure to the fuel rail? I don't think they did back in the 70's, which was the last time I was paying much attention to such details.
The electric fuel pump is, (should be) much quieter, but still audible if you listen closely. It runs whenever necessary to maintain approximately 50 psi fuel pressure, which is continuously, when the engine is running.
The older GM TBI (throttle body injection) systems of the 80's that you refer to, run at about 11 psi. Tighter emissions & fuel economy regulations led to the higher pressure MPFI, CPI, & SFI systems of newer engines. The higher pressure allows for better atomization & control of the air/fuel ratios.
Hope this helps! Dave
Any suggestions? Anybody else experienced this? I'm about to go back to the dealer again so I can use all the information I can get!
--B
On another note, the transmission started slipping today. I was stopped at a light idling for a few minutes. Hit the gas and all I got was engine RPM's but no go ... finally the transmission clunked and I was off to the races. Looks like I've more than just the alignment to discuss with the dealer now ...
--B
Interestingly, I found a slip in the truck from another shop advising me to immediately add fuel (not more than 20 gallons) and then drive all the way down to an empty tank. 1) They must have farmed out the job. 2) I assume the fill-up then down to empty allows the new components to get themselves worked out properly.
Larry
Also I took this into the dealer and they could not reproduce it. When the car is warm and the climate control fan is blowing from 1000-1500 rpm there is a sound that sounds like the fan blade is out of balance. I hear it all 80% of the time. If you shut the fan off it is not there. I have read past posts about plastic in the vents, I will check. My wife in the passenger seat says she cannot hear it (selecetive hearing). Any thoughts?
This is my 2nd DXL, 2001, 2002. Do you feel that a lot of noises are just because of all teh plastic? I understand that it is cold and that plays a part. Could anyone tell me what is normal creeks and rattles? I have taken everything out and drove it for a few days like that - all sounds still there, so it is not anyhting I have in the vehical.
Sorry for the long post. Please let me know your thoughts. Thanks again.
i thought it was one of the worst (new) cars i have ever driven
there is about 6 inches of play in the steering wheel before anything happens
the suspension is so soft that the car wallows from side to side like a dinghy in a storm and that is at 10 miles per hour, if you ever had to swerve to avoid anything you would surerly lose control
the interior looks like a time warp from the early 80s even the most basic mod cons like sat nav are not even an option
but worst of all was that 6 litre engine it was as rough sounding as a tractor probably has a 0-60 time of 20 seconds and probably consumes more than just about any passenger vehicle on the road
i am not right that this car is a dinasour and that surely its life is limited, as soon as bmw or merc produce a decent 7 seater for $50k this car will be dead
how can all you guys buy such a piece of cr** have you never driven an x5 ?
Too bad Ferrari doesn't make a SUV eh?
As for me, I haven't driven a DXL--I have an '02 Denali--but:
(1) I happen to like the relatively large neutral center on a vehicle of this size. I would not like the steering on such a large vehicle to be as tight as a sports car or sports sedan. It would be tiring on long drives.
(2) I also think that the suspension is well-tuned, soft enough to give a good ride, but firm enough to handle well. My truck does not wallow. If you read trade reviews of the Denali/Escalade duo, I think you'll find that the general consensus has been surprise at how well the truck handles, given its size.
(3) I don't know about the DXL, but I believe I've seen 0-60 times right around and in some cases under 10.0 for Denali/Escalade (better for the Escalade--tuned to put out about 25 more hp), which is certainly respectable for a car this size, and not that much off the times I've seen for an X5 (~8-8.5), given the weight difference.
There is no other vehicle in the class with an engine anywhere near the Denali/Escalade's Vortec 6.0 in power or torque. In fact, one reason I preferred and ultimately bought the Denali rather than a Navigator or a Sequoia was the superior performance.
Lastly, I don't understand the perspective of this post to begin with. No one shopping for a vehicle the size of a Denali or especially a DXL would reasonably be cross-shopping an X5. To compare the two vehicles is just silly, in my opinion, or shows that you are more concerned with owning a certain marque than with getting a vehicle with a certain set of attributes.
What do you drive now, if I might ask?
If it is only a software change anybody know what it is?
The programming may also be removed if taking the truck to the dealer for software updates or warranty work. In fact it is recommended since a reprogramming by the dealer will render your HPIII unit useless and require that you send it back to Hypertech.
you are quite right to compare an x5 and an xld is very silly. i am encouraged by what you said in your review.
lobsenza is also quite right that it is a trade off. what i am craving is an x7 the size of the xld if they every made one. the problem is that i own a 4.4 x5 now (and an 03 911 c2 cab) and i am starting to need more room. i like cars that handle well. i think i drove to xld tet drive in the 911 so that probably made the contrast worse.
i quite like those caneepa deanlis but a fully loaded one costs 130k. i fell off my chair laughing when they told me that.
Personally, if I were looking for increased hp and torque, I would go the supercharger route - a twenty point increase is probably worth only one tenth second reduction in 0-60 time. And you must run premium fuel all of the time.... The supercharger route would yeild 0-60 reductions of around 2 to 3 seconds. (On a 5,500 to 6,000 lb. truck, 2 to 3 seconds is significant.)
The more compelling reason to go with a Hypertech re-programmer is to remove the 95 mph speed limiter. HR rated tires are capable of 130 mph; the Denali can do at least 105 before wind resistance becomes a factor.
If you're thinking of a SC, then forget the HPIII as that would be throwing money away since the SC has its own tuning package.
I'd take any dyno results posted by Hypertech on their website with a grain of salt. TByrne Motorsports did an independent test and didn't even bother to post any difference after the Hypertech tuning....
http://www.tbyrne.com/99silverado.html
Course they sell the Hypertech unit so I can understand why.
(I always pry on my favorite mechanic when I go in)
Handling - Compared to previous generation(and even std Yukon), the Expeditions and Navigators I've driven the Denali is winner hands down. I haven't driven a DXL. I will give the X5 top kudos but it is a different class than the Denali or DXL, so not sure that is too fair a comparison.
Top Speed - Don't tell my dealer but I've cruised at 100mph for a few stretches with no notice of drift, lift or other issues. (Didn't know there was supposed to be a governor on the top speed.)
Power - I'm pretty happy with the 325 ponies; I'd vote for the supercharger package(Lingenfelter also offers a package for the Denali/XL) I don't think going with the Hypertech for only 20hp/20ft-lbs gain is worth the effort. With these big rigs it's the amount of torque that really counts when it comes to making them quicken - that's where the supercharger will really help.
John did two engines for me about 8 years ago. He did a great job, but my Vette was at his shop for two years. I haven't talked to him in a long time and didn't know he had a performance modification for the Suburbans.
Larry
http://www.lingenfelter.com/lingenfelter/product.asp?dept%5Fid=12- - 5&pf%5Fid=544
I was looking into them as they offered a conversion for the Sierra C3(now Sierra Denali) and they were going to offer packages for the Denali/XL. Back then the prices for the supercharger and some other treatments were in the $9k to $10k range. I decided to go with the Denali, am quite happy with it and didn't pursue supercharging.
My dealer had a Supercharger that they were/are offering but I can't remember the mfr off the top of my head - I recall it was also in the $5k-$6k range.
For lobsenza - supercharging is okay for towing - some race guys will supercharge their trucks used to tow their race vehicles and supplies to gain the power and avoid having to buy another rig. With proper installation(the kits will sometimes have upgraded parts for the engine) and aintenance there should be no problems.
http://www.gm.com/automotive/gmpowertrain/transmissions/hydra/app- s/4l60.htm
Not sure if adding a supercharger would exceed the max torque ratings since I have not found any dyno graphs. Anyone have dyno data?
If I were to add a SC to either the Denali or the Silverado that I own, I'd seriously consider one of these to go along with it.
http://www.transmissioncenter.net/4L80E.htm
Course you'd have to upgrade the rear end too.
I put a magnacharger SC on my 01 DXL. $4300 installed by by my local GMC dealer. I too was a little concerned about the transmission, considering the problems some have encountered. So far I have not had any problems. During the summer I tow a boat. With the SC it feels like the boat is not even there.
As for speed, average 0-60 is about 7 seconds. Top speed is unknown but I have had it to 123MPH (w/ proper speed rated tires). Where I live I have not been able to find a dyno that can accomodate the all-wheel drive. I guess about 100 HP increase as magnacharger indicates.
Also, with all the incentives out there, how much off sticker would constitute a good deal?
http://www.lingenfelter.com/pac6ltmagsc.asp
per the kit they do quite a bit of modifying to the engine, new camshaft, pistons, HD rod and bearings, and also replace the torque converter. Tranny rebuild is extra. It does come with 2yr/24k warranty.
at $15700 it's almost double what they advertised when I first looked at them about 2 years ago. (but you do get the Lingenfelter name)
It turns out that the front differential unit was low on gear oil (about 1 pint), but showed no signs of any leak. How could it come out of the factory like this? In any event, the noise is now 90% gone with 2100 miles and a topping off of gear oil.
I only wonder if any damage was done to the gears.
I don't know the front diff capacity in order to evaluate. Is one pint a lot??? Your thoughts would be welcome.
Being lazy myself, I didn't bother to check the quantity of fluid required for the front differential. It is included in your owner's manual if you really wanted to check. I'd keep the receipt of what the dealership did as far as adding the fluid in case there was any long term damage done. There must have been some amount of additional wear as the sound or whining would indicate. How much additional wear would be impossible to predict.
I would recommend that you have the differential unit drained and replaced with fresh gear oil as whatever extra contaminants that was created during this whine is still in the fluid acting as additional abrasives....something which you don't need.
I'm sure that's a typo - there are two pints in a quart.
