Today, i put the key in and it wouldnt turn...took 35 minutes of trying (tryed both keys i had for the car) before i could start it. had this happen a couple of times before but usually got it in three or four tries. i was ready to have the thing towed back to the dealership...any thoughts?
i love my fit but it is starting to drive me crazy. :confuse:
Have the keys gotten wet?
Was the little green key symbol by the "0" on the tachometer flashing when you tried to turn the car on?
The keys for the Fit have a microchip inside that disables the immobilizer when you turn the ignition. This makes sure that if someone else happens to have a key that could fit inside the ignition keyhole and turn the car, the microchip (or lack of) will prevent the car from actual starting.
Letting the keys get wet (putting them through the laundry or having them in your pocket at the beach) could cause the microchip to not work...consequently, your car won't start. The dealership I bought my car from is very close to the beach, and the dealer told me that often surfers would come back from a day in the water (with their keys in their pockets) only to find the car won't start!
If the little green key symbol flashes, it means an improperly coded key was stuck in the ignition. I would assume this also happens if the microchip isn't working or is damaged.
Regardless, I would let the dealership know this is happening.
boatfloyd
Going to call the dealership if it happens again.
Anybody out there have any ideas? :mad:
I brought a honda fit 7 months ago, I noticed everytime I drive over a crack, bump or stop short I notice a "boinggg" sound, like a spring is about to pop loose, it's been doing this since I brought the car, I thought it was because it was new, but then I received a recall notice about 2007 honda fits, it says in the salt-belt states, the moisture from a drivers wet shoes may penetrate under-carpet wire harness and cause the passenger's side and front airbags to malfunction, oh oh, this don't sound good, would that be the "boingg"sound? anyone have the same problem?
:confuse:
Cheers, Pete
:confuse:
i am bringing my car in next for weird noise when transmission shifts and will ask about this. I did have this problem with my 2002 honda civic..had to bring it in 3 or 4 times. Suddenly it stopped..i think they fixed it but never told me what was wrong. once it started by itself...and i did not have an automatic starter. that was very interesting. of course, no one believed me...
you need to videotape your starts...or bring a witness to " testify" at the Honda service center...that is what i do..
I see this as a serious problem. Has anyone else noticed this problem?
Please remember to check the discussion list for existing discussion before creating new ones. This helps us avoid duplicating discussions. Thanks.
I'm still learning the ropes and will be more careful.
However, this 2008 Fit (base, automatic) has odd idle speed (900 rpm) even though her engine is warm. Her fuel economy (average 33 mpg) is not so good, either. Does any one have similar issue or any suggestions? How's your idle speed when engine is warm? I would like to get an idea. Thanks.
I just got my new honda fit sport. Its my first car. I dont know much about cars but have a question. Everytime I start my car I see the Cool ( Temperature) sign lighting up. But after I drive may be about 1 mile it goes off. Can any one tell me if drving with the cool sign on hamper the engine. Also I noticed that the car does not pick up so well but ones the cool temperature sign goes off the car has good acceleration. I will really appreciate your help regarding this issue.
I have a 2007 Fit that i got in Sept. love it. Congratulations on your first car. The cool light stays on until the engine warms up. This is normal. Never noticed that my car doesnt pick up well with this light on but it could be because the engine & various fluids in the car havent warmed up yet. dont think this is a problem
did you find anything out?
-c
it has done it a couple of more times...but so far it always starts...the thought of sitting at the dealers or leaving the car...is too much..right now...when i bring it in next for service i will inform them...will let you know
Elid
I am from singapore and have heard from our local authorized honda dealer that this is a problem with the ECU for the 2008 Honda Fit.
Unfortunately it will require a reset of the ECU and there is a special machine required for this which is not yet available outside Japan. Only JDM Fits will benefit from the reset. Exported versions may have to live with this problem until the machine is deployed to authorized service centers.
Seems to be reliable info as the dealer showed me the email coming from Japan. I have just ordered the new Fit and I hope the ECU has already been corrected for this problem.
Please do keep us posted on any feedbacks from your distributors if they have the same info.
GP
Please follow this link for a write-up on what ECU is about:
http://en.wikipedia.org/wiki/Engine_Control_Unit
My 2008 Honda Fit finally broke in. Now she has average 40-42 mpg (after 6000 miles). I am happy. The idle speed backs to 700 rpm most of the time.
Gregg
P0302 Cylinder 2 Misfire Detected - This fault code indicates the Misfire Monitor has detected that a misfire in Cylinder 2 was detected. The vehicle’s computer continuously checks for engine misfires and identifies the specific cylinder or cylinders in which the misfire occurred. The Misfire Monitor continuously checks for engine misfires. A misfire occurs when the air-fuel mixture in the cylinder does not ignite properly due to the absence or incorrect proportions of spark, air and fuel in the combustion chamber. Possible Causes:
Fuel system problem affecting only Cylinder 2
Ignition system problem affecting Cylinder 2
Base engine (mechanical) problem affecting only Cylinder 2
Condition For Setting The Code:
DTC P0107, P0108, P0131, P0132, P0171, P0172, P1128, P0335, P0336, P0505, P1128, P1129, P1259, P1361, P1362, P1366, P1367 and P1519 not set, engine running under positive torque conditions, and the PCM detected a misfire condition in one cylinder. Note: If the misfire is severe, the MIL will flash on/off on the 1st trip!
P0301 Cylinder 1 Misfire Detected - This fault code indicates the Misfire Monitor has detected that a misfire in Cylinder 1 was detected. The vehicle’s computer continuously checks for engine misfires and identifies the specific cylinder or cylinders in which the misfire occurred. The Misfire Monitor continuously checks for engine misfires. A misfire occurs when the air-fuel mixture in the cylinder does not ignite properly due to the absence or incorrect proportions of spark, air and fuel in the combustion chamber. Possible Causes:
Faulty spark plug
Faulty ignition coil
Faulty fuel injector
Faulty fuel pump and/or regulator
Poor connections or loose terminals at the ignition coil, the injector, and the PCM
"Open" or "Short" circuit between the ignition coil and the under-hood fuse/relay box
"Open" or "Short" circuit between the PCM and the ignition coil
Internal engine problem
Incorrect PCM idle learn procedure
Incorrect CKP pattern learn procedure
MAF sensor
The execution time is once per driving cycle and the duration time is 200 revolutions for Type 1 and 1,000 revolutions for Type 2. Conditions for illuminating the MIL Type 1 and Type 2. * Misfire Type 1 (Severe) Per 200 revolutions 27-90 times. If a type 1 misfire (catalyst damaging) occurs once, the MIL blinks once per second, a Temporary DTC is stored, and the high rpm fuel injection stop system activates. The fuel injection stops, at high rpm only, on the cylinder that has the highest misfire counts. the MIL continues to blink, and the fuel injection stays off at high rpm, until the drive is completed. If a type 1 misfire occurs during a second drive cycle, the MIL and fuel injection behave the same and a DTC is stored. After a type 1 misfire has been detected during two drive cycles, the MIL comes on and stays on beginning with the third drive cycle, unless the Temporary DTC has been cleared by the PCM. Even if the MIL is on, it will start blinking if a type 1 misfire occurs. If the malfunction recurs during the next (second) drive cycle, the MIL comes on and the DTC and the freeze frame data are stored. * Misfire Type 2 (Light) Per 1,000 revolutions 55 times. If a type 2 misfire (emission-related but not severe enough to immediately damage the catalyst) occurs, a Temporary DTC is stored, but the MIL does come on or blink. If a type 2 misfire occurs during a second drive cycle, the MIL comes on and stays on unless the Temporary DTC has been cleared by the PCM. NOTE: Before you troubleshoot, record all freeze data and any on-board snapshot.
P0300 Random Misfire Detected - This fault code indicates the Misfire Monitor has detected that multiple misfires in multiple random cylinders (the misfire is not isolated to a single cylinder) were detected. The vehicle’s computer continuously checks for engine misfires and identifies the specific cylinder or cylinders in which the misfire occurred. The Misfire Monitor continuously checks for engine misfires. A misfire occurs when the air-fuel mixture in the cylinder does not ignite properly due to the absence or incorrect proportions of spark, air and fuel in the combustion chamber. Possible Causes:
Poor fuel quality
Clogged fuel filter
Faulty spark plugs
Faulty Fuel pump and/or regulator
Check the CKP pattern learn procedure
How i fix this?
I bought 2009 FIT DX-A about a week and a half ago. about 3 days ago, my didn't start, so I asked someone to jump start. This was fine for 3 days, then this morning the car stop running again.
When I turn a key this happenes.
ONE CLICK sound comes out.
Lights, audio, eveything else works just fine.
Tried jump start, didn't work or what's so ever.
Then, I tried to jump start again, this time the starter car had run engine for awhile... @my car went WEEN@WEEN@WEEN but not starting.
Is this a dead battery?@@I thought when battery is DEAD, all the other electric stuff wouldn't light up as well.
Could it be a starter?
Or Could it be something in the engine?
This has been super dissapointing, I live in the area where I really need a car to go around. I thought I'd ask b/c I'm trying to get a mechanic who can come to my place to fix but I haven't being able to contact him.
I'm the 3rd owner and my previous owner doesn't know if it has a warranty... I think it still does but I don't even know how to claim it when@I have no idea where they got it in a first place.
Also need an owner's manual it's not here in the car. @can I buy it?
Thanks. Hope I explained well...
