I do the same thing anytime I see an Azera owner. They always seem to love hearing it.
that the 2007 limited as well as the 2007 se have
been"discontinued"; their reviews are now directed
at the GLS and the limited XM as well as the Se XM;
does Edmunds have any information concerning this
matter,if,in fact,their statements are correct?
john baxter1
I believe that all of the new production Azera models are coming with XM radio. That is the reason the non XM models are indicated as discontinued.
FYI
I have never seen a back up camera with two lenses.
My back up system has 4 sensors and cost about $350.00 installed
What you are referring to is a back up alarm which emits a sound outside of the car warning people that the car is backing up.
The back up sensor is to alert the driver that the vehicle is approaching an obstacle when backing up.
Mine emits a beeping sound which gets louder the closer you are to the obstacle.
The sound becomes constant when about 1-2 feet from that obstacle.
At any given time the check engine light comes on and the car starts bucking and skipping.The first two times the dealer said it was coil failure and this last time he said I need to use premium gasoline. I'm really convinced they do not know what the problem is.Has anyone else had a simular problem?
Have you filed a claim, requested a factory rep, started a paper trail?
Don't tolerate it.
From the sounds of it, there are a quite a few possibilities that it could be. Maybe a bad spark plug, bad spark plug wire, could be a clog in the fuel system somewhere, could be water/moisture in your gas. There are a few things you can do yourself to cover some of those problems. There is a product I use in my gas tank with every oil change that keeps the fuel system clean and moisture free as well. It's called Berryman's Chemtool B-12.
B-12 CHEMTOOL® CARBURETOR CLEANER / POUR INCleans petroleum residue and disperses moisture from fuel system, fuel injector, valves, rings, pistons, oil returns, lifters, PCV valve, and oil pump screen with High Energy Solvent Technology (H.E.S.T.). Regular use ensures higher compression, fewer repairs, lower operation costs and increased spark plug and injector life.
Premium gas is not the problem, since almost all owners use regular with non of the problems that you are experiencing.
Perhaps you got a bad tank of gas and the problem will correct itself when it runs through. If in fact it does start to run better, it might be wise to have the gas filter changed.
A computer diagnosis should display the cause.
Otherwise, the best way for either of you to make another email address available is to go into your profile and make your address public. That will make it available only to logged in users, the spambots can't get it there.
You don't compromise your privacy with either of these methods the way you would if you posted an address, a practice which we strongly discourage for your own safety.
We thank you...for this important public service message.
The dealer should be able to plug in computer to read actual fault.
An expert should not be necessary.
The computer hold all faults, for later display.
they should of added more filters.
what do i do with my xm after 3 months they want $13.00 a month there crazy.
did anyone purchase any of the extended warrentys?. if so how much.
My 2007 Limited has 6,000 miles on it and I recently got 28 MPG driving 5 miles over the posted speed limits on a 600 mile trip. It was about 85% interstate, 10% city and 5% country roads. I am very pleased with that.
I get about 22 around town, but I live in a small town (pop. 4,400) and make very short trips.
Good luck!!!
'Even with the "wallowing" '
I though you had that taken care of? :confuse:
If not, why not?
Some posts have been removed - if anyone has any questions, the Membership Agreement is linked below. And please feel free to email me, as always.
1. I was required to have a complete set (3 keys) made.
2. I was told by the service department that they (Hyundai) could only have a total of 4 keys made to 1 vehicle at any time.
3. Out of a set of 3 keys, only 1 could be duplidated leaving me with 2 additional useless keys at a price of $160.00
Has anyone else had this problem in getting duplicate keys made for a 07 Azera?
There has been plenty of time I drive past someone and I actually see them turn around from walking to see what kind of car it is ... just a great feeling
I have sat in an office and looked outside and watch folks walk by my car, stop and look at it, in it...shake their head and walk away, then turn around and take another look. All I can do is laugh to myself.
There are various dealer computer settings. My locks activate when placed in park and lock when placed in gear. My steering wheel lowers (key out) raises (key in). I believe they only thing that can't be programed for key out / in is side mirrors folding / unfolding.
My dealer charged $45, but I got a refund after chatting with the business manager.
