On '01-'02 models, in addition to what orwoody explains above:
1. Custom Denali interior: two-piece center console with courtesy light and lock; faux black cherry trim on dash, console, switchgear; two-tone leather upholstry with Denali stitching, patterns, and custom headrests, color-key leather steering wheel and passenger grab handle; courtesy lights in footwells on rear outside mirrors.
2. 12-V accessory cigarette style ports throughout front & rear.
3. Trip & fuel computer
4. 6 disc CD with steering wheel mounted controls for radio/cd/tape
5. Larger disc brakes with performance pad material.
6. Projector style headlamp and foglamps.
7. Upgraded materials and sound deadening?
8. Michelin Cross-terrains on 17 inch wheels (these tires are awesome and I am disappointed GM opted to go with cheaper tires on the new '03).
For you guys negotiating on new Denalis, one distinct advantage you have is that you are getting a new vehicle for significantly less money than what guys were paying new in '01 & '02.
Definitely test drive a Denali back-to-back with a loaded Yukon and decide if the difference is worth the extra money. One distinct advantage of the AWD is that power is applied smoothly when accelerating through turns and instills quite a sense of confidence.
Just an update on gas mileage after a trip over Memorial Day weekend. Trip computer indicated 17.5 MPG @ average speed 67.5 MPH running 87 octane over partially hilly interstate. This is 100% freeway driving mileage where I cruised about 8 MPH over posted speed limits (traffic permitting). Overall mileage 17.0 MPG with approximately 95/5 hwy/city driving. This is better than my 3.5L V-6 Isuzu Trooper which used to get about 16MPG for the same. This speaks well for the Vortec 6.0L and Denali drive train efficiency.
Either way you can't go wrong, as both are GREAT vehicles!
Chris
Incidentally, can you feel/hear it engage? Can someone enlighten me? We have 2001 Volvo XC with what I think they call DSC or some such. Unlike ABS, I've never felt the DSC engage. (I hear/feel the chatter of the ABS every winter morning when I slide down our driveway in a Jeep Grand Cherokee.)
The best way to see the technology in action is in a very large empty parking lot during a heavy rainstorm: drive into a puddle at around 35 mph and immediately crank the steering wheel hard left or right as the car starts to hit the water. Depending on how the system is programmed, you will notice an abrupt reduction in engine power along with selective application of brakes typically on either the right front and left rear or left front and right rear depending on whether you turned left or right. The net effect is that the vehicle does not spin around in a series of 360 degree turns.
StabiliTrak will work on ice as well as water. The key is whether the on-board sensors detect an impending spin. Next to ABS, I believe that StabiliTrack (and the other variants) is one of the most compelling safety technologies available on automobiles and trucks. Some would argue that airbags should be first; however, I would respond that the airbag is relevant after a crash has started, while ABS and StabiliTrak give you a fighting chance of avoiding the accident in the first place.
The first StabiliTrak system offered by GM on full size trucks was a two-channel system which applied brakes to the front wheels to help correct driver errors and assist in low traction situations. In a 'Death Valley Comparison' test done by MotorTrend, a 2002 Cadillac Escalade with this system was the only SUV in the test fleet that needed to be pulled out of deep sand and the editors attributed this to the ineffectiveness of StabiliTrak. If StabilTrak has indeed gone to a true four-channel system, it would be a much warranted improvement. Manufacturers like Mercedes and Toyota have been using four-channel stability systems for a number of years with great success and this is definitely the future/now for AWD since you can reuse the componentry for ABS, traction assist, and stability assist. These are all fantastic safety features when well executed and well worth the premium if you can afford it.
Just finished a long trip this weekend in my '01 Denali; I added a K&N drop-in filter since the factory filter was dirty @ 40k miles and I have had good experience with these filters in the past. Butt-dyno indicated slightly more power at higher rpm and the transmission did not downshift on long uphill grades with the cruise control set at 80 MPH (this may indicate slightly more torque/power gained). Benefits may be due to the fact that I am now using a clean filter versus a filter with 40k miles. Regardless, the K&N will pay for itself in the next 40k miles since it is about 2X the price of a paper element. Highway mileage dropped to about 16MPG, since I was cruising mostly 80-85 MPH except for a few stop-and-go construction areas.
Just purchased a set of front/rear Stillen Metal Matrix brake pads to replace the worn factory pads. These ared adverstised to offer reduced braking distances and still be low-dust and rotor friendly. I'll let you guys know if these are worth a darn once I've completed the upgrade.
NOT FIXED: on full acceleration there is a noise like a belt squeal or air pressure release when shifting from 1st to 2nd. Dealer said they couldn't reproduce, I did it when I left the dealer. Any thoughts? Thanks.
Any thoughts on why? I am not excited to throw down $45K+ for a rust bucket.
Has anyone been negotiating lately and have some good pricing data?
Also, when do the '04's come out?
I would be interested to know if your howling/whine noise comes back after your new gears break in (est in a thousand miles or so). See my other posts re this issue.
How loud was the noise? Could you ever make it stop (change speed or coast)? And was it a long drawn out process to convince the dealer to undertake this large rebuilding task under warranty?
Many thanks for your reply.
erinsquared: I had an 01 and also had the belt recall done. No problems after that. I never noticed the squeal between shifts though. I am no auto guru, but what you say makes sense to me. It does only happen above 5500 rpm and I cannot reproduce it all the time.
ahesq: I took it into the dealer and said I have a howling noise coming from the front maintaining a speed at 50+ mph. It really occurred at 35+ but was most noticeable at higher speeds. When I took my foot off the gas, it would go away. I could feel it in the gas pedal and floorboard though. I called to see if my vehicle was done and they said they needed it one more day that the differential was apart and they were rebuilding it. No problems getting it done. I hope it doesn't come back, it is so quiet and smooth.
Thanks for your input.
Do all Denali's have have moonroofs? Are Denalis available with barn doors? Or were they options?
I'm replacing an 02 Bravada that was full of uncorrectable issues, and hate to get socked with another lemon. Luckily, GM bought the Bravada back after 15 months of ownership.
Thanks!!!
My 2001 has 31000 mile. It's time to add an extended warranty. Has anyone recent experiences to report.
bimmers - I bought my 2001 Denali new and have had hardly anything to gripe about. They had two recalls that I remember, and I have had nothing else to speak of in 2 years and 38k miles. I'm very happy with mine.
This road trip put on 1626 miles in 4 days. Stopped and bought petrol 6 times.
Overall the DIC measured 59.6 AMPH with 17.2 AMPG (94.4 gallons) over the 1626m. My calculated AMPG is 17.7
Trip included mountains, headwinds, road construction, some city and hauling a trailer on one lick(wedding rental chairs,tables, tents.)
Best leg: 19.52mpg all hwy but 3 mtn passes and 20-25m of construction.
worst leg: 16.3mpg mostly hwy but against strong headwinds most of that leg.
With speed limits in WA, ID and MT at 70/75 for the most part I was driving 70-80 mph except for the construction areas and had to slow up and down some of the passes.
I did run it up to 110/107(speedo/DIC) in a couple of straight stretches, and the D was very stable and felt like it could still pull higher speed.
Thanks !
Barry B
'03 YXL Denali
1. I was much more comfortable with a car manufacturer's warranty than aftermarket (even though it was not an OEM warranty).
2. The GM warranty was way to pricey. The Chrysler warranty cost about half of the GM warranty for comparable coverage.
3. Chrysler offered a 7 year 100,000 mile warranty and GM didn't.
4. Chrysler offered an option for first day rental car coverage which GM didn't.
5. Chrysler offered a $50 deductible which I thought had the best cost vs benefit ratio.
I priced over the net with Charles Capper Auto Center (Iowa)and was quoted $1840 for 84 months 50,000 miles zero deductible. Local dealers want $2290 plus 6% tax.
This is for a 2002 Denali XL.
Anyone bought the Major Guard? What does it cover?
84 mos 50,000 miles Zero Deductable for $1655
http://www.gmprotectionplan.com/majorguard.cgi
Hope it helps.
I can't make up my mind on this one. Good deal?
To address your specific question, I have read about some extended warranties being fully refundable if they are never used when the warranty term expires. Can't remember where I read that (most likely around Town Hall). I guess the company is happy to get the float on your money for a few years.
Extended Warranties: Extending The Joys Of Ownership
Understanding Extended Warranties
Another quote:
"Extended warranties are enormous moneymakers for auto dealers and anyone who sells them. One wrong move could cost you hundreds, even thousands of dollars.
"I think you have to automatically assume a 100 percent markup," says Phil Reed, consumer advice editor at Edmunds.com." Bankrate.com
