I really likes that about the Escape. However I just could not bring myself to pay that much for the Escape considering how small and uncomfortable it was for 4 people. I think it would be a great all around commuter for one or two people needing occasional SUV flexibility, but the second row seat just didn't pass inspection for me. Also, I think the Escape only had 1500# towing. My Jet Ski's and trailer weigh more than that.
I have a family of four, but the kids are still fairly young (9 and 12). We do fine with the FEH, but I would not consider it for a family of five.But it is great on city mileage (around 31 with my AWD), and the SUV design makes for a lot of space inside.
You are correct, I would not tow with an FEH. I think the technical limit it 1000 lbs, but I don't tow, so I never really checked.
With the new design on SUV's with high backs, reclining and even sliding second rows, I considered the Escape as second choice to anything else.. BTY, the Highlander is very comfortable for adults in the second row.
I've been posting on a couple of different threads here, and I think I'm in the right one now (finally). In any case, I'm looking for a synopsis of good driving techniques in order to maximize fuel economy in our 09 Hybrid Highlander Limited. Other posters have already warned me not to judge the gas mileage for (roughly) the first 2500 miles, but thus far the first tank of gas yielded 22mpg, and the second tank (still in progress) is only registering 18mpg. I've read about the following, so any clarification on any of these- or other topics - would be greatly appreciated:
Pump Float Glide?
Recommended PSI?
Hyper-Miling?
Power Meter?
Anything else?
For the second tank of gas, I've even had my wife (who predominantly drives the HyHybrid) leave the car in ECON mode....
Thanks in advance,
Gusto
I have not seen the large numbers with my 4wd HH, but with warm weather it is rising. Basically for the first 8000 miles I averaged around 23.5 mpg. However since it has warmed up I mostly see 25. My wife drives it most and she typically is around 24.5 and I'll see 26+.
I was able to average 37+ in my TCH over 67,000 miles so I know how to maximize the FE. The HH is a little less fulfilling because you don't see the large differences. For example on the same route I can get 25 or 27. Doesn't seem worth the extra effort sometimes. Where as with the TCH I would vary from 36 to 41. Really not that much difference %'wise but mentally it motivated me.
With practice you should be able to get at least 23+, which in my opinion is still pretty good. Just got back from the beach where my Expedition got 16 on the road tank and 13.5 on the tank driving around. However I hauled 6 of us and most of what we owned it seemed. Next year we'll probably take the HH and the 2010 prius I have on order.
Don't give up and read the threads.
I purchased a new HH 09 Limited last month. I am curious about best driving techniques as this is my first hybrid vehicle.
I am generally using the HH in economy mode and so far getting around 25 MPG.
I have these questions
1. Is it safe to keep driving HH in economy mode all the time. I mean it shouldnt damage vehicle to keep using economy mode all the time.
2. What are best driving tips you all the previous owners can suggest?
3. HH have the toyo tyres. How many miles/years these tyres generally give depending upon routine use of vehicle.
I appreciate your help.
Yogi Aggarwal
1. Is it safe to keep driving HH in economy mode all the time. I mean it shouldnt damage vehicle to keep using economy mode all the time."
Yes, it is. If you need to do hard acceleration, just floor the gas pedal and it will override the econ settings.
"2. What are best driving tips you all the previous owners can suggest?"
Inflate the tires to 39psi, drive gently, anticipate starts and stops. Using the heat or a/c does reduce gas milage, but do what you need to be comfortable. You do not want to drive at highway speeds with a window open, it will drive you nuts. Keep you speed below the speed limit on highways.
"3. HH have the toyo tyres. How many miles/years these tyres generally give depending upon routine use of vehicle. "
I don't know on this one. I have just under 12,000 miles on my 2008 after owning it for 21 months. I have rotate the tires twice. They still look good, but others say they are lucky to get 20,000 miles on them.
For tire pressure, recommended or written on tires is 33 psi. Are yours marked as 39psi or you just inflate then with 39. Is it from your own experiance or their is any logic behind having 39 psi as against 33.
Yogi
The data plate on the car says 33 psi, not the tire. 39 psi is within the manufacturer's specs.
The higher tire pressure reduces rolling resistance, increasing gas milage.
Perform better the 2010 Lexus 450 Hybrid?
Thank you for your kind insights.
The Lexus has identical drive components.
I live in NE North Dakota and my 2008 HH does fine in the snow, but I don't attempt to do serious off road driving.
Well, yes, and NO....!!!
More properly referred to as a F/awd vehicle, with drive torque primarily only at the front. Like most modern F/awd vehicles the rear drive is only enabled, used, during low speed acceleration when loss of traction is most probable. Since there is not a mechanical drive line coupling from the front to the rear of the HH you can expect, should expect, predominant rear drive in low speed turns when lateral traction is needed above and beyond "drive" traction.
But....
Once the front tires develop even the slightest level of slip/spin it becomes a VERY urgent matter to quickly regain front traction. Front traction MUST be quickly regained in order to alleviate the strong possibility of loss of directional control, that leading to an injury accident, or even a deadly accident.
So even with the rear drive coupled in during low speed acceleration the front drive will still have much more ability for wheelspin/slip. Once this happens the TC, Traction Control, aspect of VDIM will INSTANTLY begin braking the slipping wheel(s) and just as INSTANTLY dethrottle the engine, and......YOU'RE STUCK...
Many newer F/awd vehicles have a TC disable switch function to enable one to get UNSTUCK, or even initially getting up and going, in motion, but apparently your 2006 was/is too early in the hybrid F/awd development program.
You might be able to temporarily disable many of these "ancillary" VDIM functions by creating a CE indication. The easiest way to do that that I am aware of is to disconnect the MAF/IAT connector with the engine idling, reconnect it, restart the engine and now you have a CE that will automatically clear a few miles down the road....After you get unstuck or in motion.
4WD-I
No "jack-rabbit" starts, far from it, but reliable low speed "4WD" functionality in a F/awd HSD vehicle.
It is not the AWD, it is the Toyota implementation of HSD. The early models did not allow the wheels to spin, causing problems in snow. I think they fixed this in later models. You might check with the dealer and see if there is an update to the computer programming. I can't recall if it was only a programming change.
I have read a number of posts lambasting the Hybrid version of the Highlander (the non-hybrid version seems to perform just fine) for its snow performance. Most people attribute the car getting stuck to not being able to override the Traction Control. The Traction Control helps maintain control when moving forward and hitting a slick spot. But apparently if the car comes to a complete stop in deep snow, once the front wheels start to spin the Traction Control kicks in and automatically applies the brakes to spinning wheels. The electric motor on the rear wheels does not propel the car, and consequently it gets stuck.
Obviously in deep snow there are lots of times when all cars get stuck and you need to rock back and forth to get going. The HyHi reportedly just sits there with wheels locked and you cannot alternate between reverse and drive to get going.
I cannot tell if these complaints are limited to the older (500 plus pounds lighter) Generation 1 version of the Hybrid Highlander or are also applicable to Generation 2, or if these complaints are due to people using inappropriate tires for winter driving. (There are also lots of tire complaints but that is a separate subject.)
So, please, anyone who regularly drives a newer version Hybrid Highlander in heavy snow conditions please share a candid assessment of the car's performance. Note we will always be using it on paved roads, but with some frequency these paved roads will not have been plowed yet. Also our snow is typically wet and heavy (Sierra Cement). I would love to get the fuel efficiency of a hybrid SUV but cannot reasonably make that tradeoff if the car is not well suited for snow conditions.
All informed responses from experienced snow drivers are much appreciated.
I have driven in 8-10" snow with no great problems, but felt the limitation of the tires. The problem with the stability control system is that most drivers do not know how to use it, you must be gentle on the gas once the system is activated by detected will slip/spin.
Switching to the Toyo Open Country H/T (I just did 10 days ago) will help a great deal. Icy intersections that activated the stability control system with the Toyo Open Country A20 tires (OEM) do not set it off with the H/T tires. You could also buy a set of Bridgestone Blizzak snow tires.
Good luck. I have loved my HH and live in NE North Dakota (cold and snowy).
So now that I have to buy a new car by year end. Do a lot of canyon/hwy driving but i need my new car to handle better in the snow. Do any of you have any experience with 2011/2012 Highlander either AWD or 4-wheel drive? Which is better in the snow and which one gets better gas mileage?
I can't warrant buying snow tires when I live at the beach. Does anybody have any suggestions because most of the forums are talking about snow tires. Also, what is with W&T on the tires? How expensive is a new set? I didn't have this problem.
I am just really worried. I don't know if I should just bite the bullet and buy the Acura MDX which doesn't seem to have these problems. It about $15,000 more but I am wondering if the problems versus $$$$ will pan out since I owns my cars for 10 years!!!!
Any suggestions? I am so confused and scared on what to do!
Due to the dangers of wheelspin/slip at the primary drive, driven wheels, once slippage is detected the system goes into temporary "limp home" mode, braking is used to abate wheelspin/slip along with INSTANTANEOUS engine dethrottling.
Consider the 4runner or if in the MDX class the Porsche Cayenne V6 base.
Both of those are untimately more safe RWD base vehicles.
Also the tires are all season and kinda big (19") so there's potential traction issues with tires of this size / ratio in general on almost any vehicle; so with dedicated snow tires you will be able to get almost anywhere 'normal'.
ONE Wheel Drive..!
when you depress the gas pedal ALL of the engine torque might go to the wheel with the LEAST traction.
A much better override would have been to allow the engine to produce a more moderate level of torque, not full dethrottling, for a few seconds along with braking to apportion that torque. Unless, of course, VSC detected yawing motion.
In 2010 the RX was switched to the newer F/awd system initially used in the Ford Escape and first introduced in the Venza for Toyota. I haven't yet seen any notice that the HL followed suite.
Can you deactivate the stability control? No. You just have to use good driving technique. :shades:
You don't always know when there is black ice just around that curve.. or maybe a deer dashes out....
I have read almost enough accounts of people getting stuck in snow or having traction control stop putting power to any wheels to stop me from buying the HH.
But then I always wonder, 'what tyres were they on?' 'do they know how to drive on snow/ice?', 'would I have been using snow chains in those conditions anyway?'.
Would love to hear anymore feedback from HH owners who have been out in both unplowed and plowed roads using good winter tyres like Blizzaks. I would use chains on the HH as well if needed. These look like an easy if a bit pricey option http://www.spikes-spiders.com/
I currently run an AWD 2002 Honda CRV. I have never felt out of control in snow/ice. My snow driving in this vehicle has been on all season tyres, but I'll throw on chains if the snow looks more than a couple of inches. And when I come back to my car to find a foot of snow on top of it, I'll dig it out first, not expect to just drive straight out.
Keen to get that HH fuel economy and reduced emissions, but not if it will get stuck in snow or be dangerous in anyway. Probably 2008 is the newest I can afford, so no turning of traction control for me. Not that turning it off sounds like a really great option to me anyway.
Otherwise I need a 7 seat SUV with the best mileage possible and some AWD/4x4 ability. Gas Highlander, Kia Sorento, Honda Pilot all options, but would prefer low emissions.
All feedback welcome, and details of what model/tyres/chains/conditions would be a bonus.
Thanks All.
