Chevy S10 - GMC S15 and Sonoma Electrical Problems
1234689
  • CDIICDII Member Posts: 8
    Have you checked "LMCTRUCK.COM"
    Also, If not socket,wire to cab, or fuse. Might check turn signal switch in the steering column, I believe the brake light works through it if not mistaken.
  • longtravels10longtravels10 Member Posts: 4
    has anyone else had any luck with fixing this problem
    My 99 s10 is going crazy, the voltage drops from 14 to 11 and the truck begins to sputter and backfire and all of the dash lights and the gauges start going up and down. I know when its about to do it when the voltage begins to drop I usuallly drop the gear and it backfires and sputters like crazy but I keep it from stalling. Please help.
  • jhardy3333jhardy3333 Member Posts: 1
    the head lights work in day time but the pass side head light does not work at night when the rest of the lights are on???
  • gonogogonogo Member Posts: 879
    Your low beam on that side is burned out, the DRL during the day goes through the high beams only. If this is true your light should be out during the day when you turn your head lights on manually.
  • goofysexygoofysexy Member Posts: 1
    my cigerett liter wont work nether will the radio or the horn
    Check fuses, cig, radio, etc.
  • the_big_althe_big_al Member Posts: 1,079
    Okay - so I posted this in the climate control forum not realizing that I had done so.... oops. So here it is in the right place (I hope :D)
    Here's a truly odd one. I think I solved the heater issue I was having though. I checked the coolant level and found that it was low. I added more coolant and all seems fine now. It is time for a coolant flush though. All three of my vehicles need it as well as 2 of them need an oil change... Looks like a good half a days work.
    Anyway, I am experiences a quirky turn signal. It is on the driver's side. It only happens when the lights are on and then only intermittently. When it happens it acts like a bulb is burnt out with the fast and short blinking. Only there are not any bulbs out. When it has happened, I have gotten out of my truck to see what is happening. The front seems fine. However, the rear lights are where the quirk is. When the turn signal is on the bright lights up, but near as bright as it should. When it goes of, the reverse light, driver's side license plate light and tail-light illuminate. Then alternates back to a not as bright turn signal.
    It's hard to explain... maybe I'll try taking a video of it when it happens again and posting it. But at this point I am at a loss as to where to even begin....
    Strange electrical is always a bad ground.
    I was able to get some videos of my turn signal problem. I think I did a good job describing the problem. At least well enough to maybe help diagnose where to start. I agree with gonogo that a bad ground could be the culprit, but maybe some one knows where to start tracing this bad ground???
    waiting for my videos to appear??? Here is one short one however: http://www.carspace.com/videos/play!id=.5c97ce3f
    This one was done with my cell phone on the road. I had to be quick as it only let me do 15 second spurts. I did more when I got home with a better camera. I thought I uploaded them, but I don't see them yet. I did a few depicting several different ways in which the turn signal operation is funky. When I further investigated the problem, it appears that the problem is not isolated to just the signal, but the whole lighting system in the rear.... Brake lights, reverse lights etc.
    One more video appeared and it does a much better job describing the problem...
    http://www.carspace.com/videos/play!id=.5c97cf63
    so I think I solved my problem... (I THINK). Today I tore into it to see if I could find out what was going on mainly because things like this really bug me. I can't stand not having something like this not work right. It's like a check engine light or brake light on the dash. I have to find out the deal and get it resolved so it doesn't bug my anymore.
    Anyway, right after I got the truck I installed a Class III tow hitch and along with that hitch came the requisite wiring. The wiring kit was really simple to install. Just a couple of wiring harnesses at the back of the truck that needed to be unplugged and a trailer kit harness plugged in between. That was several years ago. One day I went to plug in the lights for a trailer I was towing and I heard a POP! and I think the driver's side, but I am not sure lights quit working. I had blown a fuse. Simple enough to fix, but when I unplugged the trailer, POP! again. It turns out the wiring had frayed causing it to short everytime it touched the frame. So wrapped it all up in electrical tape and all has been fine until just recently.
    When I started having my turn signal issue, my first thought was to check that trailer kit. So I unplugged the extension that I had used to get the wires from under the fender to the hitch. As soon as I did that the lights worked normally for a while and then they went back to being quirky. Sometimes they would work, other times I had issues. Then just in the past couple of days it went to all the time and so that is where I was at last night.
    Today, I crawled under the back of the truck and noticed that when I had unplugged the trailer kit, I only unplugged the extension. I noticed that the actual trailer kit was "spliced" in between a factory wiring harness. I say "spliced" but it really was just a couple plugs unplugged and the wiring kit plugged in between. So decided it couldn't hurt to take the trailer light kit out. I unplugged it, plugged the factory wiring harness back together and Wha-LA! The lights worked. All seemed normal. Until tonight when I went to use the signal and I was back to where I was at last night. Grrr... So something else is the problem.
    When I got to my destination I got out (this was really bugging me) and grabbed my flashlight and crawled back under the truck. I checked my connections as the harness to make sure it was still tight and as I did so and moved the harness around, I could hear the lights (the clickity turn signal sound) get erratic. Sometimes it was the fast clicking and other times it was normal. I traced the wires up to a wire loom above the frame. I could see a couple ground wires coming out and I jiggled these. Sure enough, I could move the wire one way and I would have normal operation. Move it another way and bad connections. So it does appear to be a ground wire and I think I must have found it, although I couldn't do anything about it right then. I did move it around so that the lights are working as of now until the wire gets bumped or jiggled the wrong way. Tomorrow I guess I get to crawl under and see what needs to happen to get it fixed. But at least I am closer to solving the problem!!
  • camarofreakcamarofreak Member Posts: 1
    i just had this problem fixed but it happened again..i turned on my a/c and lost all power no headlights accessories/ radio/ blinker/ ignition i got nothing. i just had it fixed the mechinic said it was the ground on the chassis....where is this ground on the 95 s10...also my airbag light came on after i got it fixed is the ground on the chassis by the chassis brain box air bag module??? soemone please help my truck is in a town im not familair with and i wanna get her home.
  • jfj600wjfj600w Member Posts: 2
    Electrical problems. . .It use to be when I would remove the key from the ignition the radio and power windows would still operate for a while. . . unless the door was opened. .
    Now that has stopped and I do not have a clue why. If it helps the inside dome lights wil not work either unless the over ride button is punched. . but then they do not shut off. Is this all related?
  • daveykc5daveykc5 Member Posts: 2
    I have a 96 chevy s10 and i just recently got t-boned in the passenger door. After getting the truck from the body show i noticed that neither of the power locks work i checked the fuses none are blown. Anyone got any Suggestions?
    you might check the switch itself and see if it was reconnected. Or maybe a wire got pinched in the crash. Did they replace the door, or just body work?? If the door was replaced, it is possible that a wire harness was left unplugged??
    Take it back to the body shop, they are responsible for anything in the doors.
  • jschettkojschettko Member Posts: 3
    Did you ever find the problem?? I have a 2003 Sonoma Zr2 with similar problems.
    Nopey , , , in fact things seem to be getting worse. . . the inside - dome light will not work unless I over ride it. . then I have to cut it off manually . . and the gas gauge seems to have gone whacky. . that may not be related. . . I just do not have the money to take it to a shop. . .
    The door thingy. . I got to the switch but was unable to get it out. . so I am not sure that is the problem or not.
    I am just scared it is going to stop on me and I will not be able to get anything running. . . scary to have a vehicle like that. . but right now. . no other choice. . ..
    I have a 1996 S-10 and i have some power door locks issues, Neither of them work. Checked the fuses they are all good. I have an idea that it might be the relay but i cant seem to find it. If any one can either tell me where to locate the power door lock relay or how to fix the relay i would appreciate it very much.
  • smittyman76smittyman76 Member Posts: 1
    Hello, My 95 S-10, 2.2l 5-speed with about 135,000 miles on it is about to get scrapped. While driving I get random electrical shorts (or hiccups) which cause the radio to pop, lights to dim, engine to miss, and if I'm really lucky everything shuts down. I have been able to get power again and start the engine within a few moments. No trouble codes from the computer so I have replaced the battery, alternator, positive terminal post(coroded), and those 2 relays that are mounted under the hood. I have also looked all over the engine for bad grounds. From what I have read from earlier posts it sounds like a semi-common problem with little or no (affordable) solution. The next step I am considering is replacing the ignition switch based on info from the internet. Any advice? PLEASE! :lemon:
  • jedifrkjedifrk Member Posts: 1
    I have a '99 Sonoma 4.3 and under heavy acceleration the engine loses power and the dash lights dim. Problem started after I replaced battery and positive battery cable to the starter (corroded through). I have since added another ground wire from the battery to the frame and sodered a new wire to the other positive wire going to the battery. I am at a total loss any help would be great.
  • vanscootervanscooter Member Posts: 1
    i have a 1999 s10. the connector for a code checker stop working ,how can i fix to read codes i plug the code reader i get nothing. code reader works ok.does the connector go bad,do i have tyo replace it, please help.
    My truck did the same thing it is probably a fuse thats what it was for mine if not try moving the wires that go into the back of the plug
    Check your cig fuse, it powers the diagnostics.
  • fatal22fatal22 Member Posts: 2
    I just bought a 98 s10. When I bought it, the guy informed me that there was a headlight out. I went and replaced one, and realized they were all dim. I went ahead and replaced all of them and only one is working properly. I am assuming its a ground issue, but am wondering if it could be anything else. It doesn't seem to be the alternator because the lights don't get any brighter as I drive. There are also no other electric issues in the truck.
    I would lean towards bad ground. I had a light issue a few weeks back involving the rear lights and turn signals and found a bad ground wire. Fixed the wire and all is good now. While yours is not the same issue, it does involve lights not working properly when the bulbs are good and the rest of the electrical is good, so the only thing left is wiring somewhere.
  • dbilldbill Member Posts: 2
    Need help, have been having a bad electrical issue, truck is running and and when the the ignition is shut off the truck continue to runs but if you turn down the dimmer switch the truck will shut off. Also with the truck off you can turn on the radio by turning on the headlight switch but if you use the dimmer you can shut the radio back off. I have replaced the headlight dimmer switch with no luck. It acts as if the headlight switch is crossing or back feeding with the ignition switch, because when you do turn on the headlight switch the service engine soon light comes on. Can anyone point me in the right direction. 2002 chevy s10 4.3L 4x4 Thanks
    Thank you for your help, although that was not the issue. After tracing and tracing and tracing finally found the problem. It was in the instrument cluster, it was back feeding through the ignition and light switch which was causing all my problems. Replaced the cluster and all is well.
  • holy_rollerholy_roller Member Posts: 4
    I have a 98, 2.2l, 5 speed, 136k, and it does the same thing. I'll lay out EXACTLY what it does in case anyone has any ideas...
    Volt meter will slowly dip from fourteen down to around 11, taking up to 5 minutes to drop, sometimes bounce back up momentarily only to drop again, and the truck will sputter and die. Sometimes I can put it in gear while it's rolling and it'll kick back in and pop back up to 14 volts and be fine...but usually if it DOES start back up, it'll just slowly dip back under 11 and die, and to keep from fighting with it I'll just coast till I find a decent place to pull over. The radio, a/c, lights, everything accessory continue to work, lights are NOT dim at all, even though the volt meter reads nothing with the key on. Then I sit, turn the ignition off and back on...sometimes getting absolutely nothing, sometimes barely over 11, but when it's ready to go and run right it'll jump all the way back to 14...and start like nothing happened. If I don't let it sit for about five minutes, I'll try to start it and it'll do something that's almost like it's fouling out...won't be weak turning over, but it's like as soon as the engine kicks in something is killing it...so I let it sit a little longer, and eventually it'll start and sometimes won't do it again. Also, I've noticed that sometimes the security light will come on...more about that in a moment.
    It has done this since around 105k, it'll happen for a couple of months, then go away, sometimes for six months at a time until it returns. It seems to happen more when it's hot outside, whether the air is running or not, and when it's raining at night, obviously when there's more of a pull on the battery. Very early on I noticed that using my blinkers would make it take huge dips, and sometimes make it begin the "slow fade" when it had been fine...so I just stopped using them altogether...and it still happens. It happens at freeway speeds, city driving, has happened while I've been stopped at red lights, it doesn't really matter...and it'll seem to be getting worse and worse, I'll repair or replace something, and then it'll go away for a few months...and come back.
    I have replaced the battery, put in two alternators, a starter, battery cables, found a security system under the steering column that would click and keep it off (may have been unrelated) and took it and all its wiring out, found a heat shield on the starter between it and the exhaust pipe that was shorting out from the hot wire to the pipe, tried to make it work and eventually removed it...found various bad connections in the dash and replace them...and all of these things would make it better for a few months, and then it'd come back.
    As far as I know I'm the third owner of the truck...the guy I bought it from told me nothing about the security system (it made the lights flash), and it has wiring that suggests that someone had an amplified sound system in it as well...all of which I've removed, and I thought maybe bad wiring by them in the past was where this was coming from, until I checked message boards and saw others having the same problems. The only things I can think to replace now are the ignition and ignition switch, and I'm starting to think maybe there's a bad circuit in the CPU or something.
    If anyone has fixed this or has any suggestions, I'd love to hear them. I'm ready to blow the truck up before it stalls on the freeway again and succeeds in killing me.
    I just posted on this, would've tagged yours in my reply if I could have. Read above and see if it sounds similar. We should start a support group...lol.
  • fserratofserrato Member Posts: 1
    :confuse: i have a 2000 gmc sonoma and my headlights dont turn on at night and sometimes during the day. i checked fuses, ground, switch and relay is good. the bulbs are good. what gets me is when i have the problem the two wires at the plug for the bulb are throwing 12v positive.any body can help it would be appreciated. thanks
  • wtpooh43wtpooh43 Member Posts: 2
    The fuse to the cigar lighter is blown. Replace it and any other fuse and the code checker will begin to function.
  • heater51957heater51957 Member Posts: 1
    1991 chevy s-10, bad ign module replaced, still only getting spark to top of distributor at end of ignition try. whats up?
  • meatemeate Member Posts: 2
    holy roller. You have described the problem exactly what my truck does. I am sure that your speedo and tach sweeps all the over just like a electrical hiccup. All gauge lights up. What do we do anything? Have you found a solution besides "For Sale". I would hate for it to die when trying to pass a vehicle.
    I replaced the crankshaft sensor and camshaft sensor as recomended by a mechanic, no help, replaced the alternator and I had to replace the catalytic converter because the backfiring ruined it, I replaced ECU and still no help I said thats enough!!!! I traded it in on a Honda Civic. I took it to several diffrent mechanics and electrical specialist and nobody could figure it out. I was also told by someone that they had a similar problem on a Acura and it was the main relay I didn't check or try it on mine because I had already gotten rid of it. Its worth a shot just don't waste your money on the parts I bought they were no help. Let me know how it turns out. Good Luck
  • gthang2008gthang2008 Member Posts: 2
    I have a 95 S-10 ZR2 and have changed the blower motor and the interior blower switch but still cannot get it to blow on the highest setting. I am wondering if it is the relay or not, and if so, whereabouts is it located on the truck?
    Eddie :shades:
    Is the motor not blowing on the highest setting, or is it blowing on the highest setting (you can hear the motor blowing), but aren't getting the proper air volume??
  • k8vk8v Member Posts: 1
    I would like to know where is the throttle position sensor located on my 97 gmc sonoma and how hard is it to replace?
  • biomed86biomed86 Member Posts: 5
    That sensor is on the opposite side of the cable coming from the accelerator pedal, it should be pretty easy to replace !!
    No solutions yet...as soon as I get some cash saved up I'm buying something else and selling it, sigh.
  • pinksonoma1994pinksonoma1994 Member Posts: 3
    I have a 1994 2.2L 5 Speed Manual Sonoma, I bought it used and it ran fine for the first year I owned it. One day driveing home from work the truck's RPM's droped slightly and when I tried to push on the gas the truck had little to no power. Since then i've tried many things such as a tune up and checking all basic tests. I found out that if you unplug the altenator or the fuse that it is hooked to the truck will run fine but die as soon as the battery runs out. I replaced the altenator it wasn't it. I replaced alot of sensors the only thing else i could think of is a short. IF ANYONE HAS ANY IDEA OF WHAT IT COULD BE PLEASE REPLY IVE DRIVIN LIKE THIS FOR 8 MONTHS.
    Only thing I can think of is the ignition module or the PCM can't handle 14 volts anymore, just a guess though.
    Checked Position Censor already but i will have to check the ignition module thanks.
    PCM Power Train Control Module. It's the engine computer.
    That was one of things we were looking at but for some reason never checked I guess I should then.
  • wildwolfwildwolf Member Posts: 1
    Does anyone have a wiring diagram for a 2001 S10 OBD2 plug under the dash? Wires are pushed out of the back and I can't scan the vehicle.
  • kjc4kjc4 Member Posts: 1
    I am having a problem with the Driver Side Power Window working off and on. I thought the problem might have been the switch. I replaced the switch module and the problem was still there. Could the problem be with the connection to the motor or a broken wire? I am looking for a drawing with instructions related to removing the inner door panel so that I can check the wiring and conection to the motor. Can someone send me information related to obtaining drawings and directions? Or, can someone give me some other ideas related to resolving the problem before I take the door apart?
