Steve
http://www.yousendit.com/
This site allows you to upload a file to it's server. The site then emails me the URL of the file which I can fetch. You do not have to create an account or login.
So In a nutshell all you do is:
1) copy LOADING.KWI from your 5.1 DVD to your desktop
2) web-over to the above URL
3) You'll see there are 3 steps, highlighted in green. In Step one you supply my email address:
opteron1@mac.com
In step two your select the file from your desktop, and step three uploads the file.
Thank you very much in advance ...
Steve
http://www.lehigh.edu/~sol0/2007CamryHybridVoiceCommands.pdf
Did you ever get the file? Did it work? Can I get a copy from you? What type of DVD does the Nav unit read? +R -R +-R?
Ben
The detailed map on the right-hand side of the screen that appears before the turns usually shows the car at a slightly different location than the regular map on the left. The detailed map shows the tip of the red triangle where the car actually is, but the main map on the left usually shows the symbol little bit lagging behind by about the radius of the circle. It is weird because both maps use the same position information.
Could someone who has experience with other navigation systems compare the one in TCH with other systems, in particular how precise it is, how reliably it receives satellite signals, how good the maps and the route calculation are, etc?
Unfortunately there's no site that compares the performance of built-in navs as far as I know. Toyota/Lexus nav systems are generally viewed favorably from everything I've read (except of course the lock-out-while-driving "feature").
I’d like to know if the Toyota Camry 2007 Navigation system has the ability to allow the user to enter multiple destinations and have the system select the shortest route to move from one destination to the other.
In other words:
I need to go to (1) the grocery store, (2) the mall, (3) A friends house and (4) the book store. I want the system to tell me the fastest most efficient way to hit all points before returning home.
My wife is a realtor and she would want this feature when looking at multiple houses in a single day in neighborhoods she is not familiar with.
m
What will happen to the rest of the car when I do that other than resetting the clock and Nav? Any complicated issues related to the Hybrid battery or Hybrid system? :confuse:
I have read about a similar problem with dealer navs in Canada
GreenHybrid Thread
Toyota Nataion Thread
Any tips, advice or particular knowledge of the 50th ed. that would shed some light on this? Thanks.
GreenHybrid Thread
http://www.toyotaiguide.com/content/07Camry/iGuide.htm
I have it on my 50th TCH. I click on Info-> Trip
i ordered my camry hybrid last week , delivery in 5 weeks.
since i had access to the pdf manual and i saw that there is a "notifying traffic restriction" setup.
is the navigation system get lively updated with traffic jam or work on the road ???
if not !! what exactly this setup means ???
thanks..
You should see the same issue when you type in your address online (into Google maps or whatever) however you wouldn't normally notice it because people don't usually zoom in that closely when they use Internet maps.
do you still need it?
I have the same error...
it appears when the street numbers were put into the master file...used by the postal service and mapping companies... the numbers may have started at the other end of the street.
I checked other points on my street and this is how it runs.
My street number is up the block while their number is where I am.
Also if you look at the postal 9 digit number you should see your zip code as ...NNNNN-1009... or close to it.
This is the best I can figure it out.
It is not a problem with your system or software.
My other "Streets and Maps", "Mapquest" and now Toyota seem to work off the master set up.
Gampa
