Visitor Agreement.
However, I have seen aftermarket grilles with a matching lower grille. Stop by a Barnes & Noble and look though some magazines that feature customized cars & SUVs.
GM's new Full Size SUVs (Inside Line)
Talk about it in the 2007 Chevrolet Tahoe/GMC Yukon discussion.
Thanks in advance.
I believe they are liable for breaking the sensor and you should ask them to get you a replacement for the one you gave them to use. By doing that I think you saved them time and money already as they could use the sensor you already had.
I had to wait a week until they got the sensor to install.
All 'professional' tire shops should know about these sensors and know how to do the tire job without breaking them.
Arrie
one thing surprised about is that they were able to find me a sensor over the weekend..i guess i'll find out when i pick the tire up.
You will need to do the re-learn procedure for the pressure transmitters to verify that the sensor in that tire they replaced is a working one. This means that you place the tire close to your vehicle and start the re-learn procedure. During this procedure you will let some air out of each tire in certain order and move to next tire as you hear a signal from the horn of the vehicle.
As you go through the tires you let air out of the extra tire in place of one of the tires mounted on the vehicle. It is best if you let air out first from that extra tire. If the sensor does not work you will not get the signal from the horn. This way you don't unnecessarily let air out of the tires on the vehicle.
One detail in this is that the sensor's battery must be charged before it can send the signal to the computer. Charging normally is done while vehicle is driven. There is a small ball or something inside the sensor that vibrates during normal driving. This vibrating ball charges the sensor (pietsoelectric?). How to best charge a sensor in a spare tire I don't know. Perhaps just bounce the tire for 10 minutes or so. Or have it installed on the vehicle and go drive a couple of miles. I learned all this when my sensor was replaced and re-learn procedure would not work. I went to drive about 4 miles and after that it worked just fine.
If I was you I would insist them to install the tire on the vehicle and go drive a few miles and then return to that shop and do the re-learn procedure while they are watching it (or doing it). That way you all witness the condition of the new sensor they installed in your spare tire.
Arrie
The ping is now reduced from severe to a much lower level. It does not ping if I accelerate it gradually ( it did before). But it still pings during hard accelerate.
Any solution or advise is much appreciated. :confuse:
There are some real wrench turners over in the GMC Yukon Denali Problems discussion, so everyone please double-check there for your pinging and surging.
I went with a 20' combo that retained the stock tire circumference and lowered the truck to minimize the gap between the well and the tire. Before lowering the truck, the gap between the tire and the well looked ungodly with wide tires.
i have a o5 yukon 5.3 with 4000 miles and am having power surges when braking. when i come to a stop, my rpms jump up. it feels as if someone else is pressing the gas pedal as i am trying to stop. is anyone else having this issue? what should i do?
Have you taken it in to the dealer to have them look at it? Were they able to find a "code" for the problem? I have an 04 with the same problem - have nearly been in a couple of accidents. My dealer can't find a "code" so it's all in my imagination.
My wife won't ride in it anymore...
Is anyone else having this problem?
Oh yeah, the next morning a tire was flat...nail...dealer replaced the tire.
http://www.gmc.com/newvehicles/2007yukon/index.jsp
Any opinions out there as to which I should go with? I know the two are "cousins," but is there a reason to choose one over the other?
IP #1513566 and everything works great except the trip od
I no longer have the option of personal or business mileage and can't turn on/off the trip, I did not have the unit flashed hours and miles are "0"...What gives? I have all the steering wheel functions but these. Help
However, I'm still interested in getting an upgraded wheel/tire via aftermarket that upgrades the look, and that can still handle the unpaved roads, snow cables, pot holes, etc.
Has anyone found a comprise along the lines of an 18" custom wheel/tire rig? If so, is there a good online vendor that you could point me to? I live in Southern California, so I imagine there may be several outfits down here I can visit, but it would be great if I could at least see an online catalog to choose from.
Any help is appreciated.
Mike
Check around all corners of the vehicle for grounding points for lights. There might be several points. You probably need to remove some of the light fixtures when tracing the wires.
Also check that trailer light hook-up.
You'll probably find a broken, loose or otherwise bad ground wire connection somewhere in the wiring system.
Your dealer, if kind, could perhaps tell you where the grounding points for light wiring are and then you can trouble shoot yourself but your dealer might also not tell you anything for free...
Arrie
And yes, the one major mechanical difference is AWD on the DXL vs. 4WD on the 'burb; if 4LO is important to you, then the DXL won't do. Entertainment-wise--although the 'burb does offer the nav option, it does not offer a factory slave CD/CD changer option...meaning, if you decide to get the nav option for the 'burb, you can either use the nav head unit either for navigation or for listening to audio CDs...but not both at the same time.
Any words of advice on having the dealer show me any vehicle functions, or are there any spare parts besides touch-up paint that I should buy now so I don't stranded somewhere? I travel for bass fishing tournaments quite a bit.
ciao,
Marc
It's better to pick up a new car in the daylight so you can inspect it for dings and scratches that otherwise you won't see until you wash it the first time (which will happen this weekend I bet, lol). After you leave the lot, it's going to be harder to get the dealer to fix any glitches like that.
Maybe take a halogen shop light along if you can't break loose from work before the sun goes down.
The most frequently overlooked item on the pre-delivery checklist seems to be the tires. Often they are overinflated to prevent flatspotting while in transit.
The only think else I can think of off-hand is maybe try to get a third key out of them at cost. Keys are getting pricy to replace these days.
Congrats on the new ride! Please post about your deal in the GMC Yukon /Yukon Denali: Prices Paid & Buying Experience discussion too. Thanks!
I bought the Yukon on a GMS deal (GM Employee discount) that I qualify for through a family member, and got the $5,500 rebate on top of it, which made me jump quick. Besides, I like a little chrome on my car bumpers, so the '07 model doesn't excite me.
ciao,
Marc
It depends. Here's a timely post (to the tune of $138!):
tom85, "Jeep Commander: Problems & Solutions" #12, 9 Jan 2006 10:29 pm
ciao,
Marc
Or did GM add some chrome stuff to the exterior of the '06 Denali? :confuse:
Got me wondering if my Brother is getting lazy on me?
So far I love the Denali, though I have to get used to the AWD feeling which is very different than my 4wd Tahoe.
ciao,
Marc
