Chevy Colorado and GMC Canyon 4x4/Transfer Case
Hi, I own a 2005 Colorado Crew Cab 4WD Pickup. I have a problem with the 4WD. The truck involuntary moves from 2 wheel drive to 4 wheel drive. This happens at least once or twice a week.
The truck randomly (involuntary) moves from 2 wheel drive to 4 wheel drive when:
1. Slowing down for hi-way construction areas for a period of time (front wheels kicking in and binding up).
2. Coming to a stop, then, turning at a stop sign. (front wheels binding up)
3. Pulling into a gas station or parking lot and turning left or right (front wheels binding up).
Does anyone else have this problem. I would like to visit with them. GM has written a bulletin on this issue, but has not come up with a solution at this time. Thanks.
well I also have the 2005 Colorado 4 wd, same problem has occurred twice....this is the easier part....Last week after making a right hand turn and getting onto the gas again, the engine revved, car felt like out of control....loss of steering
As a result wiped out the side of the truck, a mailbox and thank goodness no oncoming traffic as the truck went across the hiway.
Right now the truck is in the shop getting tested....found nothing wrong mechanically....called Customer Service at GM...opened a file, and told me to take it to another diagnostic test at a certified dealer and call back.
Scared to drive this vehicle...was lucky this time.
Does anyone else have this problem?????
Any help on this appreciated.
This in turn sends a signal to a vaaccum switch that engages the right front axle putting the truck in 2 or 4 wheel drive.
Although the lite may say a change has occurred, the vacuum switch may or may not have activated, and this is when you have the problem.
If one has a transfer case that uses a coupling inside the transfer case to engage the front axle as in selectable 4wd, the electronics operating it, can cause the same problem.
Had it occasionally on a 2002 Envoy.
One should think that the technicians should, by now, be familiar with both problems.
-george
I Know Nissan already extend warranties for the new transmission CVT. Why Chevy don't ???? American Revolution???
I apologize that you are experiencing a concern with your vehicle. Have you taken your vehicle to another dealership for a second opinion? How long has the concern been present? Is the concern intermittent or all the time? Thank you,
Mariah GM Customer Service
Didn’t they fix your concerns at the dealership? That last time I spoke with you, you had stated that everything was going fine after the fix. Did the concern return after the fix? Thank you,
Unfortunately, I can only assist customers in the U.S. However, you can talk to an agent in Canada about your situation and have them look into the concerns further. You can contact an agent in Canada at these numbers:
1-800-263-3777 (English)
1-800-263-7854 (French)
1-800-263-3830 (TDD users)
Our Customer Communication Centre hours of operation are:
Monday to Friday: 8:00 a.m. to 11:00 p.m. (E.S.T.)
Saturday: 8:00 a.m. to 5:00 p.m. (E.S.T.)
If you have any other questions please let me know. Thank you,
Sarah
GM Customer Service
Sarah
GM Customer Service
Sarah, GM Customer Service
Please let me know if you do.... Thank you so much!!!
Ive brought mine to 3 dealerships, and no-one seems to have a clue.... they all told me the same thing they told you. A new transfer case. well I put one in, and now the new one is doing the same thing that the old one and yours is doing... Go figure... If I hear anything I'll let you know. Please do the same. Thanx and good luck...
yeah right...
Hi I have a 2005 4x4 Gmc Canyon with 199,000km and the last couple of days I've been getting this thud thud thud sound from the drivers side floor only when its in 4x4 cant hear anything when the window is down ..... Is my front diff ready to explode or maybe a bearing?
You guys have to be stopped and in neutral before you can put it in 4 low.
Also, try not to ever 4x4 on the fly it wears some part down rather quickly..
Last, these trucks, most of them, have automatic locking differentials, which means you probably don't even need to use 4x4.. hi or low... And 4x4 low is low gear... meaning for towing something under 30 km/h...
These trucks also have transfer case issues and should of had been recalled.. Every single one of them has a clip inside that wears a hole in the csae which results in leaking fluid out and burning out the gears... Don't Think I will buy gm every again..
