-June 2024 Special Lease Deals-
Subaru Forester (up to 2005)
http://subaru.com/contact/contact/middle.jsp ,
Tom. I think the "Suggestions for Subaru" board works on a longer time scale, and I agree with you it is not too late to make recommendations with regard to the availability of leather and moonroof with the manual, or interior colors, etc. I hope lots of people will give it a shot.
- D.
Thanks mtngal and juice
Thanks again,
williaday
I think the two-tone gray/black looks nice, though, especially in person.
Ken: the suspension looked stock. I think the rear sway is 16 or 18mm, i.e. same as stock. Ride height seemed the same, I dunno. I think they only had 2 Foresters on the show stand, both turbos! So we could not compare side-by-side.
HOLY COW Larry! Man, that is filthy! Mine looked nothing at all like that after a year of use. I'd better check it again, I have asthma, and so does my 8 month old. :-(
Good luck shopping, williday. Let us know what you end up with, either way?
-juice
I was curious about the new auto I have heard about. Is it going to be that much better then the 2003 transmission?
If it's going to be much better I would wait for the 2004's.
Ron
2003 prices are very, very competitive right now, so if you get the 2.5l engine I'd start shopping. But one magazine had the turbo starting at $25k, so even the auto could squeeze in at under $26k.
-juice
Thanks for the reply.
I thought I heard that the auto would be of a new design for the 04's ?
What do you mean "no manual controls"? You can't select and hold a particular drive ratio in the present autos?
Ron
The XT auto will be a newly redesigned transmission, but there are not too many details on how new.
What juice was trying to say was that the XT auto won't have a "tiptronic" interface that lets the driver up/down shift at a flick of a wrist. It will have the usual D-3-2-L selectors, however.
Ken
It's not a Sportshift with tap up/down gear shifts.
-juice
What has been your experiences with wind noise coming from the moonroof?
Thanks for your help in advance.
We do detect wind noise from the driver's side mirror or window seal, not sure which. One of these days, I plan to investigate this in more detail. Mirror noise seems to be a typical thing on Outbacks and Foresters, or almost any other SUV/wagon type of vehicle.
Craig
How many miles are on yours?
The wind noise is probably from around the window seal. The gasket that attaches to the side mirror creates a very small deformation in the window seal that lets in a miniscule amount of air.
BTW, is the tweeter for the 2003s located right by the side mirror?
Ken
Gene
The moonroof is loud when it's open, because it's so huge. Opening the rear windows stops any buffeting. Then it's a virtual open air experience.
-juice
Well, if I get a Forester XT that would fix the problem. :-)
Ken
-juice
The tweeters on my WRX are mounted forward of the door handles. You have to remove the entire door panel to access them. What really bugs me though is that they are in the totally wrong place -- you can barely hear them. The mirror-level tweeters on our Outback and Forester are much better placed.
Craig
1) It sounds like I am the only one that is not in love with my Geolanders. They tend to squeal way too easily going around corners or parking with a tight radius. Yes, I've played with the air pressure and had the dealer check the alignment. They're OK in the rain and snow, but not the best. I attribute the AWD for the surefootedness more than the tires.
2) Yes, Subaru says that the G900's are custom for the Forester. But that's just marketing talk for OEM tires that have some unique characteristic that Subaru specified. I don't think there's anything too different about them from other Geolanders, IMHO.
3) I plan on replacing my tires with the top rated Dunlop SP Sport A2's. They're excellent all-around tires with great grip and are reasonable quiet. They do not have raised white letters, but after seeing pix of the Japanese spec Foresters, I like the all-black better. Also, Consumer Reports a few months back tested a bunch of tires and found that ALL tires loose most of their poor weather grip as soon as 50% tread wear. My wife read the article and agreed we will get new tires WAY sooner than when they're down to the tread indicator. Yippee!
4) Rough idle -- I only notice a *minor* vibration when the A/C is on and I am in drive with the brakes on. Otherwise, it's not that bad.
5) Wind noise -- no noticeable annoying wind noise with the sunroof or mirrors. Have never had that problem.
6) Forester vs. Santa Fe vs. Highlander -- I wanted a Highlander at first, but I comparably equipped Highlander to a loaded Forester is $9,000 more, and all you're getting is a V-6, traction control, woodgrain dash, and traction control. No thanks! The Santa Fe has evolved to a good car and is a little roomier, but the Forester is more refined and much easier to fall in love with.
7) DIRECT CONTROL -- I wish Subaru had been clearer what the Direct Control is on the XT, but it has implied it's an all-new transmission with smoother shifts. I don't know how anyone else feels, but to me this is a BIG deal. One of Subaru's biggest shortcomings are their less-than-smooth transmissions. All 3 of my Subarus have been rough shifters unless you drive them just right. I think a smoother transmission is a definite selling point for waiting for the 2004s.
Whoa! Sorry so long folks! Just my $.02.
Elliot
I personally like the snappy shifting in my Trooper and Subaru 4EATs mostly cause I know it means a longer life cycle.
-mike
Let's not get too technical there, mike! LOL
The current auto tranny is proven and robust, and to some that's what matters.
-juice
Since then, they've added EBD (XS), H-rated tires with "A" traction ratings to replace S- and "B" rated tires (X), standard head/chest side air bags (all), and a bigger rear roll bar (all). Plus quicker steering and active head rests. 2004s might even get 4 discs on the X models.
I don't think they had looked at one since the 2001 refreshened models came out.
Any how, they are tougher on their overall ratings so I doubt it'll do any better. It's virtually tied with the RAV4 for their highest overall rating already. It's also tied for 1st in reliability (with the CR-V).
-juice
Greg
Greg
-Steven-
Hope this helps.......
It's not hard at all, much easier than on the Legacy IMO. No pics, sorry, I think bitman had some but those were for the Legacy. You may want to look on NASIOC under mods, look at the short shift kit install because the instructions are basically the same for 2/3rds of your work.
-juice
The tough part on the Legacy is the ash tray removal and the screw in the way back of the radio unit. Forester is easy.
-juice
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item- =2411804060&category=13484
Mike k
Quarter million mile clubber there. Wow, if it's gone that far it'll probably never break. Someone ought to buy that.
-juice
-juice
juice: I was going to say $3900 is high given the milage. I KBB'd my Forester for grins and it spit out a figure around $8K. That's with 1/3 the miles and in "good" condition. I think used car sales are very slow in our area.
Ken
I don't know how to get them to show up as a picture, but anyway.. They're only 55 watters right now, not as bright as I'd like, but I'm going to upgrade them to 130+ watts eventually. I have it temporarily wired in to be switched on through the high beams through a single relay, I might change it though.
-Brian
I really need a car to fit an emerging family so I'm probably looking at the Legacy wagon, but with people always raving about their Foresters, I almost feel liking joining in the fun and making the family squeeze into a Forester for the long trips. I can always buy a big car-top carrier, right?
Anyhow, I'll be test driving the Subies in a month or so and make my decision thereafter. Who knows, maybe I'll even wait until I save some Subie bucks and save for the XT. Too many wonderful, exciting choices for one man alone.
Barkley.
Not trying to be a troll ... actually I'm leaning toward pulling the trigger on an '03 XS sometime in the next month or so. I took another test-drive a couple of weeks ago and enjoyed the car very much. Didn't try the cruise control, though!
Greg
Several things can affect cruise control by the way, so it's not far fetched that they might need to be adjusted at some point.
Craig
It could be possible that there might be a minor problem (small vaccum leak) in your friend's Forester that could be causing the cruise control to not perform smoothly. It's not an issue I've heard of happening, but within the realm of possibilities.
Ken
