I also used the Sylvanias. Are they just cheap or is it something else? I don't trust Mr. Goodwrench to do anything but run up a bill.
Console is the main problem. At times it works fine and then it will refuse to shut off. Now the key ignition warning also stays on when the
key is out. This key thing started after the car window was repaired and the door holder was broken in that process. We have pulled the fuse so these two don't drain the battery! Wondering WHAT is causing this and the simplest way beside the fuse pulling to solve this one?
the lights do NOT come on until the break is completely released! Try parking with the break on and turn car off and then back on. NO lights on mine when I do this!
Different years may vary but give it a try!
Hope it works for you.
If you don't care about the recirculate feature, you can also just unplug the motor at the blend door, located behind the glove box.
Carl.
There is so much room under the dash but they had to put that box in the most awkward place.When working under a dash it helps to use a mirror and flashlight.
Those mini fuses are rather expensive.
My 2 cents
Case 2
I've never posted to a forum before so hope I use proper etiquette LOL
I own a 2003 vibe that i have had very little trouble with. Yesterday I started my car to go to work and the instrument panel wasn't working. Everything else is functioning properly. I pulled the fuses under the hood and under the steering column but they were all ok. I disconnected the battery and everything started working again. A few hours later i went back out to check it and the panel wasn't working again! Any ideas???
lights are not working. I changed the rear tail light bulbs, and I replaced the
fuse even though it looked fine. I also checked and I have no power at the fuse. Is their another fuse or a circuit breaker that I'm not seeing? Is my next test going to be the switch? And if it is do I have to take the steering wheel apart to test it?
dom...
Most of the time its just the dash light or the tuner display won't work. I think I have found the problem--there seems to be a short in the front overhead light. Of course thisis one ofthose intermittent problems,so it will never do when I'm in the shop. Help!
How many times have you been to the dealership for the same concern? Has anything come up on the DIC when this occurs? How often does the concern happen? Thank you,
Mariah GM Customer Service
I have good fuse, new brake light switch, all good light bulbs.
I tried emergency parking brake trick too but it's not working.
could you please tell me what was the problem?
thanks.
My wife (its primary driver) has experienced five incidents of total lock-up/no key turn allowed/no starting/no shifting to neutral for towing onto flatbed, etc. During one of these lock-ups, someone suggested she get out and try to rock the car a bit. She did so, but dented the fender ($700 repair), and she is a smallish woman.
In all of these incidents, she did eventually start the car. The last one, the most severe, stranded her in a parking lot until the OnStar-supplied tow truck came along. The driver, giving one last try, started the car before towing. At that point, we took it to selling dealer.
The service manager (and other service managers I called, both Pontiac and Toyota) had never experienced this problem with this car. But, after a lengthy service stay (about a week), and much-appreciated "hand-holding" by GM/OnStar, the technicians took apart the steering column and found a defective part.
This part, stamped "Toyota," is a cast metal "ignition lock cylinder case" which was "damaged internally." Note that we've babied this Vibe: no rough use, regular maintenance, two adult drivers.
Again, I'm posting this note so that other Vibe and Matrix owners will have some helpful information when and if they encounter this "lock-up" problem in their cars. This problem is serious enough so that we were at the point of car-shopping for something else!
The car seems fine after the part replacement. Now, I'm working on getting some kind of relief on the $700 body damage that resulted from its refusal to start.
Sounds more like the headlight relay switch or a short moreso than a fuse. All of the wiring to your instrument panel goes through that headlight relay switch. So that may be your problem area.
Good luck
Were you planning on having the vehicle diagnosed? Please keep me posted on any information.
Thank you,
Caron, GM Customer Service
Diagnosis is scheduled for Monday.
Were you planning on having the vehicle diagnosed by a GM dealership? Please keep me posted when the issue has been taken care of.
Thank you,
Going to have the ECM recall done next week. I bought my car from a Toyota dealership and it has a 60 warranty so i will have them diagnose the issue for me. I will let you know what happens
Ken
I understand. I look forward to hearing from you when the dealership has diagnosed the vehicle.
Thank you and have a great weekend!
Were you planning on having the vehicle diagnosed by a GM dealership? Please keep me posted.
Thank you,
Went to the dealer, they seem to know all about this issues. As the GM rep, why is this not a warranty issues since it seems to be recurring in the Vibe?
The 2006 Vibe had a 3 year/36,000 mile Bumper to Bumper warranty against manufacturing or material defects as a new vehicle; however, as you know this warranty will have already expired due to time.
If we can look into this further with you, please contact us via email (include your name/Edmunds username, the last 8 digits of your VIN and current mileage, and the name of your dealership).
Sarah
GM Customer Service
