Visitor Agreement.
My 2001 S is just barely adequate in this area.
I had it checked out by a personal mechanic and dealer guys. All say it gives the best its got. The dealer guys gave me some jive that "The B14 is not as good as the earlier B12 cooler unit" (or was it B16 and B14?). Darn, it's loud on the 4 setting, and sounds like it's really working hard. Anyway, let it me the most of my concerns.
Supremely happy otherwise.
In the US it is illegal to have more than four headlight bulbs lit at any one time. Some headlights use both the low and high beam bulbs at the same time so if the fogs stayed on that could total 6. Thus the foglights are universally designed to go out when the high beams come on. The US has been historically and notoriously late in adopting new headlight technology; witness the recent HID fiasco. Having done nothing until recently to curb the use of cheap illegal blue bulbs, the DOT has only encouraged manufacturers and consumers to shy away from true HIDs.
Can't remember where I got that notion/info from.
-Dave
My wife's Legacy cools well also, and that's a 2002. Maybe that one is a higher capacity unit, I dunno.
-juice
Steve
-mike
Window defrosting - AC comes on, and if you want to prevent that, it's possible to re program its behavior.
Auto window - functionality can be switched off or on.
So, is it possible to do a custom programming to a Forester?
K
-juice
I didn't mean those specific features, but re programming in general. I'm almost sure that every computer controlled car has some way of playing with it that isn't made public. And BTW, I think that my owner's manual states that AC comes on during defrosting no matter climate or not (I don't have it also)
K
While you're waiting for a Subie to reply (c'mon, gang!) you might check out the general tire discussion in Tires, tires, tires.
http://www.endwrench.com/current/Current6/03/InsiderInfo.pdf
Cheers
Pat
I have that size now, but my wheel offset is different, +40mm IIRC. That put the wheels farther out, away from the body, leaving enough space for the bigger tires.
I have my spare inflated to something like 38psi, I'd air down my 225s so more closely match the spare if I ever got a flat. FWIW, the donut on the Legacy seemed to have a bigger difference than my unmatched spare (which is why we changed it).
-juice
Interesting also is the internal ad for remanufactured brake calipers. What does the name "Akebono" mean? I'd only heard it before as the name of a now retired sumo yokozuna who is originally from Hawaii.
Ed
Craig
Len
Thanks for this good info. I had a feeling the dealer was giving me a line. Can you comment on thermostats that work at different temps? I've read that keeping the engine at a cooler operating temp inproves performance. One article mentioned installing a 170 degree thermostat vs a 172 degree thermostat. Any opinions or comments?
OHSubeGuy
However, it helps to grease up the suspension bushings, which might otherwise squeek.
Do this when you rotate the tires, it's wide open and easy to access.
-juice
What about changing the thermostat, guys? Advantages, disadvantages?
-brianV
I've not heard that changes in temperature aids performance in any way - barring the extremes of the cold just-started engine and the over-heated engine.
So I'm interested to hear otherwise.
I think the engine management system is optimized to run the engine at a set temperature. If you lower that set value by replacing the thermostat, then you might confuse the computer which might continue to run the engine a littel richer until it warms - which is never will because the thermostat has been changed. Again, I question if 2 degree would make any difference here either.
Let us know what you find.
Steve
OHSubeGuy
Leo dC
-Frank P.
Leo -- The US Forester XS does not have self-leveling suspensions. They are only available for Japan and Australia/New Zealand.
Frank -- Tinting makes a world of difference. Even with a 70% tint (virtually clear) on the driver's side window (that's all that's allowed in CA), I can feel a huge difference in the heat hitting my arm in the summer time.
Ken
Ken
Craig
-Frank P.
rsay: I use Maguiar's Gold Class Vinyl/Rubber Protectant. It does not turn the tires brown like many products. The tires do get a slight white haze when wet for a prolonged period (a day or so) though. It is available at Auto Zone. They also have a webiste www.maguiars.com.
1) Edmunds lists an XS and an XS with Premium Package (about $1000 more). However, dealer literature doesn't describe such a difference. What is in Edmunds Premium Package?
2) Edmunds says if I buy a Popular Equipment Group for $282 three options are included (splash guards, cargo tray & rear bumper cover). However, when I look at the price sticker on the window of the car, the invoice shows the price for the Popular Equipment Group AND the three "included" options. Which is correct?
3) The dealers I've talked to have a cold weather pkg (heated seats & mirrors, front wiper defrost). I can't find these on Edmunds.
4) The dealer tells me "invoice pricing on the internet can have errors." I used to consider this garbage, but given the discrepancies noted above, I'm beginning to wonder. Help!
You may also wish to provide our editors with feedback.
2) The "Popular Equipment Group" does indeed include the items listed (usually at a slight discount from what they would cost separately). It's possible that the maroney sticker (window sticker) lists the options twice but only once should be with a price. If it appears that they're trying to make you pay twice you should point out the error to the dealership.
3) The cold weather (aka All-Weather) package comes standard on the XS and XT and isn't available on the X. Therefore the heated seats & mirrors, front wiper defrost, rear LSD and EBD (see pg 9 in brochure) are listed as standard items for these models by Edmunds.
4) Au contraire! From my rather extensive research, Edmund's prices are almost always to within the nearest dollar of the manufacturer's invoice pricing (Kudos to Edmunds!). The only exception I know of is New England dealers slap on a couple hundred dollar "regional advertising" fee.
-Frank P.
Ken
Elliot
Leo: the self-leveling shocks are only offered in Japan, though I guess you could import some at a price. kajko tried iSR's taller, beefier springs and they had issues with the fit on the new models, so that's on hold for now. Primitive does sell a front skid plate you could add for now.
-juice
-james
the self-leveling suspension is std on Australian 2003+ XS models. there's a good description of the system in the australian write-up of the Forester (i posted a link quite a while back). the struts have a little oil container that pumps more oil when strut is under load. the system is much different from the old (and prone to breakage) air suspension. What's more, 1stsubaruparts website lists the SL struts as available for the Forester here in USA. I'd be very curious if in fact they are. If so, it should be easy to upgrade. The Australians i correspond with tell me that self-leveling is great for loading the car up, e.g. camping trips. As juice mentioned, i am going the stiffer springs route (i want height and stiffness), though still waiting on the 2003 springs...
cheers
