Visitor Agreement.
and how many different sensors are there?
anyone know what this could be?
Thank you all for your help, this is a wonderful website.
:shades:
When it tries to start, it willl just barely cough & sputter for about 1/2 second. I've added drygas deicer, to no help & tried a few blasts of starting spray. Good strong battery and cranking.
But what is disturbing is that about every 5th try I get a severe backfire that ocassionally blows off the air filter cover (knocks the spring clips loose).
If I do manage to get it started, it clears its throat & runs fine for days or weeks.
Also, I noted every time I have this trouble the gas tank is near 100% full.
I have a 1996 Tracker 127,000 miles on it, 4cy 1.6 engine.
The vehicle starts up everytime on first start up no matter how hot or cold it never fails me. however, after driving it for awhile and engine is hot, it will want to stall or does stall out ,but starts right back up again, sometimes you will have to flutter gas petal to keep running, but once running it runs great no stutter or sputtering, just wants to stall or does,, any help would be greatly appriciated!! Thanks!
i absolutely am in desperate need to fix my ****** tracker as it brings me to and from work (i travel across ontario, so you see how important my pos is)
i have read millions of threads on here about cam sensors overheating and have the same problem. i have already replaced this sensor, as well as fixed the fuel filter, changed the spark plugs and have spoken to a mechanic at a shop. there have been no solutions so far. right now, my boyfriend has my windshield washer resevoir hose ziptied to the top of my camshaft sensor so when it starts to act up in traffic (or anywhere for that matter) i can quickly stop it from dying on me. i know this is not the "mechanically proper way" of fixing this issue, and i cant keep leaving pee stains everywhere i go. PLEASE HELP. someone, anyone, give me some ideas. WHY IS MY CAMSHAFT SENSOR OVERHEATING?! ??!?!?!?!?!
i am ready to pull my hair out, and my boyfriend is losing hair as i type. :lemon: I HATE THIS PROBLEM AND IT NEEDS TO STOP FOR GOOD. any suggestions????
KNOCK SENSOR 1 CIRCUIT HIGH INPUT BANK 1 OR SINGLE SENSOR
WTF???????? there is no such thing in a tracker.
The mechanic we took it to put it on the diagnostic and and he couldn't find anything wrong with the car. The check engine light does not come on and the temperature gauge does not rise. He changed the fuel filter and we hoped that that would solve the problem. Unfortunately it did not. Five days later, after no problems, the car started doing it again. It happens regardless the time of day, as it has done this in the morning, middle of the day and in the late afternoon/early evening. It has also done this with the AC being on and off. What the hell is going on here ?? My wife had a '97 GEO tracker that was stick with a 4 cylinder engine and it NEVER did this, EVER !! Now, the '02 she's driving started doing this about a couple weeks ago. It's frustrating to say the least. The one thing we don't want to do is start replacing parts frivolously in order to chase this problem down. Does ANYONE out there have a solution for us or at least a similar story that can be shared that has gotten the problem fixed ?? Thanks in advance for the information, my wife and I both certainly appreciate it.
P.S. - I've read people referencing the Cam shaft sensor and another sensor, but could it possibly be a bad or going bad catalytic converter ??
i hooked my snap on scanner mt2500 up and my timing is siting at 12* but wen the engine sputters the timing will jump to 20* and then go rite back to 12*
plugs are good,fuel is good,all the routine stuff is good
it kinda acts like i am flipping the key off and back on real quick within a half sec
wud i be correct in assuming the ckps only monitors for cyl misfire and does not give a signal for spark or injecter pulse?
