Mazda5 Tires & Wheels
Talk about your Mazda5 tire & wheel issues here.
I'm curious if the Mazda5 will have the same problem.
Really? Do you live in a small town? Because if you go to the specs page for the Mazda5 here on Edmunds.com you will see that the Mazda5 tire size is: P205/50VR17. That doesn't sound like an odd size to me.
Personally, I think the tires are way too oversize for a family wagon. If I purchase a 5 I'll probably swap out the monster rubber for 195/65 R15s and new rims. There's only about .4% speedometer error and 1) I'd get better gas mileage, at $3 per gallon this is significant and 2) I'll save $300 to $400 each time I replaced the tires.
Mazda really needs to parallel market to "sensible" over 30's. The Matrix/Vibe twins were all about youth appeal when they came out yet the majority of drivers I see in these are seniors attracted by a small economical wagon.
Do you know how much of a MPG difference this might make? At $3 per gallon, every 1.0 MPG increase in the Mazda5's mileage saves roughly $70 per 15,000 miles. So, I can see how an increase of 2-3 MPG could be significant.
Except for the initial tire change, of course
Really? Thank you for pointing out the obvious. Of course I know that the Protege5 and Mazda5 are different vehicles, especially since I own a Mazda5 (read my profile). However, his question was if the Mazda5 might have unusually sized tires and I was giving him the specs on that. Maybe I should have looked up the Protege5 specs to see what size stock tires were on that vehicle.
"Personally, I think the tires are way too oversize for a family wagon."
So-called practicality would doom it for certain. What attracted me and many others to this vehicle was not just the '5's functionality, but also some unconventional features like a manual transmission and sporty nature. Read the many customer reviews here at Edmunds and other sites on the Internet. Keep in mind, because the prospects of selling this vehicle in the NA are low to begin with, Mazda had to keep the choices simple. Europe is another story because vehicles of this class and size are extremely popular. I am sure it's the same way for American cars sold abroad. Choices are kept relatively simple when projected sales volumes are small.
"Mazda really needs to parallel market to "sensible" over 30's."
Why? And what is a sensible over 30-year-old? Again, it's the KISS principle and Mazda felt they should make the car appeal to the broadest possible audience.
The first time I had tire problems, it was in BC, but the second time, about year ago, I was in the US travelling through Washington state. We ended up "stranded" at a hotel since no one had tires close enough, it was evening, and we couldn't get home on the donut. So the next day I had to phone around and I found a dealer 1.5 hours away. Travelling that far on the freeway with a donut, going under the speed limit during local rush hour with my hazards on, and with the car completely packed to the gunnels with camping gear, was pretty stressful.
So I'm sensitive to tire availability now, which is why I'm wondering if I will have a hard time finding replacements if I get a Mazda5.
Are you sure? I did a look-up on factory specs for a 2002 Protege5 and it's 195/50R16. Maybe that's why you're having such a difficult time finding tires? I thought the size you gave sounded a bit odd - given that the Protege5 seemed to have a fairly low profile tire. I did a quick search here in SoCal for the correct tire size and had no trouble finding it in stock. I cannot say how difficult or easy it would be be to find a 195/60-16 tire.
But it's good to know the Mazda5 has a generally available tire size.
As for low profile, e.g., 17" rims vs. 15" rims, I have no idea if that makes a difference in performance. All I know is trying to get 17" snows for the Mazda5 would be difficult and expensive. We are picking our GT today and I am hoping the tires are sufficient for this winter - next winter I will put on 15" rims with snows.
1. Going to a smaller wheel will mean cheaper rims, tires, and more selection so it is definitely a good choice.
2. Friction is calculated using a coefficient of friction between two materials and normal force. Surface are is not really a factor. Therefore the width of the tire has very little effect on friction force.
3. Everyone experiences different winter driving conditions. I live in Edmonton, Alberta where we have long cold winters. Most of the driving I do is on plowed streets and highways. What concerns me is ice and packed snow. In this case I don't thing the size of the tire will make make much difference. If you encounter a lot of fresh snow and slush then I would agree that a narrow tire can be better. If you are driving through 6" of snow, there will be less rolling resistance on narrow tires and they will therefore require less traction to move forward. Narrower tires are also better for slush since there usually firm footing underneath the slush that you want to get to and a narrow tire can carve through the slush easier.
In summary, down sizing definitely makes the most financial sense. As far as ice traction goes it makes very little difference what size your tires are. Narrow tires can be better because of decrease rolling resistance through snow and cutting through slush to get to pavement.
As for tire size not affecting overall traction, that is wrong. The concept of the available force simply being a factor of the coefficient of friction times force on the contact area is so simplistic it only applies to grade 9 science. In general you want as much tire contact patch as you can "afford" as long as the surface is reasonable. Once the surface turns to junk like gravel, snow, mud, slush, etc. then you are now into a completely different ball game.
Michelin X-ICE or Nokian RSI's are excellent studless snows. We have the Nokians on an Accord V6 and I'm going to put X-Ice on my subaru this Winter.
I can verify that when 4-wheeling in NC red clay that momentum is your friend and if you lose it you sink. And walk home.
I'm also convinced beyond a shadow of a doubt that summer tires on a Miata on the ice makes for an absolutely miserable drive home.
Are there any plans for bringing out an AWD version next year?
BTW, the manual mode supports starting in 2nd gear for icy conditions. I found that starting in 2nd and using a light foot will overcome the shortcomings of the stock tires. Of course, I accepted long ago that my driving habits need to change with the weather.
So essentially, it depends what you'll be driving in, and how often. But I do want to stress to anyone thinking of buying this vehicle, that it is an excellent vehicle, a fun driver and other than in heavy snow, the stock tires will do for winter and excel in summer. But, if in doubt, you can't go wrong with a set of four snow tires, whatever the brand. They are well worth the investment and piece of mind.
How does the new tires work/affect the TPMS system? Does the warning light just stay lite on the dash all the time?
HiFive in Minnesota :shades:
Any experiences would be welcome.
I would imagine the TPMS could be temporarily disabled by the dealer as well.
I live in CT too, (Hartford area), and just this evening also mounted Dunlop M3 snow tires on 16" wheels, (Kazera's), which arrived mounted (tire on wheel) and balanced, from the Tire Rack. Though I haven't had an opportunity to drive them in the snow, as all it did was pour rain here today melting the last of what we had, I did alot of research prior to buying and the Dunlop M3's got the best rating overall. But really, any winter snow tire would do better than the stock tires in snow and ice!
Finally, there was a post a while back where someone was wondering if 15" wheels would fit on the 5. From what I can tell, the answer is a resounding no! With the 16" wheels, the wheel balancing weights clear the brake calipers by about a 1/2" at the most. Any smaller wheel and it wouldn't fit.
Vancouver, eh? I guess that makes you a Seahawks fan? I'm from Pittsburgh.
The "p195" is the width of the tire.
The "60" is the heighth of the tire as a percentage of the width. (40 being very low profile, 50 being lowish, 60 being pretty high)
The 16 is the circumference. I dunno what the "R" means!
The odd part about the measurements you quoted is the "60" That would be a relatively HIGH profile tire. That would look (and feel) kinda a little strange on a Pro 5. I would recommend a p195/50R16 (50 instead of 60). The rims don't care about that portion of the measurement.
Anyway, www.tirerack.com will point you to getting the right tire cheaply and easily.
You have to be very careful when you compare tires.
Every measurement is important.
P205/50R17: P: Tourism tires
205: Tire width (in millimeters, divide by 25 for inch)
50: % of the width applied to sidewall height
R: Radial tires
17: Size of wheel.
To find out a plus one or two or zero replacement, use that formula
(Width/25)*(sidewall/100)*2+(size of wheel) = height of tire.
Ex: Plus 1 for Mazda5 GT, Touring, Sport.
P205/50R17 = (205/25)*(50/100)*2+17 = 25.2 Inches
P225/40R18 = (225/25)*(40/100)*2+18 = 25.2 Inches
(Almost perfect match, see note (1)).
Plus 0
P205/50R17 = 25.2 Inches
P225/45R17 = 25.1 Inches, acceptable. (1)
Rule of thumb, ± .5 inches difference from original size is acceptable, more than that will affect the odometer reading.
So, for a down sizing for winter tire:
P205/50R17 = 25.2
P205/55R16 = 25.02 (acceptable)
P195/60R16 = 25.36 (higher, but still acceptable)
P195/50R16 = 23.8 (Too low, affect speedometer, tire do more turns)
(1) For those of you with more knowledge of tires, Don't forget about the compressability of the sidewall ratio.
Ex: 50 sidewall ratio tire vs a 45, IE a slightly lower 45 won't compress as much as a higher 50, thus making them almost same height...
Don't forget, when doing Plus Size, that you will test before.
Tire must clear fenders, steering and suspension when riding, turning, and going over obstacle (bumps).
Do you know if a 215 or 225/50R17 will fit the stock Mazda5 wheels?
From what i've heard, the stock wheels are 7" wide, so a 225 should fit.
Even then, it would probably protect the wheel lip, since it protrude so much from the tire.
I intend of putting a set of 225/45 this spring, like the ones on the Audi A3, to replace the Yoko.
It will hurt MPG and maybe acceleration a little, but better looking and handling than the stock.
Anyone interested for 4 brand new tires (got the car at 16 Km, removed the tires for winter ones at 80Km, so basically the tires have 45 miles)! I'll probably trade them for wider ones at the shop.
The 205/50R17 seems to be an odd size. There aren't too many replacment tires for it.
Thanks for the info!
Anybody else notice this?
Our MPV had a recall in 2003 because of a door jamb sticker. I wonder if this will be similar or is of no consequence.
John
The US Mazda5 models should have come with Toyo tires in the 205/50R17.
Discount Tire list 6 different tires that will fit, ranging from Kumho Ecsta ASX at $115 each to Michelin Pilot Exalto A/S at $195 each.
Odie
Odie's Carspace
I am considering buying a Canadian M5 GT, which comes with 17" wheels. Given my desire for comfort over maximum handling, I would actually prefer to have the 16" wheels that come with the GS. Is there anyone in the Toronto/Thornhill area that has recently purchased a GS but would like to swap wheels with a GT?
