Subaru Forester (up to 2005)
paisan: I could live with a wheel bearing failure after 50K miles. Recall I've had three already in my car, at 8K, 13K (improper install), and 32K. And still I plan to buy another Subaru, knowing that the design flaw has been addressed.
Ed
Some other guy with a Forester turned me on to them... I now have 9,000 miles on them and they are a dream....
The car grips and corners like my friend's BMW..
What a difference driving the road in Colorado between Canon City and Salida....
P.S. Discount Tire gave me $10 each for my used Geolanders ....They still had 1/4 inch of tread left.
-mike
Kim
They also want to sell me an extended warranty.
What do you all think I should do? I normally don't buy extended warranties. If I needed an extended warranty for a product, I shouldn't buy that product.
I don't like prepaid maintenance or extended warranty plans, but some people like the comfort and perks (like loaner cars) they give them. The ext. warranty may even pay off if you have a bunch of problems down the road, but I'd rather keep my money and take my chances.
Finally, ask yourself what you can do with that $1050, whether it earns interest, gets invested, etc. I'm fairly certain you will benefit from having that money more than the dealer!!
As far as the extended warranty, some people like it but I have never needed one with Subarus or Hondas. If you really want it, be sure to shop around as prices vary, and be sure to get the "Subaru" warranty. I think someone else posted that prices varied as much as $400 on the Subaru warranties depending on the dealer.
If the dealer is pushing either of these options too strongly, I would get the impression they are trying to work you over. For reference, you should be able to buy most Subarus (except the STi) for very close to invoice. We paid about $300 over for our Forester XS when they first came out last summer. Probably even better deals now.
Craig
Edmunds service for the 2004 XT doesn't match what I downloaded from Subaru. It doesn't even make sense: an oil change at 3000 and at 3750? What the hell?
gened1 Aug 24, 2003 9:10pm
Is the normal oil service change interval 3,750 and not 7,000 miles then? Sounds severe to me :-)
If you follow the severe service schedule, it's every 3750.
$134 is definitely steep, even for synthetic. When I do visit the dealer for service, they typically charge $17 for an oil change and $35 for a rotate and balance. I think $35-40 is reasonable for an oil change with synthetic considering the cost of the oil.
I really like the Subaru Forester XT. I'm almost dead set on buying one. I put $200 to hold one being brought in this week, but these service rates are making me nervous. I guess I'll have to call around and see what other area dealers charge.
Granted, wheel bearings and differentials are different beasts. I should spend a little time on the Audi boards and elsewhere to find out if all full-time AWD systems are as sensitive to changes in tire size.
Ed
Craig
I'm helping my boyfriend change oil in my '02 Forester and we've got the belly pan off and changed oil and filter but now we're trying to put the belly pan back on and we've fastened the four bolts but can't figure out how to re-attach the fasteners in the wheel wells.
Can somebody quickly tell us how to re-attach these fasteners or direct us to the right forum to ask? TIA!
I'll surely appreciate any response!
---haly
---haly
There's an oil change thread there that you can browse while waiting for responses:
hammersley "Subaru Crew - General Maintenance & Repair II" Aug 18, 2002 11:29am
Good luck!
---haly
-mike
For now, we'll just leave them un-fastened for it doesn't seem to hurting anything.
Thanks for your response, mike.
---haly
-mike
---haly
Chuck, I can see why you do that! I'll definitely consider it. Or, we were thinking of ditching the fasteners and using just a nut and bolt. Why couldn't they have just used another set of bolts that screw into the metal just like the other four bolts???
Thanks again, Steve, mike and Chuck!
---haly
Len
Sorry I was not around this weekend, I have photos of the fasteners, oh well.
-juice
If you were born yesterday and I told you an oil change costs $140 but that I can give you a "special discounted rate" of $120, you'd logically assume that I was offering you a good deal. However, since you assumably have a modicum of common sense, you know that the "real-world" cost of an oil change is a fraction of what the dealer is asking. If it were me, I might buy from them but there's now way I'd go there for service (other than for items covered under warranty).
-Frank P.
juice: Oh, I was pretty sure they popped into metal but I wasn't the one who was fighting and cussing with it.
So, as I asked over in the other theread, does everybody think a girl will have any problems changing oil in her Forester without any problems? I think I could do it by myself. I'm pretty sure I have enough strength to tighten the oil filter and the drain plug (and I don't think they need to be tightened that tight anyway, right?) but I'm hoping I have the strength to loosen the filter and the drain plug. Maybe I should start lifting weights or somethin' :P
---haly
-mike
---haly
-mike
But thanks for reprimanding me gently, tidester! At least I didn't spell it out completely! :-p
hi again, mike!: So where on your profile do I find where to buy this metal skid plate? Does it fit exactly with no modifcations? I don't want to have to cut, trim or otherwise do any modifications to a piece of metal ...I'm terrible with tools! An oil change is about the most I want to tackle that involves tools!
---haly
-mike
---haly
This has been occurring for a few weeks now, and I've gone through probably 8 or more tanks of gas, so I discount the possibility of some bad fuel. The car had new plugs, air and fuel filters (all Subaru parts) installed a few months ago, so I discount those as well.
I have an appointment with my dealer on Thursday to get it checked out, but I was hoping someone here might have heard of a similar condition involving this problem on a Subaru before.
Thanks in advance for any and all assistance.
Len
http://www.fumotovalve.com/
YM International Co., Authorized online retailer of Fumoto Engine Oil Drain Valve, wishes to provide you and your friends with a SPECIAL 15% DISCOUNT OFFER to thank you for your supporting
our business and celebrate the Holiday Season.
Using SVC5 as a discount code, you and your friends will get 15% OFF when ordering at online store: www.fumotovalve.com
This Special Offer is for limited time only. *Expiration: 12/31/03"
-Dennis
I stupidly bought the one without the nipple, dang it. Using a drain hose would have been handy. I guess I feared that the additional fitting length might make it vulnerable, but after installing the regular valve I now think the nipple-equipped unit would have been fine.
Well, I'm having trouble keeping my cross-posts straight! lol! So, I think it's time to end this all. I really don't want to be a hog! I'll copy my message from the other thread here. Again, to all of you, a big THANKS!!!!!
Jon: Yep! Boy, did I learn this past week-end how hot the engine and its parts can get! ...good tip! Thanks! And, I think you're right, I probably will use a new crush washer each time. It's a conflict between my frugal side and my obsessive-compulsive side (thanx, tidester, if you're monitoring this board too!
Dennis: Yeah! I know! But I think people on both boards are now getting tired of me. After all, I've been almost hogging both boards for the last few days. So, I think it's time that I now lay low.
Okay guys, I guess I better slow it down and stop hogging the board with my posts because others have questions too! Thanks again to everybody who has taken the time to answer my questions and give me advice! The "crew" is really something! ...it's really been a startling experience to see so many people who are willing to help and share advice. You guys are great!!!!!!!!!
---haly
-juice
My wife is constantly slamming the door on the buckle and belt; when I tell her to push the lot of it inside the car she usually mutters something about "bad design, poor quality."
Suggestions? Is there a fix?
Ed ('00 Forester, just hit 60K miles this morning)
Craig
http://www.waitnews.com/hyundai_tucson.htm
At any rate, Hyundai's quality has been steadily improving so yes, Subaru should keep an eye on it.
Ed
I think the Sorento is bigger, plus it has a full frame and a low range. This Hyundai looks more like a small sport wagon.
-juice
The Sorento's problem is weight. That causes poor fuel efficiency, which is a side effect of excess weight. Plus that 3.5l makes good torque but could do a lot better in the HP department.
Sorento is very handsome, the price is great, warranty is solid, and it offers TOD from Borg Warner. But the market wants cars, not trucks.
-juice
He said since the wear bars were showing on one of the tires he wasn't allowed to rotate them and recommended that when I replace them I replace all four at the same time.
The tires are Bridgestone Dueler H/T 634 factory original and have 27,400 miles on them. can't believe that these tires would have so much wear in what I think is a relatively short time. The car doesn't feel like it has an alignment problem but I would really welcome any advise or ideas on what is causing this. I monitor my tire pressure regularly. I'm considering having the dealer check the alignment and then purchase some new tires, but I certainly don't want the Duelers if this is how they wear.
Any suggestions on diagnosis and better replacement tires would be much appreciated!
Thanks in advance,
Donn
There are many better choices out there. If you still want a Bridgestone, look at a Dueler H/L, it is rated much better.
The tire size might limit your choices. I think Costco carries Bridgestone, BF Goodrich, and Michelin. You just missed a $60 rebate deal on 4 Michelin tires, it expired November 1st.
Look at the BF Goodrich Touring T/A HR4 tire. It's more pavement oriented. The CR-V comes with either that tire or the same Duelers you had, and the BFG tires are preferred by far. Plus the price is competitive.
-juice
