Subaru Forester (up to 2005)
Considering that Subaru lauded the additional anti-dive anti-squat characteristics of the 2nd-gen Forester suspension, it is surprising how much the nose rises when you punch an XT in the lower gears. Not knocking it, though. It truly is a "look" I haven't observed since the '60s musclecars. I suppose the relatively compliant, long-travel Forester struts have much to do with it. I genuinely am in love with the balance between ride and handling they provide.
I might be qualified to compare a base Forester to a base Legacy, given I own both. I'll comment on each of your bullet points.
Forester X
+ Hatchback - kills a sedan with no folding seat
+ Better re-sale - probably
+ Full size spare - yes, we added one to our Legacy
- Susceptible to crosswinds? - not a problem for me
Legacy Sedan L/SE
+ Lower to ground, better handling? - IMO no
+ Sunroof - double, too. Aftermarket on both of ours.
+ Leather steering, stick - easy fix, aftermarket wheel cover, OE shift knob screws on.
+ Styling - will look old when new model arrives
- No full size tire - fixable, about $120
- Potenza on snow? - so-so
- Poor resale, next model few months away - maybe
I think you can address lots of the gripes with either aftermarket and in some cases OE stuff (shift knob and steel full size wheel).
But...bottom line is a wagon always wins in versatility. That roof rack is handy. Fold those seats for boxes. Short wheelbase is actually sportier and more fun, by far, just my opinion (ours is an L with 15" rims).
35th comes very well equipped out of the box, but still, there is nothing you can do to a sedan to make it as practical as a Forester.
-juice
I saw that cupholder of yours back in '01 when you first posted it, and immediately ordered one from Griot's. I tried mounting it in my Forester in the same places you did in your Legacy, but it interfered with leg room and seat travel. I still have it. Maybe someday I'll use it somewhere. Griot's mentioned that it's the same as the one used by Mercedes. I can confirm that. A friend has a new E320 wagon, and it has those exact cupholders in the rear.
Len
I enjoy the Legacy for my hiway commute to work, plus it does come loaded with standard equipment but the Forester wins hands down for versatility (agreeing with juice).
I am looking forward to using the moonroof next spring, plus having peace of mind for AWD this winter.
Drive both and see which one you like and suits you better.
I can say you can't go wrong with either one.
It could also have been from the exhaust. There are usually a couple of flex joints, and these can sometimes open up during extreme powertrain movement. I wouldn't worry about it unless it happens frequently.
Craig
Compared to the XGT4 line, which is marketed as a sportier tire, I'd expect the MXV to be a little better riding with slightly lower handling limits. There are a few members here with the XGT4's who really like them, too.
Brian
Turned the big 40 over this morning on the way to work.
This is my first *new* car, ordered just the way I wanted from the factory. It's been everything we wanted, and has delivered as promised in every area. Towing, mileage, performance, reliability, comfort, etc, etc.
Had a problem with the bug shield (tore off in strong crosswinds twice, had it removed), and front cupholders (my wife managed to bust it once, who knows how, it's not that flimsy), and the clutch occasionally shudders (very infrequent - I'll drive it till it goes and then replace unless it changes). Just replaced the battery. New tires at 30k.
Otherwise, worry free. I'd buy another in a heartbeat.
By the way, I'm running Dunlop Sport A2's with no problems so far.
Cheers,
-brianV
Congrats on your Forester turning 40K! It's just about broken in now! :-)
I'm creeping up to 93K.
Ken
I'm not exactly wearing it out. I'm down to less than 10k per year now. The van has picked up most of our family miles.
-brianV
Ken
Eric
I am about there in time and mileage.
So, I should think about getting a new battery soon? I would hate to have a dead battery in dead of winter.
I would appreciate hearing from other '01 and earlier owners: Have you had to change your battery?
When?
The stock battery barely meets the minimum CCAs recommended in the owner's manual. I'd highly recommend a proactive change especially if you live in cold climates.
Ken
One can sure learn a lot here.
BrianV: What did you change to?
Ken: You picked the Sears Die Hard because you did a lot of research, and it turned out to be the most highly recommended? (Or was price the consideration, or not...)
Joseph
I want to do the change myself.....I have changed many batteries over the years in low tech cars, but this Subie has alot of electronics..
Is there any special procedure to employ when doing the change...?
Is there a way to keep from having to re-program the radio settings...?
thanx
Chuck
It's not really any different than changing any other car battery. Make sure to pull the negative terminal off first & put it back last. As far as the radio presets go you can write them down so you remember them or buy a 9v battery plug that goes into the cigar lighter socket to hold the memory. I bought mine from the Mac man, but I bet you could find one at the parts store.
Chuck
The reason I know how to do this is that I put a WRX radio in my Forester. You're going to love that changer.
Chuck
-Frank P.
Easy. If you already own (or can borrow) a set of battery jumper cables, just connect them between your battery cables and another car. Then, when you detach your battery cables to switch batteries, juice from the other car will hold all of your settings until the new battery takes over.
-frank: My battery had acid on top, but still cranked OK. Time for a new one. Acid indicated a cell going down, since it was never overfilled (I did top it off, so it wasn't low).
-suydam: Batteries are not mileage items, unlike drivetrain components. Batteries age over time whether you drive far or not. Heat is particularly hard on them, and we've had 3 record breaking summers in a row, including a 340 year drought year. OEM batteries often start to fail after about 3 years. Since my commute is only 9 miles, that's still a lot of engine starts. In fact, come to think of it, we've not had a battery last over 4 years since we moved to Denver. <shrug> We've had 2 short to ground and just die on us in separate vehicles in 10 years here.
-brianV
Altitude and batteries: Is there a correlation? Native Houstonian so my primary interactions with altitude are the top tier ramps from one freeway to another.
I mentioned it only as an indicator of just how bad our summers have been. Not only has it been unusually hot, it's been consistently very hot and dry for long periods.
I don't know why or how altitude could affect battery life here, other than the heat we've had. Perhaps the batteries tend to dry out ? In my case, I top them off with distilled water, so that shouldn't be a factor.
Some batteries are designed for specific climates. Because of the proximity of the mountains, most folks here seem to use "northern" batteries, but our summers have demanded "southern" batteries lately. Perhaps that's part of the problem, I don't know. I tend to buy batteries with good cold cranking power and large reserves (i.e. "northern" style), mostly because I grew up in the mid-West, and that's what I'm used to.
-brianV
-Frank P.
Question for experts: towards the end of the life of a battery, it will hold charge less than a new battery. Hence, the alternator will need to work harder. Is this going to stress the electrical systems of the car, alternator in particular?
K
1 x Envelope Net
2 x Threaded Studs
2 x Mushroom Anchors
Since the Forester was already fitted with the side cargo nets, I didn't need to install the anchors/studs.
I'd venture a guess that the side cargo net includes an anchor and a stud.
Cheers,
Lowell
Thanks for the info on the MXV4 Michelins. I'm going to see if COSTCO will let me install them while matching the 10% discount that my local installer provides as a local preferred employer employee. Of course, I'm not sure how much it costs to join COSTCO -- that may be a sticking point.
Later,
burnsmr4
Heavy marine deep-cycle batteries are built to withstand this to some extent, but not car batteries.
Deadeye
There isn't anything like that on mine. Is this added by dealers in really cold climes?
Stereo swap on the Forester is easy. The Legacy is tougher, but the Forester is cake.
Body lean? It's not too bad, you do have a long travel suspension so sure it'll lean at the limit. A fatter sway bar helps ($80-$120). Most Impreza parts bolt right on.
-juice
Deadeye
No kidding. What does it look like? Does it cover the top of the battery, so you can't see the cables and terminals without removing it first? There's nothing like that on my XT.
Enjoy the Holidays--Deadeye
OK, thanks for clarifying. That's what I'd call a battery box. I thought you were talking about some sort of insulating panel over the top of the battery.
http://www.subaruparts.com/catalog/?section=312#14
Craig
