Chrysler Sebring Brake Problems
                    Talk about problems you're having with the Sebring's brakes.
weather? I have the LXI with 16" chrome spoke rims, ABS. After driving some
distance in heavy rain, there's a delay in the "grab" that can be felt when brakes
are first applied. Scary. Service manager says no TSB's about the subject.
Anyone else have this problem?
Had an issue with both rear wheel bearings ... the left one was replaced at 25k (under warranty) and the right one just went (cost my ~$300) ... and for some reason, the front rotors have warped twice ... once they cannot be "turned" i will replace with bigger, aftermarket ones.
But other than those 2 things, the coupe's been great.
I recently helped my son buy a 2000 JXI. I went through the postings in the archived forum and we were able to gain some good information before buying.
One of the major complaints pre-2001 owners had were the brakes. Although the feel isn't great, I understand they wear fairly well, but I believe there were complaints about squeaking (the rear, I believe). If I understand it correctly, the squeaking isn't metallic sounding -- it is more like brake pad friction. Has anyone found an aftermarket solution to these noisy brakes?
So what do you think??? Is it a "money pit" or what??? Again... I'm working 3 jobs (and not because I "like" too!LOL). "Please" help me decide or "talk me out of it"! LOL
Sincerely,
A 42 year old "Spring Chicken" (LOL)
PS...all your comments have helped me so far, "greatly", as to what to look and ask for if I test drive! THANK YOU!!!
As On date i have 3000 kms on my car and problem is still there, Dealership is saying there is nothing they ca do to reduce or to eliminate this sound.I am very upset over this?What should I do?Customer service says its normal.I have driven many cars never heared this noise.
I will be greatful if anyone help me in getting this issue resolved.PLEASE DONT BUY SEBRING 2003 ,ITS LOOK GOOD BUT HAVING LOT FO PROBLEMS.
I've spent about $500 at Brake Check getting my brakes replaced, cleaned, new hardware, etc. and it is STILL making this screeching (think fingernails on a chalkboard) and a rubbing/scraping noise. It is also making that metal on metal noise while driving (usually at 35 mph with the windows down) and screeches more when I apply the brakes. I was hoping after the hardware was replaced for both rears it would stop but nothing has changed (as B.C. suggested since one side was loose). I only have 40,700 miles and I'm the only owner and driver, bought the car in June 2000 with 87 miles on it.
Any suggestions if that noise is just going to exist or if something really is wrong with the car. I'm ready to pull my hair out about this.
Gogga
I have been reading some of these posts and it does make you worry at first, but for me I suppose that a car is a machine and you have to expect that they will need maintenance. The sebring is a very reasonably priced car expecially when you compair it to the $50,000 plus you can spend on a luxury or speciality car, which lets face it a convertible is a speciality car... made for us special people. I am a psychotherapist by day, and I know how much the extra sunlight and feeling of freedom driving with the top down can really de-stress and elevate my mood. So I consider it not only my car and my toy, I consider it my 30 minute vacation on my way to and from work.. : ) I love it...
Nina
Get the car....
Has anyone had this problem? I never heard of not being able to check on a problem through being told what the problem is. This is the second time I have it in and they are saying the same. "We can't replicate the problem, therefore we cannot diagnose and fix it." Is that true?
Hope this helps.
Mykee
During the initial checkup for the used-car inspection, they failed to fix the clicking in the steering wheel. It was something I'd asked about upon purchasing the car. Turns out it is listed in things that "should be repaired but don't have to be repaired" -- I can't think of what the list is called. But the dealership is paying for it. A month after I bought the car, the A/C went out and would only work on high. I was furious, so the dealership paid for that too. Then my check engine light came on last month and, luckily, it was just an emissions fix, and it's covered.
But now, my brake light is dinging off and on all the time. Mostly when I turn right. Any clue why?
Most importantly though -- when I'm sitting idle at a stoplight or something and the A/C is running, there's this rumbling underneath the car. It sounds like it's coming from the front, but unfortunately it's not the kind of thing I can tell the dealership to fix becuase frankly ... it happens maybe once, twice a week and is completely random.
Does anyone else have this problem ...? :confuse:
Regards:
Oldengineer
Adding/changing power steering fluid has been suggested to me. I'm not sure what fluid to use, though. :sick:
any ideas
this may help.
Sorry to ask this as im sure its been asked before!I did a quick search but couldnt find the answer.
I have a 99 JXI con with 81k on it.
Ive had new rotors and pads up front and the rear drums checked and adjusted. The brakes just seem no good, Ive herd the rumers that there is a brake problem. What is it and what can be done?
Thank you so much for your help.
i get vibrations throughtout the whole car. i have replace the tire and wheels and rotors
and brakes still the same problems. cant get the vibrations to stop. anyone have a clue to stop this madness. vibration is really bad-steering wheel :confuse:
Anyone have any suggestions???
