Chrysler Sebring Climate Control Problems
                    Ask questions and talk about Chrysler Sebring's heating and air conditioning systems.
Regards:
Oldengineer
Thanks for the info!!!
ds1
Regards:
Oldengineer
Thank you very much,
Rick99
Rick99
Guy
Also both head light bulbs replaced at a cost of $70.90. All of this included labor.
I have had trouble with the tires, wheels, electrical system, transmission shifts hard, and now lights and resistor. Also it still takes about 45 minutes for the heater to blow warm air even after the new resistor!
$31,000 for this???
The car is a '96 Sebring convertible by the way
The coolant level and engine temperatures are okay. I haven't tried looking up the codes (since I will have to wait for the light to come on again). Anyone have some ideas as to what might cause a problem like this to come on suddenly? Thermostat? Bad heater core? Some kind of sensor? Thanks.
If the temperature gauge is still in the middle and you haven't put pure anitifreeze in it lately, I would rule out the aintifreeze and thermostat.
It may be the dash controler itself, no longer adjusting the hot and cold.
For some reason, the level seems to be dropping ever so slightly--maybe a cup or two a day. Not much, but just enough to affect the heater. Now I need to figure out where it's going. I haven't noticed any obvious leaks.
Thanks for the advice. By the way, you mentioned "pure antifreeze". I have always been diligent about keeping to a 50/50 mix. But I never have heard anything on how important that is or why. For the benefit of those who are as ignorant as I am, what would happen if the concentration was too rich? Gummed up thermostat or what? Just curious.
Antifreeze has about a 25% lower heat capacity than pure water. That’s one reason why a cooling system should never be filled with straight undiluted antifreeze - it increases the risk of overheating during hot weather. Because it holds less heat, during colder weather(February) it makes air coming out the heater feel cool.
But very easy to replace. Do you have any advice on a leaky transmission? I have had the gasket replaced 4 times and it is leaking again. Any similiar problems? This car has had so many problems I am at my wits end with it.
Lisa
Thanks, Brad
we were going to take it to the dealer to be fixed (they thought it was the blend door), so we empty out the glove compartment and the heater came on and works perfect
Any ideas?
Regard,
Mark
Chris
Any feed back is geatfully appriceated.
Chris
The Dealership found a service letter describing the problem and performed the recommended fix: recalibrate the temperature/damper controls. It didn't work.
Is there anyone else experienceing a similar problem and have advice?
Chris
FIrst I let the car sit all night so the engine was completely cooled. Then I opened the silver radiator cap, NOT the plastic one on the overflow tank mounted on the fender.
Next I started the engine and SLOWLY added WATER (not Anit-freeze) into the radiator. As I did this green FOAM began to rise up the radiator filler neck.At this point I gently squeezed the black radiator hose (large one connected to the radiator) and caused more foam to rise out of the system. I wiped the foam away, added more water and kept repeating this technique. When it became less foamy I reved the engine slightly and a blast of water and anti-freeze blew out (BE CAREFUL and don't rev the engine like its the Indy 500) Make sure the heater control is on RED on the dashboard. I kept adding water (slowly)until there was no more foam, replaced the metal radiator cap and have not had the problem since.
Simply stated the foam displaces the water and is causing the heater core to get air bound. That could be why when you race the engine you get heat- it basically BLOWS the foam through the radiator core. Good luck. Again I'm not saying it will cure everybodys problem but it solved mine. Thanks for reading.
Has anyone replaced that part and had success? I already had a mechanic check under the hood - he said it was something "in the dash". He suggested a solenoid (sp?) for the vents (sounds like a blower motor resistor to me!) and I would have to bring it to a dealer....we know what that means $$$$. :confuse:
Were you the original owner in '01?
