Jeep Liberty: Steering Stability and Suspension
I know it's been two years since you originally posted this, but I recently purchased a 2002 Jeep Liberty and I am experiencing this exact same problem. I was wondering if you ever happened to figure out what was wrong? I'd really appreciate any help.
How many miles do you have on the Jeep now?
Mechanically speaking, mine is still like new after 90,000 miles. It has a few dents but not much play in the transmission. Rear brakes are still perfect and moan when the temperature is cool and damp. I don't need wheel alignment yet, but why is it offered to you?
If anyone is interested the part numbers are BE5-D916-HO and BE5-D917. Bilstein is running a buy three-get the fourth one free this month. $250 free shipping which is cheaper than most OEM replacements. Caribou 1-- if you plan on keeping your jeep for a while --get a set and enjoy!!
PS --I don't own any stoc in bilstein. Actually I don't own any stock at all. Lucky me.
I have to bring the Jeep for technical inspection this summer; if I need to change the shocks, I will follow your advice.
I think you are driving on a different type of pavement and you may not have BFG T/A tires. So far, this is the best vehicle I've had in 40 years. It has a weakness in the way the ball joints were mounted on the front suspension and I know one day I may dive into the pavement if I don't keep an eye on these things
http://www.jtts4x4.com/boutique/fiche_produit.cfm?ref=XXX310&type=879&code_lg=lg- - _fr&num=830
This is another absurdity of the EU market. No we can't :sick:
I'm coming over in June and I intend to do some serious shopping...
I chose to come (on two wheels) and spend rather than buying cheap 'Jeep' labeled products that are sold in popular department stores. I'm wondering how Bilstein can propose such low priced shock absorbers? You have to cut salaries and lay off personnel to do that. So where's the trick?
The answer could be here:
http://www.complaintsboard.com/complaints/defective-bilstein-wwwbilsteincom-c974- - 67.html
I hope you will not need to join the group mentioned above
You may need to burn incense to receive the proper assurance against defects :shades:
I have taken the vehicle in for inspection to a reputable (and often used) tire and brake shop and they did a front end re-alighnment (actually twice), but could find nothing wrong with the suspension.
The vehicle has the original shocks and springs.
NOTE: The lower ball joint recall (replacement) had been completed last year.
You might try rotating tires front to back to see what happens.
From there, after tires or wheels have been eliminated, we go to suspension items, such as control arm bushings, ball joints and weak shocks. Certainly at 83K you could have weak suspension.
one of them covers this:
Dealers will replace the front lower control arm ball joints with modified assemblies and heat shields on vehicles built between January 2, 2001 and October 4, 2002. On vehicles built between October 5, 2002 and March 26, 2003, dealers will inspect the ball joint assemblies (and replace them as necessary) and install heat shields. The manufacturer has not yet provided an owner notification schedule for this campaign. Owners may contact DaimlerChrysler at 1-800-992-1997.
There's another recall for upper control arms involving only these vehicles:
NOTE : This recall applies only to the above vehicles built from May 1, 2002 through September 30, 2002 (MDH 050100 through 093023).
IMPORTANT : Only the above vehicles sold or currently registered in "salt belt" states (where large amounts of road salt are used for snow and ice removal) are involved. See "Owner Notification and Service Scheduling" section for a list of salt belt states.
