Jeep Liberty Transmission Problems
Post your comments on any Jeep Liberty transmission issues here.
See Also: (Video, 5:30) How to service the 3.7L Jeep Liberty automatic transmission
I have had problems with the tranny almost from new
they have changed a selinoid which helped fro a while but it just started again
as well i had "bump" shifting but that ha snot returned
looking for anyone who may know what the problem could be
getting a little frustrated after numerous trips to numerous shops to get it "fixed"
Transmission ,and how you say I don't want to get frustated visiting several shops, right now my SUV is in the dealer'shop and they said me the problem was a SOLENOID , so they are changing THEM , but you consider that was NOT the solution AT ALL so, I would thank you IF you could give more information about this problem and its solution because I'm worried about it.--
This is a toyota website, but gives you an idea how transmission solenoids are suppose to work.
I do not know "which" solenoid they changed, either #1, 2 or 3. I gather that shifting was rough or not at all.
The basic rule of troubleshooting is change the smallest, cheapest and easiest part first. Solenoids are on the outside of the transmission and easy to get to. Now, my question is, was the problem fixed? There may be possible issues with tranmission fluid contamination. There could be problems with the "electronics" which controls these solenoids. Did anyone check bare, exposed or worn wires which may have caused the initial problem (shorts)? Most people don't understand electronics and many believe that wires don't go bad. That's why many technicians leave the troubleshooting to the diagnostic machines instead of using their own brain.
Read the above website then quiz your dealership on what they changed and why. They should have put it on a diagnostic machine - request the printout from the diagnostic results. You should receive a printout, atleast you paid for the service and using the printout will help further troubleshooting down the road. Properly document your maintenance paper-trail.
Good Luck
John
Troubleshooting while driving, especially when the noise if coming from under the car is very hard to isolate. What about putting the car on one of those machines where the rear tires move on rollers but the car remains stationary. Taken the axles out of the picture, it might be the transmission, but I have to assume Jeep checked that. Also checked for frozen or stiff U-joints.
Most new cars pride themselves on quiet rides and reducing road noise to allow for a quiet interior. Any vibrations will only become worse over time.
I would put the car on a stationary machine and run the engine to 25-35 mph via the back wheels and see if the gripe (problem) is duplicated.
If they find nothing, its not the transmission, axle, U-joints or any mechanical linkage. What about the body.
Sometimes, a pet will refuse to ride in a particular car or truck because it has a body (weld integrity) problem and emits very high frequencies. These welds will degrade over time and their frequency slowly creeps into the human range of hearing as the metal and weld fatigue worsens, but its not suppose to be a problem in a new car. These frequencies are too high for humans, but dogs are clearly under great distress. Maybe at 25-35 mph, the frequency creeps into the human range of hearing then goes away again. Now, this is a "way out there" option, but give it the dog test.
John
what gives?
isn't gong to listen to us either on this matter. Sorry I ever traded in my Honda for a Jeep my last one ever. :lemon: :lemon: :lemon:
I've noticed the same behaviour of my CRD before I took out the EGR valve.
Typically this would happen when driving at 30mph (in a village) for a few minutes. When I needed to accelerate gently the engine wouldn't respond for about two seconds and then get stuck below the torque range with a locked converter. I had to let go the throttle pedal to release the converter and press the pedal 1/2 way to the floor to make it spin faster.
My egr valve was choking the engine by staying open too long and the computer is not programmed to consider this.
I've never seen any error codes because all the sensors are working properly.
Is yours doing the same thing?
"Just keep in mind the transfer case can lock the front right and the rear left wheels"
Why should it lock? Tried and cannot duplicate it. Is the function other as when Tracloc is present?
When the 4WD/Part time mode is engaged the front and rear transmission shafts are mechanically locked (1:1) by the transfer case. If you look how the differential is built you see that the large gear driven by the input 'hypoid(??)' gear (the one in the nose of the differential) is fixed onto the left 1/2 axel. The front differential is the same but in a mirrored position.
I've noticed this two times:
- I once had the Jeep resting on two wheels in a steep downwards ramp. I could swing the truck right to left by about 10 cm just by moving on my seat and I could also pull out without spinning the wheels. I was on the edge of an asphalt path connecting a steep road to a sideways horizontal surface...
- the second time I was working in the mud and someone told me that only my front right wheel was spinning. The person asked me: is this a real 4x4? I preffered not to answer :surprise:
We have no linkage to specific wheels. Only the driveshafts are 1:1 through the transfer case when in part time.
Perhaps BFGs made me loose the understanding of things. They just do the work every time :shades:
I just bought my Jeep Liberty 2006 a week ago, and I'm absolutely in love with it. However, today I ran into my very first problem. It was raining today, so I moved it from 2HI into 4HI, and everything seemed fine.
However, when I went to back out of my driveway, I braked at the end of my driveway (to check for oncoming traffic), and then gave a little gas to pull out onto the street. Instead of a smooth backup (as it always has in 2HI), I got:
- a deep growling noise
- a lack of movement backwards
- a feeling like my tires were locking, or spinning.. when they weren't
And so it didn't back up. I gave more gas, and it lurched a little bit, and then the "growling" noise got louder. So I put it into 2HI, reversed, and everything was fine.
So I drove in 4WD today (because of the weather), and this has been a constant issue for the entire day. I'm starting to get concerned, does anyone have any ideas or suggestions? I'd be really grateful - hahah I want to be able to reverse when in 4WD without my Jeep freaking out!
Thanks in advance,
Ashleigh.
Drive slowly when engaging or disengaging and you will have no problems.
Anyone else had transmission problems within the first few months. This has ruined my jeeps reliability in my eyes.
When I brought it in the first time, they dismissed the noises I heard to "tire noise". Nice. It was in and out of the shop for the majority of 3 weeks, which cost me over $600 in rental car fees.
Needless to say, they could never find out what the problem was, and they weren't about to give me anything for my troubles.
Hope this helps you in your next vehicle purchase.
Farout
I pulled in front of my in laws house. Put my jeep in park unbuckled my seat belt, and leaned into back seat and adjusted my baby’s head because she had fallen asleep in route. I then exited my jeep walked in front and around the jeep to the front door. I stood there a few minutes talking to my mom in law. I then saw my jeep DRIVING AWAY by its self!
It just took off. No one was even near it. In turn, I ran after it. It hit a flower bed which made turn and go down a 30ft incline into a freezing pond. I jumped in and swam out to her my father in law heard me screaming. He swam out, we couldn’t open the doors the speed had picked up enough to make the automatic lock to lock! My baby was inside drowning. The lock on the doors finally pop open. I give God the credit {but some people say the electrical stuff got wet and it made it unlock.} But then it was too late. The water pressure was to strong & I couldn’t open the door .My father in law was smart enough to pull himself on top of the jeep causing it to tilt enough for me to open the door. I almost drowned & so did my baby we all ended up in ICU but my father in law DIED he had a massive heart attach in the water and died helping to save my baby! When I got her out he was face down in the water! I had NO choice but to try to swim back to the docks and save my baby! Chrysler had a recall on 05 & 06 because of a misplaced part in the transmission. Over 400,000 of them. Chrysler SAID it didn’t apply to 04’s. I found out ALL transmissions for 03,04,05 &06 were and are the same. They all were assembled from the same product line. Chrysler even sent a their people across country to look at my jeep. Why would they do that if the KNEW it only applied to 2005 & 2006??? I know for a fact my car was in park that night! Something went WRONG with the jeep. My statue of limitations for court expires Jan. 07. My time is running out to get justice for my mother in law! I am desperately looking for someone who has had similar trouble with the transmission. Please contact me & BE CAREFULL! PARENTS BEWARE JEEP LIBERTYS CAN come out of gear when ignition is left running, ACCELERATE AND DRIVE OFF BY ITSELF!!!
M.Troxler
You should consider filing a complaint with the NHTSA (Office of Defects Investigation). You may get an email response from posting here but usually posting your email in a discussion just results in a bunch of spam.
I have a 2005 Jeep CRD . First a run down of problems,
1)Oct. Front ball joint recall. Had to replace leaking rear seal. 2) Fail injector, took 5 days for the dealership to get a part. I was out of town and had to get a motel and rental car. 3) Nov.Failure of repaired rear unit took 3 days to repair, another rental car. 4) F37 recall done. 5) 17 days later, loud bang, engine light on, can't shift past 3rd gear, towed away from home. 5) 8 days later, no word on the repair of the transmission. Living in NC, not sure if this qualifies for the lemon law. Any help here? Regards :sick: :sick: :sick: :sick: ">link title
I sure do hope they figure out what the problem is. I live in a rural area the middle Northern Michigan and am alone 5 out of 7 days a week. I'm just thankful my Hubby had the car and a cell phone to summon assistance. I would have been up a creek had it happened to me. Cell phone service is almost non-existant. Wish the Chryslers had ON STAR like the GM's do. Anyway, this wont sour me to the Jeep Liberty, unless they cant get the problem resolved.
We took out 05 CRD in for the torque converter recall. The recall said they may have to do some computer changes. BOY, did they. It does not have the torque it did. We went back because we are not happy at all. The mechanic
said the changes were to decrease the torque. It also changed the shift points.
Now, it shifts like a vehicle that hangs way to long in one gear. Had I know, I would not have authorized this. They said there was nothing they could do about it. Jeep was said the same to my husband.
If you bought a Viper truck and the recall decreased the horse power to a Hemi, that's the same thing. I did buy this vehicle. Sure, mine runs well, but it's not what I signed a financial contract on .
Be VERY careful. If you want decreased power and torque, let them reset your computer.
We took out 05 CRD in for the torque converter recall. The recall said they may have to do some computer changes if there was damage. BOY, did they. It does not have the
torque it did. We went back because we are not happy at all. The mechanic said the changes were to decrease the torque. It also changed the shift points.
Jeep was saying the same to my husband.
Be VERY careful. If you want decreased power and torque, let them reset your computer. :mad:
THANKS,
STEFANI
