Just to let you know I have the same problem and I am not bad at these type problems but I let you know what I've done. I have replaced headlight switch then a guy told me he had the same problem and it was the dimmer so I replaced it. Then I cleaned all the grounds under the hood and the frame to body and added a ground directly to the head light switch and a ground from the dash to the firewall and still have the same problem. Right know I am going to disconect my altenator to see if it has a short if it does not I am going to the rear of the truck and start their. I will let you know what happens I have been fighting this for two months and no one at dodge has been able to find it either. Wes
I have a 1997 Dodge Dakota Sport. I rented a trailer this past weekend. When I tested the lights at the rental lot, the side lights on the trailer that are supposed to come on with headlights, didn't come on. At the time, I thought it was just a connection problem with the trailer (I didn't look to see if my headlights were on at the time). Since then, my headlights aren't working. My initial assumption was that there was a short in the trailer that blew a fuse, but the headlight fuse is fine. I even replaced it to be sure. Any thoughts? I read a previous post about something similar (post #200), but I didn't see any responses to that. Nor are my problems that odd and intermittent. I'd appreciate any thoughts you have for me. Thanks!
I am having a simalar problem although my battery cables were put on backward (pos on neg neg on pos) my battery will not charge now. it is a 1995 dakota with a 318. I have checked the alt it is ok and i installed a new battery and still not charging. please help
have a 1995 dakota with a 318 the battery was put in backward (pos on neg neg on pos) now the battery will not charge I replaced the battery and the alternator and still not charging.
I have a 1995 dakota the battery was put in backward (pos on neg neg on pos) the battery will not charge now it had a 318 and is a manual. I have replaced the alt and the battery.
Well, you could have fried a part of the system, such as the brain, and that's a hell of a gremlin to find. HOwever, I'll help if I can. Nice move, with the battery. Hope that wasn't your doing.
Ok, since I got mine fixed, here's what I suggest: FIRST, swap the cables so you are properly able to take advice, and get a good ground, and et cetera.
Second, make sure EVERY SINGLE GROUND in the engine is solid and clean. I took all the bolts out, scrubbed them down to metal on both parts, and the frame, and reconnected.
Third, check every inch of wire, just to be sure that you're not having something short or ground out where it's not supposed to.
I also noticed that I have a problem with my Alternator Tension Bolt rattling loose, and thus the alternator is not turning with the engine, and therefore not charging. Tight=charging. Check it,k?
Hope this helps.
Oh, and replace the battery and possibly the Alternator. Take the alternator to the auto shop and have it bench tested to see if it's operating fully, and at amperage.
My first worry was that you blew the PCM, but one item that I'm sure has been damaged is the fusible link. The fusible link is a fuse wire that is in the cable that goes from the alternator to the battery. If the fusible link is open you will not charge the battery. A fusible link repair kit is available from a Dodge dealer.
I have a similar problem to the 1988, however, my issue includes blowing the #10 10amp fuse. The dealer does not seem to know how to deal with this and I am about to leave this for my wife as I head to Mid East. Thanks for the help
I have a 1999 Dodge Dakota & the interior lights (overhead console & floor lights) stay on when the engine is running. When I turn off the engine the lights go off. Anybody have any ideas? Thanks.
Thanks Dusty. Do you know roughly how much it costs to replace the Central Timer Module? Is this something the layman can do? Thanks again for your help.
Replacing the CTM is not diificult. On most year Daks the CTM is located behind the lower trim panel below the instrument panel on the driver's side. If I remember correctly, Chrysler's price is around $170.
Keep in mind this is only a guess on my part. I would recommend obtaining a set of wiring diagrams and troubleshooting first or have the dealer check it out to confirm.
Thanks again for your expertise Dusty. In looking at the owners manual, it appears the fuse for the overhead console lights is in the #11 cavity. I took out the fuse & the lights still stayed on. Can you verify that is the correct fuse? I would think when I take out the fuse the lights would go out.
According to the 2003 Dakota wiring diagram, the fuse for power to the Overhead Console is fuse #1 (cavity 1) in the Junction Block.
There are two areas that contain fuses, circuit breakers, and relays in Dodge trucks. One is called the Power Distribution Center (PDC) and is located under the hood, usually next to or very near the battery.
The second area is called the Junction Block (JB) and on Dakotas is located at the end of the instrument panel on the driver's side. This area uses a trim panel to cover the JB and is easily removed.
I do not have a dome lamp, just 2 lights in the overhead console. The owners manual for my 1999 Dakota Sport (no extended cab) says the #1 cavity in the JB contains a 20 Amp fuse for the stop lamp & the #11 cavity contains a 10 Amp fuse for the Console/Purge. Is this the right cavity for the overhead console lights (2) & underpanel courtesy lights (2)? Maybe it is different than the 2003 Dakota.
Sorry for all the questions Dusty. Again, I appreciate your help.
Ah. First problem is I do not have a '99 Dakota service manual at my disposal. Unfortunately, mother Mopar has a habit of changing electrical wiring, sometimes even during mid year.
However, I have to agree with your original assumption that if the courtesy lamps are still illuminating, they must be getting a DC supply from somewhere. So I think the fuse they're identifying in the book is incorrect.
I may not have the correct documentation for your year Dakota, but I'm somewhat confident that the problem is going to be the CTM, especially since in previous years this was fairly common problem component.
The CTM contains semiconductive drivers that control numerous electrical devices in the vehicle. These are placed on the low side (negative) of a device and permit the device to operate underr certain condditions. For example, the overhead courtesy lamps illuminate when a door is opened or unlocked and stay illuminated for several minutes or until the ignition switch is turned to the run position. It is the driver in the CTM that provides the conductive path for this feature. In this case, I think the driver has shorted allowing the lamps to be on all the time.
I've been told that there are a couple of diodes in the CTM that commonly fail and the CTM can be opened and repaired. I've never done this myself. If you are an electrical type of person you might be able to verify the problem and repair the CTM.
After 4 tows to the shop the truck stayed dead long enough for them to find the problem. It turned out to be a "crank angle sensor"-it is attached to the distributor somehow. This thing has been going bad for months but would only stay bad for a few hours, days or minutes so by the time I got it into the shop it would start right up. Finally it died for good. -a $50 part that cost me almost a grand in detective work and towing.
Glad to hear the problem has been solved. The term "crank angle sensor" is foreign to Mopar parlance, I suspect the defective part was the Crankshaft Position Sensor or a Hall Effect Distributor Sensor. Crankshaft Position Sensors were a somewhat common failure item on Dakotas of your vintage.
In the absence of any diagnostic data, either preliminary visual (fuses, etc.) or actual voltages checks, I'd be suspicious of a defective Central Timer Module (CTM). However, I would suggest getting a wiring diagram and performing some voltage checks. I'm not sure what bearing a bad CTM would have on the ABS lamp illuminating at the moment, but a common component to the power locks, taillights, and headlights is the CTM.
99 Dokata 5.2L - Won't start. It was getting gas, spark, air... everything was testing OK. I replaced the Crankshaft sensor but it didn't help. Checked the Camshaft sensor. It was reading good at 5V. The next step was to replace the PCM (ugh! $200 bucks minimum!). I cranked it over one last time to see if it kicked out any codes. My son noticed a blue spark close to the passenger side firewall. Sure enough! The heater hose covering had rubbed the spark plug wire and somehow, it was grounding out. We separated the hose from the wire, and it fired right up! We then replaced all of the spark plug wires and the distributor cap and button. So - Lessons learned - check all the basics before replacing components. (Although, we did check for spark on some of the plugs and eliminated that as a possible problem.)
Similar to a post last month, my dome/cab light stays on after I start the engine in my 99 Dakota. So I am currently driving around with the dome light on. It does eventually turn off after the engine is shut off, the key is removed, and the door is closed. I think the final thought, on the previous post, was that the CTM had gone bad. I have a couple of other questions.
0) Does that sound logical here?
1) Where is the CTM located and what does it look like?
2) Can I replace it myself?
3) Does the module need to be programed by the dealer?
I have a 2001 Dodge Dakota Sport. My dash lights and tail lights do not work. Checked the fuses and it was blown. I replaced it everything was fine for a few days. Today got in truck rode down the road suddenly no dash or taillights. Fuse blown changed it and the fuse blew again. Please tell me how to look for the short or if anyone has any idea how to fix this I would greatly appreciate it . Thank you SBoyle
I'm not positive on '99s, but on 2001s an up the CTM is located behind the driver's kick panel (Cowl Side Inner Panel) on the left side of the cab, approximately where your left foot would rest while driving. The CTM is a relatively square-looking module and has three connectors.
Absolutely.
No.
4) About how much should a programed CTM cost?
N/A
5) Is the only place to buy it at the dealer?
They were about $170 from Dodge the last time I needed one. I believe they are available from places like Auto Zone, etc. I'm sure they're cheaper at an auto parts store.
This must be a short somewhere. 1998 SLT 4x4 5.2L has been remarkably trouble free for it's 100K miles. Looked out the window and thought someone was trying to make off with the truck, but there was no one around, and ignition was off, but brake lights were on. Jiggled, then disconnected the switch on the brake pedal arm and observed no change. Turn signal overrides the short and the lamps blink appropriately. Disconnected the lights and trailer plug but still getting a live brake light signal at the harness connector at the back. I plugged everything back in and the lights were out. Now I see them staying on sometimes and going off otherwise. I love intermittent problems.
Just found this site and thought to throw this out, maybe there might be a suspected component before I start a long tedious search.
If I had to guess, I would suspect the signal switch, but ....??
Hi, i recently bought a 1997 Dodge Dakota Sport 3.9L V6. A couple weeks ago i was driving down the road and noticed my check gauges light started flashing. I ignored it and continued driving when all of a sudden the truck just died and lost all power. I flagged another truck down and asked for a jump thinking it was just a dead battery. So i got my truck jumped and continued on home. Not even 5 minutes later the check gauges light started to flash again. I kept driving and just as i pulled onto my street the truck died again. I then went and brought a brand new battery to see if that would help. The next day while driving it died again. So i had my father come down and give me a jump and just made it back home. I decided to get a new alternator thinking that would be the next probable cause. But again after replacing the alternator the truck died and would not hold a charge. I then decided to have a look at all the fuses. All fuses were fine but i noticed that the power distribution box looked to be missing a wire running from the 140 amp alternator fuse??. It has one wire feeding into it from the positive terminal of the battery but looks to be missing a wire coming out the other side??????? Just wondering if there should be a wire feeding into each side of the alternator amp????
My apologies, but unfortunately I can't recall a "140 amp" fuse anywhere in the electrical system. Of course, I am getting old.
I wonder if you are referring to the fusible link? I can't for the life of me figure out how something could be missing on a vehicle that ran fine one minute then died another. Let's approach this another way.
Connect a voltmeter to the correct terminals of the battery (positive meter lead to positive post; negative meter lead to negative post). You should be reading something over +12.5 volts with a fully charged battery. A partially drained battery will yield a lower voltage.
Start the engine. If you are in a cold weather area of the country, the voltmeter should be reading anywhere from +13 to +14.7 volts at initial start up and slowly drop as the battery charges. If the voltage drops from your initial reading after start up, the battery is not receiving any charge current from the alternator. This then is the problem to troubleshoot.
If the battery is receiving a charge, you probably have an intermittent problem. Check for bad connections at the alternator, Power Distribution Center (PDC), and to the Powertrain Control Module (PCM).
hey guys... i have a 2000 dakota QC manul 6 cylinder. i replaced the battery recently. when i drive with my headlights on...the lights start flickering. (headlights, dashlights..pretty much all the lights) also i hear this clicking when the lights are flickering. when the car is off and just sitting there, i c in the headlight that there is a very dim light that is on. i have to 2 disconnect the battery so it wont drain my battery.
Howdy, I had the same exact problem with my 2002 dakota 4.7 v8. It is the only reason I joined this forum. Your problem is the Central Control Module. It is a black box (5"X5")with a circuit board in it. It controls the timers. Two screws and plug it in. Done! You will have to check your manual to re-set your auto door locks and you will need to have your key fobs re-programmed. Mine was mounted vertically behind the lower left kick panel, I imagine you will find yours there. The part is about $250 at the dealer. I raised some hell at the dealership citing that it was it was a poor design/quality issue. I ended up getting it for $185. Just to reassure you, my problem was exactly the same with the flickering and clicking. Take care.
I went and looked at my old module. It actualy has three plugs and it may be called a central timing module. I guess my memory is going. Anyway it will take care of the problem.
Sorry. I don't know. Does it have lights that turn off on a timer, auto-locks or keyless entry? On my 2002 has the ctm under the lower left kick panel. It is a black box that is about 5 x 5 1.25 inches. It has three plugs on one side and screws to the body. Good luck
no automatic lights, locks, or keyless entry. CTM is not in the left kick panel. there is a box on the right side behind the glove box but its rectangular and only has one plug so i'm not sure. i called the local dodge parts dealer and asked for a CTM and they didn't know what i was talking about.
I had trouble with my cab lights staying on when I was driving my 99 dakota (4WD 5.2L). I tried to replace the CTM. I purchased a new module from the dealer. When I installed the new module and reconnected the battery the truck would not start. The cab lights and all seemed to work fine but the engine would not kickover. It does sound like the starter motor is trying.
I then tried to reinstall the original module, but as soon as I reconnected the battery negative wire the alarm started to sound. I could not shut off the alarm or start the truck.
Any suggestions on how to get the new CTM to work or to reset the old CTM module?
I asked the dealer if the new module needed to be programed. They said only to get the keyless remote to work. They said that I should be able to start and drive the truck after I installed the new module.
If you talked to a parts person, then I can understand their answer. Unfortunately, the CTM has two fused ignition circuits: one for Accessories and another for Start. So, yes, the CTM can have an influence on engine start.
However, if the stater is engaging the flywheel and trying to turn the engine over, I suspect you may have another problem.
Can I please get some assistance with this code P0441 and Is there something I can do or do I have to have a dealer fix the problem. Its a 2001 Dakota Quad Cab 4.7
P0441 means "Evaporative emission control system incorrect purge flow"
The number1 reason for this is GAS CAP which is not sealing properly. The owners-manual says to get 3 full clicks when tightening. Try tightening, or even replacing the gas cap. Don't use a cheap after market one though.
If you need to know more about the EVAP diagnostics and why they may fail, PLEASE use the search function. I have explained in explicit detail least 12 times over the past 8 years here on Edmunds. It is usually trivial to isolate the problem.
As Bpeebles said, the fuel cap is the number 1 reason for a P0441. If you've never replaced the fuel cap, its a likely bet that's the problem.
If a new cap doesn't solve the problem, there are several possibilities. One of the most common are cracked/split purge lines that go from the Evaporative Canister to the fuel tank, or to the Leak Detection Pump (LDP). If you don't have a Leak Detection Pump, you will have a Evaporative Purge Solenoid (EPS) which is mounted on the firewall.
Of course, you could have an electrical problem with either a LDP or a EPS.
I have a 1993 2wd 3.9 v6. I need to know the wiring for the bright lights behind the plug. I have a cut wire and when i placed it back together i cant get brights on one side. Does anyone know which wire behind the plug is for the brights?
Can anyone advise me? I just found out I need a new fuse block. The mechanic says it will be $450.00 parts and labor. Is this price high? Does anyone know a trustworthy mechanic in the Houston Texas area? Thanks :confuse:
I have 2001 Dakota and was driving the other day and the radio went dead. Then I went to turn and I had no blinkers. Everything else worked fine. Turned the truck off and then restarted and everything was fine. I found that if I wiggle the key while driving the blinkers and radio will go off and on. Any ideas would be appreciated.
Hope this helps.
Best to you.
Dusty
Dusty
Thanks for the help
Dusty
Dusty
Dusty
The fuse you are looking for is in the JB.
Does your model have a Dome Lamp as well?
Dusty
Best regards,
Dusty
Best regards,
Dusty
Headlights/tailights do not work
Power locks either don't work or when you push one it clicks really fast multiple times.
Also, turning the headlights on, pressing the brake pedal or using the locks will cause the ABS and Brake light (on instrument cluster) to come on.
Checked as many grounds as I could find and nothing seems to work as of yet, :sick:
Any suggestions?
Thanks in advance
Mike
Best regards,
Dusty
Bob
Mike
SBoyle
Yes.
Absolutely.
No.
N/A
Dusty
thanks a bunch. jjs
Mike
Dusty
Dusty
plz help!
All the things you mention that aren't working could be related to the CTM, except the tachometer.
Dusty
Mike
Dusty
Dusty
Check the right front signal to get an idea of where the lights are located and you should see two lights when the signal is activated.
Now check the left side to see which of the two bulbs does not function.
Hope this helped.
Thanks :confuse:
Dusty
