Mistakes in the parts list at aftermarket stores are real common. I've gotten the wrong transmission filter for my daughter's Hyundai Accent, and the wrong upper radiator hose and PCV valve for my friends '98 Chrysler Concorde in the last two weeks alone. An acquaintance is overhauling the engine on a 2001 Grand Am and told me he got the wrong intake manifold gasket set and incorrect timing chain from AutoZone.
Dusty
I have a 93 Dakota 3.9, and my power door locks suddenly quit working. I have checked the fuses and they are all good.
Also, my rear speakers don't work most of the time. Every once in a while they will work, but the next time the car is turned off and on they don't work for days at a time. I thought it was my radio but when I replaced the radio the problem persisted.
My ABS and brake dash lights ARE NOT coming on.
I recently purchased this truck in this condition, and the previous owner said that the speedo used to work until she had the ignition cylinder replaced, and stopped working since. Any ideas?
i think its the switch over heating but i replaced it and im still having the same prolem
ive talked to a few technicians and they said that i probably have a short somewhere (causing the switch to over heat)
i would just take the truck in and have them fix it but i havent been able to find a job in over a year now so thats not really an option
Dusty
The headlights utilize a circuit breaker in the fuse panel. The circuit breaker could be defective, or the circuit is drawing too much current.
Dusty
Reason I couldn't find the CTM is because CTM was not put on the Daks until 1997 (when the body style changed, this is per the dealer parts list).
So back to the problem, head, tail, dash lights out, ABS, engine check light on, tach working intermittently. But cranks and runs fine. Parts guy stated he'd had 2 Daks with no problem like this. Suggested maybe Ignition switch and or run wiring for ground. Keep in mind NO blown fuses in FB or PDC. Any other ideas on fixing this problem?
2K Dakota Slut Truck 4.7L Auto 4wd 168K miles I have an unusual blower problem with the heater/AC. It always seems to work when I first start the truck. If I stop after a while and then restart after a short while, the fan will not work at any speed. With the AC on, one can detect that the compressor is working, and cool air will come from the vents at speed. At highway speeds, the fan generally will come on after a while.
I am unsure as to whether it is the resistor or if the blower motor is going out in light of the blower's starting after getting to highway speeds. Is the AC or ambient air cooling the resistor enough to restart, or is the highway speed and air induction coming through the vents giving the blower motor enough oomph to start again?
Anyone have any ideas? Jim
Since the above was posted, the blower has stopped working alltogether. Analyzing the problem, It seems to me as if the problem is not the resistor, but I was looking around the fuse box and found a blower relay which I think might be the problem. I hope to get a response here.
Jim
If anyone is interested in the symptoms I encountered, it was the blower motor at fault. It finally started making a noise when it was working. Replaced the motor which required pulling the dash. I also had the heater core replaced because of the mileage. AC evaporator had been replaced previously, so this is the second time for pulling the dash out. If anyone has similiar problems, do all three at once, evaporator, heater core, and blower motor as it is 5 plus hours labor. Doing the motor, heater core, AC charge, and wiper blades was $665. Evaporator done last year was $800 plus, so I think the indie garage gave me a break.
Good luck on the erratic xmission problem.
Jim
:confuse:
Wes
If you find anything out please let me know. I'll do the same.
2002 Dakota SXT 2w/d No power anything or cruise.just A/C
OK Here is the problem
When the truck hits 30MPH (Exactly) the headlamp/key chime goes off and will not stop until vehicle goes under 30 MPH. Also when headlamps are on and I open the door they go off. Close the door and they go back on. The interior lamps do not work unless I turn them on at headlamp switch. I don't know if this has anything to do with it but I did notice for a few weeks before this happened that when I turned the headlamps on they would flash bright for a split second but would function properly thereafter.
Any thoughts?
Though this idea is not very consistent with your "Only happens when I drive with light on and stop then restart" comment.
Here's how I did it: Unhooked the negative battery cable so that the airbag capacitor can discharge. Lay on your back on the floorboard; with a flashlight looking up the underside of the dash on the drivers left side. Locate a 'squarish' plug, mine was green in color and at the top of a couple of other plug type connections; pull it out (as if disconnecting a plug) noting which way the connectors are aligned; take the new (replacement) flasher and plug it in the same way. Reconnect the negative battery cable, WA LA...everything is back to working order! I should get a badge for this!
Thanks in advance.
