Caravan/Voyager Brake Issues
cotero1000
Member Posts: 1
in Dodge
I have a problem and not sure how to fix it. I am trying to change my front disc pads on my fan and my top bolt on the caliber is stuck. I can not break it loose. I have tried wd-40 and motor oil and left both sit on for a couple of hours and tried again still nothing. Does anyone have any other suggestions on how to break it loose? I would greatly appreciate any help.
cotero1000
cotero1000
Has anyone done this procedure? If so, please provide
some details.
TYVM, Vanpo
However, I do not wish to spend over $200 on a fix and
regardless, I doubt if Chrysler will settle for that.
Therefore I still want more information on converting
the ABS system to non-ABS. The salvage yards are full
of non-ABS wrecks ('91-'93)and I can get the main components for less than $100. I just need some guidance on how to install these parts so that the hookup is proper. I would like to get a brakeline diagram showing the line routing and hookup to the "combination valve".
Thank you for any advise/information you can supply.
Vanpo.
Remember, the brakes are critical. Please put in the time and effort to do it right.
and the associated switch block. I already have the tools. At 75 years age, I am not as ambitous to use them as I once was. Hopefully, I can finish the job for $150 total(parts). My experience with complex items of this nature is that they don't get better as the car ages. For that reason I want to simplify the system. I did locate a diagragm in an online subscription of a service manual for the '92 T&C (ALLDATA/AutoZone). Vanpo
Obviously brakes are not rocket science. However, caliper torque settings would be nice. Does anyone have a link to an online reference for changing brake shoes and discs for a 2005 Dodge Caravan? Or even just the torque settings and words of advice?
At first it appears to be an easy job of unbolting the lines at the ABS unit to the back axle. But after a second look,the ABS support bracket is in the way.
What is involved in removing this bracket?
I believe the (2) bolt holes in the drum face will accomodate a M8x1" (metric fine)in use with a flat bar puller where a large centre bolt pushes the drum away from the centre hub. The centre of the drum may be seized so high heat and penetrating fluid may be required (drill holes through the drum around the centre hub if disposing)to break the grip.On the backside of the drum plate remove the oval rubber seal and access the star wheel with a slot screwdriver turning the adjuster down to pull in the brake shoes to create a clearance between the shoes and inside drum. The inside parking brake cable may be slightly in the way so use a flashlight to manipulate the adjuster.
When replacing make sure the drum is clean and spread high heat anti-corrosion compound to ease any future drum removal
I have a 2000 Grand Caravan with a pesky ABS light that keeps coming on.. It is only after you drive the car a little and seems to reset itself after turning the car off... It has only 85,000 miles on it and to be honest I am not happy with it... I had it in to put in a new transmission (YES IT JUST DIED ON THE HIGHWAY 200 miles from home) In the dang thing and at that time they told me that it would need a new ABS pump.... At a cost of an other 1000 dollars... I have since been driving the Van with no reall braking issues other than no ABS... But would like to get it fixed as we will be holding on to it for a while longer...
First question is Being a motor head of sorts, Is it possible to do the work my self? If so are there any manuals out there to make it easier?
By looking at it it seems rather point blank easy bolt on... And then Bleed... Of couse it would need a change of break fluid...
Any body done this out there???
Is there any recall on this or is there an issue chrysler knows about? Thanks
For several months now the antilock and Brake Warning lights have been coming on, then going off after driving . I was told by my regular mechanic that he thinks there is a small leak in the ABS system. Now both warning lights are on all the time and more frequently the brakes are really stiff and hard to apply. Les Schaub says they can't fix it, thinks the Power Booster isn't pressurizing the system. (Pre-'95, models have ABS and Power Boost tied into each other so I can't just shut down the ABS system)
I know it is probably not worth fixing if it comes to over $1000, car is not worth that much. I would like to have an extensive diagnostic test done on it that I can trust. I'm hoping that if it is just the Booster or one component of the system (a pressure switch, transducer, proportioning valve, etc....) it would be a lot cheaper to fix. I'm afraid that if I take it to the dealer they will just replace the whole thing and charge me $3,000.
My repair manual seems to indicate it might be just the hydraulic bladder accumulator (is that the same as the booster?)
I live near Vancouver, WA so if you know any brake guys you can trust I would be eternally grateful.
Any thoughts would be appreciated, thanks!
Best Regards,
Shipo
Best Regards,
Shipo
My mechanic told me that my brake pads are brittle and need replacement and so do the rotors. He's installing new ceramic brake pads and new rotors. Not to mention cylinders in the back needing replacement (he said a broken back cylinder caused the brakes to overheat causing the pads to become brittle).
All in all, he told me the cost of new parts and labor would hit me at $490.00. We've been going to this guy for years and never suspected being over estimated.
Did I get good value on all the work done?
What has everyone paid for similar work?
As far as cost, I do my own with top quality parts (usually NAPA) and can buy all of the parts for about $175 (front pads, front rotors, rear shoes and rear wheel cylinders). I have no idea what your guy is charging you for labor and the markup on parts.
Keep us posted.
Best Regards,
Shipo
I have yet to pick it up later in the afternoon when he's done and I'll be sure to ask him what else was done. (Shoes, drums, and brake fluid)
Thanks for the insight Shipo, I'll be back on later tonight to see the final job
If you are finding that brakes don't last very long on your van before the pedal starts pulsing while you're braking, you may be overtaxing the rotors, especially if you have the 14" wheels on your van. We have the sixteen inch wheels on ours and have the larger disks that came with the 15" and 16" wheeled vans, and even still, I was not getting anything more than twenty to thirty thousand miles per set (and as little as eight thousand on one set) before the pulsing in the brake pedal got so bad I couldn't stand it anymore. In desperation I bought a set of cross-drilled rotors (a little pricy but apparently worth it) and married them up with a set of ceramic pads. The good news here is that I now have 36,000 miles on that set and they're still nice and smooth.
Best Regards,
Shipo
Here's what went down:
1. Brake Inspection
2. Found front brake pads and rotors overheated
3. Found right rear wheel cylinder rusted (piston stuck)
4. Replaced front brake pads with ceramic premium pads
5. Lube caliper sliders
6. Replaced front brake rotors
7. Adjusted rear brakes and parking brake
T: $190.00 (2 hours)
1. Replaced rear wheel cylinders
2. Bleed complete system from master cylinder to calipers and wheel cylinders
3. Fill system with new brake fluid DOT 3
4. 1 Year warranty
T: $95.00
1. Replaced rear brake drums
2. Adjusted rear brakes and parking brake
T: No Charge
-Ceramic Front Brake Pads, $105 (1)
-Front Brake Rotors, $196 (2, 98 each)
-Synthetic Brake Caliper Lube, NC (1)
-Brake Fluid, NC (1)
-Wheel Cylinders, 69.96 (2, 34.98 each)
-Rear Brake Drums, $102 (2, 51 each)
PARTS : $472.96
LABOR : $295.00
TAX : $39.02
TOTAL: $796.98
The van feels and drives brand new. Better safe than sorry? I feel bad for my pockets.
Best Regards,
Shipo
I'd appreciate all the help,
Best Regards,
Shipo
As for what your next step is, geez, I don't know. I suppose a lot depends upon the condition of the rest of your van and how much you want to spend.
Best Regards,
Shipo
Best Regards,
Shipo
can you tell me how many clips, and where they should go for each side
I am having a problem with the ABS system on my 97 GC with 3.8 engine with 179K miles. Problem the ABS system will not activate on dry pavement. It will activate on gravel road. I have had the car to several dodge dealers. First dealer replaced master cylinder, power boost unit, new rotors, calipers and pads, rear brake work. Bleed brakes many times. Dealer did not fix problem refunded all of my money. Second dealer checked brakes system and stated "system works as designed".. So my problem is when I make a had stop the brake pedal is VERY spongy and goes very close to the floor. The brakes have been like this for at least 100K miles.. Any help would be greatly appreciated.
diydodge
Best Regards,
Shipo
I am impressed so far with the '98 AWD van this Spring as our winter snow pack slowly decomposes. I have crawled it through 4-6" of heavy slush up my rather steep driveway and it pulled though every time. I expected to be stuck a few times by this point. No problems with the ABS either, and I have thoroughly tested it.
Best Regards,
Shipo
Did you miss the part of my original message about the spongy pedal??? When I do a "no-holes barred, drop the freaking anchor kind of stop" this van glides to a stop and the pedal is very close to the floor. I can also sit in my driveway and continuously press on the pedal and it goes to the floor very spongy.. I do a lot of highway driving and I must always keep a good distance from the car in front of me. I cannot find a dealer who will tell me what is wrong. I have taken a service manager to vans in his lot (in for repair) had him start the vans up and these vans DO NOT have a spongy pedal like my van. This is the manager who gave me back all of my repair cost because he did not know how to fix my van. I found this web site and figured I would give it a try here.. The ABS system does work on gravel roads. I think there is air in the ABS system but no one know how to bleed it.
Thanks for your replys
diydodge
As for what on Earth could be wrong with your van, geez, there are lots of things. I'll list a few (starting with the easiest and most obvious first), many of which were hopefully covered by the shop that was working on it for you:
1) Old brake fluid with lots of water (a brake system flush should cure this)
2) Air in the brake lines (the above flush should have cured this too)
3) Corroded rear wheel cylinders (assuming you have rear drum brakes)
4) Poorly adjusted rear brake shoes (again assuming you have rear drum brakes)
5) Corroded brake caliper pistons
6) Old/weak brake hoses (i.e. the link between the metal brake lines and the wheels)
7) Old or badly rebuilt master cylinder (you should never use rebuilt in this case)
8) Brake fluid leak only under high pressure (near the braided seams by the firewall)
9) Bad ABS controller/proportioning valve (I think it's the same unit on these vans)
10) A cracked weld on the brake pedal mount (has the van ever been in an accident?)
If all of these areas have been covered, let me know and I'll try to think of a few more.
Best Regards,
Shipo
I am having a problem with my brake system. I got this vehicle used and when I got it it had a brake light on and the pedal had excessive travel but the brakes worked. Then I had a friend help me bleed the system and the light went out and the brakes were fine for a couple of days then the pedal started to travel again and the light came back.
So I changed the rear shoes and cylinders. The rear passenger cylinder seemed to have a tiny leak. And it appeared as though the side hadn't been working properly for some time. I thought I had nailed the problem down, so I bled the system and found a couple of oddities. First air continues to get into the system, and second I can't seem to bleed the rear right side properly, sometimes I get large amounts of air and other times there is a very slow flow and the pedal will not drop to the floor when I release the bleeder. All the other 3 wheels bleed proper but it seems like there is a plug in the right rear line sometimes. And lastly, I can hear a drag of the shoes on the right rear drum when I apply the brakes. so I don't believe they are engaging when applied.
I don,t have a repair manual for this particular vehicle so I don't know if it is equipped with abs or not.
The front pads were almost new and calipers in good shape up front.
thanks for any help.
Lee
PS there appears to be no fluid loss.
On the chance that you DID get yours fixed, could you tell me what fixed it?
Ed Flaherty
ed at myself.com
I have changed rotors and brake pad in April this year. Starting last week, there is sqeaky noise coming from the left front brake whenever I step on the brake. It last for a while and its gone. The brake pads and rotors are new and running less than 1,000 KM only.
Any idea what is the problem? Any experience pls?
Many thanks in advance.
